ossimImageModel Class Reference
Class to handle transforming image points, rectangles, and offsets from one reduced resolution data set (rrds) level to another. More...
#include <ossimImageModel.h>
Inheritance diagram for ossimImageModel:
ossimObject ossimReferenced ossimImageProjectionModel
Public Member Functions
 ossimImageModel ()
 default constructor More...
virtual void initialize (const ossimImageHandler &ih)
 Method to initialize class from an image handler. More...
void rnToR0 (ossim_uint32 rrds, const ossimDpt &rnPt, ossimDpt &r0Pt) const
 Get r0 point from rn point. More...
void rnToR0 (const ossimDpt &rnPt, ossimDpt &r0Pt) const
void r0ToRn (ossim_uint32 rrds, const ossimDpt &r0Pt, ossimDpt &rnPt) const
 Get rn point from r0 point. More...
void r0ToRn (const ossimDpt &r0Pt, ossimDpt &rnPt) const
void getSubImageOffset (ossim_uint32 rrds, ossimDpt &offset) const
 Get the sub image offset for a given resolution level. More...
void getImageRectangle (ossim_uint32 rrds, ossimDrect &rect) const
 Gets the zero-based image rectangle for a given reduced resolution data set. More...
void getBoundingRectangle (ossim_uint32 rrds, ossimDrect &rect) const
 Gets the model-based image rectangle for a given reduced resolution data set. More...
ossim_uint32 getNumberOfDecimationLevels () const
void setTargetRrds (ossim_uint32 rrds)
 Set theTargetRrds data member. More...
ossim_uint32 getTargetRrds () const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
Protected Member Functions
virtual ~ossimImageModel ()
 virtual destructor More...
virtual ~ossimReferenced ()
Protected Attributes
ossimDpt theSubImageOffset
 Offset from the full image. More...
 Decimation factors for each rrds level. More...
ossim_uint32 theLines
ossim_uint32 theSamples
ossim_uint32 theTargetRrds
Detailed Description
Derived from ossimObject only so users can pass via the ossimViewInterface::setView method.
Definition at line 33 of file ossimImageModel.h.
◆ ossimImageModel()
ossimImageModel::ossimImageModel ( )
default constructor
Definition at line 23 of file ossimImageModel.cpp.
24  : ossimObject(),
27  theLines(0),
28  theSamples(0),
29  theTargetRrds(0)
30 {
31 }
std::vector< ossimDpt > theDecimationFactors
◆ ~ossimImageModel()
ossimImageModel::~ossimImageModel ( )
protectedvirtual
virtual destructor
Definition at line 33 of file ossimImageModel.cpp.
34 {
35 }
Member Function Documentation
◆ getBoundingRectangle()
void ossimImageModel::getBoundingRectangle ( ossim_uint32  rrds,
ossimDrect rect
) const
If this image is a sub image the offset is applied. So if the image has a sub image offset of (1024, 1024), and has 1024 lines and 1024 samples the rectangle for r0 will be: (1024, 1024) (2047, 2047)
Parameters
rrdsThe reduced resolution data set.
rectInitialized with image rectangle for rrds.
Note
Throws ossimException on out of range rrds.
Definition at line 118 of file ossimImageModel.cpp.
References theDecimationFactors, theLines, theSamples, theSubImageOffset, ossimDpt::x, and ossimDpt::y.
120 {
121  if ( rrds < theDecimationFactors.size() )
122  {
125
126  ossim_float64 lrX = urX + theSamples*theDecimationFactors[rrds].x - 1.0;
127  ossim_float64 lrY = urY + theLines *theDecimationFactors[rrds].y - 1.0;
128  ossimDrect r(0, 0, lrX, lrY);
129  rect = r;
130  }
131  else
132  {
133  std::string e =
134  "ossimImageModel::getBoundingRectangle rrds out of range!";
135  throw ossimException(e);
136  }
137 }
double y
Definition: ossimDpt.h:165
double ossim_float64
double x
Definition: ossimDpt.h:164
◆ getImageRectangle()
void ossimImageModel::getImageRectangle ( ossim_uint32  rrds,
ossimDrect rect
) const
Parameters
Note
Definition at line 101 of file ossimImageModel.cpp.
References theDecimationFactors, theLines, and theSamples.
103 {
104  if ( rrds < theDecimationFactors.size() )
105  {
106  ossim_float64 lrX = theSamples * theDecimationFactors[rrds].x - 1.0;
107  ossim_float64 lrY = theLines * theDecimationFactors[rrds].y - 1.0;
108  ossimDrect r(0.0, 0.0, lrX, lrY);
109  rect = r;
110  }
111  else
112  {
113  std::string e = "ossimImageModel::getImageRectangle rrds out of range!";
114  throw ossimException(e);
115  }
116 }
◆ getNumberOfDecimationLevels()
ossim_uint32 ossimImageModel::getNumberOfDecimationLevels ( ) const
Returns
This returns the total number of decimation levels.
Definition at line 138 of file ossimImageModel.cpp.
References theDecimationFactors.
139 {
140  return (ossim_uint32)theDecimationFactors.size();
141 }
unsigned int ossim_uint32
◆ getSubImageOffset()
void ossimImageModel::getSubImageOffset ( ossim_uint32  rrds,
ossimDpt offset
) const
Parameters
offsetthe Point to initialize.
Note
Definition at line 86 of file ossimImageModel.cpp.
References theDecimationFactors, theSubImageOffset, ossimDpt::x, and ossimDpt::y.
