Public Member Functions | Static Public Member Functions | Public Attributes | List of all members
ossimGpkgNsgTileMatrixExtentRecord Class Reference
#include <ossimGpkgNsgTileMatrixExtentRecord.h>
Inheritance diagram for ossimGpkgNsgTileMatrixExtentRecord:
ossimGpkgDatabaseRecordBase ossimReferenced
 ossimGpkgNsgTileMatrixExtentRecord ()
 default constructor More...
 ossimGpkgNsgTileMatrixExtentRecord (const ossimGpkgNsgTileMatrixExtentRecord &obj)
const ossimGpkgNsgTileMatrixExtentRecordoperator= (const ossimGpkgNsgTileMatrixExtentRecord &obj)
virtual ~ossimGpkgNsgTileMatrixExtentRecord ()
 destructor More...
virtual bool init (sqlite3_stmt *pStmt)
 Initialize from database. More...
bool init (const std::string &tableName, ossim_int32 zoom_level, const ossimIrect &imageRect, const ossimDrect &projectionRect)
 Initialize from projection. More...
bool insert (sqlite3 *db)
 Inserst this record into gpkg_spatial_ref_sys table. More...
virtual void saveState (ossimKeywordlist &kwl, const std::string &prefix) const
 Saves the state of object. More...
- Public Member Functions inherited from ossimGpkgDatabaseRecordBase
 ossimGpkgDatabaseRecordBase ()
virtual ~ossimGpkgDatabaseRecordBase ()
 virtual destructor. More...
 Print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static const std::string & getTableName ()
 Get the table name "nsg_tile_matrix_extent". More...
static bool createTable (sqlite3 *db)
 Creates table in database. More...
Public Attributes
std::string m_table_name
ossim_int32 m_zoom_level
std::string m_extent_type
 “complete”,”missing”,“present”,”absent”,”mixed” More...
ossim_int32 m_min_column
ossim_int32 m_min_row
ossim_int32 m_max_column
ossim_int32 m_max_row
ossim_float64 m_min_x
ossim_float64 m_min_y
ossim_float64 m_max_x
ossim_float64 m_max_y
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 24 of file ossimGpkgNsgTileMatrixExtentRecord.h.
◆ ossimGpkgNsgTileMatrixExtentRecord() [1/2]
ossimGpkgNsgTileMatrixExtentRecord::ossimGpkgNsgTileMatrixExtentRecord ( )
default constructor
Definition at line 27 of file ossimGpkgNsgTileMatrixExtentRecord.cpp.
28  :
30  m_table_name(),
31  m_zoom_level(0),
32  m_extent_type(),
33  m_min_column(0),
34  m_min_row(0),
35  m_max_column(0),
36  m_max_row(0),
41 {
42 }
ossimGpkgDatabaseRecordBase()
default constructor
double nan()
Definition: ossimCommon.h:135
◆ ossimGpkgNsgTileMatrixExtentRecord() [2/2]
ossimGpkgNsgTileMatrixExtentRecord::ossimGpkgNsgTileMatrixExtentRecord ( const ossimGpkgNsgTileMatrixExtentRecord obj)
Definition at line 44 of file ossimGpkgNsgTileMatrixExtentRecord.cpp.
46  :
52  m_min_row(obj.m_min_row),
54  m_max_row(obj.m_max_row),
55  m_min_x(obj.m_min_x),
56  m_min_y(obj.m_min_y),
57  m_max_x(obj.m_max_x),
58  m_max_y(obj.m_max_y)
59 {
60 }
default constructor
◆ ~ossimGpkgNsgTileMatrixExtentRecord()
ossimGpkgNsgTileMatrixExtentRecord::~ossimGpkgNsgTileMatrixExtentRecord ( )
virtual
destructor
Definition at line 82 of file ossimGpkgNsgTileMatrixExtentRecord.cpp.
