Public Types | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimImageHandler Class Referenceabstract
This class defines an abstract Handler which all image handlers(loaders) should derive from. More...
#include <ossimImageHandler.h>
Inheritance diagram for ossimImageHandler:
ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced ossimAdrgTileSource ossimBandSeparateHandler ossimBitMaskTileSource ossimCcfTileSource ossimCibCadrgTileSource ossimDtedTileSource ossimGdalTileSource ossimGeneralRasterTileSource ossimGeoPdfReader ossimGpkgReader ossimH5ImageHandler ossimHdf5ImageHandler ossimHdfReader ossimImageCacheBase ossimImageHandlerMtAdaptor ossimJpegTileSource ossimKakaduJ2kReader ossimKakaduJp2Reader ossimKakaduJpipHandler ossimKmlSuperOverlayReader ossimLasReader ossimMG4LidarReader ossimMrSidReader ossimNitfTileSource ossimOgrGdalTileSource ossimOgrVectorTileSource ossimOpjJp2Reader ossimPngReader ossimPointCloudImageHandler ossimRangeDomeTileSource ossimRpfCacheTileSource ossimTiffTileSource ossimTiledImageHandler ossimUsgsDemTileSource ossimVideoImageHandler ossimVpfTileSource
Public Types
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
virtual bool open ()=0
 Pure virtual open. More...
 Opens the image file. More...
virtual void close ()
 Deletes the overview and clears the valid image vertices. More...
virtual bool isOpen () const =0
virtual ossim_uint32 getNumberOfLines (ossim_uint32 resLevel=0) const =0
 Pure virtual, derived classes must implement. More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 resLevel=0) const =0
 Sets the filename. More...
 Returns the filename. More...
virtual bool isValidRLevel (ossim_uint32 resLevel) const
 Connection rule. More...
virtual ossim_uint32 getImageTileWidth () const =0
virtual ossim_uint32 getImageTileHeight () const =0
virtual bool hasLut () const
virtual void loadMetaData ()
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ossim_uint32 getNumberOfInputBands () const =0
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
virtual void completeOpen ()
virtual ~ossimReferenced ()
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 35 of file ossimImageHandler.h.
◆ ossimImageHandlerOverviewCompressionType
◆ ossimImageHandler()
ossimImageHandler::ossimImageHandler ( )
Constructor (default):
Definition at line 65 of file ossimImageHandler.cpp.
66 :
67 ossimImageSource(0, 0, 0, true, false /* output list is not fixed */ ),
71 theOverview(0),
73 theMetaData(),
74 theGeometry(),
75 theLut(0),
77 theImageID(""),
81 {
82  if (traceDebug())
83  {
85  << "ossimImageHandler::ossimImageHandler() DEBUG:" << std::endl;
86 #ifdef OSSIM_ID_ENABLED
88  << "OSSIM_ID: "
89  << OSSIM_ID
90  << std::endl;
91 #endif
92  }
93
94  // Check for global preference supplementary dir.
96  preferencesKWL().findKey( std::string("ossim_supplementary_directory") );
97 }
ossimRefPtr< ossimImageGeometry > theGeometry
static const ossimFilename NIL
This was taken from Wx widgets for performing touch and access date stamps.
Definition: ossimFilename.h:40
std::vector< ossimDpt > theDecimationFactors
If true opening of overviews will be attempted.
ossimFilename theSupplementaryDirectory
ossimImageSource(ossimObject *owner=0)
vector< ossimIpt > theValidImageVertices
static ossimPreferences * instance()
ossimImageMetaData theMetaData
ossimRefPtr< ossimImageHandler > theOverview
ossimRefPtr< ossimNBandLutDataObject > theLut
ossim_uint32 theStartingResLevel
theStartingResLevel If set to something other than zero(default) this is indicative that the reader i...
const std::string & string() const
Definition: ossimString.h:414
◆ ~ossimImageHandler()
ossimImageHandler::~ossimImageHandler ( )
virtual
Destructor: Derived classes should implement.
Definition at line 99 of file ossimImageHandler.cpp.
References theOverview.
100 {
101  theOverview = 0;
102 }
Member Function Documentation
◆ buildAllHistograms()
bool ossimImageHandler::buildAllHistograms ( int  numberOfRLevels = 0,
ossimHistogramMode  mode = OSSIM_HISTO_MODE_NORMAL
virtual
Build a histograms for all image entries.
Parameters
numberOfRLevelssets the maximum number of reduced resolution level to compute histogram for.
modeOSSIM_HISTO_MODE_NORMAL or OSSIM_HISTO_MODE_FAST.
Returns
true on success, false if not open.
Definition at line 552 of file ossimImageHandler.cpp.
References buildHistogram(), getCurrentEntry(), getEntryList(), and setCurrentEntry().
554 {
555  ossim_uint32 currentEntry = getCurrentEntry();
556  std::vector<ossim_uint32> entryList;
557  getEntryList(entryList);
558  ossim_uint32 idx = 0;
559  for(idx = 0; idx < entryList.size(); ++idx)
560  {
561  setCurrentEntry(entryList[idx]);
562  if(!buildHistogram( numberOfRLevels, mode ))
563  {
564  setCurrentEntry(currentEntry);
565  return false;
566  }
567  }
568
569  setCurrentEntry(currentEntry);
570  return true;
571 }
unsigned int ossim_uint32
virtual ossim_uint32 getCurrentEntry() const
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
virtual bool buildHistogram(int numberOfRLevels=0, ossimHistogramMode mode=OSSIM_HISTO_MODE_NORMAL)
Build a histogram for image file.
◆ buildAllOverviews()
bool ossimImageHandler::buildAllOverviews ( ossimImageHandlerOverviewCompressionType  compressionType = OSSIM_OVERVIEW_COMPRESSION_NONE,
ossim_uint32  quality = 75,
ossimFilterResampler::ossimFilterResamplerType  resampleType = ossimFilterResampler::ossimFilterResampler_BOX,
bool  includeFullResFlag = false
virtual
Will build over file for all image entries.
Parameters
includeFullResFlagif true the full resolution layer will also be put in the overview format. This is handly for inefficeint formats.
Definition at line 589 of file ossimImageHandler.cpp.
References buildOverview(), getCurrentEntry(), getEntryList(), and setCurrentEntry().
593 {
594  ossim_uint32 currentEntry = getCurrentEntry();
595  std::vector<ossim_uint32> entryList;
596  getEntryList(entryList);
597  ossim_uint32 idx = 0;
598  for(idx = 0; idx < entryList.size(); ++idx)
599  {
600  setCurrentEntry(entryList[idx]);
601  if(!buildOverview(compressionType, quality, resampleType, includeFullResFlag))
602  {
603  setCurrentEntry(currentEntry);
604  return false;
605  }
606  }
607
608  setCurrentEntry(currentEntry);
609  return true;
610 }
virtual bool buildOverview(ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false)
Will build over file for theImageFile.
◆ buildHistogram()
bool ossimImageHandler::buildHistogram ( int  numberOfRLevels = 0,
virtual
Parameters
Returns
Definition at line 507 of file ossimImageHandler.cpp.
References ossimListenerManager::addListener(), ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnect(), ossimSource::enableSource(), ossimHistogramWriter::execute(), ossimRefPtr< T >::get(), getFilenameWithThisExtension(), getNumberOfDecimationLevels(), isOpen(), ossimImageHistogramSource::setComputationMode(), ossimHistogramWriter::setFilename(), ossimImageHistogramSource::setMaxNumberOfRLevels(), and theStdOutProgress.
Referenced by buildAllHistograms(), and ATP::AtpGenerator::constructChain().
509 {
510  if(isOpen())
511  {
512  ossimFilename file =
514
517
518  if(numberOfRLevels)
519  {
520  histoSource->setMaxNumberOfRLevels(numberOfRLevels);
521  }
522  else
523  {
525  }
526
527  //---
528  // Note if mode==OSSIM_HISTO_MODE_UNKNOWN the histoSource defaults to
529  // normal mode.
530  //---
531  histoSource->setComputationMode( mode );
532
533  histoSource->connectMyInputTo(0, this);
534  histoSource->enableSource();
535  writer->connectMyInputTo(0, histoSource.get());
536  writer->setFilename(file);
537  writer->addListener(&theStdOutProgress);
538  writer->execute();
539  histoSource->disconnect();
540  writer->disconnect();
541  histoSource = 0;
542  writer = 0;
543  }
544  else
545  {
546  return false;
547  }
548
549  return true;
550 }
virtual bool addListener(ossimListener *listener)
void setComputationMode(ossimHistogramMode mode)
virtual void disconnect(ossimConnectableObject *object=0)
Will disconnect the object passed in.
OSSIM_DLL ossimStdOutProgress theStdOutProgress
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
virtual bool isOpen() const =0
virtual void enableSource()
Definition: ossimSource.cpp:84
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
virtual void setMaxNumberOfRLevels(ossim_uint32 number)
virtual void setFilename(const ossimFilename &filename)
ossimFilename getFilenameWithThisExtension(const ossimString &ext, bool set_e0_prefix=false) const
Returns the image file with extension set using supplentary directory for dirname if set...
◆ buildOverview() [1/2]
bool ossimImageHandler::buildOverview ( ossimImageHandlerOverviewCompressionType  compressionType = OSSIM_OVERVIEW_COMPRESSION_NONE,
virtual
Parameters
Definition at line 573 of file ossimImageHandler.cpp.
References getFilenameWithThisExtension(), openOverview(), and theOverviewFile.
Referenced by buildAllOverviews().
577 {
579
580  theOverviewFile = file;
581  if(buildOverview(file, compressionType, quality, resampleType, includeFullResFlag))
582  {
583  openOverview();
584  }
585
586  return true;
587 }
virtual bool openOverview()
Searches for an overview.
◆ buildOverview() [2/2]
bool ossimImageHandler::buildOverview ( const ossimFilename filename,
virtual
Will build an over file for filename.
Parameters
filenameName of image file.
Definition at line 613 of file ossimImageHandler.cpp.
References ossimTiffOverviewBuilder::buildOverview(), closeOverview(), ossim::COMPRESSION_NONE, isOpen(), OSSIM_OVERVIEW_COMPRESSION_DEFLATE, OSSIM_OVERVIEW_COMPRESSION_JPEG, OSSIM_OVERVIEW_COMPRESSION_LZW, OSSIM_OVERVIEW_COMPRESSION_NONE, OSSIM_OVERVIEW_COMPRESSION_PACKBITS, ossimTiffOverviewBuilder::setCompressionType(), ossimTiffOverviewBuilder::setInputSource(), ossimTiffOverviewBuilder::setJpegCompressionQuality(), ossimTiffOverviewBuilder::setResampleType(), and theOverviewFile.
618 {
619  closeOverview();
620  if(!isOpen())
621  {
622  return false;
623  }
624
625  theOverviewFile = filename;
626  ossimTiffOverviewBuilder tiffBuilder;
627  if ( tiffBuilder.setInputSource(this) == false )
628  {
629  return false;
630  }
631
633  switch(compressionType)
634  {
636  {
637  cType = COMPRESSION_NONE;
638  break;
639  }
641  {
642  cType = COMPRESSION_JPEG;
643  break;
644  }
646  {
647  cType = COMPRESSION_LZW;
648  break;
649  }
651  {
652
653  cType = COMPRESSION_DEFLATE;
654  break;
655  }
657  {
658  cType = COMPRESSION_PACKBITS;
659  break;
660  }
661  }
662  tiffBuilder.setJpegCompressionQuality(quality);
663  tiffBuilder.setCompressionType(cType);
664  tiffBuilder.setResampleType(resampleType);
665  tiffBuilder.buildOverview(filename, includeFullResFlag);
666
667  return true;
668 }
virtual void closeOverview()
If theOverview is initialized it will be deleted and set to NULL.
unsigned short ossim_uint16
void setJpegCompressionQuality(ossim_int32 quality)
Sets the compression quality for use when using a compression type of COMPRESSION_JPEG.
virtual bool setInputSource(ossimImageHandler *imageSource)
Sets the input to the builder.
void setCompressionType(ossim_uint16 compression_type)
Sets the compression type to use when building overviews.
bool buildOverview(const ossimFilename &overview_file, bool copy_all=false)
Builds overview file and sets "theOutputFile" to that of the overview_file.
void setResampleType(ossimFilterResampler::ossimFilterResamplerType resampleType)
Supports BOX or NEAREST NEIGHBOR.
◆ canConnectMyInputTo()
bool ossimImageHandler::canConnectMyInputTo ( ossim_int32  inputIndex,
const ossimConnectableObject object
) const
virtual
Connection rule.
Since image handler currently don't have any inputs this will just return false saying we can't connect anything to an image handler.
Implements ossimConnectableObject.
Reimplemented in ossimImageHandlerMtAdaptor.
Definition at line 1538 of file ossimImageHandler.cpp.
1540 {
1541  return false;
1542 }
◆ close()
void ossimImageHandler::close ( )
virtual
Reimplemented in ossimPngReader, ossimGpkgReader, ossimOpjJp2Reader, ossimJpegTileSource, ossimH5ImageHandler, ossimHdfReader, ossimHdf5ImageHandler, ossimAdrgTileSource, ossimGeneralRasterTileSource, ossimBitMaskTileSource, ossimNitfTileSource, ossimRangeDomeTileSource, ossimCibCadrgTileSource, ossimTiffTileSource, ossimLasReader, ossimplugins::ossimTerraSarTiffReader, ossimRpfCacheTileSource, ossimPointCloudImageHandler, ossimplugins::ossimRadarSat2TiffReader, ossimImageHandlerMtAdaptor, ossimDtedTileSource, ossimCcfTileSource, ossimImageCacheTileSource, ossimOgrGdalTileSource, ossimOgrVectorTileSource, ossimTiledImageHandler, ossimGdalTileSource, ossimKakaduJpipHandler, ossimBandSeparateHandler, ossimKmlSuperOverlayReader, ossimImageCacheBase, ossimVideoImageHandler, and ossimVpfTileSource.
Definition at line 1264 of file ossimImageHandler.cpp.
References setState(), theDecimationFactors, theGeometry, theOverview, and theValidImageVertices.
Referenced by ossimKakaduJpipHandler::close(), ossimImageHandlerMtAdaptor::close(), ossimPointCloudImageHandler::close(), ossimLasReader::close(), ossimTiffTileSource::close(), ossimCibCadrgTileSource::close(), ossimBitMaskTileSource::close(), ossimGeneralRasterTileSource::close(), ossimHdf5ImageHandler::close(), ossimH5ImageHandler::close(), ossimOpjJp2Reader::close(), ossimGpkgReader::close(), ossimPngReader::close(), ossimMG4LidarReader::closeEntry(), ossimGeoPdfReader::closeEntry(), ossimMrSidReader::closeEntry(), ossimKakaduJp2Reader::closeEntry(), ossimKakaduJ2kReader::closeEntry(), ossimGeoidImage::open(), open(), and ossimHdfReader::~ossimHdfReader().
1265 {
1266  theOverview = 0;
1267  theGeometry = 0;
1268  theValidImageVertices.clear();
1269  theDecimationFactors.clear();
1270  setState(0);
1271 }
void setState(std::shared_ptr< ossim::ImageHandlerState > state)
◆ closeOverview()
void ossimImageHandler::closeOverview ( )
virtual
Also clears theOverviewFile.
Returns
void
Definition at line 830 of file ossimImageHandler.cpp.
Referenced by buildOverview(), and ossimImageHandlerMtAdaptor::close().
831 {
832  theOverview = 0;
833 }
◆ completeOpen()
void ossimImageHandler::completeOpen ( )
protectedvirtual
Will complete the opening process.
If there are overviews it will open them. If there is meta data it will open that and if there is valid vertices it will open that.
Reimplemented in ossimLasReader.
Definition at line 1519 of file ossimImageHandler.cpp.
Referenced by ossimBandSeparateHandler::open(), ossimPointCloudImageHandler::open(), ossimPngReader::open(), ossimKakaduJpipHandler::openStream(), ossimHdf5ImageHandler::setCurrentEntry(), ossimH5ImageHandler::setCurrentEntry(), ossimNitfTileSource::setCurrentEntry(), ossimGpkgReader::setCurrentEntry(), ossimRpfCacheTileSource::setCurrentEntry(), ossimCibCadrgTileSource::setCurrentEntry(), ossimPointCloudImageHandler::setPointCloudHandler(), and setSupplementaryDirectory().
1520 {
1521  if(traceDebug())
1522  {
1523  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimImageHandler::completeOpen(): Entered........" << std::endl;
1524  }
1525  loadMetaData();
1526  if ( theOpenOverviewFlag )
1527  {
1528  openOverview();
1529  }
1531  if(traceDebug())
1532  {
1533  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimImageHandler::completeOpen(): Leaving......." << std::endl;
1534  }
1536 }
virtual bool openValidVertices()
Creates vertices file name based on image, then tries to open.
virtual void establishDecimationFactors()
Virtual method determines the decimation factors at each resolution level.
virtual void loadMetaData()
There is an external file with an omd extension.
◆ createDefaultGeometryFilename()
ossimFilename ossimImageHandler::createDefaultGeometryFilename ( ) const
virtual
Returns
ossimFilename represents an external OSSIM geometry filename.
Definition at line 1844 of file ossimImageHandler.cpp.
References getFilenameWithThisExtension().
Referenced by getProperty().
1845 {
1846  return getFilenameWithThisExtension("geom");
1847 }
◆ createDefaultHistogramFilename()
ossimFilename ossimImageHandler::createDefaultHistogramFilename ( ) const
virtual
Returns
ossimFilename represents an external OSSIM histogram filename.
Definition at line 1854 of file ossimImageHandler.cpp.
1855 {
1856  return getFilenameWithThisExtension("his");
1857 }
◆ createDefaultMetadataFilename()
ossimFilename ossimImageHandler::createDefaultMetadataFilename ( ) const
virtual
Returns
ossimFilename represents an external OSSIM metadata filename.
