Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossimFftw3Factory Class Reference
#include <ossimFftw3Factory.h>
Inheritance diagram for ossimFftw3Factory:
ossimImageSourceFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimFftw3Factory ()
virtual ossimObjectcreateObject (const ossimString &name) const
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
- Public Member Functions inherited from ossimImageSourceFactoryBase
virtual ossimImageSourcecreateImageSource (const ossimString &name) const
virtual ossimImageSourcecreateImageSource (const ossimKeywordlist &kwl, const char *prefix=0) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimFftw3Factoryinstance ()
 ossimFftw3Factory (const ossimFftw3Factory &)
const ossimFftw3Factoryoperator= (ossimFftw3Factory &)
- Protected Member Functions inherited from ossimImageSourceFactoryBase
 ossimImageSourceFactoryBase ()
 ossimImageSourceFactoryBase (const ossimImageSourceFactoryBase &)
const ossimImageSourceFactoryBaseoperator= (const ossimImageSourceFactoryBase &)
virtual ~ossimReferenced ()
static ossimFftw3FactorytheInstance =NULL
Detailed Description
Definition at line 12 of file ossimFftw3Factory.h.
◆ ~ossimFftw3Factory()
ossimFftw3Factory::~ossimFftw3Factory ( )
virtual
Definition at line 20 of file ossimFftw3Factory.cpp.
References ossimImageSourceFactoryRegistry::instance(), theInstance, and ossimImageSourceFactoryRegistry::unregisterFactory().
21 {
22  theInstance = NULL;
24 }
void unregisterFactory(ossimImageSourceFactoryBase *factory)
static ossimFftw3Factory * theInstance
static ossimImageSourceFactoryRegistry * instance()
◆ ossimFftw3Factory() [1/2]
ossimFftw3Factory::ossimFftw3Factory ( )
protected
Definition at line 101 of file ossimFftw3Factory.cpp.
Referenced by instance().
◆ ossimFftw3Factory() [2/2]
ossimFftw3Factory::ossimFftw3Factory ( const ossimFftw3Factory )
protected
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimFftw3Factory::createObject ( const ossimString typeName) const
virtual
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 35 of file ossimFftw3Factory.cpp.
References STATIC_TYPE_NAME.
36 {
37
38  // lets do the filters first
40  return new ossimFftw3Filter;
41
42  return NULL;
43 }
#define STATIC_TYPE_NAME(T)
Definition: ossimRtti.h:325
◆ createObject() [2/2]
ossimObject * ossimFftw3Factory::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Creates and object given a keyword list.
Definition at line 45 of file ossimFftw3Factory.cpp.
47 {
48  static const char* MODULE = "ossimFftw3Factory::createSource";
49
50  ossimString copyPrefix;
51  if (prefix)
52  {
53  copyPrefix = prefix;
54  }
55
56  ossimObject* result = NULL;
57
58  if(traceDebug())
59  {
60  CLOG << "looking up type keyword for prefix = " << copyPrefix << endl;
61  }
62
63  const char* lookup = kwl.find(copyPrefix, "type");
64  if(lookup)
65  {
66  ossimString name = lookup;
67  result = createObject(name);
68
69  if(result)
70  {
71  if(traceDebug())
72  {
73  CLOG << "found source " << result->getClassName() << " now loading state" << endl;
74  }
75  result->loadState(kwl, copyPrefix.c_str());
76  }
77  else
78  {
79  if(traceDebug())
80  {
81  CLOG << "type not found " << lookup << endl;
82  }
83  }
84  }
85  else
86  {
87  if(traceDebug())
88  {
89  CLOG << "type keyword not found" << endl;
90  }
91  }
92  return result;
93 }
#define CLOG
Definition: ossimTrace.h:23
virtual ossimObject * createObject(const ossimString &name) const
virtual ossimString getClassName() const
Definition: ossimObject.cpp:64
const char * c_str() const
Definition: ossimString.h:396
◆ getTypeNameList()
void ossimFftw3Factory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 95 of file ossimFftw3Factory.cpp.
96 {
97  typeList.push_back(STATIC_TYPE_NAME(ossimFftw3Filter));
98 }
◆ instance()
ossimFftw3Factory * ossimFftw3Factory::instance ( )
static
Definition at line 25 of file ossimFftw3Factory.cpp.
References ossimFftw3Factory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
26 {
27  if(!theInstance)
28  {
30  }
31
32  return theInstance;
33 }
◆ operator=()
const ossimFftw3Factory & ossimFftw3Factory::operator= ( ossimFftw3Factory )
protected
Definition at line 109 of file ossimFftw3Factory.cpp.
110 {
111  return *this;
112 }
Member Data Documentation
◆ theInstance
ossimFftw3Factory * ossimFftw3Factory::theInstance =NULL
staticprotected
Definition at line 27 of file ossimFftw3Factory.h.
Referenced by instance(), and ~ossimFftw3Factory().