83 {
84 }
Member Function Documentation
◆ createTable()
bool ossimGpkgNsgTileMatrixExtentRecord::createTable ( sqlite3 *  db)
static
Parameters
db
Returns
Definition at line 230 of file ossimGpkgNsgTileMatrixExtentRecord.cpp.
References status, and ossim_sqlite::tableExists().
Referenced by ossimGpkgWriter::createTables().
231 {
232  bool status = false;
233  if ( db )
234  {
235  status = ossim_sqlite::tableExists( db, TABLE_NAME );
236  if ( !status )
237  {
238  std::ostringstream sql;
239  sql << "CREATE TABLE " << TABLE_NAME << " ( "
240  << "table_name TEXT NOT NULL, "
241  << "zoom_level INTEGER NOT NULL, "
242  << "extent_type TEXT NOT NULL, "
243  << "min_column INTEGER NOT NULL, "
244  << "min_row INTEGER NOT NULL, "
245  << "max_column INTEGER NOT NULL, "
246  << "max_row INTEGER NOT NULL, "
247  << "min_x DOUBLE NOT NULL, "
248  << "min_y DOUBLE NOT NULL, "
249  << "max_x DOUBLE NOT NULL, "
250  << "max_y DOUBLE NOT NULL, "
251  << "CONSTRAINT pk_ntme PRIMARY KEY (table_name, zoom_level, extent_type, min_column, min_row, max_column, max_row), "
252  << "CONSTRAINT fk_ntme FOREIGN KEY (table_name, zoom_level) "
253  << "REFERENCES gpkg_tile_matrix(table_name, zoom_level)"
254  << ")";
255
256  if ( ossim_sqlite::exec( db, sql.str() ) == SQLITE_DONE )
257  {
258  status = true;
259  }
260  }
261  }
262  return status;
263 }
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
int exec(sqlite3 *db, const std::string &sql)
Preforms sqlite3_prepare_v2, sqlite3_step and sqlite3_finalize.
bool tableExists(sqlite3 *db, const std::string &tableName)
Checks for existance of table.
return status
◆ getTableName()
const std::string & ossimGpkgNsgTileMatrixExtentRecord::getTableName ( )
static
Returns
table name
Definition at line 86 of file ossimGpkgNsgTileMatrixExtentRecord.cpp.
Referenced by ossim_gpkg::getNewTableRecord(), ossim_gpkg::getTileEntries(), and ossim_gpkg::getTileEntry().
87 {
88  return TABLE_NAME;
89 }
◆ init() [1/2]
bool ossimGpkgNsgTileMatrixExtentRecord::init ( sqlite3_stmt *  pStmt)
virtual
Parameters
pStmtSQL statement, i.e. result of sqlite3_prepare_v2(...) call.
Implements ossimGpkgDatabaseRecordBase.
Definition at line 91 of file ossimGpkgNsgTileMatrixExtentRecord.cpp.
References m_extent_type, m_max_column, m_max_row, m_max_x, m_max_y, m_min_column, m_min_row, m_min_x, m_min_y, m_table_name, m_zoom_level, ossimNotify(), ossimNotifyLevel_WARN, and status.
92 {
93  static const char M[] = "ossimGpkgNsgTileMatrixExtentRecord::init";
94
95  bool status = false;
96
97  if ( pStmt )
98  {
99  const ossim_int32 EXPECTED_COLUMNS = 11;
100  ossim_int32 nCol = sqlite3_column_count( pStmt );
101
102  if ( nCol != EXPECTED_COLUMNS )
103  {
105  << M << " WARNING:\nUnexpected number of columns: " << nCol
106  << "Expected column count: " << EXPECTED_COLUMNS
107  << std::endl;
108  }
109
110  if ( nCol >= EXPECTED_COLUMNS )
111  {
112  ossim_int32 columnsFound = 0;
113  std::string colName;
114  ossim_int32 type;
115
116  const char* c = 0; // To catch null so not to pass to string.
