Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimCurlHttpRequest Class Reference
#include <ossimCurlHttpRequest.h>
Inheritance diagram for ossimCurlHttpRequest:
ossimHttpRequest ossimWebRequest ossimObject ossimReferenced
 ossimCurlHttpRequest ()
virtual ~ossimCurlHttpRequest ()
virtual ossimRefPtr< ossimWebResponsegetResponse ()
virtual bool supportsProtocol (const ossimString &protocol) const
ossim_int64 getContentLength () const
- Public Member Functions inherited from ossimHttpRequest
 ossimHttpRequest ()
bool set (const ossimUrl &url, const ossimKeywordlist &headerOptions, HttpMethodType methodType=HTTP_METHOD_GET)
virtual ~ossimHttpRequest ()
void setHeaderOptions (const ossimKeywordlist &options)
void addHeaderOption (const ossimString &name, const ossimString &value)
void clearHeaderOptions ()
ossimKeywordlistgetHeaderOptions ()
const ossimKeywordlistgetHeaderOptions () const
virtual ossimString getLastError () const
- Public Member Functions inherited from ossimWebRequest
 ossimWebRequest ()
 ossimWebRequest (const ossimUrl &url)
const ossimUrlgetUrl () const
virtual bool setUrl (const ossimUrl &url)
void clearLastError ()
void clearLastError () const
const ossimString getLastError ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static int curlWriteResponseBody (void *buffer, size_t size, size_t nmemb, void *stream)
static int curlWriteResponseHeader (void *buffer, size_t size, size_t nmemb, void *stream)
void setDefaultSSL (CURL *curl) const
virtual ~ossimReferenced ()
CURL * m_curl
ossimRefPtr< ossimCurlHttpResponsem_response
- Protected Attributes inherited from ossimHttpRequest
ossimKeywordlist m_headerOptions
HttpMethodType m_methodType
 TYPE_DATA
- Protected Attributes inherited from ossimWebRequest
ossimUrl m_url
ossimString m_lastError
 TYPE_DATA
Additional Inherited Members
- Public Types inherited from ossimHttpRequest
enum  HttpMethodType { HTTP_METHOD_UNKNOWN = 0, HTTP_METHOD_GET = 1, HTTP_METHOD_POST = 2 }
Detailed Description
Definition at line 13 of file ossimCurlHttpRequest.h.
◆ ossimCurlHttpRequest()
ossimCurlHttpRequest::ossimCurlHttpRequest ( )
inline
Definition at line 16 of file ossimCurlHttpRequest.h.
References m_curl.
17  :m_curl(0)
18  {
19  m_curl = curl_easy_init();
20  }
◆ ~ossimCurlHttpRequest()
virtual ossimCurlHttpRequest::~ossimCurlHttpRequest ( )
inlinevirtual
Definition at line 21 of file ossimCurlHttpRequest.h.
References m_curl.
22  {
23  if(m_curl)
24  {
25  curl_easy_cleanup(m_curl);
26  m_curl = 0;
27  }
28  }
Member Function Documentation
◆ curlWriteResponseBody()
int ossimCurlHttpRequest::curlWriteResponseBody ( void *  buffer,
size_t  size,
size_t  nmemb,
void *  stream
static
Definition at line 96 of file ossimCurlHttpRequest.cpp.
References ossimHttpResponse::bodyStream(), and size.
Referenced by getContentLength(), and getResponse().
97 {
98  ossimHttpResponse* cStream = static_cast<ossimHttpResponse*>(stream);
99
100  if(cStream)
101  {
102  cStream->bodyStream().write((char*)buffer, nmemb*size);
103  return nmemb*size;
104  }
105
106  return 0;
107 }
yy_size_t size
std::iostream & bodyStream()
◆ curlWriteResponseHeader()
int ossimCurlHttpRequest::curlWriteResponseHeader ( void *  buffer,
size_t  size,
size_t  nmemb,
void *  stream
static
Definition at line 109 of file ossimCurlHttpRequest.cpp.