Definition at line 1849 of file ossimImageHandler.cpp.
1850 {
1851  return getFilenameWithThisExtension("omd");
1852 }
◆ createDefaultOverviewFilename()
ossimFilename ossimImageHandler::createDefaultOverviewFilename ( ) const
virtual
Returns
ossimFilename represents an external OSSIM overview filename.
Definition at line 1839 of file ossimImageHandler.cpp.
1840 {
1841  return getFilenameWithThisExtension("ovr");
1842 }
◆ createDefaultValidVerticesFilename()
ossimFilename ossimImageHandler::createDefaultValidVerticesFilename ( ) const
virtual
Returns
ossimFilename represents an external OSSIM valid vertices filename.
Definition at line 1859 of file ossimImageHandler.cpp.
References ossimFilename::dirCat(), ossimFilename::fileNoExtension(), getCurrentEntry(), getNumberOfEntries(), ossimFilename::path(), theImageFile, and ossimString::toString().
Referenced by getProperty(), ATP::AtpGenerator::getValidVertices(), and writeValidImageVertices().
1860 {
1861  ossimFilename result;
1862
1863  result = theImageFile.path();
1864  result = result.dirCat(theImageFile.fileNoExtension());
1865  result += "_vertices";
1866  if(getNumberOfEntries() > 1)
1867  {
1868  result += "_e";
1870  }
1871  result += ".kwl";
1872
1873  return result;
1874 }
Numeric to string methods.
virtual ossim_uint32 getNumberOfEntries() const
ossimFilename fileNoExtension() const
ossimFilename dirCat(const ossimFilename &file) const
ossimFilename path() const
◆ establishDecimationFactors()
void ossimImageHandler::establishDecimationFactors ( )
protectedvirtual
This base class implementation computes the decimation by considering the ratios in image size between resolution levels, with fuzzy logic for rounding ratios to the nearest power of 2 if possible. Derived classes need to override this method if the decimations are provided as part of the image metadata.
Reimplemented in ossimNitfTileSource, ossimRpfCacheTileSource, ossimImageCacheBase, and ossimBitMaskTileSource.
Definition at line 442 of file ossimImageHandler.cpp.
References getNumberOfDecimationLevels(), getNumberOfLines(), getNumberOfSamples(), theDecimationFactors, ossimDpt::x, and ossimDpt::y.
Referenced by ossimLasReader::completeOpen(), ossimImageCacheBase::establishDecimationFactors(), ossimRpfCacheTileSource::establishDecimationFactors(), and ossimNitfTileSource::establishDecimationFactors().
443 {
444  double line_decimation, samp_decimation, decimation, ratio;
445  ossim_uint32 num_lines, num_samps;
446
447  // The error margin here is effectively the percent error tolerated between ideal number of
448  // pixels for given power-of-2 decimation, and the actual number of pixels found at this
449  // decimation level. Typically, the last level will have fewer pixels than expected, hence the
450  // need for this logic...
451  static const double ERROR_MARGIN = 1.1; // 10% allowance
452
453  // NOTE -- Until the end of this method, all decimation values are actually inverse quantities,
454  // i.e., a decimation of 0.5 typical for rlevel 1 is represented here as 2. This facilitates the
455  // fuzzy logic for recognizing powers of 2 (as integers)
456
457  // Default implementation assumes R0 is not decimated. Check for R0 defined by derived class
458  // however, in case this is not the case:
459  ossimDpt decimation_r0 (1.0, 1.0);
460  if (theDecimationFactors.size() > 0)
461  {
462  decimation_r0.x = 1.0/theDecimationFactors[0].x; // note use of inverse decimation
463  decimation_r0.y = 1.0/theDecimationFactors[0].y;
464  }
465  else
466  theDecimationFactors.push_back(decimation_r0);
467
468  // Variables used in loop below:
469  ossim_uint32 num_lines_r0 = getNumberOfLines(0);
470  ossim_uint32 num_samps_r0 = getNumberOfSamples(0);
471  ossim_uint32 power_of_2_decimation = (ossim_uint32) decimation_r0.x;
472
473  // Remaining res levels are computed as a ratio of image size at R0 to image size at Rn:
475  for(ossim_uint32 res_level = 1; res_level < nRlevels; ++res_level)
476  {
477  num_lines = getNumberOfLines(res_level);
478  num_samps = getNumberOfSamples(res_level);
479
480  if ((num_lines < 2) || (num_samps < 2))
481  break;
482
483  line_decimation = decimation_r0.y * num_lines_r0 / (double)num_lines;
484  samp_decimation = decimation_r0.x * num_samps_r0 / (double)num_samps;
485  decimation = line_decimation<samp_decimation ? line_decimation:samp_decimation;
486
487  // Check for possible error due to inexact ratios.
488  // Loop until reasonable effort was made to establish the corresponding power-of-2 decimation.
489  // If close match is found, the exact integer value is assigned:
490  do
491  {
492  power_of_2_decimation *= 2;
493  ratio = (double)power_of_2_decimation / decimation;
494  if (ratio < 1.0)
495  ratio = 1.0/ratio;
496  if (ratio < ERROR_MARGIN)
497  decimation = (double) power_of_2_decimation;
498
499  } while ((double) power_of_2_decimation < decimation);
500
501  // Convert the computed decimation back to fractional form before saving in the factors list:
502  decimation = 1.0/decimation;
503  theDecimationFactors.push_back(ossimDpt(decimation, decimation));
504  }
505 }
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
◆ getBoundingRect()
ossimIrect ossimImageHandler::getBoundingRect ( ossim_uint32  resLevel = 0) const
virtual
◆ getCurrentEntry()
ossim_uint32 ossimImageHandler::getCurrentEntry ( ) const
virtual
◆ getDecimationFactor()
void ossimImageHandler::getDecimationFactor ( ossim_uint32  resLevel,
ossimDpt result
) const
virtual
Parameters
resLevelReduced resolution set for requested decimation.
resultossimDpt to initialize with requested decimation.
Note
Initialized "result" with the decimation factor for the passed in resLevel. Most of the time the returned factor is a square decimation along x and y indicated by result.x and .y = 1.0/(resLevel^2) where ^ means rasing to the power of. If the resLevel is 1 then the return decimation .5, .5. this is not the decimation to each resolution level but the total decimation from res level 0. So if resLevel is 2 then the return is .25, .25.
Derived classes should override if the decimation is anything other than a power of two change in each direction per res level.
Reimplemented in ossimGdalTileSource, ossimKakaduJ2kReader, and ossimMrSidReader.
Definition at line 419 of file ossimImageHandler.cpp.
References ossimDpt::makeNan(), and theDecimationFactors.
Referenced by ossimTiledImageHandler::getImageRectangle(), and getValidImageVertices().
420 {
421  if (resLevel < theDecimationFactors.size())
422  result = theDecimationFactors[resLevel];
423  else
424  result.makeNan();
425 }
void makeNan()
Definition: ossimDpt.h:65
◆ getDecimationFactors()
void ossimImageHandler::getDecimationFactors ( vector< ossimDpt > &  decimations) const
virtual
This returns all decimation for all levels.
Reimplemented in ossimKakaduJ2kReader, and ossimMrSidReader.
Definition at line 427 of file ossimImageHandler.cpp.
References theDecimationFactors.
Referenced by ossimImageModel::initialize().
428 {
429  decimations = theDecimationFactors;
430 }
◆ getEntryList()
void ossimImageHandler::getEntryList ( std::vector< ossim_uint32 > &  entryList) const
virtual
◆ getEntryName()
void ossimImageHandler::getEntryName ( ossim_uint32  entryIdx,
std::string &  name
) const
virtual
Get the name of entry as a string.
This implementation clears name. Derived classes that support multiple entries and have "named" entries should re-implement to provide entry names. Example given from HDF5 file:
entry_name: /All_Data/VIIRS-IMG-GTM-EDR-GEO_All/QF1_VIIRSGTMGEO
Parameters
entryIdxZero based entry index. If out of range name will be cleared.
nameInitialized by this.
Definition at line 1510 of file ossimImageHandler.cpp.
References getEntryNames().
Referenced by ossimInfo::getImageInfo().
1511 {
1512  name = "";
1513  std::vector<ossimString> entryNames;
1514  getEntryNames(entryNames);
1515  if (entryIdx < entryNames.size())
1516  name = entryNames[entryIdx].string();
1517 }
virtual void getEntryNames(std::vector< ossimString > &entryNames) const
◆ getEntryNames()
void ossimImageHandler::getEntryNames ( std::vector< ossimString > &  entryNames) const
virtual
Parameters
getEntryNamesList to initialize with strings associated with entries.
Note
This implementation calls getEntryList and converts entries in the list to strings. Derived classes that support multiple entries with associated strings should re-implement.
Reimplemented in ossimGpkgReader, ossimGdalTileSource, ossimH5ImageHandler, ossimHdf5ImageHandler, and ossimPointCloudImageHandler.
Definition at line 1505 of file ossimImageHandler.cpp.
Referenced by getEntryName(), and ossimGdalTileSource::getEntryNames().
1506 {
1507  entryStringList.clear();
1508 }
◆ getExternalImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimImageHandler::getExternalImageGeometry ( ) const
protectedvirtual
The geometry contains full-to-local image transform as well as projection (image-to-world).
This method just looks for external .geom style override only. If you want to go through a registry then call getImageGeometry().
Reimplemented in ossimMrSidReader.
Definition at line 726 of file ossimImageHandler.cpp.
References ossimFilename::dirCat(), ossimFilename::exists(), ossimFilename::expand(), ossimFilename::file(), ossimKeywordlist::findKey(), getCurrentEntry(), getFilenameWithThisExt(), getFilenameWithThisExtension(), ossimImageGeometry::loadState(), ossimString::string(), theSupplementaryDirectory, ossimString::toString(), and ossimKeywordNames::TYPE_KW.
Referenced by ossimMrSidReader::getExternalImageGeometry(), ossimViirsHandler::getImageGeometry(), ossimQuickbirdTiffTileSource::getImageGeometry(), ossimQbTileFilesHandler::getImageGeometry(), ossimERSTileSource::getImageGeometry(), ossimGdalTileSource::getImageGeometry(), ossimAdrgTileSource::getImageGeometry(), ossimUsgsDemTileSource::getImageGeometry(), ossimGeneralRasterTileSource::getImageGeometry(), ossimOpjJp2Reader::getImageGeometry(), ossimJpegTileSource::getImageGeometry(), ossimMG4LidarReader::getImageGeometry(), ossimPointCloudImageHandler::getImageGeometry(), ossimGeoPdfReader::getImageGeometry(), ossimH5ImageHandler::getImageGeometry(), ossimLasReader::getImageGeometry(), ossimKakaduJp2Reader::getImageGeometry(), ossimPngReader::getImageGeometry(), ossimGpkgReader::getImageGeometry(), ossimCibCadrgTileSource::getImageGeometry(), and getImageGeometry().
727 {
729  // No geometry object has been set up yet. Check for external geometry file.
730  // Try "foo.geom" if image is "foo.tif":
731  ossimFilename filename;
732  getFilenameWithThisExt( ossimString(".geom"), filename );
733
734  if(!filename.exists())
735  {
736  // Try "foo_e0.tif" if image is "foo.tif" where "e0" is entry index.
737  filename = getFilenameWithThisExtension(ossimString(".geom"), true);
738  }
739
740 #if 0
741 /* getgetFilenameWithThisExt... methods tack on sup dir if set. drb */
742  if(!filename.exists())
743  {
744  // Try supplementary data directory for remote geometry:
745  filename = getFilenameWithThisExtension(ossimString(".geom"), false);
746  filename = theSupplementaryDirectory.dirCat(filename.file());
747  }
748  if(!filename.exists())
749  {
750  // Try supplementary data directory for remote geometry with entry index:
751  filename = getFilenameWithThisExtension(ossimString(".geom"), true);
752  filename = theSupplementaryDirectory.dirCat(filename.file());
753  }
754 #endif
755
756  if(filename.exists())
757  {
758  // Open the geom file as a KWL and initialize our geometry object:
759  filename = filename.expand();
760  ossimKeywordlist geomKwl(filename);
761
762  // Try loadState with no prefix.
763  std::string prefix = "";
764  std::string key = ossimKeywordNames::TYPE_KW;
765  std::string value = geomKwl.findKey(prefix, key);
766
767  if ( value.empty() || (value != "ossimImageGeometry") )
768  {
769  // Try with "image0." type prefix.
770  prefix += std::string("image") + ossimString::toString(getCurrentEntry()).string() +
771  std::string(".");
772  value = geomKwl.findKey(prefix, key);
773
774  if ( value.empty() || (value != "ossimImageGeometry") )
775  {
776  // Try with "image0.geometry." prefix.
777  prefix += std::string( "geometry." );
778  value = geomKwl.findKey(prefix, key);
779
780  if ( value.empty() || (value != "ossimImageGeometry") )
781  {
782  // Try with "geometry." prefix.
783  prefix = std::string( "geometry." );
784  value = geomKwl.findKey(prefix, key);
785  }
786  }
787  }
788
789  if ( value == "ossimImageGeometry" )
790  {
791  geom = new ossimImageGeometry;
792  if( !geom->loadState(geomKwl, prefix.c_str()) )
793  {
794  geom = 0;
795  }
796  }
797  }
798
799  return geom;
800 }
Attempts to initialize a transform and a projection given the KWL.
ossimFilename expand() const
Method to do file name expansion.
static const char * TYPE_KW
bool exists() const
void getFilenameWithThisExt(const ossimString &ext, ossimFilename &f) const
ossimFilename file() const
◆ getFilename()
const ossimFilename & ossimImageHandler::getFilename ( ) const
virtual
◆ getFilenameWithNoExtension()
void ossimImageHandler::getFilenameWithNoExtension ( ossimFilename f) const
protected
Get filename with no extension, using supplentary directory for dirname if set.
Examples:
f = "foo.tif" f = "foo"
Definition at line 1784 of file ossimImageHandler.cpp.
References ossimString::after(), ossimFilename::drive(), ossimFilename::merge(), ossimFilename::setExtension(), ossimString::size(), ossimFilename::split(), and theSupplementaryDirectory.
Referenced by getFilenameWithThisExt(), and getFilenameWithThisExtension().
1785 {
1786  //---
1787  // If the supplementary directory is set, find the extension at that
1788  // location instead of at the default.
1789  //---
1791  {
1792  ossimString drivePart;
1793  ossimString pathPart;
1794  ossimString filePart;
1795  ossimString extPart;
1796
1797  f.split(drivePart,
1798  pathPart,
1799  filePart,
1800  extPart);
1801
1803  ossimFilename newPathPart = theSupplementaryDirectory.after(newDrivePart);
1804
1805  f.merge( newDrivePart, newPathPart, filePart, extPart );
1806  }
1807
1808  // Wipe out the extension.
1809  f.setExtension("");
1810 }
void split(ossimString &drivePart, ossimString &pathPart, ossimString &filePart, ossimString &extPart) const
std::string::size_type size() const
Definition: ossimString.h:405
void merge(const ossimString &drivePart, const ossimString &pathPart, const ossimString &filePart, const ossimString &extPart)
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
ossimString after(const ossimString &str, std::string::size_type pos=0) const
METHOD: after(str, pos) Returns string immediately after the token str.
ossimFilename drive() const
◆ getFilenameWithThisExt()
void ossimImageHandler::getFilenameWithThisExt ( const ossimString ext,
ossimFilename f
) const
This is like the getFilenameWithThisExtension(...) method except it does NOT add the "_en" if image is multi entry.
Examples:
  • theImageFile = "foo.tif"
  • ext parameter = "geom"
  • return of method will = "foo.geom"
Parameters
extExtension to tack onto file. Can have or have not ".", it will be added if "." is not the first character.
fInitialized by this.
Definition at line 1766 of file ossimImageHandler.cpp.
References getFilename(), getFilenameWithNoExtension(), ossimString::size(), and ossimString::string().
Referenced by getExternalImageGeometry(), and ossimLasReader::init().
1768 {
1769  // Get the image file.
1770  f = getFilename();
1771
1773
1774  if (ext.size())
1775  {
1776  if (ext.string()[0] != '.')
1777  {
1778  f += ".";
1779  }
1780  f += ext;
1781  }
1782 }
virtual const ossimFilename & getFilename() const
void getFilenameWithNoExtension(ossimFilename &f) const
◆ getFilenameWithThisExtension()
ossimFilename ossimImageHandler::getFilenameWithThisExtension ( const ossimString ext,
bool  set_e0_prefix = false
) const
Default behaviour is to add the "_en.ext" only if the file is multi-entry. Use set_e0_prefix to override this.
Examples:
  • theImageFile = "foo.hdf"
  • The number of entries = 1
  • The number of entries = 12
  • The current entry = 3
  • return of method will = "foo_e3.geom"
Parameters
set_e0_prefixIf true and the number of entries = 1 then "foo.geom" would come out "foo_e0.geom" instead. Default = false.
Returns
theImageFile with the extension replaced with ext.
Definition at line 1740 of file ossimImageHandler.cpp.
References getCurrentEntry(), getFilename(), getFilenameWithNoExtension(), getNumberOfEntries(), ossimString::size(), ossimString::string(), and ossimString::toString().
Referenced by ossimSingleImageChain::addHistogramRemapper(), ossimSingleImageChain::addImageHandler(), buildHistogram(), buildOverview(), createDefaultGeometryFilename(), createDefaultHistogramFilename(), createDefaultMetadataFilename(), createDefaultOverviewFilename(), getExternalImageGeometry(), getImageHistogram(), ossimImageUtil::getThumbnailFilename(), loadMetaData(), ossimSingleImageChain::openHistogram(), saveImageGeometry(), and ossimOverviewSequencer::writeHistogram().
1743 {
1744  // Get the image file.
