Public Member Functions | Friends | List of all members
ossimImageViewTransform Class Referenceabstract
#include <ossimImageViewTransform.h>
Inheritance diagram for ossimImageViewTransform:
ossim2dTo2dTransform ossimViewInterface ossimObject ossimReferenced ossimImageViewAffineTransform ossimImageViewProjectionTransform
 ossimImageViewTransform ()
virtual void forward (const ossimDpt &input, ossimDpt &output) const
virtual void inverse (const ossimDpt &input, ossimDpt &output) const
virtual bool isIdentity () const =0
virtual bool isValid () const =0
virtual ossimDpt getInputMetersPerPixel () const =0
virtual ossimDpt getOutputMetersPerPixel () const =0
virtual void getImageToViewScale (ossimDpt &resultScale, const ossimDpt &imagePoint, const ossimDpt &deltaImagePointXY) const
virtual void getViewToImageScale (ossimDpt &resultScale, const ossimDpt &imagePoint, const ossimDpt &deltaImagePointXY) const
virtual void imageToView (const ossimDpt &imagePoint, ossimDpt &viewPoint) const
virtual void viewToImage (const ossimDpt &viewPoint, ossimDpt &imagePoint) const
 Generic print method. More...
ossimDpt imageToView (const ossimDpt &imagePoint) const
ossimDpt viewToImage (const ossimDpt &viewPoint) const
virtual void getScaleChangeImageToView (ossimDpt &result, const ossimDrect &imageRect)
virtual void getScaleChangeViewToImage (ossimDpt &result, const ossimDrect &viewRect)
virtual void getRoundTripErrorView (ossimDpt &result, const ossimDpt &viewPt) const
virtual ossimDpt getRoundTripErrorView (const ossimDpt &viewPt) const
virtual void getRoundTripErrorImage (ossimDpt &result, const ossimDpt &imagePt) const
virtual ossimDpt getRoundTripErrorImage (const ossimDpt &imagePt) const
virtual ossimDrect getImageToViewBounds (const ossimDrect &imageRect) const
 Computes the bounding rect in view space of the quad formed by the transformed image points of the input rect corners. More...
virtual ossimDrect getViewToImageBounds (const ossimDrect &viewRect) const
 Computes the bounding rect in image space of the quad formed by the transformed view points of the input rect corners. More...
- Public Member Functions inherited from ossim2dTo2dTransform
virtual void forward (ossimDpt &modify_this) const
virtual void inverse (ossimDpt &modify_this) const
virtual const ossim2dTo2dTransformoperator= (const ossim2dTo2dTransform &rhs)
virtual ossimDpt getOrigin () const
void setConvergenceThreshold (const double &new_threshold)
void setMaxIterations (int new_max_iters)
void setDxDy (const ossimDpt &dxdy)
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
- Public Member Functions inherited from ossimViewInterface
 ossimViewInterface ()
 ossimViewInterface (ossimObject *base)
virtual ~ossimViewInterface ()
virtual bool setView (ossimObject *baseObject)=0
virtual ossimObjectgetView ()=0
virtual const ossimObjectgetView () const =0
virtual void refreshView ()
ossimObjectgetBaseObject ()
Friends
OSSIMDLLEXPORT ostream & operator<< (ostream &out, const ossimImageViewTransform &data)
Additional Inherited Members
- Protected Member Functions inherited from ossim2dTo2dTransform
 ossim2dTo2dTransform ()
virtual ~ossim2dTo2dTransform ()
virtual ~ossimReferenced ()
- Protected Attributes inherited from ossim2dTo2dTransform
double theConvergenceThreshold
int theMaxIterations
ossimDpt theDxDy
- Protected Attributes inherited from ossimViewInterface
ossimObjecttheObject
Detailed Description
Definition at line 25 of file ossimImageViewTransform.h.
◆ ossimImageViewTransform()
ossimImageViewTransform::ossimImageViewTransform ( )
Member Function Documentation
◆ forward()
void ossimImageViewTransform::forward ( const ossimDpt input,
ossimDpt output
) const
virtual
Implements ossim2dTo2dTransform.
