ossimImageViewProjectionTransform Class Reference
#include <ossimImageViewProjectionTransform.h>
Inheritance diagram for ossimImageViewProjectionTransform:
ossimImageViewTransform ossim2dTo2dTransform ossimViewInterface ossimObject ossimReferenced
Public Member Functions
 ossimImageViewProjectionTransform (ossimImageGeometry *imageGeometry=0, ossimImageGeometry *viewGeometry=0)
 ossimImageViewProjectionTransform (const ossimImageViewProjectionTransform &src)
 copy constructor More...
virtual ~ossimImageViewProjectionTransform ()
virtual bool isValid () const
 Satisfies base class pure virtual. Returns TRUE if both input and output geoms exist. More...
virtual bool isIdentity () const
 Returns TRUE if both input and output geometries are identical. More...
void setViewGeometry (ossimImageGeometry *g)
 Assigns the geometry to use for output view. This object does NOT own the geometry. More...
void setImageGeometry (ossimImageGeometry *g)
 Assigns the geometry to use for input image. This object does NOT own the geometry. More...
virtual void imageToView (const ossimDpt &imagePoint, ossimDpt &viewPoint) const
 Workhorse of the object. Converts image-space to view-space. More...
virtual void viewToImage (const ossimDpt &viewPoint, ossimDpt &imagePoint) const
 Other workhorse of the object. Converts view-space to image-space. More...
 Dumps contents to stream. More...
ossimImageGeometrygetImageGeometry ()
ossimImageGeometrygetViewGeometry ()
const ossimImageGeometrygetImageGeometry () const
const ossimImageGeometrygetViewGeometry () const
virtual void getViewSegments (std::vector< ossimDrect > &viewBounds, ossimPolyArea2d &polyArea, ossim_uint32 numberOfEdgePoints=25) const
 Because of the fact we can have dateline crossings there exist on the view plane both positive and negative bounds. More...
virtual bool setView (ossimObject *baseObject)
 This is used a a general access point for setting a view to a chain. More...
virtual ossimObjectgetView ()
virtual const ossimObjectgetView () const
virtual ossimDpt getInputMetersPerPixel () const
 Returns the GSD of input image. More...
virtual ossimDpt getOutputMetersPerPixel () const
 Returns the GSD of the output view. More...
virtual ossimDrect getImageToViewBounds (const ossimDrect &imageRect) const
 Gets the image bounding rect in view-space coordinates. More...
 After rewrite for incorporating ossimImageGeometry: No longer needed. More...
- Public Member Functions inherited from ossimImageViewTransform
 ossimImageViewTransform ()
virtual void forward (const ossimDpt &input, ossimDpt &output) const
virtual void inverse (const ossimDpt &input, ossimDpt &output) const
virtual void getImageToViewScale (ossimDpt &resultScale, const ossimDpt &imagePoint, const ossimDpt &deltaImagePointXY) const
virtual void getViewToImageScale (ossimDpt &resultScale, const ossimDpt &imagePoint, const ossimDpt &deltaImagePointXY) const
ossimDpt imageToView (const ossimDpt &imagePoint) const
ossimDpt viewToImage (const ossimDpt &viewPoint) const
virtual void getScaleChangeImageToView (ossimDpt &result, const ossimDrect &imageRect)
virtual void getScaleChangeViewToImage (ossimDpt &result, const ossimDrect &viewRect)
virtual void getRoundTripErrorView (ossimDpt &result, const ossimDpt &viewPt) const
virtual ossimDpt getRoundTripErrorView (const ossimDpt &viewPt) const
virtual void getRoundTripErrorImage (ossimDpt &result, const ossimDpt &imagePt) const
virtual ossimDpt getRoundTripErrorImage (const ossimDpt &imagePt) const
virtual ossimDrect getViewToImageBounds (const ossimDrect &viewRect) const
 Computes the bounding rect in image space of the quad formed by the transformed view points of the input rect corners. More...
- Public Member Functions inherited from ossim2dTo2dTransform
virtual void forward (ossimDpt &modify_this) const
virtual void inverse (ossimDpt &modify_this) const
virtual const ossim2dTo2dTransformoperator= (const ossim2dTo2dTransform &rhs)
virtual ossimDpt getOrigin () const
void setConvergenceThreshold (const double &new_threshold)
void setMaxIterations (int new_max_iters)
void setDxDy (const ossimDpt &dxdy)
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
- Public Member Functions inherited from ossimViewInterface
 ossimViewInterface ()
 ossimViewInterface (ossimObject *base)
virtual ~ossimViewInterface ()
virtual void refreshView ()
ossimObjectgetBaseObject ()
Protected Member Functions
bool initializeViewSize ()
 Initializes the view geometry image size from image geometry bounding rect. More...
void initializeDatelineCrossing ()
- Protected Member Functions inherited from ossim2dTo2dTransform
 ossim2dTo2dTransform ()
virtual ~ossim2dTo2dTransform ()
virtual ~ossimReferenced ()
Protected Attributes
ossimRefPtr< ossimImageGeometrym_imageGeometry
ossimRefPtr< ossimImageGeometrym_viewGeometry
bool m_crossesDateline
- Protected Attributes inherited from ossim2dTo2dTransform
double theConvergenceThreshold
int theMaxIterations
ossimDpt theDxDy
- Protected Attributes inherited from ossimViewInterface
ossimObjecttheObject
Detailed Description
Definition at line 25 of file ossimImageViewProjectionTransform.h.