1745  ossimFilename f = getFilename();
1746
1748
1749  if (set_e0_prefix || (getNumberOfEntries() > 1))
1750  {
1751  f += "_e";
1753  }
1754
1755  if (ext.size())
1756  {
1757  if (ext.string()[0] != '.')
1758  {
1759  f += ".";
1760  }
1761  f += ext;
1762  }
1763  return f;
1764 }
◆ getImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimImageHandler::getImageGeometry ( )
virtual
Reimplemented in ossimCibCadrgTileSource, ossimGpkgReader, ossimPngReader, ossimImageCacheBase, ossimKakaduJp2Reader, ossimRpfCacheTileSource, ossimLasReader, ossimH5ImageHandler, ossimMrSidReader, ossimGeoPdfReader, ossimPointCloudImageHandler, ossimMG4LidarReader, ossimJpegTileSource, ossimOpjJp2Reader, ossimHdfReader, ossimGeneralRasterTileSource, ossimUsgsDemTileSource, ossimOgrVectorTileSource, ossimAdrgTileSource, ossimKmlSuperOverlayReader, ossimDtedTileSource, ossimGdalTileSource, ossimVpfTileSource, ossimRangeDomeTileSource, ossimBitMaskTileSource, ossimBandSeparateHandler, ossimplugins::ossimTerraSarTiffReader, ossimplugins::ossimRadarSat2TiffReader, ossimKakaduJpipHandler, ossimVideoImageHandler, ossimLandsatTileSource, ossimEnviTileSource, ossimERSTileSource, ossimSrtmTileSource, ossimQbTileFilesHandler, ossimDoqqTileSource, ossimQuickbirdTiffTileSource, ossimViirsHandler, ossimViirsHandler, and ossimQuickbirdNitfTileSource.
Definition at line 685 of file ossimImageHandler.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), getExternalImageGeometry(), getInternalImageGeometry(), initImageParameters(), ossimImageGeometryRegistry::instance(), and theGeometry.
Referenced by ossimPointObservation::addMeasurement(), ATP::AtpGenerator::constructChain(), ossimKakaduJpipImageGeometryFactory::extendGeometry(), ossimImageGeometryFactory::extendGeometry(), ossimInfo::getCenterGround(), ossimInfo::getGrd2img(), ossimInfo::getImageBounds(), ossimQuickbirdNitfTileSource::getImageGeometry(), ossimKakaduJpipHandler::getImageGeometry(), ossimInfo::getImageGeometryInfo(), ossimInfo::getImg2grd(), ossimChipperUtil::getIrect(), ossimInfo::getNorthUpAngle(), ossimInfo::getUpIsUpAngle(), ATP::AtpGenerator::getValidVertices(), ossimChipperUtil::hasSensorModelInput(), ossimImageProjectionModel::initialize(), ossimTiledElevationDatabase::initializeReferenceProjection(), ossimEquationUtil::initInputSources(), main(), ossimChipProcTool::newIdentityProjection(), ossimGeoidImage::open(), ossimImageElevationHandler::open(), ossimImageGeometry::open(), ossimTilingPoly::parseShpFile(), ossimRpcSolver::solve(), and ossimIvtGeomXformVisitor::visit().
686 {
687  if ( !theGeometry )
688  {
689  //---
690  // Check factory for external geom:
691  //---
693
694  if ( !theGeometry )
695  {
696  //---
697  // WARNING:
698  // Must create/set the geometry at this point or the next call to
699  // ossimImageGeometryRegistry::extendGeometry will put us in an infinite loop
700  // as it does a recursive call back to ossimImageHandler::getImageGeometry().
701  //---
704
705  //---
706  // And finally allow factories to extend the internal geometry.
707  // This allows plugins for tagged formats with tags not know in the base
708  // to extend the internal geometry.
709  //
710  // Plugins can do handler->getImageGeometry() then modify/extend.
711  //---
713  {
714  //---
715  // Check for internal, for geotiff, nitf and so on as last resort for getting some
716  // kind of geometry loaded
717  //---
720  }
721  }
722  }
723  return theGeometry;
724 }
static ossimImageGeometryRegistry * instance()
virtual bool extendGeometry(ossimImageHandler *handler) const
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
virtual ossimRefPtr< ossimImageGeometry > getInternalImageGeometry() const
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
Returns the image geometry object associated with this tile source or NULL if non defined...
◆ getImageHistogram()
ossimRefPtr< ossimMultiResLevelHistogram > ossimImageHandler::getImageHistogram ( ) const
Fetches the current entry image's histogram.
Returns
Ref pointer to histogram or null if histogram does not exist.
Note
Old behaviour: "If none exists, it will be created." taken out.
Do: ossimRefPtr<ossimMultiResLevelHistogram> his = ih->getImageHistogram(); if ( ih.valid() ) { } else { ih->buildHistogram(); }
Definition at line 670 of file ossimImageHandler.cpp.
References getFilenameWithThisExtension(), ossimMultiResLevelHistogram::importHistogram(), and isOpen().
Referenced by ossimShorelineTool::autoComputeThreshold(), ATP::AtpGenerator::constructChain(), and ossimBandMergeTool::initHistogramStretch().
671 {
673  if ( isOpen() )
674  {
676  histogram = new ossimMultiResLevelHistogram();
677  if ( histogram->importHistogram(histoFile) == false )
678  {
679  histogram = 0;
680  }
681  }
682  return histogram;
683 }
virtual bool importHistogram(const ossimFilename &inputFile)
◆ getImageID()
const ossimString& ossimImageHandler::getImageID ( ) const
inline
This is initialized to -1 in the constructor but is searched for in loadState():
Definition at line 715 of file ossimImageHandler.h.
Referenced by ATP::AtpGenerator::constructChain(), ATP::AtpGenerator::getCmpImageID(), and ATP::AtpGenerator::getRefImageID().
715 { return theImageID; }
◆ getImageRectangle()
ossimIrect ossimImageHandler::getImageRectangle ( ossim_uint32  resLevel = 0) const
virtual
Returns zero-based bounding rectangle of the image.
Note sub-image offset now in ossimImageGeometry class.
Parameters
resLevelReduced resolution level for rectangle.
Returns
Rectangle of reduced resolution level.
Reimplemented in ossimCibCadrgTileSource, ossimRpfCacheTileSource, ossimOgrGdalTileSource, ossimAdrgTileSource, ossimOgrVectorTileSource, ossimDtedTileSource, ossimH5ImageHandler, ossimOpjJp2Reader, ossimPngReader, ossimCcfTileSource, ossimGdalTileSource, ossimTiledImageHandler, ossimHdf5ImageHandler, ossimGpkgReader, ossimJpegTileSource, ossimUsgsDemTileSource, ossimKmlSuperOverlayReader, ossimVpfTileSource, and ossimImageCacheBase.
Definition at line 388 of file ossimImageHandler.cpp.
References getNumberOfLines(), getNumberOfSamples(), isOpen(), isValidRLevel(), and ossimIrect::makeNan().
Referenced by getBoundingRect(), ossimGdalTileSource::getImageRectangle(), ossimGeoPdfReader::getIntersectingEntries(), ossimChipperUtil::getIrect(), ossimHdfReader::getTile(), ossimBitMaskTileSource::getTile(), ossimTiffTileSource::getTile(), ossimGeoPdfReader::getTile(), ossimGdalDataset::init(), ossimOverviewSequencer::initialize(), ossimTiffTileSource::loadFromScanLine(), ossimGeoidImage::open(), and ossimQuickbirdRpcModel::parseTiffFile().
389 {
390  ossimIrect result;
391
392  if( isOpen() && isValidRLevel(resLevel) )
393  {
394  ossim_int32 lines = getNumberOfLines(resLevel);
395  ossim_int32 samples = getNumberOfSamples(resLevel);
396  if( !lines || !samples )
397  {
398  result.makeNan();
399  }
400  else
401  {
402  result = ossimIrect(0, 0, samples-1, lines-1);
403  }
404  }
405  else
406  {
407  result.makeNan();
408  }
409
410  return result;
411 }
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
void makeNan()
Definition: ossimIrect.h:329
int ossim_int32
◆ getImageTileHeight()
virtual ossim_uint32 ossimImageHandler::getImageTileHeight ( ) const
pure virtual
◆ getImageTileWidth()
virtual ossim_uint32 ossimImageHandler::getImageTileWidth ( ) const
pure virtual
◆ getInternalImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimImageHandler::getInternalImageGeometry ( ) const
protectedvirtual
Reimplemented in ossimMrSidReader, ossimGeoPdfReader, ossimMG4LidarReader, ossimJpegTileSource, ossimUsgsDemTileSource, ossimGdalTileSource, ossimOgrGdalTileSource, ossimOgrVectorTileSource, ossimKmlSuperOverlayReader, ossimEnviTileSource, ossimplugins::ossimTerraSarTiffReader, and ossimplugins::ossimRadarSat2TiffReader.
Definition at line 802 of file ossimImageHandler.cpp.
Referenced by getImageGeometry().
803 {
804  // Default, derived classes should override.
806  return geom;
807 }
◆ getLut()
ossimRefPtr< ossimNBandLutDataObject > ossimImageHandler::getLut ( ) const
virtual
Definition at line 1829 of file ossimImageHandler.cpp.
References theLut.
Referenced by ossimGdalWriter::checkColorLut(), ossimTiffWriter::checkColorLut(), and ossimInfo::getImagePalette().
1830 {
1831  return theLut;
1832 }
◆ getMaxPixelValue()
double ossimImageHandler::getMaxPixelValue ( ossim_uint32  band = 0) const
virtual
Reimplemented in ossimNitfTileSource, ossimGdalTileSource, ossimLasReader, ossimTiffTileSource, ossimPointCloudImageHandler, ossimHdf5ImageHandler, ossimPngReader, ossimOgrVectorTileSource, ossimOgrGdalTileSource, ossimKakaduNitfReader, ossimGeneralRasterTileSource, ossimOpjJp2Reader, ossimVpfTileSource, ossimImageCacheTileSource, ossimDtedTileSource, ossimBitMaskTileSource, ossimUsgsDemTileSource, ossimImageHandlerMtAdaptor, and ossimLandsatTileSource.
Definition at line 1424 of file ossimImageHandler.cpp.
References ossim::defaultMax(), ossimImageMetaData::getMaxPix(), ossimImageMetaData::getNumberOfBands(), ossimImageSource::getOutputScalarType(), and theMetaData.
Referenced by ossimInfo::getImageInfo(), ossimImageHandlerMtAdaptor::getMaxPixelValue(), ossimImageCacheTileSource::getMaxPixelValue(), ossimKakaduNitfReader::getMaxPixelValue(), ossimHdf5ImageHandler::getMaxPixelValue(), ossimTiffTileSource::getMaxPixelValue(), ossimGdalTileSource::getMaxPixelValue(), and ossimNitfTileSource::getMaxPixelValue().
1425 {
1427  {
1428  return theMetaData.getMaxPix(band);
1429  }
1431 }
double getMaxPix(ossim_uint32 band) const
ossim_uint32 getNumberOfBands() const
OSSIM_DLL double defaultMax(ossimScalarType scalarType)
◆ getMinPixelValue()
double ossimImageHandler::getMinPixelValue ( ossim_uint32  band = 0) const
virtual
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Reimplemented in ossimNitfTileSource, ossimGdalTileSource, ossimTiffTileSource, ossimLasReader, ossimHdf5ImageHandler, ossimPointCloudImageHandler, ossimOgrVectorTileSource, ossimOgrGdalTileSource, ossimKakaduNitfReader, ossimGeneralRasterTileSource, ossimVpfTileSource, ossimImageCacheTileSource, ossimDtedTileSource, ossimBitMaskTileSource, ossimUsgsDemTileSource, ossimImageHandlerMtAdaptor, and ossimLandsatTileSource.
Definition at line 1415 of file ossimImageHandler.cpp.
References ossim::defaultMin(), ossimImageMetaData::getMinPix(), ossimImageMetaData::getNumberOfBands(), ossimImageSource::getOutputScalarType(), and theMetaData.
Referenced by ossimInfo::getImageInfo(), ossimImageHandlerMtAdaptor::getMinPixelValue(), ossimImageCacheTileSource::getMinPixelValue(), ossimKakaduNitfReader::getMinPixelValue(), ossimHdf5ImageHandler::getMinPixelValue(), ossimTiffTileSource::getMinPixelValue(), ossimGdalTileSource::getMinPixelValue(), and ossimNitfTileSource::getMinPixelValue().
1416 {
1418  {
1419  return theMetaData.getMinPix(band);
1420  }
1422 }
double getMinPix(ossim_uint32 band) const
OSSIM_DLL double defaultMin(ossimScalarType scalarType)
Definition: ossimCommon.cpp:73
◆ getNullPixelValue()
double ossimImageHandler::getNullPixelValue ( ossim_uint32  band = 0) const
virtual
Reimplemented in ossimNitfTileSource, ossimGdalTileSource, ossimLasReader, ossimTiffTileSource, ossimH5ImageHandler, ossimPointCloudImageHandler, ossimHdf5ImageHandler, ossimOgrVectorTileSource, ossimOgrGdalTileSource, ossimKakaduNitfReader, ossimGeneralRasterTileSource, ossimVpfTileSource, ossimImageCacheTileSource, ossimDtedTileSource, ossimBitMaskTileSource, ossimUsgsDemTileSource, ossimImageHandlerMtAdaptor, ossimLandsatTileSource, ossimViirsHandler, and ossimViirsHandler.
Definition at line 1433 of file ossimImageHandler.cpp.
References ossim::defaultNull(), ossimImageMetaData::getNullPix(), ossimImageMetaData::getNumberOfBands(), ossimImageSource::getOutputScalarType(), and theMetaData.
Referenced by ossimInfo::getImageInfo(), ossimImageHandlerMtAdaptor::getNullPixelValue(), ossimImageCacheTileSource::getNullPixelValue(), ossimKakaduNitfReader::getNullPixelValue(), ossimHdf5ImageHandler::getNullPixelValue(), ossimH5ImageHandler::getNullPixelValue(), ossimTiffTileSource::getNullPixelValue(), ossimGdalTileSource::getNullPixelValue(), ossimNitfTileSource::getNullPixelValue(), and ossimRangeDomeTileSource::getTile().
1434 {
1436  {
1437  return theMetaData.getNullPix(band);
1438  }
1439
1441 }
double getNullPix(ossim_uint32 band) const
OSSIM_DLL double defaultNull(ossimScalarType scalarType)
◆ getNumberOfDecimationLevels()
ossim_uint32 ossimImageHandler::getNumberOfDecimationLevels ( ) const
virtual
It is important to note that res level 0 or full resolution is included in the list and has decimation values 1.0, 1.0
Reimplemented in ossimLasReader, ossimGpkgReader, ossimPointCloudImageHandler, ossimTiffTileSource, ossimKakaduJ2kReader, ossimKakaduJp2Reader, ossimMrSidReader, ossimMG4LidarReader, ossimOgrGdalTileSource, ossimOgrVectorTileSource, ossimBitMaskTileSource, ossimCcfTileSource, ossimGdalTileSource, ossimOpjJp2Reader, ossimKakaduNitfReader, ossimVpfTileSource, ossimImageHandlerMtAdaptor, and ossimKakaduJpipHandler.
Definition at line 373 of file ossimImageHandler.cpp.
References getNumberOfDecimationLevels(), theOverview, and ossimRefPtr< T >::valid().
Referenced by buildHistogram(), establishDecimationFactors(), ossimAdrgTileSource::getImageGeometry(), ossimInfo::getImageInfo(), ossimKakaduJpipHandler::getNumberOfDecimationLevels(), ossimImageHandlerMtAdaptor::getNumberOfDecimationLevels(), ossimKakaduNitfReader::getNumberOfDecimationLevels(), ossimOpjJp2Reader::getNumberOfDecimationLevels(), ossimGdalTileSource::getNumberOfDecimationLevels(), ossimMG4LidarReader::getNumberOfDecimationLevels(), ossimMrSidReader::getNumberOfDecimationLevels(), ossimKakaduJp2Reader::getNumberOfDecimationLevels(), ossimKakaduJ2kReader::getNumberOfDecimationLevels(), ossimTiffTileSource::getNumberOfDecimationLevels(), ossimGpkgReader::getNumberOfDecimationLevels(), getNumberOfDecimationLevels(), getNumberOfReducedResSets(), getProperty(), hasOverviews(), ossimImageUtil::hasRequiredOverview(), initImageParameters(), ossimJpegTileSource::isValidRLevel(), isValidRLevel(), main(), and ossimBitMaskTileSource::open().
374 {
375  ossim_uint32 result = 1; // Add r0
376  if (theOverview.valid())
377  {
379  }
380  return result;
381 }
bool valid() const
Definition: ossimRefPtr.h:75
◆ getNumberOfEntries()
ossim_uint32 ossimImageHandler::getNumberOfEntries ( ) const
virtual
Returns
The number of entries (images) in the image file.
Reimplemented in ossimGeoPdfReader, ossimNitfTileSource, ossimGpkgReader, ossimOgrVectorTileSource, ossimHdfReader, ossimH5ImageHandler, ossimHdf5ImageHandler, and ossimVideoImageHandler.
Definition at line 1497 of file ossimImageHandler.cpp.
References getEntryList().
Referenced by createDefaultValidVerticesFilename(), getFilenameWithThisExtension(), ossimInfo::getImagePalette(), ossimKakaduNitfOverviewBuilder::getOutputFile(), and openValidVertices().
1498 {
1499  std::vector<ossim_uint32> tempList;
1500  getEntryList(tempList);
1501
1502  return (ossim_uint32)tempList.size();
1503 }
◆ getNumberOfLines()
virtual ossim_uint32 ossimImageHandler::getNumberOfLines ( ossim_uint32  resLevel = 0) const
pure virtual
Parameters
resLevelReduced resolution level to return lines of. Default = 0
Returns
The number of lines for specified reduced resolution level.