Definition at line 17 of file ossimImageViewTransform.cpp.
References imageToView().
19 {
20  imageToView(input, output);
21 }
virtual void imageToView(const ossimDpt &imagePoint, ossimDpt &viewPoint) const
◆ getImageToViewBounds()
ossimDrect ossimImageViewTransform::getImageToViewBounds ( const ossimDrect imageRect) const
virtual
Reimplemented in ossimImageViewProjectionTransform.
Definition at line 294 of file ossimImageViewTransform.cpp.
References imageToView(), ossimDrect::ll(), ossimDrect::lr(), ossimDrect::ul(), and ossimDrect::ur().
Referenced by ossimImageViewProjectionTransform::getImageToViewBounds(), and ossimImageRenderer::initializeBoundingRects().
295 {
296  ossimDpt p1;
297  ossimDpt p2;
298  ossimDpt p3;
299  ossimDpt p4;
300
301  imageToView(imageRect.ul(), p1);
302  imageToView(imageRect.ur(), p2);
303  imageToView(imageRect.lr(), p3);
304  imageToView(imageRect.ll(), p4);
305
306  return ossimDrect(p1, p2, p3, p4);
307 }
const ossimDpt & ul() const
Definition: ossimDrect.h:339
const ossimDpt & ur() const
Definition: ossimDrect.h:340
const ossimDpt & ll() const
Definition: ossimDrect.h:342
const ossimDpt & lr() const
Definition: ossimDrect.h:341
◆ getImageToViewScale()
void ossimImageViewTransform::getImageToViewScale ( ossimDpt resultScale,
const ossimDpt imagePoint,
const ossimDpt deltaImagePointXY
) const
virtual
If it needs to it will use the information passed in to get the scae factor by transforming the line point.x to point.x+deltaXY and point.y to point.y + deltaXY.y. It will comput new delta's and set the ratio of deltaXY/newDeltaXY to the result scale.
Derived classes can overide this default implementation. Note: if the scale changes are only subpixel then it will return a scale of one. We have to see how this works before we actually keep this implementation.
Definition at line 214 of file ossimImageViewTransform.cpp.
References FLT_EPSILON, imageToView(), ossimDpt::x, and ossimDpt::y.
217 {
218  ossimDpt p1 = imagePoint;
219  ossimDpt p2(imagePoint.x + deltaImagePointXY.x,
220  imagePoint.y);
221  ossimDpt p3(imagePoint.x,
222  imagePoint.y + deltaImagePointXY.y);
223
224  ossimDpt transformedP1;
225  ossimDpt transformedP2;
226  ossimDpt transformedP3;
227
228  imageToView(p1, transformedP1);
229  imageToView(p2, transformedP2);
230  imageToView(p3, transformedP3);
231
232  ossimDpt deltaP1P2 = transformedP1 - transformedP2;
233  ossimDpt deltaP1P3 = transformedP1 - transformedP3;
234
235  // now compute the distances.
236  double sumSquaredSqrtP1P2 = sqrt((deltaP1P2.x*deltaP1P2.x) +
237  (deltaP1P2.y*deltaP1P2.y));
238  double sumSquaredSqrtP1P3 = sqrt((deltaP1P3.x*deltaP1P3.x) +
239  (deltaP1P3.y*deltaP1P3.y));
240
241  resultScale.x = 0;
242  resultScale.y = 0;
243
244  if(sumSquaredSqrtP1P2 > FLT_EPSILON)
245  {
246  resultScale.x = sumSquaredSqrtP1P2/deltaImagePointXY.x;
247  }
248  if(sumSquaredSqrtP1P3 > FLT_EPSILON)
249  {
250  resultScale.y = sumSquaredSqrtP1P3/deltaImagePointXY.y;
251  }
252 }
double y
Definition: ossimDpt.h:165
#define FLT_EPSILON
double x
Definition: ossimDpt.h:164
◆ getInputMetersPerPixel()
virtual ossimDpt ossimImageViewTransform::getInputMetersPerPixel ( ) const
pure virtual
◆ getOutputMetersPerPixel()
virtual ossimDpt ossimImageViewTransform::getOutputMetersPerPixel ( ) const
pure virtual
◆ getRoundTripErrorImage() [1/2]
void ossimImageViewTransform::getRoundTripErrorImage ( ossimDpt result,
const ossimDpt imagePt
) const
virtual
Definition at line 92 of file ossimImageViewTransform.cpp.