◆ ossimImageViewProjectionTransform() [1/2]
ossimImageViewProjectionTransform::ossimImageViewProjectionTransform ( ossimImageGeometry imageGeometry = 0,
ossimImageGeometry viewGeometry = 0
Definition at line 38 of file ossimImageViewProjectionTransform.cpp.
39 : m_imageGeometry(imageGeometry),
40  m_viewGeometry(viewGeometry),
41  m_crossesDateline(false)
42 {
43 }
ossimRefPtr< ossimImageGeometry > m_imageGeometry
ossimRefPtr< ossimImageGeometry > m_viewGeometry
◆ ossimImageViewProjectionTransform() [2/2]
ossimImageViewProjectionTransform::ossimImageViewProjectionTransform ( const ossimImageViewProjectionTransform src)
◆ ~ossimImageViewProjectionTransform()
ossimImageViewProjectionTransform::~ossimImageViewProjectionTransform ( )
virtual
Definition at line 60 of file ossimImageViewProjectionTransform.cpp.
61 {
62 }
Member Function Documentation
◆ dup()
virtual ossimObject* ossimImageViewProjectionTransform::dup ( ) const
inlinevirtual
Definition at line 34 of file ossimImageViewProjectionTransform.h.
34 { return new ossimImageViewProjectionTransform(*this); }
ossimImageViewProjectionTransform(ossimImageGeometry *imageGeometry=0, ossimImageGeometry *viewGeometry=0)
◆ getImageGeometry() [1/2]
ossimImageGeometry* ossimImageViewProjectionTransform::getImageGeometry ( )
inline
◆ getImageGeometry() [2/2]
const ossimImageGeometry* ossimImageViewProjectionTransform::getImageGeometry ( ) const
inline
Definition at line 61 of file ossimImageViewProjectionTransform.h.
61 { return m_imageGeometry.get(); }
◆ getImageToViewBounds()
ossimDrect ossimImageViewProjectionTransform::getImageToViewBounds ( const ossimDrect imageRect) const
virtual
Reimplemented from ossimImageViewTransform.
Definition at line 417 of file ossimImageViewProjectionTransform.cpp.
References ossimGpt::datum(), ossimProjection::getGroundClipPoints(), ossimImageViewTransform::getImageToViewBounds(), ossimImageGeometry::getProjection(), ossimGeoPolygon::getVertexList(), ossimDrect::hasNans(), ossimImageGeometry::hasProjection(), ossimDrect::ll(), ossimImageGeometry::localToWorld(), ossimDrect::lr(), m_imageGeometry, m_viewGeometry, ossimProjection::origin(), ossimGeoPolygon::size(), ossimDrect::ul(), ossimDrect::ur(), ossimRefPtr< T >::valid(), and ossimImageGeometry::worldToLocal().
Referenced by initializeViewSize().
418 {
419  // Let base class try:
421
422  // If not successful, compute using input and output geometries:
423  if (result.hasNans() && m_imageGeometry.valid() && m_viewGeometry.valid() &&
425  {
426  ossimGeoPolygon viewClip;
428  if(viewClip.size())
429  {
430  std::vector<ossimGpt> imageGpts(4);
431  m_imageGeometry->localToWorld(imageRect.ul(), imageGpts[0]);
432  m_imageGeometry->localToWorld(imageRect.ur(), imageGpts[1]);
433  m_imageGeometry->localToWorld(imageRect.lr(), imageGpts[2]);
434  m_imageGeometry->localToWorld(imageRect.ll(), imageGpts[3]);
435
436  const ossimDatum* viewDatum = m_viewGeometry->getProjection()->origin().datum();
437  imageGpts[0].changeDatum(viewDatum);
438  imageGpts[1].changeDatum(viewDatum);
439  imageGpts[2].changeDatum(viewDatum);
440  imageGpts[3].changeDatum(viewDatum);
441
442  ossimPolyArea2d viewPolyArea(viewClip.getVertexList());
443  ossimPolyArea2d imagePolyArea(imageGpts);
444  viewPolyArea &= imagePolyArea;
445  std::vector<ossimPolygon> visiblePolygons;
446  viewPolyArea.getVisiblePolygons(visiblePolygons);
447  if(visiblePolygons.size())
448  {
449  std::vector<ossimDpt> vpts;
450  ossim_uint32 idx = 0;
451  for(idx=0; idx<visiblePolygons[0].getNumberOfVertices();++idx)
452  {
453  ossimDpt tempPt;
454  ossimGpt gpt(visiblePolygons[0][idx].lat, visiblePolygons[0][idx].lon, 0.0, viewDatum);
455  m_viewGeometry->worldToLocal(gpt, tempPt);
456  vpts.push_back(tempPt);
457  }
458  result = ossimDrect(vpts);
459  }
460  }
461  }
462  return result;
463 }
bool valid() const
Definition: ossimRefPtr.h:75
const ossimDpt & ul() const
Definition: ossimDrect.h:339
const ossimDatum * datum() const
datum().
