Class derived from ossimImageModel, this adds an image projection for lineSampleToWorld and worldToLineSample. More...
#include <ossimImageProjectionModel.h>
ossimImageProjectionModel () | |
default constructor More... | |
virtual void | initialize (const ossimImageHandler &ih) |
Method to initialize class from an image handler. More... | |
const ossimProjection * | getProjection () const |
Method to get projection. More... | |
ossimImageModel () | |
void | rnToR0 (ossim_uint32 rrds, const ossimDpt &rnPt, ossimDpt &r0Pt) const |
Get r0 point from rn point. More... | |
void | rnToR0 (const ossimDpt &rnPt, ossimDpt &r0Pt) const |
void | r0ToRn (ossim_uint32 rrds, const ossimDpt &r0Pt, ossimDpt &rnPt) const |
Get rn point from r0 point. More... | |
void | r0ToRn (const ossimDpt &r0Pt, ossimDpt &rnPt) const |
void | getSubImageOffset (ossim_uint32 rrds, ossimDpt &offset) const |
Get the sub image offset for a given resolution level. More... | |
void | getImageRectangle (ossim_uint32 rrds, ossimDrect &rect) const |
Gets the zero-based image rectangle for a given reduced resolution data set. More... | |
void | getBoundingRectangle (ossim_uint32 rrds, ossimDrect &rect) const |
Gets the model-based image rectangle for a given reduced resolution data set. More... | |
ossim_uint32 | getNumberOfDecimationLevels () const |
void | setTargetRrds (ossim_uint32 rrds) |
Set theTargetRrds data member. More... | |
ossim_uint32 | getTargetRrds () const |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
virtual | ~ossimImageProjectionModel () |
virtual destructor More... | |
virtual | ~ossimImageModel () |
virtual | ~ossimReferenced () |
Protected Attributes | |
ossimProjection * | theProjection |
ossimDpt | theSubImageOffset |
Offset from the full image. More... | |
std::vector< ossimDpt > | theDecimationFactors |
Decimation factors for each rrds level. More... | |
ossim_uint32 | theLines |
ossim_uint32 | theSamples |
ossim_uint32 | theTargetRrds |
Note that image points fed to projection methods should be full resolution with any sub image offset applied.
Definition at line 30 of file ossimImageProjectionModel.h.
ossimImageProjectionModel::ossimImageProjectionModel | ( | ) |
default constructor
protectedvirtual |
virtual destructor
Definition at line 30 of file ossimImageProjectionModel.cpp.
References theProjection.
const ossimProjection * ossimImageProjectionModel::getProjection | ( | ) | const |
Definition at line 51 of file ossimImageProjectionModel.cpp.
ih | Image handler. |
Reimplemented from ossimImageModel.
Definition at line 35 of file ossimImageProjectionModel.cpp.
References ossimImageHandler::getImageGeometry(), ossimImageGeometry::getProjection(), ossimImageModel::initialize(), theProjection, and ossimRefPtr< T >::valid().
protected |
Definition at line 56 of file ossimImageProjectionModel.h.
Referenced by getProjection(), initialize(), and ~ossimImageProjectionModel().