References ossimHttpResponse::headerStream(), and size.
110 {
111  ossimHttpResponse* cStream = static_cast<ossimHttpResponse*>(stream);
112  if(cStream)
113  {
114  cStream->headerStream().write((char*)buffer, nmemb*size);
115  return nmemb*size;
116  }
117
118  return 0;
119 }
std::iostream & headerStream()
yy_size_t size
◆ getContentLength()
ossim_int64 ossimCurlHttpRequest::getContentLength ( ) const
Definition at line 121 of file ossimCurlHttpRequest.cpp.
References ossimString::c_str(), ossimWebRequest::clearLastError(), ossimHttpResponse::convertHeaderStreamToKeywordlist(), curlWriteResponseBody(), curlWriteResponseHeader(), ossimRefPtr< T >::get(), ossimKeywordlist::getMap(), ossimUrl::getProtocol(), ossimWebRequest::getUrl(), m_curl, ossimHttpRequest::m_headerOptions, ossimWebRequest::m_lastError, setDefaultSSL(), and ossimUrl::toString().
122 {
123  double contentLength=-1;
124  curl_easy_reset(m_curl);
125  clearLastError();
126  ossimString urlString = getUrl().toString();
127  ossimString protocol = getUrl().getProtocol();
129
130  curl_easy_setopt(m_curl, CURLOPT_HEADERFUNCTION, curlWriteResponseHeader);
131  curl_easy_setopt(m_curl, CURLOPT_HEADERDATA, (void*)response.get());
132  curl_easy_setopt(m_curl, CURLOPT_WRITEFUNCTION, curlWriteResponseBody);
133  curl_easy_setopt(m_curl, CURLOPT_WRITEDATA, (void*)response.get());
134  curl_easy_setopt(m_curl, CURLOPT_HEADER, 0);
135  curl_easy_setopt(m_curl, CURLOPT_NOBODY, 1);
136  curl_easy_setopt(m_curl, CURLOPT_RANGE, "");
137
139  struct curl_slist *headers=0; /* init to NULL is important */
140
141  ossimKeywordlist::KeywordMap::const_iterator iter = headerMap.begin();
142  while(iter != headerMap.end())
143  {
144 // std::cout << ((*iter).first + ":"+(*iter).second).c_str() << std::endl;
145  headers = curl_slist_append(headers, ((*iter).first + ":"+(*iter).second).c_str());
146  ++iter;
147  }
148  curl_easy_setopt(m_curl, CURLOPT_URL, urlString.c_str());
149  if(protocol == "https")
150  {
152  }
153  int rc = curl_easy_perform(m_curl);
154
155  //rc = curl_easy_getinfo(m_curl, CURLINFO_CONTENT_LENGTH_DOWNLOAD, &contentLength);
156  if(rc == CURLE_SSL_CONNECT_ERROR)
157  {
158  // try default if an error for SSL connect ocurred
159  curl_easy_setopt(m_curl, CURLOPT_SSLVERSION, CURL_SSLVERSION_SSLv3);
160  rc = curl_easy_perform(m_curl);
161  }
162  bool result = (rc < 1);
163  if(result)
164  {
166  rc = curl_easy_getinfo(m_curl, CURLINFO_CONTENT_LENGTH_DOWNLOAD, &contentLength);
167  //if(rc>=1) contentLength = -1;
168  // response->convertHeaderStreamToKeywordlist();
169  //std::cout << response->headerKwl() << "\n";
170  }
171  else
172  {
173  m_lastError = curl_easy_strerror((CURLcode)rc);
174  //std::cout << curl_easy_strerror((CURLcode)rc) << std::endl;
175  }
176
177  return static_cast<ossim_int64> (contentLength);
178 }
static int curlWriteResponseHeader(void *buffer, size_t size, size_t nmemb, void *stream)
void setDefaultSSL(CURL *curl) const
ossimString toString() const
Definition: ossimUrl.cpp:106
std::map< std::string, std::string > KeywordMap
const ossimString & getProtocol() const
Definition: ossimUrl.h:17
const ossimUrl & getUrl() const
const ossimKeywordlist::KeywordMap & getMap() const
long long ossim_int64
const char * c_str() const
Definition: ossimString.h:396
static int curlWriteResponseBody(void *buffer, size_t size, size_t nmemb, void *stream)
void convertHeaderStreamToKeywordlist()
This will parse out the response code from the status line and initialize the header variables into a...