Implemented in ossimKakaduJ2kReader, ossimKakaduJp2Reader, ossimMrSidReader, ossimGeoPdfReader, ossimMG4LidarReader, ossimCibCadrgTileSource, ossimTiffTileSource, ossimNitfTileSource, ossimHdfReader, ossimLasReader, ossimRpfCacheTileSource, ossimPointCloudImageHandler, ossimKakaduNitfReader, ossimAdrgTileSource, ossimH5ImageHandler, ossimOpjJp2Reader, ossimPngReader, ossimRangeDomeTileSource, ossimDtedTileSource, ossimOgrGdalTileSource, ossimHdf5ImageHandler, ossimOgrVectorTileSource, ossimGpkgReader, ossimGdalTileSource, ossimCcfTileSource, ossimJpegTileSource, ossimGeneralRasterTileSource, ossimKmlSuperOverlayReader, ossimBitMaskTileSource, ossimUsgsDemTileSource, ossimVpfTileSource, ossimTiledImageHandler, ossimImageHandlerMtAdaptor, ossimBandSeparateHandler, ossimKakaduJpipHandler, ossimImageCacheBase, and ossimVideoImageHandler.
Referenced by establishDecimationFactors(), ossimKakaduJ2kReader::getDecimationFactor(), getImageRectangle(), ossimVideoImageHandler::getImageTileHeight(), ossimKakaduJpipHandler::getNumberOfLines(), ossimImageHandlerMtAdaptor::getNumberOfLines(), ossimUsgsDemTileSource::getNumberOfLines(), ossimJpegTileSource::getNumberOfLines(), ossimGdalTileSource::getNumberOfLines(), ossimGpkgReader::getNumberOfLines(), ossimHdf5ImageHandler::getNumberOfLines(), ossimDtedTileSource::getNumberOfLines(), ossimH5ImageHandler::getNumberOfLines(), ossimOpjJp2Reader::getNumberOfLines(), ossimPngReader::getNumberOfLines(), ossimAdrgTileSource::getNumberOfLines(), ossimKakaduNitfReader::getNumberOfLines(), ossimRpfCacheTileSource::getNumberOfLines(), ossimNitfTileSource::getNumberOfLines(), ossimCibCadrgTileSource::getNumberOfLines(), ossimTiffTileSource::getNumberOfLines(), ossimGeoPdfReader::getNumberOfLines(), ossimKakaduJp2Reader::getNumberOfLines(), ossimGdalTileSource::getNumberOfSamples(), ossimOpjJp2Reader::getNumberOfSamples(), getProperty(), ossimOverviewBuilderBase::getRequiredResLevels(), ossimImageElevationHandler::getSizeOfElevCell(), ossimImageUtil::hasRequiredOverview(), ossimImageModel::initialize(), and ossimImageElevationHandler::open().
◆ getNumberOfReducedResSets()
ossim_uint32 ossimImageHandler::getNumberOfReducedResSets ( ) const
virtual
This method is obsolete.
Please use getNumberOfDecimationLevels.
For backwards compatibility this calls getNumberOfDecimationLevels.
Definition at line 383 of file ossimImageHandler.cpp.
References getNumberOfDecimationLevels().
384 {
386 }
◆ getNumberOfSamples()
virtual ossim_uint32 ossimImageHandler::getNumberOfSamples ( ossim_uint32  resLevel = 0) const
pure virtual
Parameters
resLevelReduced resolution level to return samples of. Default = 0
Returns
The number of samples for specified reduced resolution level.
Implemented in ossimKakaduJ2kReader, ossimKakaduJp2Reader, ossimMrSidReader, ossimGeoPdfReader, ossimMG4LidarReader, ossimCibCadrgTileSource, ossimTiffTileSource, ossimLasReader, ossimHdfReader, ossimNitfTileSource, ossimRpfCacheTileSource, ossimPointCloudImageHandler, ossimKakaduNitfReader, ossimAdrgTileSource, ossimH5ImageHandler, ossimOpjJp2Reader, ossimPngReader, ossimDtedTileSource, ossimOgrGdalTileSource, ossimHdf5ImageHandler, ossimRangeDomeTileSource, ossimOgrVectorTileSource, ossimGpkgReader, ossimGdalTileSource, ossimCcfTileSource, ossimJpegTileSource, ossimGeneralRasterTileSource, ossimKmlSuperOverlayReader, ossimUsgsDemTileSource, ossimBitMaskTileSource, ossimVpfTileSource, ossimTiledImageHandler, ossimImageHandlerMtAdaptor, ossimBandSeparateHandler, ossimImageCacheBase, ossimKakaduJpipHandler, and ossimVideoImageHandler.
Referenced by establishDecimationFactors(), ossimKakaduJ2kReader::getDecimationFactor(), getImageRectangle(), ossimVideoImageHandler::getImageTileWidth(), ossimHdfReader::getNumberOfLines(), ossimMG4LidarReader::getNumberOfLines(), ossimMrSidReader::getNumberOfLines(), ossimKakaduJpipHandler::getNumberOfSamples(), ossimImageHandlerMtAdaptor::getNumberOfSamples(), ossimUsgsDemTileSource::getNumberOfSamples(), ossimJpegTileSource::getNumberOfSamples(), ossimGpkgReader::getNumberOfSamples(), ossimHdf5ImageHandler::getNumberOfSamples(), ossimDtedTileSource::getNumberOfSamples(), ossimPngReader::getNumberOfSamples(), ossimH5ImageHandler::getNumberOfSamples(), ossimAdrgTileSource::getNumberOfSamples(), ossimKakaduNitfReader::getNumberOfSamples(), ossimRpfCacheTileSource::getNumberOfSamples(), ossimNitfTileSource::getNumberOfSamples(), ossimHdfReader::getNumberOfSamples(), ossimTiffTileSource::getNumberOfSamples(), ossimCibCadrgTileSource::getNumberOfSamples(), ossimMG4LidarReader::getNumberOfSamples(), ossimGeoPdfReader::getNumberOfSamples(), ossimMrSidReader::getNumberOfSamples(), ossimKakaduJp2Reader::getNumberOfSamples(), getProperty(), ossimOverviewBuilderBase::getRequiredResLevels(), ossimImageElevationHandler::getSizeOfElevCell(), ossimImageUtil::hasRequiredOverview(), ossimImageModel::initialize(), and ossimImageElevationHandler::open().
◆ getOpenOverviewFlag()
bool ossimImageHandler::getOpenOverviewFlag ( ) const
Returns
theOpenOverviewFlag
Definition at line 1886 of file ossimImageHandler.cpp.
References theOpenOverviewFlag.
1887 {
1888  return theOpenOverviewFlag;
1889 }
◆ getOverview()
const ossimImageHandler * ossimImageHandler::getOverview ( ) const
virtual
Returns
the image handler of the overview, if it has been successfully opened.
Definition at line 835 of file ossimImageHandler.cpp.
References ossimRefPtr< T >::get(), and theOverview.
Referenced by ossimSingleImageChain::addImageHandler(), ossimInfo::getImageInfo(), and ossimImageHandlerFactory::openSrcRecord().
836 {
837  return theOverview.get();
838 }
◆ getOverviewFile()
ossimFilename ossimImageHandler::getOverviewFile ( ) const
Definition at line 1471 of file ossimImageHandler.cpp.
References theOverviewFile.
1472 {
1473  return theOverviewFile;
1474 }
◆ getOverviewTile()
bool ossimImageHandler::getOverviewTile ( ossim_uint32  resLevel,
ossimImageData result
protectedvirtual
Method to get an overview tile.
Derived classes should override if they have built in overviews or something different than the standard external overview file. Image handlers can call this method from getTile in place of inlining code or if derived class needs to override this method.
Parameters
resLevelThe resolution level to pull from with resLevel 0 being full res.
resultThe tile to stuff. passing.
Returns
true on success false on error. Typically this will return false if resLevel==0 unless the overview has r0. If return is false, result is undefined so caller should handle appropriately with makeBlank or whatever.
Reimplemented in ossimKakaduJp2Reader, ossimKakaduJ2kReader, ossimOpjJp2Reader, and ossimKakaduNitfReader.
Definition at line 1812 of file ossimImageHandler.cpp.
References ossimImageData::getNumberOfBands(), ossimImageSource::getNumberOfOutputBands(), ossimImageSource::getTile(), isValidRLevel(), status, theOverview, and ossimRefPtr< T >::valid().
Referenced by ossimKakaduNitfReader::getOverviewTile(), ossimUsgsDemTileSource::getTile(), ossimJpegTileSource::getTile(), ossimGpkgReader::getTile(), ossimHdf5ImageHandler::getTile(), ossimCcfTileSource::getTile(), ossimHdfReader::getTile(), ossimDtedTileSource::getTile(), ossimPngReader::getTile(), ossimH5ImageHandler::getTile(), ossimAdrgTileSource::getTile(), ossimTiffTileSource::getTile(), ossimGeoPdfReader::getTile(), ossimRpfCacheTileSource::getTile(), ossimNitfTileSource::getTile(), ossimCibCadrgTileSource::getTile(), and ossimKakaduJpipHandler::getTileAtRes().
1814 {
1815  bool status = false;
1816
1817  if (theOverview.valid())
1818  {
1819  if (theOverview->isValidRLevel(resLevel) && result &&
1820  (result->getNumberOfBands() == getNumberOfOutputBands()) )
1821  {
1822  status = theOverview->getTile(result, resLevel);
1823  }
1824  }
1825
1826  return status;
1827 }
bool valid() const
return status
◆ getPixelType()
ossimPixelType ossimImageHandler::getPixelType ( ) const
inline
Returns the raster pixel alignment type.
OSSIM treats all alignments internally as pixel-is-point. This is only a flag to identify the source's alignment type.
Definition at line 722 of file ossimImageHandler.h.
722 { return thePixelType; }
◆ getProperty()
ossimRefPtr< ossimProperty > ossimImageHandler::getProperty ( const ossimString name) const
virtual
Reimplemented in ossimCibCadrgTileSource, ossimRpfCacheTileSource, ossimLasReader, ossimTiffTileSource, ossimGdalTileSource, ossimPointCloudImageHandler, ossimH5ImageHandler, ossimNitfTileSource, ossimHdf5ImageHandler, ossimOgrGdalTileSource, ossimDtedTileSource, ossimAdrgTileSource, ossimCcfTileSource, ossimJpegTileSource, ossimPngReader, ossimGpkgReader, ossimRangeDomeTileSource, ossimEnviTileSource, ossimLandsatTileSource, ossimKakaduJpipHandler, ossimSrtmTileSource, and ossimDoqqTileSource.
Definition at line 1601 of file ossimImageHandler.cpp.
References ossimStringProperty::addConstraint(), createDefaultGeometryFilename(), createDefaultHistogramFilename(), createDefaultMetadataFilename(), createDefaultOverviewFilename(), createDefaultValidVerticesFilename(), ossimKeywordNames::ENTRY_KW, getCurrentEntry(), getEntryList(), getFilename(), getNumberOfDecimationLevels(), ossimImageSource::getNumberOfInputBands(), getNumberOfLines(), getNumberOfSamples(), ossimImageSource::getOutputScalarType(), ossimScalarTypeLut::instance(), ossimKeywordNames::NUMBER_BANDS_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_REDUCED_RES_SETS_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimFilenameProperty::ossimFilenamePropertyIoType_INPUT, ossimKeywordNames::SCALAR_TYPE_KW, ossimProperty::setCacheRefreshBit(), ossimStringProperty::setEditableFlag(), ossimProperty::setFullRefreshBit(), ossimFilenameProperty::setIoType(), ossimProperty::setReadOnlyFlag(), and ossimString::toString().
Referenced by ossimHistogramMatchFilter::autoLoadInputHistogram(), ossimDoqqTileSource::getProperty(), ossimRangeDomeTileSource::getProperty(), ossimGpkgReader::getProperty(), ossimJpegTileSource::getProperty(), ossimCcfTileSource::getProperty(), ossimAdrgTileSource::getProperty(), ossimDtedTileSource::getProperty(), ossimNitfTileSource::getProperty(), ossimTiffTileSource::getProperty(), ossimRpfCacheTileSource::getProperty(), ossimCibCadrgTileSource::getProperty(), ossimInfo::isImageEntryOverview(), and ossimImageHandlerRegistry::printReaderProps().
1602 {
1603
1604  if(name == ossimKeywordNames::ENTRY_KW)
1605  {
1606  std::vector<ossim_uint32> entryList;
1607  getEntryList(entryList);
1608
1609  ossimStringProperty* stringProperty = new ossimStringProperty(name,
1611  ossim_uint32 idx = 0;
1612  for(idx = 0; idx < entryList.size(); ++idx)
1613  {
1614  stringProperty->addConstraint(ossimString::toString(entryList[idx]));
1615  }
1616  stringProperty->setFullRefreshBit();
1617  stringProperty->setEditableFlag(false);
1618
1619  return stringProperty;
1620  }
1621  else if(name == ossimKeywordNames::NUMBER_SAMPLES_KW)
1622  {
1624  prop->setReadOnlyFlag(true);
1625
1626  return prop;
1627  }
1628  else if(name == ossimKeywordNames::NUMBER_LINES_KW)
1629  {
1631  prop->setReadOnlyFlag(true);
1632
1633  return prop;
1634  }
1635  else if(name == ossimKeywordNames::NUMBER_BANDS_KW)
1636  {
1638  prop->setReadOnlyFlag(true);
1639
1640  return prop;
1641  }
1643  {
1645  prop->setReadOnlyFlag(true);
1646
1647  return prop;
1648  }
1649  else if(name == ossimKeywordNames::SCALAR_TYPE_KW)
1650  {
1652  prop->setReadOnlyFlag(true);
1653
1654  return prop;
1655  }
1656  else if(name == "histogram_filename")
1657  {
1658  ossimFilenameProperty* filenameProp =
1660
1662  filenameProp->setCacheRefreshBit();
1663
1664  return filenameProp;
1665
1666  }
1667  else if(name == "geometry_filename")
1668  {
1669  ossimFilenameProperty* filenameProp =
1671
1673  filenameProp->setCacheRefreshBit();
1674
1675  return filenameProp;
1676
1677  }
1678  else if(name == "valid_vertices_filename")
1679  {
1680  ossimFilenameProperty* filenameProp =
1682
1684  filenameProp->setCacheRefreshBit();
1685
1686  return filenameProp;
1687  }
1688  else if(name == "metadata_filename")
1689  {
1690  ossimFilenameProperty* filenameProp =
1692
1694  filenameProp->setCacheRefreshBit();
1695
1696  return filenameProp;
1697  }
1698  else if(name == "overview_filename")
1699  {
1700  ossimFilenameProperty* filenameProp =
1702
1704  filenameProp->setCacheRefreshBit();
1705
1706  return filenameProp;
1707  }
1708  else if(name == "filename")
1709  {
1710  ossimFilenameProperty* filenameProp =
1711  new ossimFilenameProperty(name, getFilename());
1712
1714  filenameProp->setFullRefreshBit();
1715
1716  return filenameProp;
1717  }
1718  else if ( name == OPEN_OVERVIEW_FLAG_KW)
1719  {
1721  new ossimBooleanProperty(ossimString(OPEN_OVERVIEW_FLAG_KW), theOpenOverviewFlag);
1722  return result;
1723  }
1724
1725  return ossimImageSource::getProperty(name);
1726 }
Pure virtual, derived classes must implement.
static const char * NUMBER_LINES_KW
bool theOpenOverviewFlag
virtual ossimFilename createDefaultOverviewFilename() const
virtual void setReadOnlyFlag(bool flag)
void addConstraint(const ossimString &value)
void setFullRefreshBit()
static ossimScalarTypeLut * instance()
Returns the static instance of an ossimScalarTypeLut object.
virtual ossimFilename createDefaultValidVerticesFilename() const
Returns the filename.
static const char * NUMBER_BANDS_KW
static const char * ENTRY_KW
virtual ossimFilename createDefaultGeometryFilename() const
void setIoType(ossimFilenamePropertyIoType ioType)
void setEditableFlag(bool flag)
static const char * SCALAR_TYPE_KW
virtual ossimFilename createDefaultMetadataFilename() const
virtual ossimFilename createDefaultHistogramFilename() const
static const char * NUMBER_REDUCED_RES_SETS_KW
virtual ossim_uint32 getNumberOfInputBands() const =0
static const char * NUMBER_SAMPLES_KW
void setCacheRefreshBit()
◆ getPropertyNames()
void ossimImageHandler::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Reimplemented in ossimCibCadrgTileSource, ossimLasReader, ossimGdalTileSource, ossimTiffTileSource, ossimH5ImageHandler, ossimHdf5ImageHandler, ossimNitfTileSource, ossimOgrGdalTileSource, ossimDtedTileSource, ossimAdrgTileSource, ossimCcfTileSource, ossimJpegTileSource, ossimPngReader, ossimGpkgReader, ossimEnviTileSource, ossimLandsatTileSource, ossimSrtmTileSource, ossimKakaduJpipHandler, and ossimDoqqTileSource.
Definition at line 1728 of file ossimImageHandler.cpp.
References ossimKeywordNames::ENTRY_KW, ossimImageSource::getPropertyNames(), ossimKeywordNames::NUMBER_BANDS_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_REDUCED_RES_SETS_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, and ossimKeywordNames::SCALAR_TYPE_KW.
Referenced by ossimDoqqTileSource::getPropertyNames(), ossimKakaduJpipHandler::getPropertyNames(), ossimGpkgReader::getPropertyNames(), ossimJpegTileSource::getPropertyNames(), ossimCcfTileSource::getPropertyNames(), ossimAdrgTileSource::getPropertyNames(), ossimDtedTileSource::getPropertyNames(), ossimNitfTileSource::getPropertyNames(), ossimHdf5ImageHandler::getPropertyNames(), ossimH5ImageHandler::getPropertyNames(), ossimTiffTileSource::getPropertyNames(), ossimCibCadrgTileSource::getPropertyNames(), and ossimImageHandlerRegistry::printReaderProps().