117
118  for ( ossim_int32 i = 0; i < nCol; ++i )
119  {
120  colName = sqlite3_column_name(pStmt, i);
121  type = sqlite3_column_type(pStmt, i);
122  if ( colName.size() )
123  {
124  if ( colName == "table_name" )
125  {
126  c = (const char*)sqlite3_column_text(pStmt, i);
127  m_table_name = (c ? c : "");
128  ++columnsFound;
129  }
130  else if ( ( colName == "zoom_level" ) && ( type == SQLITE_INTEGER ) )
131  {
132  m_zoom_level = sqlite3_column_int(pStmt, i);
133  ++columnsFound;
134  }
135  else if ( colName == "extent_type" )
136  {
137  c = (const char*)sqlite3_column_text(pStmt, i);
138  m_extent_type = (c ? c : "");
139  ++columnsFound;
140  }
141  else if ( ( colName == "min_column" ) && ( type == SQLITE_INTEGER ) )
142  {
143  m_min_column = sqlite3_column_int(pStmt, i);
144  ++columnsFound;
145  }
146  else if ( ( colName == "min_row" ) && ( type == SQLITE_INTEGER ) )
147  {
148  m_min_row = sqlite3_column_int(pStmt, i);
149  ++columnsFound;
150  }
151  else if ( ( colName == "max_column" ) && ( type == SQLITE_INTEGER ) )
152  {
153  m_max_column = sqlite3_column_int(pStmt, i);
154  ++columnsFound;
155  }
156  else if ( ( colName == "max_row" ) && ( type == SQLITE_INTEGER ) )
157  {
158  m_max_row = sqlite3_column_int(pStmt, i);
159  ++columnsFound;
160  }
161  else if ( ( colName == "min_x" ) && ( type == SQLITE_FLOAT ) )
162  {
163  m_min_x = sqlite3_column_double(pStmt, i);
164  ++columnsFound;
165  }
166  else if ( ( colName == "min_y" ) && ( type == SQLITE_FLOAT ) )
167  {
168  m_min_y = sqlite3_column_double(pStmt, i);
169  ++columnsFound;
170  }
171  else if ( ( colName == "max_x" ) && ( type == SQLITE_FLOAT ) )
172  {
173  m_max_x = sqlite3_column_double(pStmt, i);
174  ++columnsFound;
175  }
176  else if ( colName == "max_y" )
177  {
178  m_max_y = sqlite3_column_double(pStmt, i);
179  ++columnsFound;
180  }
181  else
182  {
184  << M << " Unhandled column name["
185  << i << "]: " << colName << std::endl;
186  }
187
188  } // Matches: if ( colName.size() )
189
190  if ( columnsFound == EXPECTED_COLUMNS )
191  {
192  status = true;
193  break;
194  }
195
196  } // Matches: for ( int i = 0; i < nCol; ++i )
197  }
198
199  } // Matches: if ( pStmt )
200
201  return status;
202
203 } // End: ossimGpkgNsgTileMatrixExtentRecord::init( pStmt )
return status
int ossim_int32
◆ init() [2/2]
bool ossimGpkgNsgTileMatrixExtentRecord::init ( const std::string &  tableName,
const ossimIrect imageRect,
const ossimDrect projectionRect
Parameters
tableNamee.g. "tiles"
zoom_level
imageRect
projectionRectEdge to edge either Easting Northin or lat lon.
Returns
Definition at line 205 of file ossimGpkgNsgTileMatrixExtentRecord.cpp.