References ossimDpt::hasNans(), imageToView(), ossimDpt::makeNan(), and viewToImage().
94 {
95  ossimDpt ipt;
96  ossimDpt vpt;
97  imageToView(imagePt, vpt);
98  if(vpt.hasNans())
99  {
100  ipt.makeNan();
101  }
102  else
103  {
104  viewToImage(vpt, ipt);
105  }
106
107  if(ipt.hasNans())
108  {
109  result.makeNan();
110  }
111  else
112  {
113  result = imagePt-ipt;
114  }
115
116 // result = ossimDpt(0,0);
117 }
bool hasNans() const
Definition: ossimDpt.h:67
void makeNan()
Definition: ossimDpt.h:65
virtual void viewToImage(const ossimDpt &viewPoint, ossimDpt &imagePoint) const
◆ getRoundTripErrorImage() [2/2]
ossimDpt ossimImageViewTransform::getRoundTripErrorImage ( const ossimDpt imagePt) const
virtual
Definition at line 119 of file ossimImageViewTransform.cpp.
References getRoundTripErrorView().
120 {
121  ossimDpt result;
122  getRoundTripErrorView(result, imagePt);
123  return result;
124 }
virtual void getRoundTripErrorView(ossimDpt &result, const ossimDpt &viewPt) const
◆ getRoundTripErrorView() [1/2]
void ossimImageViewTransform::getRoundTripErrorView ( ossimDpt result,
const ossimDpt viewPt
) const
virtual
Definition at line 59 of file ossimImageViewTransform.cpp.
Referenced by getRoundTripErrorImage(), and getRoundTripErrorView().
61 {
62  ossimDpt ipt;
63  ossimDpt vpt;
64  viewToImage(viewPt, ipt);
65  if(ipt.hasNans())
66  {
67  vpt.makeNan();
68  }
69  else
70  {
71  imageToView(ipt, vpt);
72  }
73
74  if(vpt.hasNans())
75  {
76  result.makeNan();
77  }
78  else
79  {
80  result = viewPt-vpt;
81  }
82  // result = ossimDpt(0,0);
83 }
void makeNan()
◆ getRoundTripErrorView() [2/2]
ossimDpt ossimImageViewTransform::getRoundTripErrorView ( const ossimDpt viewPt) const
virtual
Definition at line 85 of file ossimImageViewTransform.cpp.
86 {
87  ossimDpt result;
88  getRoundTripErrorView(result, viewPt);
89  return result;
90 }
◆ getScaleChangeImageToView()
void ossimImageViewTransform::getScaleChangeImageToView ( ossimDpt result,
virtual
This should compute output/input.
Definition at line 138 of file ossimImageViewTransform.cpp.
References ossimDpt::hasNans(), ossimDrect::hasNans(), ossimDrect::height(), imageToView(), ossimDrect::ll(), ossimDrect::lr(), ossimDpt::makeNan(), ossimDrect::ul(), ossimDrect::ur(), ossimDrect::width(), ossimDpt::x, and ossimDpt::y.