1729 {
1730  ossimImageSource::getPropertyNames(propertyNames);
1731  propertyNames.push_back(ossimKeywordNames::ENTRY_KW);
1732  propertyNames.push_back(ossimKeywordNames::NUMBER_SAMPLES_KW);
1733  propertyNames.push_back(ossimKeywordNames::NUMBER_LINES_KW);
1734  propertyNames.push_back(ossimKeywordNames::NUMBER_BANDS_KW);
1735  propertyNames.push_back(ossimKeywordNames::NUMBER_REDUCED_RES_SETS_KW);
1736  propertyNames.push_back(ossimKeywordNames::SCALAR_TYPE_KW);
1737  propertyNames.push_back(OPEN_OVERVIEW_FLAG_KW);
1738 }
◆ getRgbBandList()
bool ossimImageHandler::getRgbBandList ( std::vector< ossim_uint32 > &  bandList) const
virtual
Convenience method to get the zero based rgb output band list.
This method returns false and is here only so derived classes can override.
Parameters
bandList
Returns
false
Reimplemented in ossimNitfTileSource, and ossimEnviTileSource.
Definition at line 1283 of file ossimImageHandler.cpp.
References ossimImageMetaData::getRgbBands(), and theMetaData.
Referenced by ossimBandSelector::getRgbBandList(), ossimInfo::getRgbBands(), and ossimSingleImageChain::setToThreeBands().
1284 {
1285  // Looks for "rgb_bands" key in dot omd file. E.g. "rgb_bands: (2,1,0)"
1286  return theMetaData.getRgbBands( bandList );
1287 }
ossimImageMetaData theMetaData
const std::string & getRgbBands() const
◆ getStartingResLevel()
ossim_uint32 ossimImageHandler::getStartingResLevel ( ) const
Definition at line 1876 of file ossimImageHandler.cpp.
References theStartingResLevel.
1877 {
1878  return theStartingResLevel;
1879 }
ossim_uint32 theStartingResLevel
theStartingResLevel If set to something other than zero(default) this is indicative that the reader i...
◆ getState() [1/2]
std::shared_ptr<ossim::ImageHandlerState> ossimImageHandler::getState ( )
inline
Definition at line 740 of file ossimImageHandler.h.
Referenced by ossimImageHandlerRegistry::addToStateCache(), and ossimTiffProjectionFactory::createProjection().
740 {return m_state;}
std::shared_ptr< ossim::ImageHandlerState > m_state
◆ getState() [2/2]
std::shared_ptr<const ossim::ImageHandlerState> ossimImageHandler::getState ( ) const
inline
Definition at line 741 of file ossimImageHandler.h.
741 {return m_state;}
◆ getStateAs() [1/2]
template<class T >
std::shared_ptr<T> ossimImageHandler::getStateAs ( )
inline
Definition at line 737 of file ossimImageHandler.h.
737 {return dynamic_pointer_cast<T> (m_state);}
◆ getStateAs() [2/2]
template<class T >
std::shared_ptr<const T> ossimImageHandler::getStateAs ( ) const
inline
Definition at line 739 of file ossimImageHandler.h.
739 {return dynamic_pointer_cast<const T> (m_state);}
◆ getSupplementaryDirectory()
const ossimFilename & ossimImageHandler::getSupplementaryDirectory ( ) const
virtual
Returns the supplementary directory.
Definition at line 1577 of file ossimImageHandler.cpp.
References theSupplementaryDirectory.
1578 {
1580 }
ossimFilename theSupplementaryDirectory
◆ getValidImageVertices()
void ossimImageHandler::getValidImageVertices ( vector< ossimIpt > &  validVertices,
ossimVertexOrdering  ordering = OSSIM_CLOCKWISE_ORDER,
) const
virtual
ordering specifies how the vertices should be arranged.
valid image vertices is basically the tightly fit convex hull of the image. Usually an image has NULL values and are internally not upright rectangular. This can cause problems some spatial filters.
The default implementation is to return the bounding rect.
Definition at line 1232 of file ossimImageHandler.cpp.
References getDecimationFactor(), ossimImageSource::getValidImageVertices(), ossimDpt::hasNans(), OSSIM_COUNTERCLOCKWISE_ORDER, theValidImageVertices, ossimDpt::x, x, and ossimDpt::y.
Referenced by ATP::AtpGenerator::getValidVertices().
1235 {
1236  ossimDpt decimation;
1237  getDecimationFactor(resLevel, decimation);
1238  if(decimation.hasNans())
1239  {
1240  return;
1241  }
1242  if (theValidImageVertices.size() != 0)
1243  {
1244  validVertices.clear();
1245  for (ossim_uint32 i=0; i<theValidImageVertices.size(); ++i)
1246  {
1247  ossimIpt pt(ossim::round<int>(theValidImageVertices[i].x*decimation.x),
1248  ossim::round<int>(theValidImageVertices[i].y*decimation.y));
1249  validVertices.push_back(pt);
1250  }
1251
1252  if(ordering == OSSIM_COUNTERCLOCKWISE_ORDER)
1253  {
1254  std::reverse(validVertices.begin()+1, validVertices.end());
1255  }
1256  }
1257  else
1258  {
1259  // Call the base class method which will set to bounding rectangle.
1260  ossimImageSource::getValidImageVertices(validVertices, ordering, resLevel);
1261  }
1262 }
ossim_uint32 x
double y
Definition: ossimDpt.h:165
virtual void getDecimationFactor(ossim_uint32 resLevel, ossimDpt &result) const
virtual void getValidImageVertices(std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const
unsigned int ossim_uint32
vector< ossimIpt > theValidImageVertices
bool hasNans() const
Definition: ossimDpt.h:67
double x
Definition: ossimDpt.h:164
◆ hasLut()
bool ossimImageHandler::hasLut ( ) const
virtual
Definition at line 1834 of file ossimImageHandler.cpp.
References theLut, and ossimRefPtr< T >::valid().
Referenced by ossimGdalWriter::checkColorLut().
1835 {
1836  return theLut.valid();
1837 }
bool valid() const
ossimRefPtr< ossimNBandLutDataObject > theLut
◆ hasMetaData()
bool ossimImageHandler::hasMetaData ( ) const
virtual
Definition at line 1544 of file ossimImageHandler.cpp.
References ossimImageMetaData::isValid(), and theMetaData.
Referenced by ossimGdalTileSource::computeMinMax().
1545 {
1546  return theMetaData.isValid();
1547 }
◆ hasOverviews()
bool ossimImageHandler::hasOverviews ( ) const
virtual
Returns
true if getNumberOfReducedResSets > 1, false if not.
See also
Definition at line 840 of file ossimImageHandler.cpp.
841 {
842  return (getNumberOfDecimationLevels() > 1);
843 }
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
◆ initialize()
void ossimImageHandler::initialize ( )
virtual
initialize Does nothing in this class.
Implemented to satisfy pure virtual.
Implements ossimImageSource.
Reimplemented in ossimRangeDomeTileSource, and ossimVideoImageHandler.
Definition at line 104 of file ossimImageHandler.cpp.
105 {
106 }
◆ initImageParameters()
void ossimImageHandler::initImageParameters ( ossimImageGeometry geom) const
protected
At time of writing sets the decimation and image size.
Parameters
geomossimImageGeometry to initiale.
Definition at line 1898 of file ossimImageHandler.cpp.
References getBoundingRect(), ossimImageGeometry::getImageSize(), getNumberOfDecimationLevels(), ossimImageGeometry::getNumberOfDecimations(), ossimIpt::hasNans(), ossimIrect::height(), ossimImageGeometry::setDiscreteDecimation(), ossimImageGeometry::setImageSize(), theDecimationFactors, and ossimIrect::width().
Referenced by ossimDoqqTileSource::getImageGeometry(), ossimQbTileFilesHandler::getImageGeometry(), ossimERSTileSource::getImageGeometry(), ossimKakaduJpipHandler::getImageGeometry(), ossimVpfTileSource::getImageGeometry(), ossimGdalTileSource::getImageGeometry(), ossimDtedTileSource::getImageGeometry(), ossimUsgsDemTileSource::getImageGeometry(), ossimGeneralRasterTileSource::getImageGeometry(), ossimOpjJp2Reader::getImageGeometry(), ossimJpegTileSource::getImageGeometry(), ossimMG4LidarReader::getImageGeometry(), ossimGeoPdfReader::getImageGeometry(), ossimMrSidReader::getImageGeometry(), ossimH5ImageHandler::getImageGeometry(), ossimLasReader::getImageGeometry(), ossimRpfCacheTileSource::getImageGeometry(), ossimKakaduJp2Reader::getImageGeometry(), ossimPngReader::getImageGeometry(), ossimGpkgReader::getImageGeometry(), ossimCibCadrgTileSource::getImageGeometry(), and getImageGeometry().
1899 {
1900  if ( geom )
1901  {
1902  // Set decimation levels
1904  if ((num_levels > 0) && (num_levels != geom->getNumberOfDecimations()))
1905  {
1907  }
1908
1909  // Set image size.
1910  if(geom->getImageSize().hasNans())
1911  {
1912  ossimIrect rect = getBoundingRect();
1913  geom->setImageSize(ossimIpt(rect.width(), rect.height()));
1914  }
1915  }
1916 }
const ossimIpt & getImageSize() const
std::vector< ossimDpt > theDecimationFactors
ossim_uint32 height() const
Definition: ossimIrect.h:487
void setImageSize(const ossimIpt &size)
ossim_uint32 width() const
Definition: ossimIrect.h:500
void setDiscreteDecimation(const std::vector< ossimDpt > &decimation_list)
Sets the decimation scheme to a discrete list of decimation factors.
Definition: ossimIpt.h:58
ossim_uint32 getNumberOfDecimations() const
◆ initVertices()
bool ossimImageHandler::initVertices ( const char *  file)
protected
Opens file and attempts to initialize the valid image vertices.
Definition at line 267 of file ossimImageHandler.cpp.
References ossim::StreamFactoryRegistry::createIstream(), ossimString::find(), ossim::StreamFactoryRegistry::instance(), m_state, and ossimErrorCodes::OSSIM_OK.
Referenced by openValidVertices().
268 {
269  static const char MODULE[] = "ossimImageHandler::initVertices";
270  bool loadFromFileFlag = true;
271  std::shared_ptr<ossimKeywordlist> kwl;
272  if(m_state)
273  {
274  bool validVerticesFlag = false;
275  if(m_state->getValidVertices())
276  {
277  loadFromFileFlag = false;
278  kwl = m_state->getValidVertices();
279  if(kwl)
280  {
281  ossimString connectionString = kwl->find("connection_string");
282  if(connectionString != file)
283  {
284  loadFromFileFlag = true;
285  }
286  else if(kwl->getSize()<=0)
287  {
288  return false;
289  }
290  }
291  }
292  else
293  {
294  loadFromFileFlag = true;
295  }
296  }
297  if(!kwl) kwl = std::make_shared<ossimKeywordlist>();
298
299  if(loadFromFileFlag)
300  {
301  kwl = std::make_shared<ossimKeywordlist>();
302  std::shared_ptr<ossim::istream> instream = ossim::StreamFactoryRegistry::instance()->createIstream(file);
303  kwl->add("connection_string", file, true);
304  if (!instream)
305  {
306  //if(m_state)
307  // m_state->setValidVertices(kwl);
308  return false;
309  }
310
311  kwl->parseStream(*instream);
312  if(m_state && kwl->getSize())
313  m_state->setValidVertices(kwl);
314  }
315
316  if (kwl->getErrorStatus() != ossimErrorCodes::OSSIM_OK)
317  {
318  if (traceDebug())
319  {
321  << "ossimImageHandler::initVertices NOTICE:"
322  << "\nError reading valid vertice file: " << file << std::endl;
323  }
324  return false;
325  }
326
327  // Clean out any old vertices...
328  theValidImageVertices.clear();
329  std::vector<ossimString> indexedPrefixes;
330  kwl->getSortedList(indexedPrefixes, "point");
331  ossim_uint32 number_of_points = indexedPrefixes.size();
332  for (ossim_uint32 i=0; i<number_of_points; i++)
333  {
334  ossimIpt pt;
335  const char* lookup;
336  lookup = kwl->find(indexedPrefixes[i], ".x");
337  if (lookup)
338  {
339  pt.x = atoi(lookup);
340  lookup = kwl->find(indexedPrefixes[i], ".y");
341  if (lookup)
342  pt.y = atoi(lookup);
343  }
344
345  if (!lookup)
346  {
347  if (traceDebug())
348  CLOG << " ERROR: lookup failed for: " << indexedPrefixes[i] << std::endl;
349  return false;
350  }
351
352  theValidImageVertices.push_back(pt);
353  }
354
355
356  if (traceDebug())
357  {
358  CLOG << " DEBUG:"
359  << "\nVertices file: " << file
360  << "\nValid image vertices:"
361  << std::endl;
362  for (ossim_uint32 i=0; i<theValidImageVertices.size(); ++i)
363  {
365  << "\npoint[" << i << "]: " << theValidImageVertices[i];
366  }
367  ossimNotify(ossimNotifyLevel_DEBUG) << std::endl;
368  }
369
370  return true;
371 }
#define CLOG
Definition: ossimTrace.h:23
static const ossimErrorCode OSSIM_OK
static StreamFactoryRegistry * instance()
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
virtual std::shared_ptr< ossim::istream > createIstream(const std::string &connectionString, const ossimKeywordlist &options=ossimKeywordlist(), std::ios_base::openmode mode=std::ios_base::in|std::ios_base::binary) const
Will try to creates an istream interface to the connectionString passed in.
std::string::size_type find(const std::string &s, std::string::size_type pos=0) const
Searches for s as a substring of *this, beginning at character pos of *this.
Definition: ossimString.h:753
◆ isBandSelector()
bool ossimImageHandler::isBandSelector ( ) const
virtual
Indicates whether or not the image handler can control output band selection via the setOutputBandList method.
Returns
true if band selector; false, if not.
Reimplemented in ossimGeneralRasterTileSource, and ossimTiffTileSource.
Definition at line 1273 of file ossimImageHandler.cpp.
Referenced by ossimOverviewBuilderBase::finalize(), ossimBandSelector::getBandSelectableImageHandler(), ossimTiffTileSource::isBandSelector(), ossimGeneralRasterTileSource::isBandSelector(), ossimOverviewBuilderBase::setInputSource(), and setOutputToInputBandList().
1274 {
1275  return false;
1276 }
◆ isIdentityBandList()
bool ossimImageHandler::isIdentityBandList ( const std::vector< ossim_uint32 > &  bandList) const
virtual
Convenience method to see if band list is identity.
Parameters
bandListList to check.
Returns
Definition at line 1301 of file ossimImageHandler.cpp.
References ossimImageSource::getOutputBandList().
Referenced by ossimTiffTileSource::saveState().
1302 {
1303  bool result = false;
1304  const ossim_uint32 BANDS = (ossim_uint32)bandList.size();
1305  if ( BANDS )
1306  {
1307  std::vector<ossim_uint32> inputList;
1308  ossimImageSource::getOutputBandList( inputList ); // This populates an identity band list.
1309
1310  if ( inputList.size() == BANDS )
1311  {
1312  ossim_uint32 band = 0;
1313  while ( band < BANDS )
1314  {
1315  if ( inputList[band] != bandList[band] )
1316  {
1317  break;
1318  }
1319  ++band;
1320  }
1321  if ( band == BANDS )
1322  {
1323  result = true;
1324  }
1325  }
1326  }
1327  return result;
1328 }
virtual void getOutputBandList(std::vector< ossim_uint32 > &bandList) const
Initializes bandList.
◆ isImageTiled()
bool ossimImageHandler::isImageTiled ( ) const
virtual
Indicates whether or not the image is tiled internally.
This implementation returns true if (getImageTileWidth() && getImageTileHeight()) are both non zero. Override in the image handler if something else is desired. Returns true if tiled, false if not.
Reimplemented in ossimTiledImageHandler, and ossimKakaduJpipHandler.
Definition at line 1369 of file ossimImageHandler.cpp.
References getImageTileHeight(), and getImageTileWidth().
Referenced by ossimSingleImageChain::createRenderedChain().
1370 {
1371  return (getImageTileWidth() && getImageTileHeight());
1372 }
virtual ossim_uint32 getImageTileHeight() const =0
virtual ossim_uint32 getImageTileWidth() const =0
◆ isOpen()
virtual bool ossimImageHandler::isOpen ( ) const
pure virtual
◆ isValidRLevel()
bool ossimImageHandler::isValidRLevel ( ossim_uint32  resLevel) const
virtual
If this reader is used as an overview the caller should pass in a resLevel relative to the full image.
Parameters
resLevelzero base resolution level.
Returns
Reimplemented in ossimCibCadrgTileSource, ossimRpfCacheTileSource, ossimTiffTileSource, ossimImageCacheBase, ossimJpegTileSource, ossimGeneralRasterTileSource, and ossimBitMaskTileSource.
Definition at line 1207 of file ossimImageHandler.cpp.
References getNumberOfDecimationLevels(), and theStartingResLevel.