◆ getResponse()
ossimRefPtr< ossimWebResponse > ossimCurlHttpRequest::getResponse ( )
virtual
Reimplemented from ossimWebRequest.
Definition at line 4 of file ossimCurlHttpRequest.cpp.
References ossimString::c_str(), ossimWebRequest::clearLastError(), ossimHttpResponse::convertHeaderStreamToKeywordlist(), curlWriteResponseBody(), curlWriteResponseHeader(), ossimKeywordlist::find(), ossimRefPtr< T >::get(), ossimUrl::getProtocol(), ossimWebRequest::getUrl(), ossimHttpRequest::HTTP_METHOD_GET, m_curl, ossimHttpRequest::m_headerOptions, ossimWebRequest::m_lastError, ossimHttpRequest::m_methodType, setDefaultSSL(), ossimString::substitute(), supportsProtocol(), and ossimUrl::toString().
5 {
8  if(!supportsProtocol(protocol))
9  {
10  return 0;
11  }
12  curl_easy_reset(m_curl);
14  switch (m_methodType)
15  {
17  {
18  ossimCurlHttpResponse* curlResponse = new ossimCurlHttpResponse();
19  response = curlResponse;
20
21  curl_easy_setopt(m_curl, CURLOPT_HEADERFUNCTION, curlWriteResponseHeader);
22  curl_easy_setopt(m_curl, CURLOPT_HEADERDATA, (void*)response.get());
23  curl_easy_setopt(m_curl, CURLOPT_WRITEFUNCTION, curlWriteResponseBody);
24  curl_easy_setopt(m_curl, CURLOPT_WRITEDATA, (void*)response.get());
25  curl_easy_setopt(m_curl, CURLOPT_HEADER, 0);
26  curl_easy_setopt(m_curl, CURLOPT_NOBODY, 0);
27  //curl_easy_setopt(m_curl, CURLOPT_CONNECT_ONLY, 1);
28  // ossimKeywordlist::KeywordMap& headerMap = m_headerOptions.getMap();
29  // struct curl_slist *headers=0; /* init to NULL is important */
30  ossimString range = m_headerOptions.find("Range");
31  range=range.substitute("bytes=", "");
32  curl_easy_setopt(m_curl, CURLOPT_RANGE, range.c_str());
33  // ossimKeywordlist::KeywordMap::iterator iter = headerMap.begin();
34  // while(iter != headerMap.end())
35  // {
36  // std::cout << ((*iter).first + ":"+(*iter).second).c_str() << std::endl;
37  // headers = curl_slist_append(headers, ((*iter).first + ":"+(*iter).second).c_str());
38  // ++iter;
39  // }
40  ossimString urlString = getUrl().toString();
41  curl_easy_setopt(m_curl, CURLOPT_URL, urlString.c_str());
42
43
44  if(protocol == "https")
45  {
47  }
48
49  int rc = curl_easy_perform(m_curl);
50
51  if(rc == CURLE_SSL_CONNECT_ERROR)
52  {
53  // try default if an error for SSL connect ocurred
54  curl_easy_setopt(m_curl, CURLOPT_SSLVERSION, CURL_SSLVERSION_SSLv3);
55  rc = curl_easy_perform(m_curl);
56  }
57  bool result = (rc < 1);
58  if(result)
59  {
60  curlResponse->convertHeaderStreamToKeywordlist();
61  }
62  else
63  {
64  m_lastError = curl_easy_strerror((CURLcode)rc);
65  //std::cout << curl_easy_strerror((CURLcode)rc) << std::endl;
66  response = 0;
67  }
68  break;
69  }
70
71  default:
72  break;
73  }
74
75  return response;
76 }
ossimString substitute(const ossimString &searchKey, const ossimString &replacementValue, bool replaceAll=false) const
Substitutes searchKey string with replacementValue and returns a string.