88 {
89  if ( rrds < theDecimationFactors.size() )
90  {
91  offset.x = theSubImageOffset.x * theDecimationFactors[rrds].x;
92  offset.y = theSubImageOffset.y * theDecimationFactors[rrds].y;
93  }
94  else
95  {
96  std::string e = "ossimImageModel::getSubImageOffset rrds out of range!";
97  throw ossimException(e);
98  }
99 }
double y
double x
◆ getTargetRrds()
ossim_uint32 ossimImageModel::getTargetRrds ( ) const
Returns
The target reduced resolution data set.
Definition at line 148 of file ossimImageModel.cpp.
References theTargetRrds.
149 {
150  return theTargetRrds;
151 }
◆ initialize()
void ossimImageModel::initialize ( const ossimImageHandler ih)
virtual
Parameters
ihImage handler.
Reimplemented in ossimImageProjectionModel.
Definition at line 37 of file ossimImageModel.cpp.
References ossimImageHandler::getDecimationFactors(), ossimImageHandler::getNumberOfLines(), ossimImageHandler::getNumberOfSamples(), theDecimationFactors, theLines, theSamples, and theSubImageOffset.
Referenced by ossimImageProjectionModel::initialize().
38 {
40  theLines = ih.getNumberOfLines(0);
43 }
virtual void getDecimationFactors(vector< ossimDpt > &decimations) const
This returns all decimation for all levels.
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
◆ r0ToRn() [1/2]
void ossimImageModel::r0ToRn ( ossim_uint32  rrds,
const ossimDpt r0Pt,
ossimDpt rnPt
) const
Parameters
rrdsTarget (rnPt) reduced resolution data set.
r0PtThe image point to tranform.
rnPtthe Point to initialize.
Note
Definition at line 65 of file ossimImageModel.cpp.
References theDecimationFactors, ossimDpt::x, and ossimDpt::y.
Referenced by r0ToRn().
68 {
69  if ( rrds < theDecimationFactors.size() )
70  {
71  rnPt.x = r0Pt.x * theDecimationFactors[rrds].x;
72  rnPt.y = r0Pt.y * theDecimationFactors[rrds].y;
73  }
74  else
75  {
76  std::string e = "ossimImageModel::r0ToRn rrds out of range!";
77  throw ossimException(e);
78  }
79 }
double y
double x
◆ r0ToRn() [2/2]
void ossimImageModel::r0ToRn ( const ossimDpt r0Pt,
ossimDpt rnPt
) const
This requires calling setTargetRrds(ossim_uint32 rrds) to the level for rnPt.
Parameters
Note
See also
setTargetRrds
Definition at line 81 of file ossimImageModel.cpp.
References r0ToRn(), and theTargetRrds.
82 {
83  r0ToRn(theTargetRrds, r0Pt, rnPt);
84 }
void r0ToRn(ossim_uint32 rrds, const ossimDpt &r0Pt, ossimDpt &rnPt) const
◆ rnToR0() [1/2]
void ossimImageModel::rnToR0 ( ossim_uint32  rrds,
const ossimDpt rnPt,
ossimDpt r0Pt
) const
Parameters
rrdsSource (rnPt) reduced resolution data set.
rnPtThe image point to tranform.
r0Ptthe Point to initialize.
Note
Definition at line 45 of file ossimImageModel.cpp.
Referenced by rnToR0().
48 {
49  if ( rrds < theDecimationFactors.size() )
50  {
51  r0Pt.x = rnPt.x / theDecimationFactors[rrds].x;
52  r0Pt.y = rnPt.y / theDecimationFactors[rrds].y;
53  }
54  else
55  {
56  std::string e = "ossimImageModel::rnToR0 rrds out of range!";
57  throw ossimException(e);
58  }
59 }
double y
double x
◆ rnToR0() [2/2]
void ossimImageModel::rnToR0 ( const ossimDpt rnPt,
ossimDpt r0Pt
) const
Parameters
Note
See also
setTargetRrds
Definition at line 60 of file ossimImageModel.cpp.
References rnToR0(), and theTargetRrds.
61 {
62  rnToR0(theTargetRrds, rnPt, r0Pt);
63 }
void rnToR0(ossim_uint32 rrds, const ossimDpt &rnPt, ossimDpt &r0Pt) const
◆ setTargetRrds()
void ossimImageModel::setTargetRrds ( ossim_uint32  rrds)
This is used by methods rnToR0 and r0ToRn that do not take a rrds argument.
Parameters
rrdsTarget reduced resolution data set.
Definition at line 143 of file ossimImageModel.cpp.
144 {
145  theTargetRrds = rrds;
146 }
Member Data Documentation
◆ theDecimationFactors
std::vector<ossimDpt> ossimImageModel::theDecimationFactors
protected
Definition at line 180 of file ossimImageModel.h.
Referenced by getBoundingRectangle(), getImageRectangle(), getNumberOfDecimationLevels(), getSubImageOffset(), initialize(), r0ToRn(), and rnToR0().
◆ theLines
ossim_uint32 ossimImageModel::theLines
protected
Definition at line 182 of file ossimImageModel.h.
Referenced by getBoundingRectangle(), getImageRectangle(), and initialize().
◆ theSamples
ossim_uint32 ossimImageModel::theSamples
protected
Definition at line 183 of file ossimImageModel.h.
◆ theSubImageOffset
ossimDpt ossimImageModel::theSubImageOffset
protected
Definition at line 177 of file ossimImageModel.h.
Referenced by getBoundingRectangle(), getSubImageOffset(), and initialize().
◆ theTargetRrds
ossim_uint32 ossimImageModel::theTargetRrds
protected
Definition at line 184 of file ossimImageModel.h.
Referenced by getTargetRrds(), r0ToRn(), rnToR0(), and setTargetRrds().