Referenced by getImageRectangle(), ossimGdalTileSource::getMaxSize(), ossimGdalTileSource::getNumberOfLines(), ossimOpjJp2Reader::getNumberOfLines(), ossimKakaduNitfReader::getNumberOfLines(), ossimMrSidReader::getNumberOfLines(), ossimKakaduJp2Reader::getNumberOfLines(), ossimGdalTileSource::getNumberOfSamples(), ossimOpjJp2Reader::getNumberOfSamples(), ossimKakaduNitfReader::getNumberOfSamples(), ossimMrSidReader::getNumberOfSamples(), ossimKakaduJp2Reader::getNumberOfSamples(), ossimKakaduNitfReader::getOverviewTile(), getOverviewTile(), ossimUsgsDemTileSource::getTile(), ossimOpjJp2Reader::getTile(), ossimGdalTileSource::getTile(), ossimGpkgReader::getTile(), ossimHdf5ImageHandler::getTile(), ossimCcfTileSource::getTile(), ossimHdfReader::getTile(), ossimDtedTileSource::getTile(), ossimPngReader::getTile(), ossimH5ImageHandler::getTile(), ossimMrSidReader::getTile(), ossimMG4LidarReader::getTile(), ossimAdrgTileSource::getTile(), ossimKakaduJ2kReader::getTile(), ossimKakaduJp2Reader::getTile(), ossimGeoPdfReader::getTile(), ossimNitfTileSource::getTile(), ossimJpegTileSource::isValidRLevel(), ossimRpfCacheTileSource::isValidRLevel(), and ossimCibCadrgTileSource::isValidRLevel().
1208 {
1209  bool result = false;
1210
1211  const ossim_uint32 LEVELS = getNumberOfDecimationLevels();
1212
1213  if ( !theStartingResLevel) // Not an overview.
1214  {
1215  result = (resLevel < LEVELS);
1216  }
1217  else // Used as overview.
1218  {
1219  if (resLevel >= theStartingResLevel)
1220  {
1221  //---
1222  // Adjust the res level to be zero based for this overview before
1223  // checking.
1224  //---
1225  result = ( (resLevel - theStartingResLevel) < LEVELS);
1226  }
1227  }
1228
1229  return result;
1230 }
◆ loadMetaData()
void ossimImageHandler::loadMetaData ( )
virtual
There is an external file with an omd extension.
this file contains additional information about the image such as the null pixel, min and max values. For general raster it will contain much more than that.
Reimplemented in ossimDtedTileSource, and ossimHdf5ImageHandler.
Definition at line 1374 of file ossimImageHandler.cpp.
References ossimString::c_str(), ossimImageMetaData::clear(), ossim::StreamFactoryRegistry::createIstream(), getFilenameWithThisExtension(), ossimImageSource::getOutputScalarType(), ossim::StreamFactoryRegistry::instance(), ossimImageMetaData::loadState(), m_state, ossimKeywordlist::parseStream(), ossimImageMetaData::setScalarType(), and theMetaData.
Referenced by ossimHdf5ImageHandler::loadMetaData().
1375 {
1376
1377  if(m_state&&m_state->getMetaData())
1378  {
1379  theMetaData = *m_state->getMetaData();
1380  }
1381  else
1382  {
1383  ossimFilename filename = getFilenameWithThisExtension(ossimString(".omd"), false);
1384  theMetaData.clear();
1385
1386  std::shared_ptr<ossim::istream> instream = ossim::StreamFactoryRegistry::instance()->createIstream(filename.c_str());
1387
1388  if(!instream)
1389  {
1390  filename = getFilenameWithThisExtension(ossimString(".omd"), true);
1392  }
1393
1394  if(instream)
1395  {
1396  ossimKeywordlist kwl;
1397
1398  kwl.parseStream(*instream);
1399
1400  theMetaData.loadState(kwl);
1401  }
1402  else
1403  {
1405  }
1406  if(m_state)
1407  {
1408  m_state->setMetaData(std::make_shared<ossimImageMetaData>(theMetaData));
1409  }
1410
1411  }
1412
1413 }
void setScalarType(ossimScalarType aType)
bool loadState(const ossimKeywordlist &kwl, const char *prefix=0)
virtual bool parseStream(ossim::istream &is, bool ignoreBinaryChars)
deprecated method
const char * c_str() const
Definition: ossimString.h:396
ossimFilename getFilenameWithThisExtension(const ossimString &ext, bool set_e0_prefix=false) const
Returns the image file with extension set using supplentary directory for dirname if set...
◆ loadState()
bool ossimImageHandler::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Reimplemented in ossimCibCadrgTileSource, ossimLasReader, ossimKakaduJp2Reader, ossimKakaduJ2kReader, ossimPointCloudImageHandler, ossimMrSidReader, ossimGeoPdfReader, ossimMG4LidarReader, ossimTiffTileSource, ossimRpfCacheTileSource, ossimHdfReader, ossimNitfTileSource, ossimCcfTileSource, ossimOgrGdalTileSource, ossimAdrgTileSource, ossimDtedTileSource, ossimOgrVectorTileSource, ossimH5ImageHandler, ossimOpjJp2Reader, ossimPngReader, ossimGdalTileSource, ossimHdf5ImageHandler, ossimGpkgReader, ossimUsgsDemTileSource, ossimJpegTileSource, ossimImageCacheBase, ossimKmlSuperOverlayReader, ossimRangeDomeTileSource, ossimVpfTileSource, ossimGeneralRasterTileSource, ossimTiledImageHandler, ossimKakaduJpipHandler, ossimBandSeparateHandler, ossimplugins::ossimTerraSarTiffReader, ossimplugins::ossimRadarSat2TiffReader, ossimEnviTileSource, ossimLandsatTileSource, ossimImageHandlerMtAdaptor, ossimSrtmTileSource, ossimERSTileSource, ossimQuickbirdNitfTileSource, and ossimDoqqTileSource.
Definition at line 141 of file ossimImageHandler.cpp.
References theDecimationFactors.
Referenced by ossimDoqqTileSource::loadState(), ossimBandSeparateHandler::loadState(), ossimKakaduJpipHandler::loadState(), ossimTiledImageHandler::loadState(), ossimVpfTileSource::loadState(), ossimRangeDomeTileSource::loadState(), ossimKmlSuperOverlayReader::loadState(), ossimJpegTileSource::loadState(), ossimUsgsDemTileSource::loadState(), ossimGpkgReader::loadState(), ossimHdf5ImageHandler::loadState(), ossimGdalTileSource::loadState(), ossimH5ImageHandler::loadState(), ossimOpjJp2Reader::loadState(), ossimPngReader::loadState(), ossimAdrgTileSource::loadState(), ossimDtedTileSource::loadState(), ossimOgrVectorTileSource::loadState(), ossimOgrGdalTileSource::loadState(), ossimCcfTileSource::loadState(), ossimNitfTileSource::loadState(), ossimHdfReader::loadState(), ossimTiffTileSource::loadState(), ossimMG4LidarReader::loadState(), ossimGeoPdfReader::loadState(), ossimMrSidReader::loadState(), ossimKakaduJ2kReader::loadState(), ossimKakaduJp2Reader::loadState(), ossimLasReader::loadState(), ossimKakaduJpipInfo::open(), ossimHdf5PluginHandlerFactory::open(), and ossimplugins::ossimPluginReaderFactory::open().
143 {
144  static const char MODULE[] = "ossimImageHandler::loadState(kwl, prefix)";
145  theDecimationFactors.clear();
146  if(traceDebug())
147  {
149  << MODULE << " DEBUG: entered ..."
150  << std::endl;
151  }
152
153  ossimImageSource::loadState(kwl, prefix);
154
156  {
158  << MODULE
159  << "WARNING: error detected in keyword list! State not load."
160  << std::endl;
161
162  if(traceDebug())
163  {
165  << MODULE << " DEBUG: "
166  << "leaving with error in kwl ..." << std::endl;
167  }
168  return false;
169  }
170
171  const char* lookup = kwl.find(prefix, ossimKeywordNames::FILENAME_KW);
172  if (!lookup)
173  {
174  // Deprecated...
175  lookup = kwl.find(prefix, ossimKeywordNames::IMAGE_FILE_KW);
176  }
177
178  if (lookup)
179  {
180  theImageFile = lookup;
181  }
182
183  lookup = kwl.find(prefix, ossimKeywordNames::OVERVIEW_FILE_KW);
184  if(lookup)
185  {
186  theOverviewFile = ossimFilename(lookup);
187  }
188  if(traceDebug())
189  {
191  << MODULE << " DEBUG:\n"
192  << "filename = " << theImageFile << std::endl;
193  }
194
195  // Check for an external geometry file to initialize our image geometry object:
196  lookup = kwl.find(prefix, ossimKeywordNames::GEOM_FILE_KW);
197  if (lookup)
198  {
199  ossimKeywordlist geomKwl;
200  if (geomKwl.addFile(lookup) == true)
201  {
203  theGeometry->loadState(geomKwl);
204  if(traceDebug())
205  {
207  << MODULE << " DEBUG:"
208  << "Loaded external geometry file: "
209  << lookup
210  << "\n" << geomKwl << std::endl;
211  }
212  }
213  }
214
215  // Check for an valid image vetices file.
216  lookup = kwl.find(prefix, VALID_VERTICES_FILE_KW);
217  if (lookup)
218  {
219  initVertices(lookup);
220  }
221
222  // Starting resolution level.
223  lookup = kwl.find(prefix, START_RES_LEVEL_KW);
224  if (lookup)
225  {
227  }
228
229  // Open overview flag.
230  lookup = kwl.find(prefix, OPEN_OVERVIEW_FLAG_KW);
231  if (lookup)
232  {
233  setOpenOverviewFlag( ossimString(lookup).toBool() );
234  }
235
236  // The supplementary directory for finding the overview
237  lookup = kwl.find(prefix, SUPPLEMENTARY_DIRECTORY_KW);
238  if (lookup)
239  {
241  }
242
243  if(getNumberOfInputs())
244  {
245  theInputObjectList.clear();
246  }
248
249  // Read image id if present:
251
252  lookup = kwl.find(prefix, ossimKeywordNames::PIXEL_TYPE_KW);
253  if (lookup)
254  {
255  thePixelType = (ossimPixelType) atoi(lookup);
256  }
257
258  if(traceDebug())
259  {
261  << MODULE << " DEBUG: Leaving Ok ..."
262  << std::endl;
263  }
264  return true;
265 }
static const char * OVERVIEW_FILE_KW
void setOpenOverviewFlag(bool flag)
Sets theOpenOverviewFlag.
ossimRefPtr< ossimImageGeometry > theGeometry
ossimFilename theImageFile
bool addFile(const char *file)
static const ossimErrorCode OSSIM_ERROR
ossim_uint32 toUInt32() const
static const char * IMAGE_ID_KW
ossimPixelType thePixelType
static const char * GEOM_FILE_KW
ossimPixelType
ConnectableObjectList theInputObjectList
Holds a list of input objects.
virtual ossimErrorCode getErrorStatus() const
static const char * PIXEL_TYPE_KW
virtual ossim_uint32 getNumberOfInputs() const
Returns the number of input objects.
bool theInputListIsFixedFlag
Indicates whether the theInputObjectList is fixed.
ossimFilename theOverviewFile
static const char * IMAGE_FILE_KW
static const char * FILENAME_KW
bool initVertices(const char *file)
◆ open() [1/4]
virtual bool ossimImageHandler::open ( )
pure virtual
Pure virtual open.
Derived classes must implement.
Returns
Note
This method relies on the data member ossimImageData::theImageFile being set. Callers should do a "setFilename" prior to calling this method or use the ossimImageHandler::open that takes a file name and an entry index.
Implemented in ossimH5ImageHandler, ossimTiffTileSource, ossimPngReader, ossimGpkgReader, ossimHdf5ImageHandler, ossimJpegTileSource, ossimKakaduJ2kReader, ossimKakaduJp2Reader, ossimMrSidReader, ossimGeoPdfReader, ossimOpjJp2Reader, ossimMG4LidarReader, ossimGeneralRasterTileSource, ossimHdfReader, ossimBitMaskTileSource, ossimCibCadrgTileSource, ossimRangeDomeTileSource, ossimNitfTileSource, ossimRpfCacheTileSource, ossimOgrGdalTileSource, ossimAdrgTileSource, ossimOgrVectorTileSource, ossimImageHandlerMtAdaptor, ossimGdalTileSource, ossimLasReader, ossimDtedTileSource, ossimImageCacheTileSource, ossimPointCloudImageHandler, ossimKmlSuperOverlayReader, ossimCcfTileSource, ossimKakaduJpipHandler, ossimTiledImageHandler, ossimUsgsDemTileSource, ossimImageCacheBase, ossimBandSeparateHandler, ossimVpfTileSource, ossimEnviTileSource, ossimLandsatTileSource, ossimQbTileFilesHandler, ossimSrtmTileSource, ossimVideoImageHandler, ossimQuickbirdTiffTileSource, and ossimQuickbirdNitfTileSource.
Referenced by ossimImageCacheTileSource::fillTile(), ossimDtedTileSource::loadState(), main(), ossimImageHandlerFactory::open(), ossimHdf5PluginHandlerFactory::open(), ossimplugins::ossimPluginReaderFactory::open(), ossimKakaduJpipInfo::open(), ossimImageHandlerMtAdaptor::open(), ossimImageHandlerRegistry::open(), open(), ossimGdalFactory::openOverview(), ossimOpjReaderFactory::openOverview(), ossimImageHandlerFactory::openOverview(), and ossimKakaduReaderFactory::openOverview().
◆ open() [2/4]
bool ossimImageHandler::open ( const ossimFilename imageFile,
ossim_uint32  entryIndex
virtual
Opens the image file.
Parameters
imageFileFile to open.
entryIndex
Returns
Definition at line 1173 of file ossimImageHandler.cpp.
References close(), isOpen(), open(), setCurrentEntry(), and setFilename().
1175 {
1176  if(isOpen())
1177  {
1178  close();
1179  }
1180  setFilename(imageFile);
1181
1182  bool result = open();
1183
1184  if(result)
1185  {
1186  return setCurrentEntry(entryIndex);
1187  }
1188
1189  return result;
1190 }
virtual bool open()=0
Pure virtual open.
virtual bool isOpen() const =0
virtual void setFilename(const ossimFilename &filename)
Sets the filename.
virtual void close()
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
◆ open() [3/4]
bool ossimImageHandler::open ( const ossimFilename imageFile)
virtual
Reimplemented in ossimJpegTileSource, ossimTiffTileSource, ossimplugins::ossimTerraSarTiffReader, ossimplugins::ossimRadarSat2TiffReader, ossimERSTileSource, and ossimDoqqTileSource.
Definition at line 1161 of file ossimImageHandler.cpp.
References close(), isOpen(), open(), and setFilename().
1162 {
1163  if(isOpen())
1164  {
1165  close();
1166  }
1167
1168  setFilename(imageFile);
1169
1170  return open();
1171 }
Pure virtual open.
Sets the filename.
◆ open() [4/4]
bool ossimImageHandler::open ( std::shared_ptr< ossim::ImageHandlerState >  state)
virtual
Definition at line 1192 of file ossimImageHandler.cpp.
References close(), isOpen(), open(), setFilename(), and setState().
1193 {
1194  bool result = false;
1195  if(isOpen())
1196  {
1197  close();
1198  }
1199  setFilename(state->getConnectionString());
1200  setState(state);
1201  result = open();
1202
1203  return result;
1204 }
Pure virtual open.
void setState(std::shared_ptr< ossim::ImageHandlerState > state)
Sets the filename.
◆ openOverview() [1/2]
bool ossimImageHandler::openOverview ( )
virtual
Searches for an overview.
Uses theImageFile as a key. If theImageFile = "foo.tif" it will look for "foo.ovr" first, then "foo_ovr.tif" next. Calls openOverview(const ossimFilename& overview_file)
Returns
See also
Definition at line 927 of file ossimImageHandler.cpp.
Referenced by ossimSingleImageChain::addImageHandler(), buildOverview(), and ossimImageHandlerFactory::openSrcRecord().
928 {
929  static const char MODULE[] = "ossimImageHandler::openOverview()";
930  if (traceDebug())
931  {
932  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
933  }
934
935  bool result = false;
936
937  closeOverview();
938
939  if(m_state)
940  {
941  // check if we have an overview state
942  std::shared_ptr<ossim::ImageHandlerState> overviewState = m_state->getOverviewState();
943  if(overviewState)
944  {
945  // check to see if the overvies state was cached
946  // to mark has checked but no overview
947  if(overviewState->getConnectionString().empty())
948  {
949  return false;
950  }
951  ossim_uint32 overviewStartingResLevel = getNumberOfDecimationLevels();
953  if(theOverview)
954  {
955  result = true;
956  //---
957  // Set the owner in case the overview reader needs to get something
958  // from the it like min/max/null.
959  //---
960  theOverview->changeOwner(this);
961
962  // Set the starting res level of the overview.
963  theOverview->setStartingResLevel(overviewStartingResLevel);
964
965  // Capture the file name.
966  theOverviewFile = overviewState->getConnectionString();
967
968  //---
969  // Some overview handlers cannot store what the null is. Like dted
970  // null is -32767 not default -32768 so this allows passing this to the
971  // overview reader provided it overrides setMin/Max/NullPixel value
972  // methods. (drb)
973  //---
974  const ossim_uint32 BANDS = getNumberOfOutputBands();
975  for (ossim_uint32 band = 0; band < BANDS; ++band)
976  {
980  }
981  if (traceDebug())
982  {
984  << "overview starting res level: " << overviewStartingResLevel
985  << "\noverview levels: "
987  << "\nlevels: " << getNumberOfDecimationLevels()
988  << endl;
989  }
990
991  //---
992  // This is not really a container event; however, using for now.
993  //---
994  ossimContainerEvent event(this,
996  event.setObjectList(theOverview.get());
997  fireEvent(event);
998  return result;
999  }
1000  }
1001  }
1002  // 1) ESH 03/2009 -- Use the overview file set e.g. using a .spec file.
1003  ossimFilename overviewFilename = getOverviewFile();
1004
1005  // ossimFilename::exists() currently does not work with s3 url's.
1006  if ( overviewFilename.empty() ) // || (overviewFilename.exists() == false) )
1007  {
1008  // 2) Generate the name from image name.
1009  overviewFilename = createDefaultOverviewFilename();
1010  }
1011
1012  // ossimFilename::exists() currently does not work with s3 url's.