Definition: ossimGpt.h:196
virtual void getGroundClipPoints(ossimGeoPolygon &gpts) const
virtual ossimDrect getImageToViewBounds(const ossimDrect &imageRect) const
Computes the bounding rect in view space of the quad formed by the transformed image points of the in...
bool localToWorld(const ossimDpt &local_pt, ossimGpt &world_pt) const
Exposes the 3D projection from image to world coordinates.
unsigned int ossim_uint32
const std::vector< ossimGpt > & getVertexList() const
bool hasNans() const
Definition: ossimDrect.h:396
ossim_uint32 size() const
virtual ossimGpt origin() const =0
const ossimDpt & ur() const
Definition: ossimDrect.h:340
bool hasProjection() const
Returns TRUE if valid projection defined.
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
const ossimDpt & ll() const
Definition: ossimDrect.h:342
const ossimDpt & lr() const
Definition: ossimDrect.h:341
◆ getInputMetersPerPixel()
ossimDpt ossimImageViewProjectionTransform::getInputMetersPerPixel ( ) const
virtual
Implements ossimImageViewTransform.
Definition at line 515 of file ossimImageViewProjectionTransform.cpp.
References ossimProjection::getMetersPerPixel(), ossimImageGeometry::getProjection(), ossimImageGeometry::hasProjection(), m_imageGeometry, ossimDpt::makeNan(), and ossimRefPtr< T >::valid().
516 {
517  ossimDpt result;
518
521  else
522  result.makeNan();
523
524  return result;
525 }
bool valid() const
virtual ossimDpt getMetersPerPixel() const =0
void makeNan()
Definition: ossimDpt.h:65
◆ getOutputMetersPerPixel()
ossimDpt ossimImageViewProjectionTransform::getOutputMetersPerPixel ( ) const
virtual
Definition at line 530 of file ossimImageViewProjectionTransform.cpp.
References ossimProjection::getMetersPerPixel(), ossimImageGeometry::getProjection(), ossimImageGeometry::hasProjection(), m_viewGeometry, ossimDpt::makeNan(), and ossimRefPtr< T >::valid().
531 {
532  ossimDpt result;
533
536  else
537  result.makeNan();
538
539  return result;
540 }
bool valid() const
void makeNan()
◆ getView() [1/2]
virtual ossimObject* ossimImageViewProjectionTransform::getView ( )
inlinevirtual
Implements ossimViewInterface.
Definition at line 90 of file ossimImageViewProjectionTransform.h.
90 { return m_viewGeometry.get(); }
◆ getView() [2/2]
virtual const ossimObject* ossimImageViewProjectionTransform::getView ( ) const
inlinevirtual
Definition at line 91 of file ossimImageViewProjectionTransform.h.
91 { return m_viewGeometry.get(); }
◆ getViewGeometry() [1/2]
ossimImageGeometry* ossimImageViewProjectionTransform::getViewGeometry ( )
inline
◆ getViewGeometry() [2/2]
const ossimImageGeometry* ossimImageViewProjectionTransform::getViewGeometry ( ) const
inline
Definition at line 62 of file ossimImageViewProjectionTransform.h.
62 { return m_viewGeometry.get(); }
◆ getViewSegments()
void ossimImageViewProjectionTransform::getViewSegments ( std::vector< ossimDrect > &  viewBounds,
ossimPolyArea2d polyArea,
ossim_uint32  numberOfEdgePoints = 25
) const
virtual
We need a generalized interface that allows us to calculate the valid bounds of an image transformed to the view.
Parameters
viewBoundsReturns bounds for each segment
polyAreaReturns the polygons for each segment.
numberOfEdgePointsIf the value is 0 it will do a standard bounds check. If the paramter is greater than 0 this will only be used if the input projection is affected by elevation. If it's not affected by elevation then the default bounds will be calculated.
Definition at line 189 of file ossimImageViewProjectionTransform.cpp.
References ossimPolyArea2d::add(), ossimPolyArea2d::clear(), ossimPolygon::clear(), ossimPolygon::clipToRect(), ossimImageGeometry::getBoundingRect(), ossimImageGeometry::getImageEdgePoints(), ossimDpt::hasNans(), imageToView(), ossimImageGeometry::isAffectedByElevation(), ossimGpt::isLatNan(), ossimGpt::isLonNan(), ossimDrect::ll(), ossimImageGeometry::localToWorld(), ossimGpt::lond(), ossimDrect::lr(), m_crossesDateline, m_imageGeometry, m_viewGeometry, ossimDrect::midPoint(), ossim::sgn(), ossimDrect::ul(), ossimDrect::ur(), ossimRefPtr< T >::valid(), and ossimImageGeometry::worldToLocal().
