Public Member Functions | Static Public Member Functions | Public Attributes | List of all members
ossimGpkgContentsRecord Class Reference
#include <ossimGpkgContentsRecord.h>
Inheritance diagram for ossimGpkgContentsRecord:
ossimGpkgDatabaseRecordBase ossimReferenced
 ossimGpkgContentsRecord ()
 default constructor More...
 ossimGpkgContentsRecord (const ossimGpkgContentsRecord &obj)
const ossimGpkgContentsRecordoperator= (const ossimGpkgContentsRecord &copy_this)
virtual ~ossimGpkgContentsRecord ()
 destructor More...
virtual bool init (sqlite3_stmt *pStmt)
 Initialize from database. More...
bool init (const std::string &tableName, ossim_int32 srs_id, const ossimDpt &minPt, const ossimDpt &maxPt)
 Initialize from projection. More...
bool insert (sqlite3 *db)
 Inserst this record into gpkg_spatial_ref_sys table. More...
virtual void saveState (ossimKeywordlist &kwl, const std::string &prefix) const
 Saves the state of object to keyword list. More...
- Public Member Functions inherited from ossimGpkgDatabaseRecordBase
 ossimGpkgDatabaseRecordBase ()
virtual ~ossimGpkgDatabaseRecordBase ()
 virtual destructor. More...
 Print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static const std::string & getTableName ()
 Get the table name "gpkg_contents". More...
static bool createTable (sqlite3 *db)
 Creates table in database. More...
Public Attributes
std::string m_table_name
std::string m_data_type
std::string m_identifier
std::string m_description
std::string m_last_change
ossim_float64 m_min_x
ossim_float64 m_min_y
ossim_float64 m_max_x
ossim_float64 m_max_y
ossim_int32 m_srs_id
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 24 of file ossimGpkgContentsRecord.h.
◆ ossimGpkgContentsRecord() [1/2]
ossimGpkgContentsRecord::ossimGpkgContentsRecord ( )
default constructor
Definition at line 25 of file ossimGpkgContentsRecord.cpp.
26  :
28  m_table_name(),
29  m_data_type(),
30  m_identifier(),
31  m_description(),
32  m_last_change(),
37  m_srs_id(0)
38 {
39 }
ossimGpkgDatabaseRecordBase()
default constructor
double nan()
Definition: ossimCommon.h:135
◆ ossimGpkgContentsRecord() [2/2]
ossimGpkgContentsRecord::ossimGpkgContentsRecord ( const ossimGpkgContentsRecord obj)
Definition at line 41 of file ossimGpkgContentsRecord.cpp.
42  :
49  m_min_x(obj.m_min_x),
50  m_min_y(obj.m_min_y),
51  m_max_x(obj.m_max_x),
52  m_max_y(obj.m_max_y),
53  m_srs_id(obj.m_srs_id)
54 {
55 }
default constructor
◆ ~ossimGpkgContentsRecord()
ossimGpkgContentsRecord::~ossimGpkgContentsRecord ( )
virtual
destructor
Definition at line 76 of file ossimGpkgContentsRecord.cpp.
77 {
78 }
Member Function Documentation
◆ createTable()
bool ossimGpkgContentsRecord::createTable ( sqlite3 *  db)
static
Parameters
db
Returns
Definition at line 219 of file ossimGpkgContentsRecord.cpp.
References status, and ossim_sqlite::tableExists().
Referenced by ossimGpkgWriter::createTables().
220 {
221  bool status = false;
222  if ( db )
223  {
224  status = ossim_sqlite::tableExists( db, TABLE_NAME );
225
226  if ( !status )
227  {
228  std::ostringstream sql;
229  sql << "CREATE TABLE " << TABLE_NAME << " ( "
230  << "table_name TEXT NOT NULL PRIMARY KEY, "
231  << "data_type TEXT NOT NULL, "
232  << "identifier TEXT UNIQUE, "
233  << "description TEXT DEFAULT \"\", "
234
235  //---
236  // Requirement 13:
237  // Note: Spec changed to %fZ. No %f on linux but sqlite library handles.
