#include <ossimViewshedTool.h>
Classes | |
class | Radial |
ossimViewshedTool () | |
~ossimViewshedTool () | |
virtual void | setUsage (ossimArgumentParser &ap) |
Initializes the aurgument parser with expected parameters and options. More... | |
virtual bool | initialize (ossimArgumentParser &ap) |
Initializes from command line arguments. More... | |
virtual void | initialize (const ossimKeywordlist &kwl) |
Reads processing params from KWL and prepares for execute. More... | |
virtual ossimRefPtr< ossimImageData > | getChip (const ossimIrect &img_rect) |
Computes the viewshed for the area represented by argument AOI. More... | |
virtual bool | execute () |
Writes product to output file. More... | |
virtual void | clear () |
Disconnects and clears the DEM and image layers. More... | |
virtual ossimString | getClassName () const |
void | test () |
For engineering/debug. More... | |
ossimChipProcTool () | |
default constructor More... | |
virtual | ~ossimChipProcTool () |
virtual destructor More... | |
virtual void | abort () |
virtual bool | isChipProcessor () const |
Overrides base class implementation to indicate this class supports getChip() calls. More... | |
virtual ossimListenerManager * | getManager () |
virtual ossimObject * | getObject () |
virtual const ossimObject * | getObject () const |
virtual ossimRefPtr< ossimImageData > | getChip (const ossimGrect &gnd_rect) |
ossimRefPtr< ossimImageData > | getChip (const ossimDrect &map_bounding_rect, const ossimDpt &gsd) |
ossimRefPtr< ossimImageData > | getChip () |
Get chip method that assumes pre-initialized state. More... | |
const ossimFilename & | getProductFilename () const |
ossimTool () | |
virtual | ~ossimTool () |
virtual void | loadJSON (const Json::Value &json_request) |
Reads processing params from JSON object provided. More... | |
virtual void | saveJSON (Json::Value &json) const |
Fetch product as JSON object when applicable Always returns true since using exception on error. More... | |
virtual const std::string & | getResponse () const |
Fetch product as string (typically JSON) when applicable, otherwise passes back empty string. More... | |
virtual void | getKwlTemplate (ossimKeywordlist &kwl) |
Assigns a template keywordlist to string for initializing derived classes. More... | |
void | getAPI (std::string &out) const |
Outputs a JSON representation of the Utility's API. More... | |
std::string | getAPI () const |
void | getBuildDate (std::string &s) const |
Gets build date. More... | |
void | getRevision (std::string &s) const |
Gets revision. More... | |
void | getVersion (std::string &s) const |
Gets version. More... | |
void | setOutputStream (std::ostream *os) |
Redirects any console output to the supplied stream for logging or JNI application. More... | |
bool | helpRequested () const |
Returns true when the initialization detects a "--help" option, so caller can avoid subsequent execute() call. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
JsonInterface () | |
virtual | ~JsonInterface () |
ossimProcessInterface () | |
virtual | ~ossimProcessInterface () |
bool | needsAborting () const |
bool | isAbortRequested () const |
bool | isAborted () const |
bool | isExecuting () const |
ossimProcessStatus | getProcessStatus () const |
virtual void | setProcessStatus (ossimProcessStatus processStatus) |
virtual double | getPercentComplete () const |
virtual void | setPercentComplete (double percentComplete) |
void | enableEvents () |
void | disableEvents () |
void | setCurrentMessage (const ossimString &message) |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
Static Public Attributes | |
static const char * | DESCRIPTION |
Used by ossimUtilityFactory. More... | |
virtual void | initProcessingChain () |
Derived classes initialize their custom chains here. More... | |
virtual void | initializeProjectionGsd () |
Initializes the projection gsd. More... | |
virtual void | initializeAOI () |
Initializes m_aoiViewRect with the output area of interest as specified in master KWL. More... | |
void | paintReticle () |
void | initRadials () |
bool | writeHorizonProfile () |
void | computeRadius () |
bool | optimizeFOV () |
bool | computeViewshed () |
void | processRemainingArgs (ossimArgumentParser &ap) |
Intended to be called after derived class has picked off its own options from the parser, and arguments remain (such as input and output filenames). More... | |
virtual void | finalizeChain () |
Called after initProcessingChain() to append common items to the processing chain. More... | |
virtual void | loadImageFiles () |