Referenced by ossimImageRenderer::initializeBoundingRects().
192 {
193  ossimDrect imageRect;
194  ossimDrect worldRect(ossimDpt(-180,-90),
195  ossimDpt(-180,90),
196  ossimDpt(180,90),
197  ossimDpt(180,-90));
198  viewBounds.clear();
199  polyArea.clear();
200
201  if(m_imageGeometry.valid())
202  {
203  m_imageGeometry->getBoundingRect(imageRect);
204  ossim_uint32 idx=0;
205  std::vector<ossimDpt> points;
206  std::vector<ossimGpt> gPoints;
207  bool affectedByElevation = m_imageGeometry->isAffectedByElevation();
208
209
210  if((numberOfEdgePoints > 2)&&(affectedByElevation))
211  {
212  m_imageGeometry->getImageEdgePoints(points, numberOfEdgePoints);
213  }
214  else
215  {
216  points.resize(4);
217
218  points[0] = imageRect.ul();
219  points[1] = imageRect.ur();
220  points[2] = imageRect.lr();
221  points[3] = imageRect.ll();
222  }
224  {
225  ossimDpt testPt;
226  ossimGpt cg;
227  m_imageGeometry->localToWorld(imageRect.midPoint(), cg);
228  ossim_int32 sgn = static_cast<ossim_int32>(ossim::sgn(cg.lond()));
229  std::vector<ossimPolygon> polyList;
230  for(idx=0; idx < points.size();++idx)
231  {
232  ossimGpt testGpt;
233  m_imageGeometry->localToWorld(points[idx], testGpt);
234
235  if(!testGpt.isLatNan()&&!testGpt.isLonNan())
236  {
237  gPoints.push_back(testGpt);
238  }
239  }
240
241  // first we get the list of ground points initialized
242  // and shifted to one side of the full world rect
243  // We will do the other side next
244  //
245  for(idx=0; idx < gPoints.size();++idx)
246  {
247  if(std::fabs(gPoints[idx].lond()-cg.lond()) > 180)
248  {
249  gPoints[idx].lond(gPoints[idx].lond()+sgn*360);
250  }
251  }
252
253  // now clip the ground list to the full ground rect
254  //
255  ossimPolygon tempPoly(gPoints);
256  tempPoly.clipToRect(polyList, worldRect);
257
258  ossim_uint32 pointListIdx=0;
259
260  // Loop through the clipped polygons and find their
261  // view projection. We will add this to the view
262  // bounds and we will add to the poly Area. Poly Area
263  // is used for a tighter clip.
264  //
265  for(pointListIdx=0;pointListIdx<polyList.size();++pointListIdx)
266  {
267  const std::vector<ossimDpt>& clipPoints = polyList[pointListIdx].getVertexList();
268  points.clear();
269  for(idx = 0; idx<clipPoints.size(); ++idx)
270  {
271  m_viewGeometry->worldToLocal(ossimGpt(clipPoints[idx]), testPt);
272  if(!testPt.hasNans())
273  {
274  points.push_back(testPt);
275  }
276  }
277  viewBounds.push_back(ossimDrect(points));
278
279  if (points.size() >= 4)
280  {
281  points.push_back(points[0]);
282  polyArea.add(ossimPolyArea2d(points));//ossimPolygon(points)));
283  }
284  }
285
286  // now shift the ground points to the other side of the world rect
287  //
288  for(idx=0; idx < gPoints.size();++idx)
289  {
290  gPoints[idx].lond(gPoints[idx].lond()+(-sgn*360));
291  }
292
293  // Now we will do the same thing to the other side of the world
294  // and find the view projection and add those to the poly area
295  // and the view rect
296  //
297  tempPoly = gPoints;
298  polyList.clear();
299  tempPoly.clipToRect(polyList, worldRect);
300
301  for(pointListIdx=0;pointListIdx<polyList.size();++pointListIdx)
302  {
303  const std::vector<ossimDpt>& clipPoints = polyList[pointListIdx].getVertexList();
304  points.clear();
305  for(idx = 0; idx<clipPoints.size(); ++idx)
306  {
307  m_viewGeometry->worldToLocal(ossimGpt(clipPoints[idx]), testPt);
308  if(!testPt.hasNans())
309  {
310  points.push_back(testPt);
311  }
312  }
313  viewBounds.push_back(ossimDrect(points));
314  if (points.size() >= 4)
315  {
316  points.push_back(points[0]);
317  polyArea.add(ossimPolyArea2d(points));//ossimPolygon(points)));
318  }
319
320  }
321  }// end: if(m_crossesDateline)
322  else
323  {
324  ossimDpt testPoint;
325  std::vector<ossimDpt> vpoints;
326
327  for(idx=0; idx < points.size();++idx)
328  {
329  ossimDpt testDpt;
330  imageToView(points[idx], testDpt);
331  if(!testDpt.hasNans())
332  {
333  vpoints.push_back(testDpt);
334  }
335  }
336
337  if(vpoints.size())
338  {
339  vpoints.push_back(vpoints[0]);
340  viewBounds.push_back(ossimDrect(vpoints));
341  polyArea = vpoints;// = ossimPolyArea2d(points);
342
343  }
344  }
345  }
346 }
virtual void imageToView(const ossimDpt &imagePoint, ossimDpt &viewPoint) const
bool isAffectedByElevation() const
Returns TRUE if this geometry is sensitive to elevation.