238  // << "last_change DATETIME NOT NULL DEFAULT (strftime('%Y-%m-%dT%H:%M:%SZ','now')), "
239  //---
240  << "last_change DATETIME NOT NULL DEFAULT (strftime('%Y-%m-%dT%H:%M:%fZ','now')), "
241  << "min_x DOUBLE, "
242  << "min_y DOUBLE, "
243  << "max_x DOUBLE, "
244  << "max_y DOUBLE, "
245  << "srs_id INTEGER, "
246  << "CONSTRAINT fk_gc_r_srs_id FOREIGN KEY (srs_id) "
247  << "REFERENCES gpkg_spatial_ref_sys(srs_id)"
248  << ")";
249
250  if ( ossim_sqlite::exec( db, sql.str() ) == SQLITE_DONE )
251  {
252  status = true;
253  }
254  }
255  }
256  return status;
257 }
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
int exec(sqlite3 *db, const std::string &sql)
Preforms sqlite3_prepare_v2, sqlite3_step and sqlite3_finalize.
bool tableExists(sqlite3 *db, const std::string &tableName)
Checks for existance of table.
return status
◆ getTableName()
const std::string & ossimGpkgContentsRecord::getTableName ( )
static
Returns
table name
Definition at line 80 of file ossimGpkgContentsRecord.cpp.
Referenced by ossim_gpkg::getNewTableRecord().
81 {
82  return TABLE_NAME;
83 }
◆ init() [1/2]
bool ossimGpkgContentsRecord::init ( sqlite3_stmt *  pStmt)
virtual
Parameters
pStmtSQL statement, i.e. result of sqlite3_prepare_v2(...) call.
Returns
Implements ossimGpkgDatabaseRecordBase.
Definition at line 85 of file ossimGpkgContentsRecord.cpp.
References m_data_type, m_description, m_identifier, m_last_change, m_max_x, m_max_y, m_min_x, m_min_y, m_srs_id, m_table_name, ossimNotify(), ossimNotifyLevel_WARN, and status.
Referenced by ossimGpkgWriter::writeGpkgContentsTable().
86 {
87  static const char M[] = "ossimGpkgContentsRecord::init";
88
89  bool status = false;
90
91  if ( pStmt )
92  {
93  const ossim_int32 EXPECTED_COLUMNS = 10;
94  ossim_int32 nCol = sqlite3_column_count( pStmt );
95
96  if ( nCol != EXPECTED_COLUMNS )
97  {
99  << M << " WARNING:\nUnexpected number of columns: " << nCol
100  << "Expected column count: " << EXPECTED_COLUMNS
101  << std::endl;
102  }
103
104  if ( nCol >= EXPECTED_COLUMNS )
105  {
106  ossim_int32 columnsFound = 0;
107  std::string colName;
108  const char* c = 0; // To catch null so not to pass to string.
109
110  for ( ossim_int32 i = 0; i < nCol; ++i )
111  {
112  colName = sqlite3_column_name(pStmt, i);
113  if ( colName.size() )
114  {
115  if ( colName == "table_name" )
116  {
117  c = (const char*)sqlite3_column_text(pStmt, i);
118  m_table_name = (c ? c : "");
119  ++columnsFound;
120  }
121  else if ( colName == "data_type" )
122  {
123  c = (const char*)sqlite3_column_text(pStmt, i);
124  m_data_type = (c ? c : "");
125  ++columnsFound;
126  }
127  else if ( colName == "identifier" )
128  {
129  c = (const char*)sqlite3_column_text(pStmt, i);
130  m_identifier = (c ? c : "");
131  ++columnsFound;
132  }
133  else if ( colName == "description" )
134  {
135  c = (const char*)sqlite3_column_text(pStmt, i);
136  m_description = (c ? c : "");
137  ++columnsFound;
138  }
139  else if ( colName == "last_change" )
140  {
141  c = (const char*)sqlite3_column_text(pStmt, i);
142  m_last_change = (c ? c : "");
143  ++columnsFound;
144  }
145  else if ( colName == "min_x" )
146  {
147  m_min_x = sqlite3_column_double(pStmt, i);
148  ++columnsFound;
149  }
150  else if ( colName == "min_y" )
151  {
152  m_min_y = sqlite3_column_double(pStmt, i);
153  ++columnsFound;
154  }
155  else if ( colName == "max_x" )