1013  if ( overviewFilename.size() )
1014  {
1015  result = openOverview( overviewFilename );
1016
1017  if (traceDebug())
1018  {
1020  << (result?"Opened ":"Could not open ") << "overview: " << overviewFilename
1021  << "\n";
1022  }
1023  }
1024  if ( !result )
1025  {
1026  if (overviewFilename.empty() || (overviewFilename.exists() == false) )
1027  {
1028  // 3) For backward compatibility check if single entry and _e0.ovr
1029  overviewFilename = getFilenameWithThisExtension(ossimString(".ovr"), true);
1030
1031  if (overviewFilename.empty() || (overviewFilename.exists() == false) )
1032  {
1033  //---
1034  // 4) For overviews built with gdal.
1035  // Examples:
1036  // Single entry: foo.tif.ovr
1037  // Multi-entry: foo.tif.x.ovr where "x" == one based entry number.
1038  //
1039  // Note: Take into account a supplementary dir if any.
1040  //---
1042  {
1043  overviewFilename = getFilename();
1044  }
1045  else
1046  {
1047  overviewFilename = theSupplementaryDirectory;
1048  overviewFilename = overviewFilename.dirCat( getFilename().file() );
1049
1050  }
1051
1052  if ( getNumberOfEntries() > 1 )
1053  {
1054  overviewFilename += ".";
1055  // Sample multi-entry data "one" based; hence, the + 1.
1056  overviewFilename += ossimString::toString( getCurrentEntry()+1 );
1057  }
1058  overviewFilename += ".ovr";
1059  }
1060  }
1061
1062  if ( overviewFilename.exists() )
1063  {
1064  result = openOverview( overviewFilename );
1065
1066  if (traceDebug())
1067  {
1069  << (result?"Opened ":"Could not open ") << "overview: " << overviewFilename
1070  << "\n";
1071  }
1072  }
1073  }
1074
1075  if (traceDebug())
1076  {
1078  << MODULE << " exit result: " << (result?"true":"false") << "\n";
1079  }
1080
1081  return result;
1082 }
virtual void setMaxPixelValue(ossim_uint32 band, const ossim_float64 &pix)
convenience method to set max pixel value.
virtual ossimImageHandler * open(const ossimFilename &fileName, bool trySuffixFirst=true, bool openOverview=true) const
open that takes a filename.
Numeric to string methods.
virtual void closeOverview()
If theOverview is initialized it will be deleted and set to NULL.
virtual void fireEvent(ossimEvent &event)
virtual bool openOverview()
virtual void changeOwner(ossimObject *owner)
Permits changing the object&#39;s owner.
bool exists() const
virtual const ossimFilename & getFilename() const
std::string::size_type size() const
Definition: ossimString.h:405
#define OSSIM_EVENT_ADD_OBJECT_ID
Definition: ossimEventIds.h:27
virtual void setMinPixelValue(ossim_uint32 band, const ossim_float64 &pix)
convenience method to set min pixel value.
virtual ossim_uint32 getCurrentEntry() const
virtual ossim_uint32 getNumberOfEntries() const
void setStartingResLevel(ossim_uint32 level)
ossimRefPtr< ossimImageHandler > theOverview
ossimFilename getOverviewFile() const
ossimFilename dirCat(const ossimFilename &file) const
bool empty() const
Definition: ossimString.h:411
static ossimImageHandlerRegistry * instance()
virtual void setNullPixelValue(ossim_uint32 band, const ossim_float64 &pix)
convenience method to set null pixel value.
◆ openOverview() [2/2]
bool ossimImageHandler::openOverview ( const ossimFilename overview_file)
virtual
Calls closeOverview(), then attempts to open the overview_file.
On success, theOverviewFile will be set and theOverview will be initialized. On failure, theOverviewFile will be cleared and theOverview deleted and set to NULL.
Parameters
overview_fileossimFilename representing overview file.
Returns
See also
closeOverview()
Definition at line 845 of file ossimImageHandler.cpp.
846 {
847  bool result = false;
848  if (traceDebug())
849  {
851  << "ossimImageHandler::openOverview(overview_file): ...entered!";
852  }
853  closeOverview();
854
855  if (overview_file != theImageFile) // Make sure we don't open ourselves.
856  {
857  //---
858  // Get the number of level before the call to opening the overview so
859  // the overview can be told what it's starting res level is.
860  //---
861  ossim_uint32 overviewStartingResLevel = getNumberOfDecimationLevels();
862
863
864  // Try to open:
866  if (theOverview.valid())
867  {
868  result = true;
869
870  //---
871  // Set the owner in case the overview reader needs to get something
872  // from the it like min/max/null.
873  //---
874  theOverview->changeOwner(this);
875
876  // Set the starting res level of the overview.
877  theOverview->setStartingResLevel(overviewStartingResLevel);
878
879  // Capture the file name.
880  theOverviewFile = overview_file;
881
882  //---
883  // Some overview handlers cannot store what the null is. Like dted
884  // null is -32767 not default -32768 so this allows passing this to the
885  // overview reader provided it overrides setMin/Max/NullPixel value
886  // methods. (drb)
887  //---
888  const ossim_uint32 BANDS = getNumberOfOutputBands();
889  for (ossim_uint32 band = 0; band < BANDS; ++band)
890  {
894  }
895  if(m_state)
896  {
897  m_state->setOverviewState(theOverview->getState());
898  }
899  if (traceDebug())
900  {
902  << "overview starting res level: " << overviewStartingResLevel
903  << "\noverview levels: "
905  << "\nlevels: " << getNumberOfDecimationLevels()
906  << endl;
907  }
908
909  //---
910  // This is not really a container event; however, using for now.
911  //---
912  ossimContainerEvent event(this,
914  event.setObjectList(theOverview.get());
915  fireEvent(event);
916  }
917  }
918  if (traceDebug())
919  {
921  << "ossimImageHandler::openOverview(overview_file): ...leaving!";
922  }
923
924  return result;
925 }
virtual ossimRefPtr< ossimImageHandler > openOverview(const ossimFilename &file) const
Open overview that takes a file name.
bool valid() const
std::shared_ptr< ossim::ImageHandlerState > getState()
◆ openValidVertices() [1/2]
bool ossimImageHandler::openValidVertices ( const ossimFilename vertices_file)
virtual
Opens the valid image vertices file and sets theValidImageVerticesFile variable.
Parameters
vertices_fileFile name containing valid vertices for image.
Returns
Definition at line 1132 of file ossimImageHandler.cpp.
References initVertices().
1133 {
1134  return initVertices(vertices_file);
1135 }
◆ openValidVertices() [2/2]
bool ossimImageHandler::openValidVertices ( )
virtual
Creates vertices file name based on image, then tries to open.
If theImageFile = "foo.tif" it will look for "foo_vertices.kwl".
Returns
Definition at line 1137 of file ossimImageHandler.cpp.
References ossimFilename::dirCat(), ossimFilename::fileNoExtension(), getCurrentEntry(), getNumberOfEntries(), ossimFilename::path(), theImageFile, and ossimString::toString().
1138 {
1139  ossimFilename vertices_file;
1140  vertices_file = theImageFile.path();
1141  vertices_file = vertices_file.dirCat(theImageFile.fileNoExtension());
1142  if(getNumberOfEntries() > 1)
1143  {
1144  vertices_file += ossimString("_vertices") + "_e" + ossimString::toString(getCurrentEntry()) + ".kwl";
1145  }
1146  else
1147  {
1148  vertices_file += "_vertices.kwl";
1149  }
1150
1151  if (traceDebug())
1152  {
1154  << "Looking for " << vertices_file
1155  << " vertices file..." << std::endl;
1156  }
1157
1158  return openValidVertices(vertices_file);
1159 }
virtual bool openValidVertices()
ossimFilename fileNoExtension() const
ossimFilename path() const
◆ saveImageGeometry() [1/2]
void ossimImageHandler::saveImageGeometry ( ) const
virtual
Saves the image geometry to a file that will be made based on the image file name.
Definition at line 814 of file ossimImageHandler.cpp.
References getFilenameWithThisExtension().
815 {
816  ossimFilename geometryFile = getFilenameWithThisExtension(ossimString(".geom"));
817  saveImageGeometry(geometryFile);
818 }
virtual void saveImageGeometry() const
◆ saveImageGeometry() [2/2]
void ossimImageHandler::saveImageGeometry ( const ossimFilename geometry_file) const
virtual
Definition at line 820 of file ossimImageHandler.cpp.
References ossimString::chars(), ossimImageGeometry::saveState(), theGeometry, ossimRefPtr< T >::valid(), and ossimKeywordlist::write().
821 {
822  if (theGeometry.valid())
823  {
824  ossimKeywordlist kwl;
825  theGeometry->saveState(kwl);
826  kwl.write(geometry_file.chars());
827  }
828 }
bool valid() const
virtual bool write(const char *file, const char *comment=0) const
Methods to dump the ossimKeywordlist to a file on disk.
const char * chars() const
For backward compatibility.
Definition: ossimString.h:77
Saves the transform (if any) and projection (if any) states to the KWL.
◆ saveState()
bool ossimImageHandler::saveState ( ossimKeywordlist kwl,
) const
virtual
Reimplemented in ossimGeoPdfReader, ossimLasReader, ossimCibCadrgTileSource, ossimPointCloudImageHandler, ossimTiffTileSource, ossimRpfCacheTileSource, ossimNitfTileSource, ossimCcfTileSource, ossimOgrGdalTileSource, ossimAdrgTileSource, ossimDtedTileSource, ossimOgrVectorTileSource, ossimH5ImageHandler, ossimOpjJp2Reader, ossimPngReader, ossimGdalTileSource, ossimHdf5ImageHandler, ossimGpkgReader, ossimRangeDomeTileSource, ossimJpegTileSource, ossimUsgsDemTileSource, ossimKmlSuperOverlayReader, ossimVpfTileSource, ossimGeneralRasterTileSource, ossimImageCacheBase, ossimKakaduJpipHandler, ossimTiledImageHandler, ossimBandSeparateHandler, ossimplugins::ossimTerraSarTiffReader, ossimplugins::ossimRadarSat2TiffReader, ossimEnviTileSource, ossimImageHandlerMtAdaptor, ossimSrtmTileSource, and ossimQuickbirdNitfTileSource.
Definition at line 111 of file ossimImageHandler.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimKeywordNames::FILENAME_KW, ossimErrorStatusInterface::getErrorStatus(), ossimErrorCodes::OSSIM_ERROR, ossimNotify(), ossimNotifyLevel_WARN, ossimImageSource::saveState(), and theImageFile.
Referenced by ossimBandSeparateHandler::saveState(), ossimTiledImageHandler::saveState(), ossimKakaduJpipHandler::saveState(), ossimImageCacheBase::saveState(), ossimKmlSuperOverlayReader::saveState(), ossimJpegTileSource::saveState(), ossimRangeDomeTileSource::saveState(), ossimGpkgReader::saveState(), ossimHdf5ImageHandler::saveState(), ossimGdalTileSource::saveState(), ossimH5ImageHandler::saveState(), ossimOpjJp2Reader::saveState(), ossimOgrVectorTileSource::saveState(), ossimDtedTileSource::saveState(), ossimAdrgTileSource::saveState(), ossimOgrGdalTileSource::saveState(), ossimCcfTileSource::saveState(), ossimNitfTileSource::saveState(), ossimRpfCacheTileSource::saveState(), ossimTiffTileSource::saveState(), ossimPointCloudImageHandler::saveState(), ossimCibCadrgTileSource::saveState(), and ossimGeoPdfReader::saveState().
113 {
114  static const char MODULE[] = "ossimImageHandler::saveState";
115
116  ossimImageSource::saveState(kwl, prefix);
118  {
120  << MODULE
121  << " ERROR detected in keyword list! State not saved."
122  << std::endl;
123  return false;
124  }
125
127  kwl.add(prefix, HAS_LUT_KW, (theLut.valid()?"true":"false"), true);
128  kwl.add(prefix, ossimKeywordNames::IMAGE_ID_KW, theImageID, true);
130  kwl.add(prefix, SUPPLEMENTARY_DIRECTORY_KW, theSupplementaryDirectory.c_str(), true);
131  kwl.add(prefix, START_RES_LEVEL_KW, theStartingResLevel, true);
132  kwl.add(prefix, OPEN_OVERVIEW_FLAG_KW, (theOpenOverviewFlag?"1":"0"), true);
134
135  return true;
136 }
bool valid() const
If true opening of overviews will be attempted.
unsigned short ossim_uint16
◆ setCurrentEntry()
bool ossimImageHandler::setCurrentEntry ( ossim_uint32  entryIdx)
virtual
◆ setFilename()
void ossimImageHandler::setFilename ( const ossimFilename filename)
virtual
Sets the filename.
Definition at line 1549 of file ossimImageHandler.cpp.
References theImageFile.
Referenced by ossimHdf5Tool::loadImageFiles(), and open().
1550 {
1551  theImageFile = filename;
1552 }
◆ setImageGeometry()
void ossimImageHandler::setImageGeometry ( ossimImageGeometry geom)
virtual
Sets the image geometry object.
Note
Callers should note that this will override any existing geometry.
This does not write the geometry to disk, to do so call one of the saveImageGeometry methods.
Definition at line 809 of file ossimImageHandler.cpp.
References theGeometry.
810 {
811  theGeometry = geom;
812 }
◆ setImageID()
void ossimImageHandler::setImageID ( const ossimString id)
inline
Sets the image ID in case it is externally generated.
Definition at line 718 of file ossimImageHandler.h.
Referenced by ATP::AtpGenerator::constructChain().
718 { theImageID = id; }
◆ setMaxPixelValue()
void ossimImageHandler::setMaxPixelValue ( ossim_uint32  band,
const ossim_float64 pix
virtual
Added for overview readers so that the image handler that owns the overview reader can pass on it's max value.
Parameters
bandZero based band to set.
pixMax pixel value.
Reimplemented in ossimKakaduNitfReader.
Definition at line 1449 of file ossimImageHandler.cpp.
References ossimImageMetaData::setMaxPix(), and theMetaData.
Referenced by ossimKakaduNitfReader::setMaxPixelValue().
1451 {
1452  theMetaData.setMaxPix(band, pix);
1453 }
void setMaxPix(ossim_uint32 band, double pix)
◆ setMinPixelValue()
void ossimImageHandler::setMinPixelValue ( ossim_uint32  band,
virtual
Added for overview readers so that the image handler that owns the overview reader can pass on it's min value.
Parameters
pixMin pixel value.
Definition at line 1443 of file ossimImageHandler.cpp.
References ossimImageMetaData::setMinPix(), and theMetaData.
Referenced by ossimKakaduNitfReader::setMinPixelValue().
1445 {
1446  theMetaData.setMinPix(band, pix);
1447 }
void setMinPix(ossim_uint32 band, double pix)
◆ setNullPixelValue()
void ossimImageHandler::setNullPixelValue ( ossim_uint32  band,
virtual
Parameters
pixNull pixel value.
Definition at line 1455 of file ossimImageHandler.cpp.
References ossimImageMetaData::setNullPix(), and theMetaData.
Referenced by ossimKakaduNitfReader::setNullPixelValue().
1457 {
1458  theMetaData.setNullPix(band, pix);
1459 }
void setNullPix(ossim_uint32 band, double pix)
◆ setOpenOverviewFlag()
void ossimImageHandler::setOpenOverviewFlag ( bool  flag)
If true opening of overviews will be attempted on normal open. If false only the base image will be opened (shallow open). Defaulted to true in constructor.
Definition at line 1891 of file ossimImageHandler.cpp.
Referenced by ossimHdf5PluginHandlerFactory::open(), ossimplugins::ossimPluginReaderFactory::open(), ossimImageHandlerFactory::open(), ossimPngReaderFactory::open(), ossimKakaduReaderFactory::open(), ossimGdalFactory::openOverview(), ossimOpjReaderFactory::openOverview(), ossimImageHandlerFactory::openOverview(), and ossimKakaduReaderFactory::openOverview().
1892 {
1893  theOpenOverviewFlag = flag;
1894
1895  // If false close overview if open??? (drb)
1896 }
◆ setOutputBandList() [1/2]
bool ossimImageHandler::setOutputBandList ( const std::vector< ossim_uint32 > &  band_list)
virtual
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled.
This method returns false. Derived classes that are band selectors should override.
Parameters
band_listRequested bands.
Returns
Reimplemented in ossimGdalTileSource, ossimHdfReader, ossimGeneralRasterTileSource, and ossimTiffTileSource.
Definition at line 1278 of file ossimImageHandler.cpp.
Referenced by ossimOverviewBuilderBase::finalize(), ossimBandSelector::setOutputBandList(), ossimTiffTileSource::setOutputBandList(), ossimGeneralRasterTileSource::setOutputBandList(), setOutputBandList(), and setOutputToInputBandList().
1279 {
1280  return false;
1281 }
◆ setOutputBandList() [2/2]
bool ossimImageHandler::setOutputBandList ( const std::vector< ossim_uint32 > &  inBandList,
std::vector< ossim_uint32 > &  outBandList
protectedvirtual
Convenience method to set output band list.
This performs range checking and calls theOverview->setOutputBandList on success.
Parameters
inBandListThe new band list.
outBandListBand list to initialize.
Returns
Definition at line 1331 of file ossimImageHandler.cpp.
References ossimImageSource::getNumberOfInputBands(), ossimImageSource::getOutputBandList(), setOutputBandList(), theOverview, and ossimRefPtr< T >::valid().
1333 {
1334  bool result = false;
1335
1336  const ossim_uint32 INPUT_BANDS = getNumberOfInputBands();
1337  const ossim_uint32 OUTPUT_BANDS = (ossim_uint32)inBandList.size();
1338
1339  if ( INPUT_BANDS && OUTPUT_BANDS )
1340  {
1341  result = true;
1342  outBandList.resize( OUTPUT_BANDS );
1343  for ( ossim_uint32 band = 0; band < OUTPUT_BANDS; ++band )
1344  {
1345  if ( inBandList[band] < INPUT_BANDS )
1346  {
1347  outBandList[band] = inBandList[band];
1348  }
1349  else // Out of range...