T sgn(T x)
Definition: ossimCommon.h:339
double lond() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:97
bool isLonNan() const
Definition: ossimGpt.h:140
bool valid() const
void getBoundingRect(ossimIrect &bounding_rect) const
Get the bounding rect of (0, 0) to (imageSize.x-1, imageSize.y-1).
bool isLatNan() const
Definition: ossimGpt.h:139
Definition: ossimDpt.h:67
void add(const ossimPolyArea2d &rhs)
ossimDpt midPoint() const
Definition: ossimDrect.h:817
int ossim_int32
void getImageEdgePoints(std::vector< ossimDpt > &result, ossim_uint32 partitions=25) const
◆ imageToView()
void ossimImageViewProjectionTransform::imageToView ( const ossimDpt imagePoint,
ossimDpt viewPoint
) const
virtual
Definition at line 81 of file ossimImageViewProjectionTransform.cpp.
References ossimImageGeometry::decimationFactor(), ossimImageGeometry::fullToRn(), ossimImageGeometry::getProjection(), ossimImageGeometry::getTransform(), ossimImageGeometry::localToWorld(), m_imageGeometry, m_viewGeometry, ossimDpt::makeNan(), ossimImageGeometry::rnToFull(), and ossimImageGeometry::worldToLocal().
Referenced by ATP::AtpGenerator::constructChain(), ATP::AtpGenerator::getValidVertices(), and getViewSegments().
82 {
83  // Check for same geometries on input and output (this includes NULL geoms):
85  {
86  vp = ip;
87  return;
88  }
89
90  // Otherwise we need access to good geoms. Check for a bad geometry object:
92  {
93  vp.makeNan();
94  return;
95  }
96
97  // Check for same projection on input and output sides to save projection to ground:
99  {
100  // Check for possible same 2D transforms as well:
103  {
104  vp = ip;
105  return;
106  }
107
108  // Not the same 2D transform, so just perform local-image -> full-image -> local-view:
109  ossimDpt fp;
110  m_imageGeometry->rnToFull(ip, 0, fp);
111  m_viewGeometry->fullToRn(fp, 0, vp);
112  return;
113  }
114
115  //---
116  // Completely different left and right side geoms (typical situation).
117  // Need to project to ground.
118  //---
119  ossimGpt gp;
120  m_imageGeometry->localToWorld(ip, gp);
121  m_viewGeometry->worldToLocal(gp, vp);
122
123 #if 0 /* Please leave for debug. */
124  cout <<"DEBUG ossimImageViewProjectionTransform::imageToView:"
125  <<"\n ip: "<<ip
126  <<"\n gp: "<<gp
127  <<"\n vp: "<<vp<<std::endl;
128 #endif
129 }
void rnToFull(const ossimDpt &rnPt, ossim_uint32 resolutionLevel, ossimDpt &fullPt) const
rnToFull is a utility method that takes a rn resolution image point and maps it to the full image poi...
const ossim2dTo2dTransform * getTransform() const
Access methods for transform (may be NULL pointer).
void fullToRn(const ossimDpt &fullPt, ossim_uint32 resolutionLevel, ossimDpt &rnPt) const
fullToRn is a utility method that takes a full image point and maps it to a rn resolution image point...
ossimDpt decimationFactor(ossim_uint32 r_index) const
Returns the decimation factor from R0 for the resolution level specified.
◆ initializeDatelineCrossing()
void ossimImageViewProjectionTransform::initializeDatelineCrossing ( )
protected
◆ initializeViewSize()
bool ossimImageViewProjectionTransform::initializeViewSize ( )
protected
This is needed for the ossimImageGeometry::worldToLocal if the underlying projection is geographic to handle images that cross the date line.
Parameters
Inputimage rectangle.
Returns
Definition at line 543 of file ossimImageViewProjectionTransform.cpp.
References ossimRefPtr< T >::get(), ossimImageGeometry::getCrossesDateline(), ossimMapProjection::getDecimalDegreesPerPixel(), ossimImageGeometry::getImageSize(), getImageToViewBounds(), ossimImageGeometry::getProjection(), ossimDrect::height(), ossimGpt::lat, ossimImageGeometry::localToWorld(), ossimGpt::lon, ossimGpt::lond(), m_crossesDateline, m_imageGeometry, m_viewGeometry, ossimImageGeometry::setImageSize(), ossim::sgn(), size, ossimRefPtr< T >::valid(), ossimDrect::width(), ossimImageGeometry::worldToLocal(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Referenced by setView().