156  {
157  m_max_x = sqlite3_column_double(pStmt, i);
158  ++columnsFound;
159  }
160  else if ( colName == "max_y" )
161  {
162  m_max_y = sqlite3_column_double(pStmt, i);
163  ++columnsFound;
164  }
165  else if ( colName == "srs_id" )
166  {
167  m_srs_id = sqlite3_column_int(pStmt, i);
168  ++columnsFound;
169  }
170  else
171  {
173  << M << " Unhandled column name["
174  << i << "]: " << colName << std::endl;
175  }
176
177  } // Matches: if ( colName.size() )
178
179  if ( columnsFound == EXPECTED_COLUMNS )
180  {
181  status = true;
182  break;
183  }
184
185  } // Matches: for ( ossim_int32 i = 0; i < nCol; ++i )
186  }
187
188  } // Matches: if ( pStmt )
189
190  return status;
191
192 } // End: ossimGpkgContentsRecord::init( sqlite3_stmt* pStmt )
return status
int ossim_int32
◆ init() [2/2]
bool ossimGpkgContentsRecord::init ( const std::string &  tableName,
ossim_int32  srs_id,
const ossimDpt minPt,
const ossimDpt maxPt
Parameters
tableNamee.g. "tiles"
srs_idID of gpkg_spatial_ref_sys record our projection is relative to.
minPtMinimum bounds in either Easting Northin or lat lon.
maxPtMaximum bounds in either Easting Northin or lat lon. *
Returns
Definition at line 194 of file ossimGpkgContentsRecord.cpp.
References ossim_sqlite::getTime(), ossimDpt::hasNans(), m_data_type, m_description, m_identifier, m_last_change, m_max_x, m_max_y, m_min_x, m_min_y, m_srs_id, m_table_name, status, ossimDpt::x, and ossimDpt::y.
197 {
198  bool status = false;
199  if ( (minPt.hasNans() == false) && (maxPt.hasNans() == false) )
200  {
201  m_table_name = tableName;
202  m_data_type = "tiles";
203  m_identifier = "Raster Tiles for ";
204  m_identifier += tableName;
205  m_description = "Create by ossim gpkg writer.";
206
208
209  m_min_x = minPt.x;
210  m_min_y = minPt.y;
211  m_max_x = maxPt.x;
212  m_max_y = maxPt.y;
213  m_srs_id = srs_id;
214  status = true;
215  }
216  return status;
217 }
double y
Definition: ossimDpt.h:165
bool hasNans() const
Definition: ossimDpt.h:67
return status
void getTime(std::string &result)
Gets time in the form of "%Y-%m-%dT%H:%M:%S.000Z".
double x
Definition: ossimDpt.h:164
◆ insert()
bool ossimGpkgContentsRecord::insert ( sqlite3 *  db)
Parameters
db
Returns
Definition at line 259 of file ossimGpkgContentsRecord.cpp.
References ossim_sqlite::exec(), m_data_type, m_description, m_identifier, m_last_change, m_max_x, m_max_y, m_min_x, m_min_y, m_srs_id, m_table_name, and status.
260 {
261  bool status = false;
262  if ( db )
263  {
264  std::ostringstream sql;
265  sql << "INSERT INTO gpkg_contents VALUES ( "
266  << "'" << m_table_name << "', "
267  << "'" << m_data_type << "', "
268  << "'" << m_identifier << "', "
269  << "'" << m_description << "', "
270  << "'" << m_last_change << "', "
271  << std::setprecision(16)
272  << m_min_x << ", "
273  << m_min_y << ", "
274  << m_max_x << ", "
275  << m_max_y << ", "
276  << m_srs_id
277  << " )";
278
279  if ( ossim_sqlite::exec( db, sql.str() ) == SQLITE_DONE )
280  {
281  status = true;
282  }
283  }
284  return status;
285 }
return status
◆ operator=()
const ossimGpkgContentsRecord & ossimGpkgContentsRecord::operator= ( const ossimGpkgContentsRecord copy_this)
Definition at line 57 of file ossimGpkgContentsRecord.cpp.
References m_data_type, m_description, m_identifier, m_last_change, m_max_x, m_max_y, m_min_x, m_min_y, m_srs_id, and m_table_name.