References ossimIrect::hasNans(), ossimDrect::hasNans(), ossimDrect::ll(), ossimIrect::lr(), m_extent_type, m_max_column, m_max_row, m_max_x, m_max_y, m_min_column, m_min_row, m_min_x, m_min_y, m_table_name, m_zoom_level, status, ossimIrect::ul(), ossimDrect::ur(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
209 {
210  bool status = false;
211  if ( (imageRect.hasNans() == false) && (projectionRect.hasNans() == false) )
212  {
213  m_table_name = tableName;
214  m_zoom_level = zoom_level;
215  m_extent_type = "complete";
216  m_min_column = imageRect.ul().x;
217  m_min_row = imageRect.ul().y;
218  m_max_column = imageRect.lr().x;
219  m_max_row = imageRect.lr().y;
220  m_min_x = projectionRect.ll().x;
221  m_min_y = projectionRect.ll().y;
222  m_max_x = projectionRect.ur().x;
223  m_max_y = projectionRect.ur().y;
224
225  status = true;
226  }
227  return status;
228 }
double y
Definition: ossimDpt.h:165
const ossimIpt & ul() const
Definition: ossimIrect.h:274
const ossimIpt & lr() const
Definition: ossimIrect.h:276
bool hasNans() const
Definition: ossimDrect.h:396
return status
ossim_int32 y
Definition: ossimIpt.h:142
const ossimDpt & ur() const
Definition: ossimDrect.h:340
double x
Definition: ossimDpt.h:164
Definition: ossimIrect.h:337
ossim_int32 x
Definition: ossimIpt.h:141
const ossimDpt & ll() const
Definition: ossimDrect.h:342
◆ insert()
bool ossimGpkgNsgTileMatrixExtentRecord::insert ( sqlite3 *  db)
Parameters
db
Returns
Definition at line 265 of file ossimGpkgNsgTileMatrixExtentRecord.cpp.
References ossim_sqlite::exec(), m_extent_type, m_max_column, m_max_row, m_max_x, m_max_y, m_min_column, m_min_row, m_min_x, m_min_y, m_table_name, m_zoom_level, and status.
266 {
267  bool status = false;
268  if ( db )
269  {
270  std::ostringstream sql;
271  sql << "INSERT INTO nsg_tile_matrix_extent VALUES ( "
272  << "'" << m_table_name << "', "
273  << m_zoom_level << ", "
274  << "'" << m_extent_type << "', "
275  << m_min_column << ", "
276  << m_min_row << ", "
277  << m_max_column << ", "
278  << m_max_row << ", "
279  << std::setprecision(16)
280  << m_min_x << ", "
281  << m_min_y << ", "
282  << m_max_x << ", "
283  << m_max_y
284  << " )";
285
286  if ( ossim_sqlite::exec( db, sql.str() ) == SQLITE_DONE )
287  {
288  status = true;
289  }
290  }
291  return status;
292 }
return status
◆ operator=()
const ossimGpkgNsgTileMatrixExtentRecord & ossimGpkgNsgTileMatrixExtentRecord::operator= ( const ossimGpkgNsgTileMatrixExtentRecord obj)
Definition at line 62 of file ossimGpkgNsgTileMatrixExtentRecord.cpp.
References m_extent_type, m_max_column, m_max_row, m_max_x, m_max_y, m_min_column, m_min_row, m_min_x, m_min_y, m_table_name, and m_zoom_level.
64 {
65  if ( this != &obj )
66  {
71  m_min_row = obj.m_min_row;
73  m_max_row = obj.m_max_row;
74  m_min_x = obj.m_min_x;
75  m_min_y = obj.m_min_y;
76  m_max_x = obj.m_max_x;
77  m_max_y = obj.m_max_y;
78  }
79  return *this;
80 }
◆ saveState()
void ossimGpkgNsgTileMatrixExtentRecord::saveState ( ossimKeywordlist kwl,
const std::string &  prefix
) const
virtual
Parameters
kwlInitialized by this.
prefixe.g. "image0.". Can be empty.
Definition at line 294 of file ossimGpkgNsgTileMatrixExtentRecord.cpp.
References ossimKeywordlist::addPair(), m_extent_type, m_max_column, m_max_row, m_max_x, m_max_y, m_min_column, m_min_row, m_min_x, m_min_y, m_table_name, m_zoom_level, ossimString::string(), and ossimString::toString().