544 {
545  bool result = false;
546  m_crossesDateline = false;
547  if ( m_imageGeometry.valid() )
548  {
550  ossimDrect imageRect( 0, 0,
553  ossimDpt size;
554  ossimDrect rect;
556  {
557  ossimGpt ulg;
558  ossimGpt urg;
559  ossimGpt lrg;
560  ossimGpt llg;
561  ossimGpt cg;
562  ossimDpt ul;
563  ossimDpt ur;
564  ossimDpt lr;
565  ossimDpt ll;
566  m_imageGeometry->localToWorld(imageRect.ul(), ulg);
567  m_imageGeometry->localToWorld(imageRect.ur(), urg);
568  m_imageGeometry->localToWorld(imageRect.lr(), lrg);
569  m_imageGeometry->localToWorld(imageRect.ll(), llg);
570  m_imageGeometry->localToWorld(imageRect.midPoint(), cg);
571
572  if(std::fabs(ulg.lond()-cg.lond()) > 180)
573  {
574  ulg.lond(ulg.lond()+ossim::sgn(cg.lond())*360);
575  }
576  if(std::fabs(urg.lond()-cg.lond()) > 180)
577  {
578  urg.lond((urg.lond()+ossim::sgn(cg.lond())*360));
579  }
580  if(std::fabs(lrg.lond()-cg.lond()) > 180)
581  {
582  lrg.lond(lrg.lond()+ossim::sgn(cg.lond())*360);
583  }
584  if(std::fabs(llg.lond()-cg.lond()) > 180)
585  {
586  llg.lond(llg.lond()+ossim::sgn(cg.lond())*360);
587  }
588
589  m_viewGeometry->worldToLocal(ulg, ul);
590  m_viewGeometry->worldToLocal(urg, ur);
591  m_viewGeometry->worldToLocal(lrg, lr);
592  m_viewGeometry->worldToLocal(llg, ll);
593
594  rect= ossimDrect(ul,ur,lr,ll);
595  }
596  else
597  {
598  rect = getImageToViewBounds( imageRect );
599  }
600  size.x = ossim::round<ossim_int32>( rect.width() );
601  size.y = ossim::round<ossim_int32>( rect.height() );
602  if ( size.hasNans() == false )
603  {
605  result = true;
606  }
607 // std::cout << "VIEW SIZE ============== " << size << "\n";
608 #if 0
609
610  if ( (imageRect.hasNans() == false) && m_viewGeometry.valid() )
611  {
613  if ( viewProj.valid() )
614  {
615  ossimIpt size;
616  size.makeNan();
617
618  const ossimEquDistCylProjection* eqProj =
619  dynamic_cast<const ossimEquDistCylProjection*>( viewProj.get() );
620  if ( eqProj )
621  {
622  // Specialized to take into consideration a date line crossing.
623
624  // Get the ground points we need:
625  ossimDpt iRight(imageRect.ul().x+1, imageRect.ul().y);
626  ossimDpt iDown(imageRect.ul().x, imageRect.ul().y+1);
627  ossimGpt gul;
628  ossimGpt gur;
629  ossimGpt glr;
630  ossimGpt gll;
631  ossimGpt gRight;
632  ossimGpt gDown;
633  ossim_float64 hdd; // height decimal degrees
634  ossim_float64 wdd; // width decimal degrees
635  ossim_float64 leftLon;
636  ossim_float64 rightLon;
637
638  m_imageGeometry->localToWorld( imageRect.ul(), gul );
639  m_imageGeometry->localToWorld( imageRect.ur(), gur );
640  m_imageGeometry->localToWorld( imageRect.lr(), glr );
641  m_imageGeometry->localToWorld( imageRect.ll(), gll );
642  m_imageGeometry->localToWorld( iRight, gRight );
643  m_imageGeometry->localToWorld( iDown, gDown );
644
645  //---
646  // Determine the direction of the image and get the geographic bounding box.
647  // For the longitude consider a date line crossing.
648  //---
649  if ( gul.lat > gDown.lat ) // oriented north up
650  {
651  if ( gul.lat >= gRight.lat ) // straight up or leaning right
652  {
653  hdd = gul.lat - glr.lat;
654  leftLon = gll.lon;
655  rightLon = gur.lon;
656  }
657  else // leaning left
658  {
659  hdd = gur.lat - gll.lat;
660  leftLon = gul.lon;
661  rightLon = glr.lon;
662  }
663  }
664  else // south or on side
665  {
666  if ( gRight.lat >= gul.lat ) // straight down or leaning right
667  {
668  hdd = glr.lat - gul.lat;
669  leftLon = gur.lon;
670  rightLon = gll.lon;
671  }
672  else // leaning left
673  {
674  hdd = gll.lat - gur.lat;
675  leftLon = glr.lon;
676  rightLon = gul.lon;
677  }
678  }
679
680  if ( rightLon > leftLon )
681  {
682  wdd = rightLon - leftLon;
683  }
684  else // Date line cross:
685  {
686  wdd = rightLon + 360.0 - leftLon;
687  }
688
689  //---
690  // Add one pixel width/height to the point to point size to make it edge to edge
691  // before dividing by gsd to get the size. The view projection gsd is used here
692  // since the view could be a different resolution than the input projection.