Creates chains for image entries associated with specified keyword. More... | |
virtual void | loadDemFiles () |
Loads all DEM files specified in master KWL into the elev manager's database. More... | |
ossimRefPtr< ossimSingleImageChain > | createInputChain (const ossimFilename &image_file, ossim_uint32 entry_index=0) |
Creates the ossimSingleImageChain from image filename and populates the chain with resampler and product output projection on view-side of resampler's IVT. More... | |
void | createOutputProjection () |
Creates the output or view projection. More... | |
ossimRefPtr< ossimMapProjection > | newIdentityProjection () |
Sets the single image chain for identity operations view to a ossimImageViewAffineTransform. More... | |
ossimRefPtr< ossimMapProjection > | newUtmProjection () |
Convenience method to get a utm projection. More... | |
bool | getProjectionOrigin (ossimGpt &gpt) |
Reads the KWL for origin latitude and central meridian. More... | |
ossimRefPtr< ossimImageFileWriter > | newWriter () |
Creates a new writer. More... | |
void | propagateGeometryToChains () |
Loops through all chains and sets the output projection. More... | |
ossimRefPtr< ossimImageSource > | combineLayers (std::vector< ossimRefPtr< ossimSingleImageChain > > &layers) const |
When multiple input sources are present, this method instantiates a combiner and adds inputs. More... | |
void | computeAdjustedViewFromGrect () |
Initializes m_aoiViewRect given m_aoiGroundRect. More... | |
void | setAoiToInputs () |
Assigns the AOI to be the bounding rect of the union of all inputs. More... | |
void | getBandList (ossim_uint32 image_idx, std::vector< ossim_uint32 > &bandList) const |
Gets the band list if BANDS keyword is set. More... | |
void | setReaderProps (ossimImageHandler *ih) const |
Passes reader properties to single image handler if any. More... | |
ossimChipProcTool (const ossimChipProcTool &obj) | |
Hidden from use copy constructor. More... | |
const ossimChipProcTool & | operator= (const ossimChipProcTool &) |
Hidden from use assignment operator. More... | |
ossimRefPtr< ossimGeoPolygon > | createClipPolygon () const |
void | findCenterGpt (ossimGpt &gpt) |
Tries to determine the AOI center point based on KWL entries, else returns NaNs in gpt. More... | |
ossimRefPtr< ossimImageSource > | mosaicDemSources () |
Some utilities need to work on DEMs as images. More... | |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
Friends | |
class | SectorProcessorJob |
class | RadialProcessorJob |
class | RadialProcessor |
enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
Class for computing the viewshed on a DEM given the viewer location and max range of visibility
Definition at line 21 of file ossimViewshedTool.h.
ossimViewshedTool::ossimViewshedTool | ( | ) |
Definition at line 47 of file ossimViewshedTool.cpp.
References m_observerGpt, and ossimGpt::makeNan().
ossimViewshedTool::~ossimViewshedTool | ( | ) |
Leaves OSSIM initialized.
Reimplemented from ossimChipProcTool.
Definition at line 305 of file ossimViewshedTool.cpp.
References ossimChipProcTool::clear(), m_horizonMap, m_jobMtQueue, m_observerGpt, m_outBuffer, m_visRadius, and ossimGpt::makeNan().
protected |
Definition at line 700 of file ossimViewshedTool.cpp.
References ossimGpt::distanceTo(), ossimIrect::hasNans(), ossimGrect::ll(), ossimGrect::lr(), ossimChipProcTool::m_aoiGroundRect, ossimChipProcTool::m_aoiViewRect, m_observerGpt, m_visRadius, ossimGrect::ul(), and ossimGrect::ur().
Referenced by initProcessingChain().
protected |
Definition at line 486 of file ossimViewshedTool.cpp.
References ossimImageDataFactory::create(), d_accumT, ossimImageData::fill(), ossimImageChain::getNullPixelValue(), ossim::getNumberOfThreads(), ossimIrect::height(), ossimImageData::initialize(), initRadials(), ossimImageDataFactory::instance(), ossimChipProcTool::m_aoiViewRect, m_halfWindow, m_jobMtQueue, m_memSource, m_numThreads, m_outBuffer, ossimChipProcTool::m_procChain, m_radials, m_threadBySector, ossimProcessInterface::needsAborting(), optimizeFOV(), OSSIM_UINT8, ossimNotify(), ossimNotifyLevel_INFO, paintReticle(), ossimMemoryImageSource::setImage(), ossimImageData::setImageRectangle(), ossim::Thread::sleepInMicroSeconds(), ossimRefPtr< T >::valid(), and ossimIrect::width().
Referenced by execute(), and getChip().
Returns true if successful.
Definition at line 472 of file ossimViewshedTool.cpp.
References computeViewshed(), ossimString::empty(), ossimChipProcTool::execute(), ossimTool::m_helpRequested, m_horizonFile, ossimNotify(), ossimNotifyLevel_INFO, and writeHorizonProfile().