virtual bool supportsProtocol(const ossimString &protocol) const
◆ loadState()
virtual bool ossimCurlHttpRequest::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
inlinevirtual
Reimplemented from ossimHttpRequest.
Definition at line 34 of file ossimCurlHttpRequest.h.
References ossimHttpRequest::loadState(), and m_response.
35  {
36  m_response = 0;
37  return ossimHttpRequest::loadState(kwl, prefix);
38  }
ossimRefPtr< ossimCurlHttpResponse > m_response
◆ setDefaultSSL()
void ossimCurlHttpRequest::setDefaultSSL ( CURL *  curl) const
protected
Definition at line 180 of file ossimCurlHttpRequest.cpp.
References ossim::CurlStreamDefaults::m_cacert, ossim::CurlStreamDefaults::m_clientCert, ossim::CurlStreamDefaults::m_clientCertType, ossim::CurlStreamDefaults::m_clientKey, and ossim::CurlStreamDefaults::m_clientKeyPassword.
181 {
182  curl_easy_setopt(curl, CURLOPT_SSLVERSION, CURL_SSLVERSION_DEFAULT);//);
184  {
185  curl_easy_setopt(curl, CURLOPT_CAINFO, ossim::CurlStreamDefaults::m_cacert.c_str());
186  curl_easy_setopt(curl, CURLOPT_SSL_VERIFYPEER, 1L);
187  }
188  else
189  {
190  curl_easy_setopt(curl, CURLOPT_SSL_VERIFYPEER, 0L);
191  }
193  {
194  curl_easy_setopt(curl, CURLOPT_SSLCERT, ossim::CurlStreamDefaults::m_clientCert.c_str());
195  }
197  {
198  curl_easy_setopt(curl, CURLOPT_SSLCERTTYPE, ossim::CurlStreamDefaults::m_clientCertType.c_str());
199  }
201  {
202  curl_easy_setopt(curl, CURLOPT_SSLKEYPASSWD, ossim::CurlStreamDefaults::m_clientKeyPassword.c_str());
203  }
205  {
206  curl_easy_setopt(curl, CURLOPT_SSLKEY, ossim::CurlStreamDefaults::m_clientKey.c_str());
207  }
208 }
static ossimFilename m_cacert
static ossimFilename m_clientKey
static ossimString m_clientCertType
static ossimString m_clientKeyPassword
static ossimFilename m_clientCert
◆ supportsProtocol()
bool ossimCurlHttpRequest::supportsProtocol ( const ossimString protocol) const
virtual
Definition at line 78 of file ossimCurlHttpRequest.cpp.
Referenced by ossimWebPluginRequestFactory::create(), and getResponse().
79 {
80  bool result = false;
81  if(protocol == "http")
82  {
83  result = true;
84  }
85  else if(protocol == "https")
86  {
87  curl_version_info_data * vinfo = curl_version_info( CURLVERSION_NOW );
88  if( vinfo->features & CURL_VERSION_SSL )
89  {
90  result = true;
91  }
92  }
93  return result;
94 }
Member Data Documentation
◆ m_curl
CURL* ossimCurlHttpRequest::m_curl
protected
◆ m_response
ossimRefPtr<ossimCurlHttpResponse> ossimCurlHttpRequest::m_response
mutableprotected
Definition at line 42 of file ossimCurlHttpRequest.h.
Referenced by loadState().