693  //---
694  size.x = ossim::round<ossim_int32>(
695  ( wdd + eqProj->getDecimalDegreesPerPixel().x ) /
696  eqProj->getDecimalDegreesPerPixel().x );
697  size.y = ossim::round<ossim_int32>(
698  ( hdd + eqProj->getDecimalDegreesPerPixel().y ) /
699  eqProj->getDecimalDegreesPerPixel().y );
700
701 #if 0 /* Please leave for debug: */
702  cout << "\nwdd: " << wdd
703  << "\nhdd: " << hdd
704  << "\ngul: " << gul
705  << "\ngur: " << gur
706  << "\nglr: " << glr
707  << "\ngll: " << gll
708  << endl;
709 #endif
710  }
711  else // Not an ossimEquDistCylProjection:
712  {
713  ossimDrect rect = getImageToViewBounds( imageRect );
714  size.x = ossim::round<ossim_int32>( rect.width() );
715  size.y = ossim::round<ossim_int32>( rect.height() );
716  }
717
718 #if 0 /* Please leave for debug: */
719  cout << "m_imageGeometry:\n" << *(m_imageGeometry.get())
720  << "\n\nm_viewGeometry:\n" << *(m_viewGeometry.get())
721  << "\n\ncomputed view size: " << size << endl;
722 #endif
723
724  if ( size.hasNans() == false )
725  {
727  result = true;
728  }
729
730  } // Matches: if ( viewProj.valid() )
731
732  } // Matches: if ( (imageRect.hasNans() == false) ...
733 #endif
734
735  } // Matches: if ( m_imageGeometry.valid() && ...
736
737  return result;
738
739 } // End: bool ossimImageViewProjectionTransform::initializeViewSize()
virtual const ossimDpt & getDecimalDegreesPerPixel() const
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing...
T sgn(T x)
ossim_float64 width() const
Definition: ossimDrect.h:522
const ossimIpt & getImageSize() const
double lond() const
bool valid() const
double y
Definition: ossimDpt.h:165
void setImageSize(const ossimIpt &size)
double ossim_float64
yy_size_t size
ossim_float64 lon
Definition: ossimGpt.h:266
ossim_float64 height() const
Definition: ossimDrect.h:517
ossim_int32 y
Definition: ossimIpt.h:142
double x
Definition: ossimDpt.h:164
ossim_int32 x
Definition: ossimIpt.h:141
ossim_float64 lat
Definition: ossimGpt.h:265
◆ isIdentity()
virtual bool ossimImageViewProjectionTransform::isIdentity ( ) const
inlinevirtual
Presently implemented as limited compare of geometry pointers
Definition at line 42 of file ossimImageViewProjectionTransform.h.
42 { return (m_imageGeometry == m_viewGeometry); }
◆ isValid()
virtual bool ossimImageViewProjectionTransform::isValid ( void  ) const
inlinevirtual
Definition at line 38 of file ossimImageViewProjectionTransform.h.
38 { return (m_imageGeometry.valid() && m_viewGeometry.valid()); }
bool valid() const
◆ loadState()
bool ossimImageViewProjectionTransform::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 468 of file ossimImageViewProjectionTransform.cpp.
References ossimString::c_str(), ossimImageViewTransform::loadState(), ossimImageGeometry::loadState(), m_imageGeometry, m_viewGeometry, and ossimKeywordlist::numberOf().
470 {
471  bool result = ossimImageViewTransform::loadState(kwl, prefix);
472  if(result)
473  {
474  ossimString imagePrefix = ossimString(prefix)+"image_geometry.";
475  ossimString viewPrefix = ossimString(prefix)+"view_geometry.";
476  if(kwl.numberOf(imagePrefix.c_str())>0)
477  {
479  m_imageGeometry->loadState(kwl, imagePrefix.c_str());
480  }
481  if(kwl.numberOf(viewPrefix.c_str())>0)
482  {
484  m_viewGeometry->loadState(kwl, viewPrefix.c_str());
485  }
486
487  }
488
489  return result;
490 }
ossim_uint32 numberOf(const char *str) const
Attempts to initialize a transform and a projection given the KWL.
const char * c_str() const
Definition: ossimString.h:396
◆ print()
std::ostream & ossimImageViewProjectionTransform::print ( std::ostream &  out) const
virtual
Definition at line 389 of file ossimImageViewProjectionTransform.cpp.
References m_imageGeometry, m_viewGeometry, ossimImageGeometry::print(), and ossimRefPtr< T >::valid().
390 {
391  out << "ossimImageViewProjectionTransform::print: ..... entered " <<endl;
392
393  if(m_imageGeometry.valid())
394  {
395  out << " Input Image (LEFT) Geometry: " << endl;
396  m_imageGeometry->print(out);
397  }
398  else
399  {
400  out << " None defined." << endl;
401  }
402  if(m_viewGeometry.valid())
403  {
404  out << "Output View (RIGHT) Geometry: " << endl;
405  m_viewGeometry->print(out);
406  }
407  else
408  {
409  out << " None defined." << endl;
410  }
411  return out;
412 }
bool valid() const
std::ostream & print(std::ostream &out) const
Prints contents to output stream.