Definition at line 449 of file ossimViewshedTool.cpp.
References computeViewshed(), ossimImageChain::getTile(), ossimImageGeometry::localToWorld(), ossimChipProcTool::m_aoiGroundRect, ossimChipProcTool::m_aoiViewRect, ossimChipProcTool::m_geom, ossimChipProcTool::m_procChain, ossimImageGeometry::setImageSize(), ossimIrect::size(), and ossimRefPtr< T >::valid().
inlinevirtual |
Reimplemented from ossimTool.
Definition at line 58 of file ossimViewshedTool.h.
Definition at line 133 of file ossimViewshedTool.cpp.
References ossimKeywordlist::addPair(), ossimChipProcTool::initialize(), ossimTool::m_helpRequested, ossimTool::m_kwl, ossimArgumentParser::read(), and ossimString::toDouble().
Returns TRUE if successful.
Definition at line 225 of file ossimViewshedTool.cpp.
References ossimKeywordlist::findKey().
protectedvirtual |
Initialization will either come from user defined cut options or the source bounding rect with user options taking precidence.
Definition at line 336 of file ossimViewshedTool.cpp.
References ossimKeywordlist::hasKey(), ossimGrect::hasNans(), ossimGpt::hasNans(), ossimChipProcTool::initializeAOI(), ossimChipProcTool::m_aoiGroundRect, ossimTool::m_kwl, m_observerGpt, m_visRadius, and ossimGrect::midPoint().
protectedvirtual |
This loops through all chains to find the minimum gsd.
Definition at line 315 of file ossimViewshedTool.cpp.
References ossimElevManager::getHeightAboveEllipsoid(), ossimElevManager::getMeanSpacingMeters(), ossimImageGeometry::getProjection(), ossimDpt::hasNans(), ossimGpt::hasNans(), ossimChipProcTool::initializeProjectionGsd(), ossimElevManager::instance(), ossimChipProcTool::m_geom, ossimChipProcTool::m_geoScaled, ossimChipProcTool::m_gsd, m_observerGpt, ossimMapProjection::setMetersPerPixel(), ossimMapProjection::setOrigin(), ossimDpt::x, and ossimDpt::y.
protectedvirtual |
Implements ossimChipProcTool.
Definition at line 379 of file ossimViewshedTool.cpp.
References ossimImageChain::add(), ossimIrect::area(), ossimIrect::clipToRect(), ossimChipProcTool::combineLayers(), computeRadius(), ossimConnectableObject::connectMyInputTo(), ossimRefPtr< T >::get(), ossimElevManager::getHeightAboveEllipsoid(), ossimImageGeometry::getProjection(), ossimGpt::hasNans(), ossimIrect::hasNans(), ossimIrect::height(), ossimGpt::hgt, ossimImageDataFactory::instance(), ossimElevManager::instance(), ossimImageGeometry::localToWorld(), ossimChipProcTool::m_aoiGroundRect, ossimChipProcTool::m_aoiViewRect, ossimChipProcTool::m_geom, ossimChipProcTool::m_gsd, m_halfWindow, ossimChipProcTool::m_imgLayers, m_memSource, m_observerGpt, m_observerVpt, m_obsHgtAbvTer, m_outBuffer, ossimChipProcTool::m_procChain, m_visRadius, OSSIM_UINT8, ossimMemoryImageSource::setImage(), ossimMemoryImageSource::setImageGeometry(), ossimImageData::setImageRectangle(), ossimImageGeometry::setImageSize(), ossimIrect::size(), size, ossimRefPtr< T >::valid(), ossimIrect::width(), ossimImageGeometry::worldToLocal(), and ossimDpt::x.
protected |
Definition at line 724 of file ossimViewshedTool.cpp.
References ossimViewshedTool::Radial::azimuth, m_halfWindow, m_radials, m_startFov, and m_stopFov.
Referenced by computeViewshed().
protected |
Definition at line 577 of file ossimViewshedTool.cpp.
References ossimGpt::azimuthTo(), ossimGpt::lat, ossimGrect::ll(), ossimGpt::lon, ossimGrect::lr(), ossimChipProcTool::m_aoiGroundRect, m_observerGpt, m_startFov, m_stopFov, ossimNotify(), ossimNotifyLevel_INFO, ossimGrect::pointWithin(), ossimGrect::ul(), and ossimGrect::ur().
Referenced by computeViewshed(), and test().
protected |
Definition at line 794 of file ossimViewshedTool.cpp.