296 {
297  std::string myPref = prefix.size() ? prefix : std::string("nsg_tile_matrix_extent.");
298  std::string value;
299
300  std::string key = "table_name";
301  kwl.addPair(myPref, key, m_table_name, true);
302
303  key = "zoom_level";
305  kwl.addPair(myPref, key, value, true);
306
307  key = "extent_type";
308  kwl.addPair(myPref, key, m_extent_type, true);
309
310  key = "min_column";
312  kwl.addPair(myPref, key, value, true);
313
314  key = "min_row";
316  kwl.addPair(myPref, key, value, true);
317
318  key = "max_column";
320  kwl.addPair(myPref, key, value, true);
321
322  key = "max_row";
324  kwl.addPair(myPref, key, value, true);
325
326  key = "min_x";
327  value = ossimString::toString(m_min_x, 20).string();
328  kwl.addPair(myPref, key, value, true);
329
330  key = "min_y";
331  value = ossimString::toString(m_min_y, 20).string();
332  kwl.addPair(myPref, key, value, true);
333
334  key = "max_x";
335  value = ossimString::toString(m_max_x, 20).string();
336  kwl.addPair(myPref, key, value, true);
337
338  key = "max_y";
339  value = ossimString::toString(m_max_y, 20).string();
340  kwl.addPair(myPref, key, value, true);
341 }
Numeric to string methods.
void addPair(const std::string &key, const std::string &value, bool overwrite=true)
const std::string & string() const
Definition: ossimString.h:414
Member Data Documentation
◆ m_extent_type
std::string ossimGpkgNsgTileMatrixExtentRecord::m_extent_type
Definition at line 92 of file ossimGpkgNsgTileMatrixExtentRecord.h.
Referenced by init(), insert(), operator=(), and saveState().
◆ m_max_column
ossim_int32 ossimGpkgNsgTileMatrixExtentRecord::m_max_column
Definition at line 96 of file ossimGpkgNsgTileMatrixExtentRecord.h.
◆ m_max_row
ossim_int32 ossimGpkgNsgTileMatrixExtentRecord::m_max_row
Definition at line 97 of file ossimGpkgNsgTileMatrixExtentRecord.h.
◆ m_max_x
ossim_float64 ossimGpkgNsgTileMatrixExtentRecord::m_max_x
Definition at line 100 of file ossimGpkgNsgTileMatrixExtentRecord.h.
◆ m_max_y
ossim_float64 ossimGpkgNsgTileMatrixExtentRecord::m_max_y
Definition at line 101 of file ossimGpkgNsgTileMatrixExtentRecord.h.
◆ m_min_column
ossim_int32 ossimGpkgNsgTileMatrixExtentRecord::m_min_column
Definition at line 94 of file ossimGpkgNsgTileMatrixExtentRecord.h.
◆ m_min_row
ossim_int32 ossimGpkgNsgTileMatrixExtentRecord::m_min_row
Definition at line 95 of file ossimGpkgNsgTileMatrixExtentRecord.h.
◆ m_min_x
ossim_float64 ossimGpkgNsgTileMatrixExtentRecord::m_min_x
Definition at line 98 of file ossimGpkgNsgTileMatrixExtentRecord.h.
◆ m_min_y
ossim_float64 ossimGpkgNsgTileMatrixExtentRecord::m_min_y
Definition at line 99 of file ossimGpkgNsgTileMatrixExtentRecord.h.
◆ m_table_name
std::string ossimGpkgNsgTileMatrixExtentRecord::m_table_name
Definition at line 88 of file ossimGpkgNsgTileMatrixExtentRecord.h.
◆ m_zoom_level
ossim_int32 ossimGpkgNsgTileMatrixExtentRecord::m_zoom_level
Definition at line 89 of file ossimGpkgNsgTileMatrixExtentRecord.h.