140 {
141  result.makeNan();
142  if(!imageRect.hasNans())
143  {
144  ossimDpt vul;
145  ossimDpt vur;
146  ossimDpt vlr;
147  ossimDpt vll;
148
149  imageToView(imageRect.ul(),
150  vul);
151  imageToView(imageRect.ur(),
152  vur);
153  imageToView(imageRect.lr(),
154  vlr);
155  imageToView(imageRect.ll(),
156  vll);
157
158  if(!vul.hasNans()&&
159  !vur.hasNans()&&
160  !vlr.hasNans()&&
161  !vll.hasNans())
162  {
163
164  double deltaTop = (vul - vur).length();
165  double deltaBottom = (vll - vlr).length();
166  double deltaRight = (vur - vlr).length();
167
168  double w = imageRect.width();
169  double h = imageRect.height();
170  result.x = (deltaTop/w + deltaBottom/w)*.5;
171  result.y = (deltaRight/h + deltaRight/h)*.5;
172  }
173  }
174 }
ossim_float64 width() const
Definition: ossimDrect.h:522
double y
Definition: ossimDrect.h:396
ossim_float64 height() const
Definition: ossimDrect.h:517
double x
void makeNan()
◆ getScaleChangeViewToImage()
void ossimImageViewTransform::getScaleChangeViewToImage ( ossimDpt result,
const ossimDrect viewRect
virtual
Definition at line 176 of file ossimImageViewTransform.cpp.
178 {
179  result.makeNan();
180  if(!viewRect.hasNans())
181  {
182  ossimDpt iul;
183  ossimDpt iur;
184  ossimDpt ilr;
185  ossimDpt ill;
186
187  imageToView(viewRect.ul(),
188  iul);
189  imageToView(viewRect.ur(),
190  iur);
191  imageToView(viewRect.lr(),
192  ilr);
193  imageToView(viewRect.ll(),
194  ill);
195
196  if(!iul.hasNans()&&
197  !iur.hasNans()&&
198  !ilr.hasNans()&&
199  !ill.hasNans())
200  {
201
202  double deltaTop = (iul - iur).length();
203  double deltaBottom = (ill - ilr).length();
204  double deltaRight = (iur - ilr).length();
205
206  double w = viewRect.width();
207  double h = viewRect.height();
208  result.x = (deltaTop/w + deltaBottom/w)*.5;
209  result.y = (deltaRight/h + deltaRight/h)*.5;
210  }
211  }
212 }
double y
double x
void makeNan()
◆ getViewToImageBounds()
ossimDrect ossimImageViewTransform::getViewToImageBounds ( const ossimDrect viewRect) const
virtual
Definition at line 309 of file ossimImageViewTransform.cpp.
References ossimDrect::ll(), ossimDrect::lr(), ossimDrect::ul(), ossimDrect::ur(), and viewToImage().
310 {
311  ossimDpt p1;
312  ossimDpt p2;
313  ossimDpt p3;
314  ossimDpt p4;
315
316  viewToImage(viewRect.ul(), p1);
317  viewToImage(viewRect.ur(), p2);
318  viewToImage(viewRect.lr(), p3);
319  viewToImage(viewRect.ll(), p4);
320
321  return ossimDrect(p1, p2, p3, p4);
322 }
◆ getViewToImageScale()
void ossimImageViewTransform::getViewToImageScale ( ossimDpt resultScale,
) const
virtual
Definition at line 254 of file ossimImageViewTransform.cpp.
References FLT_EPSILON, viewToImage(), ossimDpt::x, and ossimDpt::y.
257 {
258  ossimDpt p1 = viewPoint;
259  ossimDpt p2(viewPoint.x + deltaViewPointXY.x,
260  viewPoint.y);
261  ossimDpt p3(viewPoint.x,
262  viewPoint.y + deltaViewPointXY.y);
263
264  ossimDpt transformedP1;
265  ossimDpt transformedP2;
266  ossimDpt transformedP3;
267
268  viewToImage(p1, transformedP1);
269  viewToImage(p2, transformedP2);
270  viewToImage(p3, transformedP3);
271
272  ossimDpt deltaP1P2 = transformedP1 - transformedP2;
273  ossimDpt deltaP1P3 = transformedP1 - transformedP3;
274
275  // now compute the distances.