1350  {
1351  result = false;
1352  break;
1353  }
1354  }
1355  if ( result && theOverview.valid() )
1356  {
1357  result = theOverview->setOutputBandList( inBandList );
1358  }
1359  }
1360
1361  if ( result == false )
1362  {
1363  ossimImageSource::getOutputBandList( outBandList ); // Set to identity.
1364  }
1365
1366  return result;
1367 }
bool valid() const
Definition: ossimRefPtr.h:75
virtual bool setOutputBandList(const std::vector< ossim_uint32 > &band_list)
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled...
◆ setOutputToInputBandList()
bool ossimImageHandler::setOutputToInputBandList ( )
virtual
If the image handler "isBandSeletor()" then the band selection of the output are set to input or identity.
Does nothing and returns false if not a band selector.
Returns
If band selector, returns the output of setOutputBandList; if not, returns false.
Definition at line 1289 of file ossimImageHandler.cpp.
References ossimImageSource::getOutputBandList(), isBandSelector(), and setOutputBandList().
Referenced by ossimOverviewBuilderBase::setInputSource().
1290 {
1291  bool result = false;
1292  if ( isBandSelector() )
1293  {
1294  std::vector<ossim_uint32> bandList;
1296  result = setOutputBandList( bandList );
1297  }
1298  return result;
1299 }
virtual bool isBandSelector() const
Indicates whether or not the image handler can control output band selection via the setOutputBandLis...
◆ setProperty()
void ossimImageHandler::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Reimplemented in ossimLasReader, ossimTiffTileSource, ossimGdalTileSource, ossimPointCloudImageHandler, ossimNitfTileSource, ossimH5ImageHandler, ossimOgrGdalTileSource, ossimHdf5ImageHandler, ossimPngReader, ossimGpkgReader, ossimRangeDomeTileSource, and ossimKakaduJpipHandler.
Definition at line 1582 of file ossimImageHandler.cpp.
References ossimKeywordNames::ENTRY_KW, ossimProperty::getName(), setCurrentEntry(), ossimRefPtr< T >::valid(), and ossimProperty::valueToString().
Referenced by ossimKakaduJpipHandler::setProperty(), ossimRangeDomeTileSource::setProperty(), ossimGpkgReader::setProperty(), ossimNitfTileSource::setProperty(), and ossimTiffTileSource::setProperty().
1583 {
1584  if ( property.valid() )
1585  {
1586  if(property->getName() == ossimKeywordNames::ENTRY_KW)
1587  {
1588  setCurrentEntry(property->valueToString().toUInt32());
1589  }
1590  else if ( property->getName() == OPEN_OVERVIEW_FLAG_KW )
1591  {
1592  setOpenOverviewFlag( property->valueToString().toBool() );
1593  }
1594  else
1595  {
1597  }
1598  }
1599 }
virtual void valueToString(ossimString &valueResult) const =0
bool valid() const
const ossimString & getName() const
◆ setStartingResLevel()
void ossimImageHandler::setStartingResLevel ( ossim_uint32  level)
Definition at line 1881 of file ossimImageHandler.cpp.
1882 {
1883  theStartingResLevel = level;
1884 }
◆ setState()
void ossimImageHandler::setState ( std::shared_ptr< ossim::ImageHandlerState >  state)
inline
Definition at line 742 of file ossimImageHandler.h.
Referenced by close(), and open().
742 {m_state = state;}
◆ setSupplementaryDirectory()
void ossimImageHandler::setSupplementaryDirectory ( const ossimFilename dir)
virtual
Sets the supplementary directory.
Definition at line 1559 of file ossimImageHandler.cpp.
References completeOpen(), ossimFilename::isDir(), ossimFilename::path(), theDecimationFactors, theOverview, theSupplementaryDirectory, and ossimRefPtr< T >::valid().
Referenced by ossimSingleImageChain::addImageHandler(), and ossimImageHandlerFactory::openSrcRecord().
1560 {
1561  if (dir.isDir())
1563  else
1565  // A change in supplementary directory presents an opportunity to find the OVR that could not be
1566  // opened previously, as well as other support data items:
1567  if (!theOverview.valid())
1568  {
1569  if (theDecimationFactors.size() > 0)
1570  {
1571  theDecimationFactors.clear();
1572  }
1573  completeOpen();
1574  }
1575 }
bool valid() const
bool isDir() const
virtual void completeOpen()
Will complete the opening process.
◆ useEntryIndex()
bool ossimImageHandler::useEntryIndex ( ) const
Convenience method to determine if entry index should be used for support files, e.g.
file.his or file_e1.his.
Returns
true if file is open, && ( (entryList.size() > 1) || (entryList[0] != 0) ) false otherwise.
Note
This is just a hint. Put here as code was duplicated everywhere. Callers can do what they wish.
Definition at line 1481 of file ossimImageHandler.cpp.
References getEntryList(), and isOpen().
1482 {
1483  bool result = false;
1484  if ( isOpen() )
1485  {
1486  std::vector<ossim_uint32> entryList;
1487  getEntryList(entryList);
1488
1489  if ( entryList.size() )
1490  {
1491  if ( (entryList.size() > 1) || (entryList[0] != 0) ) result = true;
1492  }
1493  }
1494  return result;
1495 }
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
◆ writeValidImageVertices()
bool ossimImageHandler::writeValidImageVertices ( const std::vector< ossimIpt > &  vertices,
const ossimFilename file = ossimFilename("")
virtual
Outputs vertices to file and updates the internal vertex array variable "theValidImageVertices".
Parameters
verticesArray of ossimIpts to write.
fileName of output file to write to. If file is empty, the output file will be the image file with no extension + _vertices.kwl. So if the image is "foo.tif" you'll get "foo_vertices.kwl".
Returns
Definition at line 1085 of file ossimImageHandler.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimPolygon::checkOrdering(), createDefaultValidVerticesFilename(), ossimFilename::exists(), ossimPolygon::getOrdering(), OSSIM_COUNTERCLOCKWISE_ORDER, theValidImageVertices, ossimString::toString(), and ossimKeywordlist::write().
1086 {
1087  ossimFilename tempFile = file;
1088  if(tempFile == "")
1089  {
1091  }
1092  ossim_uint32 i = 0;
1093  ossimKeywordlist tempKwl;
1094  ossimPolygon poly(vertices);
1095
1096  poly.checkOrdering();
1097
1098  // Capture the vertices.
1099  theValidImageVertices = vertices;
1100
1101  if(poly.getOrdering() == OSSIM_COUNTERCLOCKWISE_ORDER)
1102  {
1103  std::reverse(theValidImageVertices.begin(), theValidImageVertices.end());
1104  }
1105
1106  if(theValidImageVertices.size())
1107  {
1108  for(i = 0; i < theValidImageVertices.size(); ++i)
1109  {
1110  ossimString prefix = ossimString("point") + ossimString::toString(i) + ".";
1111  tempKwl.add(prefix.c_str(),
1112  "x",
1113  theValidImageVertices[i].x,
1114  true);
1115  tempKwl.add(prefix.c_str(),
1116  "y",
1117  theValidImageVertices[i].y,
1118  true);
1119  }
1120
1121  tempKwl.write(tempFile.c_str());
1122  }
1123
1124  if ( tempFile.exists() )
1125  {
1126  return true;
1127  }
1128
1129  return false; // Write of file failed.
1130 }
bool exists() const
Member Data Documentation
◆ m_state
std::shared_ptr<ossim::ImageHandlerState> ossimImageHandler::m_state
protected
Definition at line 856 of file ossimImageHandler.h.
Referenced by initVertices(), and loadMetaData().
◆ theDecimationFactors
std::vector<ossimDpt> ossimImageHandler::theDecimationFactors
protected
◆ theGeometry
ossimRefPtr<ossimImageGeometry> ossimImageHandler::theGeometry
mutableprotected
Definition at line 838 of file ossimImageHandler.h.
Referenced by ossimRangeDomeTileSource::close(), close(), ossimMrSidReader::getDecimationFactor(), ossimMrSidReader::getDecimationFactors(), ossimViirsHandler::getImageGeometry(), ossimQuickbirdTiffTileSource::getImageGeometry(), ossimDoqqTileSource::getImageGeometry(), ossimQbTileFilesHandler::getImageGeometry(), ossimERSTileSource::getImageGeometry(), ossimVideoImageHandler::getImageGeometry(), ossimKakaduJpipHandler::getImageGeometry(), ossimRangeDomeTileSource::getImageGeometry(), ossimVpfTileSource::getImageGeometry(), ossimDtedTileSource::getImageGeometry(), ossimGdalTileSource::getImageGeometry(), ossimAdrgTileSource::getImageGeometry(), ossimGeneralRasterTileSource::getImageGeometry(), ossimUsgsDemTileSource::getImageGeometry(), ossimHdfReader::getImageGeometry(), ossimOpjJp2Reader::getImageGeometry(), ossimJpegTileSource::getImageGeometry(), ossimMG4LidarReader::getImageGeometry(), ossimPointCloudImageHandler::getImageGeometry(), ossimGeoPdfReader::getImageGeometry(), ossimMrSidReader::getImageGeometry(), ossimH5ImageHandler::getImageGeometry(), ossimLasReader::getImageGeometry(), ossimRpfCacheTileSource::getImageGeometry(), ossimKakaduJp2Reader::getImageGeometry(), ossimPngReader::getImageGeometry(), ossimGpkgReader::getImageGeometry(), ossimCibCadrgTileSource::getImageGeometry(), getImageGeometry(), ossimOgrGdalTileSource::getInternalImageGeometry(), ossimRangeDomeTileSource::getNumberOfLines(), ossimPointCloudImageHandler::getNumberOfLines(), ossimRangeDomeTileSource::getNumberOfSamples(), ossimPointCloudImageHandler::getNumberOfSamples(), ossimMrSidReader::getTile(), ossimPointCloudImageHandler::getTile(), ossimRangeDomeTileSource::getTile(), ossimPointCloudImageHandler::getValidImageVertices(), ossimRangeDomeTileSource::initialize(), saveImageGeometry(), ossimHdfReader::setCurrentEntry(), ossimH5ImageHandler::setCurrentEntry(), ossimGdalTileSource::setCurrentEntry(), ossimGeoPdfReader::setCurrentEntry(), ossimNitfTileSource::setCurrentEntry(), ossimGpkgReader::setCurrentEntry(), ossimRpfCacheTileSource::setCurrentEntry(), ossimCibCadrgTileSource::setCurrentEntry(), ossimPointCloudImageHandler::setGSD(), and setImageGeometry().
◆ theImageFile
ossimFilename ossimImageHandler::theImageFile
protected
Definition at line 832 of file ossimImageHandler.h.
Referenced by ossimQbTileFilesHandler::computeImageRects(), createDefaultValidVerticesFilename(), ossimBandSeparateHandler::getBandFileNames(), ossimMrSidReader::getExternalImageGeometry(), ossimGdalTileSource::getExternalImageGeometryFromXml(), getFilename(), ossimMrSidReader::getGeoProjection(), ossimGeneralRasterTileSource::getHdrInfo(), ossimQuickbirdTiffTileSource::getImageGeometry(), ossimQbTileFilesHandler::getImageGeometry(), ossimGeneralRasterTileSource::getImageGeometry(), ossimH5ImageHandler::getLatLonDatasets(), ossimCibCadrgTileSource::getPropertyNames(), ossimKmlSuperOverlayReader::getTopLevelKmlFileInfo(), ossimGeneralRasterTileSource::getXmlInfo(), if(), ossimKakaduJp2Reader::isJp2(), ossimOgrVectorTileSource::isOgrVectorDataSource(), ossimKmlSuperOverlayReader::isOpen(), ossimGeoPdfReader::isOpen(), ossimRpfCacheTileSource::isOpen(), ossimBitMaskTileSource::isSupportedExtension(), ossimHdfReader::isSupportedExtension(), ossimDtedTileSource::loadMetaData(), ossimDtedTileSource::loadState(), ossimVpfTileSource::open(), ossimKmlSuperOverlayReader::open(), ossimPointCloudImageHandler::open(), ossimTiffTileSource::open(), ossimOgrGdalTileSource::open(), ossimRangeDomeTileSource::open(), ossimBitMaskTileSource::open(), ossimJpegTileSource::open(), ossimPngReader::open(), openValidVertices(), ossimTiffTileSource::print(), ossimPngReader::restart(), saveState(), setFilename(), and ossimTiffTileSource::validateMinMaxNull().
◆ theImageID
ossimString ossimImageHandler::theImageID
protected
Definition at line 841 of file ossimImageHandler.h.
◆ theLut
ossimRefPtr<ossimNBandLutDataObject> ossimImageHandler::theLut
protected
◆ theMetaData
ossimImageMetaData ossimImageHandler::theMetaData
protected
◆ theOpenOverviewFlag
bool ossimImageHandler::theOpenOverviewFlag
protected
Definition at line 853 of file ossimImageHandler.h.
Referenced by getOpenOverviewFlag(), and setOpenOverviewFlag().
◆ theOverview
ossimRefPtr<ossimImageHandler> ossimImageHandler::theOverview
protected
Definition at line 835 of file ossimImageHandler.h.
Referenced by close(), closeOverview(), ossimRpfCacheTileSource::deleteAll(), ossimCibCadrgTileSource::deleteAll(), ossimNitfTileSource::destroy(), ossimKakaduJ2kReader::getDecimationFactor(), ossimGdalTileSource::getMaxSize(), ossimKakaduJpipHandler::getNumberOfDecimationLevels(), ossimKakaduNitfReader::getNumberOfDecimationLevels(), ossimOpjJp2Reader::getNumberOfDecimationLevels(), ossimGdalTileSource::getNumberOfDecimationLevels(), ossimMG4LidarReader::getNumberOfDecimationLevels(), ossimMrSidReader::getNumberOfDecimationLevels(), ossimKakaduJp2Reader::getNumberOfDecimationLevels(), ossimKakaduJ2kReader::getNumberOfDecimationLevels(), ossimTiffTileSource::getNumberOfDecimationLevels(), ossimGpkgReader::getNumberOfDecimationLevels(), getNumberOfDecimationLevels(), ossimKakaduJpipHandler::getNumberOfLines(), ossimUsgsDemTileSource::getNumberOfLines(), ossimJpegTileSource::getNumberOfLines(), ossimGdalTileSource::getNumberOfLines(), ossimGpkgReader::getNumberOfLines(), ossimHdf5ImageHandler::getNumberOfLines(), ossimDtedTileSource::getNumberOfLines(), ossimOpjJp2Reader::getNumberOfLines(), ossimPngReader::getNumberOfLines(), ossimH5ImageHandler::getNumberOfLines(), ossimAdrgTileSource::getNumberOfLines(), ossimKakaduNitfReader::getNumberOfLines(), ossimRpfCacheTileSource::getNumberOfLines(), ossimHdfReader::getNumberOfLines(), ossimNitfTileSource::getNumberOfLines(), ossimTiffTileSource::getNumberOfLines(), ossimCibCadrgTileSource::getNumberOfLines(), ossimMG4LidarReader::getNumberOfLines(), ossimGeoPdfReader::getNumberOfLines(), ossimMrSidReader::getNumberOfLines(), ossimKakaduJp2Reader::getNumberOfLines(), ossimKakaduJpipHandler::getNumberOfSamples(), ossimUsgsDemTileSource::getNumberOfSamples(), ossimJpegTileSource::getNumberOfSamples(), ossimGdalTileSource::getNumberOfSamples(), ossimGpkgReader::getNumberOfSamples(), ossimHdf5ImageHandler::getNumberOfSamples(), ossimDtedTileSource::getNumberOfSamples(), ossimOpjJp2Reader::getNumberOfSamples(), ossimH5ImageHandler::getNumberOfSamples(), ossimPngReader::getNumberOfSamples(), ossimAdrgTileSource::getNumberOfSamples(), ossimKakaduNitfReader::getNumberOfSamples(), ossimRpfCacheTileSource::getNumberOfSamples(), ossimNitfTileSource::getNumberOfSamples(), ossimHdfReader::getNumberOfSamples(), ossimTiffTileSource::getNumberOfSamples(), ossimCibCadrgTileSource::getNumberOfSamples(), ossimMG4LidarReader::getNumberOfSamples(), ossimGeoPdfReader::getNumberOfSamples(), ossimMrSidReader::getNumberOfSamples(), ossimKakaduJp2Reader::getNumberOfSamples(), getOverview(), ossimKakaduNitfReader::getOverviewTile(), ossimKakaduJ2kReader::getOverviewTile(), ossimKakaduJp2Reader::getOverviewTile(), getOverviewTile(), ossimGdalTileSource::getTile(), ossimBandSeparateHandler::getTile(), ossimMrSidReader::getTile(), ossimMG4LidarReader::getTile(), ossimTiledImageHandler::getTile(), ossimKakaduJpipHandler::getTileAtRes(), ossimTiffTileSource::isBandSelector(), ossimGeneralRasterTileSource::isBandSelector(), ossimJpegTileSource::isValidRLevel(), ossimRpfCacheTileSource::isValidRLevel(), ossimCibCadrgTileSource::isValidRLevel(), ossimTiffTileSource::print(), ossimHdfReader::setCurrentEntry(), ossimGdalTileSource::setCurrentEntry(), setOutputBandList(), setSupplementaryDirectory(), and ~ossimImageHandler().
◆ theOverviewFile
ossimFilename ossimImageHandler::theOverviewFile
protected
◆ thePixelType
ossimPixelType ossimImageHandler::thePixelType
mutableprotected
◆ theStartingResLevel
ossim_uint32 ossimImageHandler::theStartingResLevel
protected
◆ theSupplementaryDirectory
ossimFilename ossimImageHandler::theSupplementaryDirectory
protected
◆ theValidImageVertices
vector<ossimIpt> ossimImageHandler::theValidImageVertices
protected