59 {
60  if ( this != &copy_this )
61  {
62  m_table_name = copy_this.m_table_name;
63  m_data_type = copy_this.m_data_type;
64  m_identifier = copy_this.m_identifier;
65  m_description = copy_this.m_description;
66  m_last_change = copy_this.m_last_change;
67  m_min_x = copy_this.m_min_x;
68  m_min_y = copy_this.m_min_y;
69  m_max_x = copy_this.m_max_x;
70  m_max_y = copy_this.m_max_y;
71  m_srs_id = copy_this.m_srs_id;
72  }
73  return *this;
74 }
◆ saveState()
void ossimGpkgContentsRecord::saveState ( ossimKeywordlist kwl,
const std::string &  prefix
) const
virtual
Parameters
kwlInitialized by this.
prefixe.g. "image0.". Can be empty.
Definition at line 287 of file ossimGpkgContentsRecord.cpp.
References ossimKeywordlist::addPair(), m_data_type, m_description, m_identifier, m_last_change, m_max_x, m_max_y, m_min_x, m_min_y, m_srs_id, m_table_name, ossimString::string(), and ossimString::toString().
289 {
290  std::string myPref = prefix.size() ? prefix : std::string("gpkg_contents.");
291  std::string value;
292
293  std::string key = "table_name";
294  kwl.addPair(myPref, key, m_table_name, true);
295
296  key = "data_type";
297  kwl.addPair(myPref, key, m_data_type, true);
298
299  key = "identifier";
300  kwl.addPair(myPref, key, m_identifier, true);
301
302  key = "description";
303  kwl.addPair(myPref, key, m_description, true);
304
305  key = "last_change";
306  kwl.addPair(myPref, key, m_last_change, true);
307
308  key = "min_x";
309  value = ossimString::toString(m_min_x, 15).string();
310  kwl.addPair(myPref, key, value, true);
311
312  key = "min_y";
313  value = ossimString::toString(m_min_y, 15).string();
314  kwl.addPair(myPref, key, value, true);
315
316  key = "max_x";
317  value = ossimString::toString(m_max_x, 15).string();
318  kwl.addPair(myPref, key, value, true);
319
320  key = "max_y";
321  value = ossimString::toString(m_max_y, 15).string();
322  kwl.addPair(myPref, key, value, true);
323
324  key = "srs_id";
326  kwl.addPair(myPref, key, value, true);
327 }
Numeric to string methods.
void addPair(const std::string &key, const std::string &value, bool overwrite=true)
const std::string & string() const
Definition: ossimString.h:414
Member Data Documentation
◆ m_data_type
std::string ossimGpkgContentsRecord::m_data_type
Definition at line 89 of file ossimGpkgContentsRecord.h.
Referenced by init(), insert(), operator=(), and saveState().
◆ m_description
std::string ossimGpkgContentsRecord::m_description
Definition at line 91 of file ossimGpkgContentsRecord.h.
◆ m_identifier
std::string ossimGpkgContentsRecord::m_identifier
Definition at line 90 of file ossimGpkgContentsRecord.h.
◆ m_last_change
std::string ossimGpkgContentsRecord::m_last_change
Definition at line 92 of file ossimGpkgContentsRecord.h.
◆ m_max_x
ossim_float64 ossimGpkgContentsRecord::m_max_x
Definition at line 95 of file ossimGpkgContentsRecord.h.
◆ m_max_y
ossim_float64 ossimGpkgContentsRecord::m_max_y
Definition at line 96 of file ossimGpkgContentsRecord.h.
◆ m_min_x
ossim_float64 ossimGpkgContentsRecord::m_min_x
Definition at line 93 of file ossimGpkgContentsRecord.h.
◆ m_min_y
ossim_float64 ossimGpkgContentsRecord::m_min_y
Definition at line 94 of file ossimGpkgContentsRecord.h.
◆ m_srs_id
ossim_int32 ossimGpkgContentsRecord::m_srs_id
Definition at line 97 of file ossimGpkgContentsRecord.h.
◆ m_table_name
std::string ossimGpkgContentsRecord::m_table_name
Definition at line 88 of file ossimGpkgContentsRecord.h.