References ossimIrect::lr(), ossimChipProcTool::m_aoiViewRect, m_displayAsRadar, ossimChipProcTool::m_geom, m_observerGpt, m_observerVpt, m_outBuffer, m_overlayValue, m_reticleSize, ossimIrect::pointWithin(), ossimImageData::setValue(), ossimIrect::ul(), ossimImageGeometry::worldToLocal(), ossimIpt::x, ossimDpt::x, x, ossimIpt::y, ossimDpt::y, and y.
It does not output anything. To see the usage, the caller will need to do something like:
ap.getApplicationUsage()->write(<ostream>);
Definition at line 79 of file ossimViewshedTool.cpp.
References ossimApplicationUsage::addCommandLineOption(), DESCRIPTION, ossimArgumentParser::getApplicationName(), ossimArgumentParser::getApplicationUsage(), ossimApplicationUsage::setCommandLineUsage(), ossimApplicationUsage::setDescription(), and ossimChipProcTool::setUsage().
void ossimViewshedTool::test | ( | ) |
Definition at line 1013 of file ossimViewshedTool.cpp.
References ossimChipProcTool::m_aoiGroundRect, m_observerGpt, m_startFov, m_stopFov, and optimizeFOV().
protected |
Definition at line 829 of file ossimViewshedTool.cpp.
References ossim::atand(), ossimString::chars(), m_halfWindow, m_horizonFile, m_horizonMap, and m_radials.
Referenced by execute().
friend |
Definition at line 25 of file ossimViewshedTool.h.
friend |
Definition at line 24 of file ossimViewshedTool.h.
friend |
Definition at line 23 of file ossimViewshedTool.h.
protected |
Definition at line 112 of file ossimViewshedTool.h.
protected |
Definition at line 113 of file ossimViewshedTool.h.
static |
Definition at line 61 of file ossimViewshedTool.h.
Referenced by ossimToolFactory::getCapabilities(), and setUsage().
protected |
Definition at line 94 of file ossimViewshedTool.h.
Referenced by RadialProcessor::doRadial(), and paintReticle().
protected |
Definition at line 95 of file ossimViewshedTool.h.
Referenced by computeViewshed(), RadialProcessor::doRadial(), initProcessingChain(), initRadials(), and writeHorizonProfile().
protected |
Definition at line 99 of file ossimViewshedTool.h.
Referenced by RadialProcessor::doRadial().
protected |
Definition at line 108 of file ossimViewshedTool.h.
Referenced by execute(), and writeHorizonProfile().
protected |
Definition at line 109 of file ossimViewshedTool.h.
Referenced by clear(), and writeHorizonProfile().
protected |
Definition at line 103 of file ossimViewshedTool.h.
Referenced by clear(), and computeViewshed().
protected |
Definition at line 97 of file ossimViewshedTool.h.
Referenced by computeViewshed(), and initProcessingChain().
protected |
Definition at line 104 of file ossimViewshedTool.h.
protected |
Definition at line 88 of file ossimViewshedTool.h.
Referenced by clear(), computeRadius(), RadialProcessor::doRadial(), initializeAOI(), initializeProjectionGsd(), initProcessingChain(), optimizeFOV(), ossimViewshedTool(), paintReticle(), and test().
protected |
Definition at line 89 of file ossimViewshedTool.h.
Referenced by RadialProcessor::doRadial(), initProcessingChain(), and paintReticle().
protected |
Definition at line 90 of file ossimViewshedTool.h.
Referenced by RadialProcessor::doRadial(), and initProcessingChain().
protected |
Definition at line 93 of file ossimViewshedTool.h.
protected |
Definition at line 96 of file ossimViewshedTool.h.
Referenced by clear(), computeViewshed(), RadialProcessor::doRadial(), initProcessingChain(), and paintReticle().
protected |
Definition at line 100 of file ossimViewshedTool.h.
protected |
Definition at line 92 of file ossimViewshedTool.h.
Referenced by computeViewshed(), RadialProcessor::doRadial(), initRadials(), writeHorizonProfile(), and ~ossimViewshedTool().
protected |
Definition at line 101 of file ossimViewshedTool.h.
Referenced by paintReticle().
protected |
Definition at line 102 of file ossimViewshedTool.h.
protected |
Definition at line 105 of file ossimViewshedTool.h.
Referenced by initRadials(), optimizeFOV(), and test().
protected |
Definition at line 106 of file ossimViewshedTool.h.
protected |
Definition at line 107 of file ossimViewshedTool.h.
protected |
Definition at line 98 of file ossimViewshedTool.h.
protected |
Definition at line 91 of file ossimViewshedTool.h.
Referenced by clear(), computeRadius(), initializeAOI(), and initProcessingChain().