276  double sumSquaredSqrtP1P2 = sqrt((deltaP1P2.x*deltaP1P2.x) +
277  (deltaP1P2.y*deltaP1P2.y));
278  double sumSquaredSqrtP1P3 = sqrt((deltaP1P3.x*deltaP1P3.x) +
279  (deltaP1P3.y*deltaP1P3.y));
280
281  resultScale.x = 0;
282  resultScale.y = 0;
283
284  if(sumSquaredSqrtP1P2 > FLT_EPSILON)
285  {
286  resultScale.x = sumSquaredSqrtP1P2/deltaViewPointXY.x;
287  }
288  if(sumSquaredSqrtP1P3 > FLT_EPSILON)
289  {
290  resultScale.y = sumSquaredSqrtP1P3/deltaViewPointXY.y;
291  }
292 }
double y
#define FLT_EPSILON
double x
◆ imageToView() [1/2]
void ossimImageViewTransform::imageToView ( const ossimDpt imagePoint,
ossimDpt viewPoint
) const
virtual
◆ imageToView() [2/2]
ossimDpt ossimImageViewTransform::imageToView ( const ossimDpt imagePoint) const
Definition at line 41 of file ossimImageViewTransform.cpp.
42 {
43  ossimDpt tempPt;
44
45  imageToView(imagePoint, tempPt);
46
47  return tempPt;
48 }
◆ inverse()
void ossimImageViewTransform::inverse ( const ossimDpt input,
ossimDpt output
) const
virtual
Reimplemented from ossim2dTo2dTransform.
Definition at line 23 of file ossimImageViewTransform.cpp.
References viewToImage().
25 {
26  viewToImage(input, output);
27 }
◆ isIdentity()
virtual bool ossimImageViewTransform::isIdentity ( ) const
pure virtual
derived classes will specify if the imageViewTransform is an identity.
Implemented in ossimImageViewAffineTransform, and ossimImageViewProjectionTransform.
◆ isValid()
virtual bool ossimImageViewTransform::isValid ( ) const
pure virtual
◆ loadState()
bool ossimImageViewTransform::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Reimplemented in ossimImageViewAffineTransform, and ossimImageViewProjectionTransform.
Definition at line 126 of file ossimImageViewTransform.cpp.
References ossim2dTo2dTransform::loadState().
Referenced by ossimImageViewTransformFactory::createTransform(), ossimImageViewProjectionTransform::loadState(), and ossimImageViewAffineTransform::loadState().
128 {
129  return ossim2dTo2dTransform::loadState(kwl, prefix);
130 }
◆ print()
std::ostream & ossimImageViewTransform::print ( std::ostream &  out) const
virtual
Derived classes should re-implement as they see fit.
Returns
std::ostream&
Definition at line 324 of file ossimImageViewTransform.cpp.
Referenced by operator<<().
325 {
326  return out;
327 }
◆ saveState()
bool ossimImageViewTransform::saveState ( ossimKeywordlist kwl,
) const
virtual
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 132 of file ossimImageViewTransform.cpp.
References ossim2dTo2dTransform::saveState().
Referenced by ossimImageRenderer::saveState(), ossimImageViewProjectionTransform::saveState(), and ossimImageViewAffineTransform::saveState().
134 {
135  return ossim2dTo2dTransform::saveState(kwl, prefix);
136 }
◆ viewToImage() [1/2]
void ossimImageViewTransform::viewToImage ( const ossimDpt viewPoint,
ossimDpt imagePoint
) const
virtual
◆ viewToImage() [2/2]
ossimDpt ossimImageViewTransform::viewToImage ( const ossimDpt viewPoint) const
Definition at line 50 of file ossimImageViewTransform.cpp.
51 {
52  ossimDpt tempPt;
53
54  viewToImage(viewPoint, tempPt);
55
56  return tempPt;
57 }
◆ operator<<
OSSIMDLLEXPORT ostream& operator<< ( ostream &  out,
const ossimImageViewTransform data
friend