◆ saveState()
bool ossimImageViewProjectionTransform::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 495 of file ossimImageViewProjectionTransform.cpp.
References ossimString::c_str(), m_imageGeometry, m_viewGeometry, ossimImageViewTransform::saveState(), ossimImageGeometry::saveState(), and ossimRefPtr< T >::valid().
497 {
498  ossimString imagePrefix = ossimString(prefix)+"image_geometry.";
499  ossimString viewPrefix = ossimString(prefix)+"view_geometry.";
500
501  if(m_imageGeometry.valid())
502  {
503  m_imageGeometry->saveState(kwl, imagePrefix.c_str());
504  }
505  if(m_viewGeometry.valid())
506  {
507  m_viewGeometry->saveState(kwl, viewPrefix.c_str());
508  }
509  return ossimImageViewTransform::saveState(kwl, prefix);
510 }
bool valid() const
Saves the transform (if any) and projection (if any) states to the KWL.
◆ setImageGeometry()
void ossimImageViewProjectionTransform::setImageGeometry ( ossimImageGeometry g)
Definition at line 72 of file ossimImageViewProjectionTransform.cpp.
References initializeDatelineCrossing(), and m_imageGeometry.
Referenced by ossimImageRenderer::disconnectInputEvent(), ossimEquationUtil::initInputSources(), and ossimImageRenderer::refreshEvent().
◆ setView()
bool ossimImageViewProjectionTransform::setView ( ossimObject baseObject)
virtual
There are multiple locations that need a projector in order to run properly.
When a "Set View" event is sent through the chain. Typically this is passed down from The renderer.
Definition at line 349 of file ossimImageViewProjectionTransform.cpp.
References initializeViewSize(), m_crossesDateline, m_viewGeometry, ossimImageGeometry::setProjection(), and ossimRefPtr< T >::valid().
350 {
351  ossimImageGeometry* g = dynamic_cast<ossimImageGeometry*>(baseObject);
352  bool new_view_set = false;
353  m_crossesDateline = false;
354  if (g)
355  {
356  m_viewGeometry = g;
357  new_view_set = true;
358  }
359  else
360  {
361  ossimProjection* proj = dynamic_cast<ossimProjection*>(baseObject);
362  if(proj)
363  {
364  if(m_viewGeometry.valid())
365  {
367  }
368  else
369  {
370  m_viewGeometry = new ossimImageGeometry(0, proj);
371  }
372
373  new_view_set = true;
374  }
375  }
376
377  if ( m_viewGeometry.valid() && m_viewGeometry-> getImageSize().hasNans() )
378  {
379  // Sets the view image size from the image geometry if present.
381  }
382
383  return new_view_set;
384 }
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
bool valid() const
bool initializeViewSize()
◆ setViewGeometry()
void ossimImageViewProjectionTransform::setViewGeometry ( ossimImageGeometry g)
Definition at line 64 of file ossimImageViewProjectionTransform.cpp.
References initializeDatelineCrossing(), and m_viewGeometry.
Referenced by ossimEquationUtil::initInputSources().
◆ viewToImage()
void ossimImageViewProjectionTransform::viewToImage ( const ossimDpt viewPoint,
ossimDpt imagePoint
) const
virtual
Definition at line 134 of file ossimImageViewProjectionTransform.cpp.
References ossimImageGeometry::decimationFactor(), ossimImageGeometry::fullToRn(), ossimImageGeometry::getProjection(), ossimImageGeometry::getTransform(), ossimObject::isEqualTo(), ossimProjection::isEqualTo(), ossimImageGeometry::localToWorld(), m_imageGeometry, m_viewGeometry, ossimDpt::makeNan(), ossimImageGeometry::rnToFull(), and ossimImageGeometry::worldToLocal().
Referenced by ATP::AtpGenerator::constructChain().
135 {
136  // Check for same geometries on input and output (this includes NULL geoms):
138  {
139  ip = vp;
140  return;
141  }
142
143  // Otherwise we need access to good geoms. Check for a bad geometry object:
145  {
146  ip.makeNan();
147  return;
148  }
149
150  // Check for same projection on input and output sides to save projection to ground:
152  const ossimProjection* vproj = m_viewGeometry->getProjection();
153  if ((iproj && vproj && iproj->isEqualTo(*vproj)) || (iproj == vproj))
154  {
155  // Check for possible same 2D transforms as well:
158  if (((ixform && vxform && ixform->isEqualTo(*vxform)) || (ixform == vxform)) &&
160  {
161  ip = vp;
162  return;
163  }
164
165  // Not the same 2D transform, so just perform local-image -> full-image -> local-view:
166  ossimDpt fp;
167  m_viewGeometry->rnToFull(vp, 0, fp);
168  m_imageGeometry->fullToRn(fp, 0, ip);
169  return;
170  }
171
172  //---
173  // Completely different left and right side geoms (typical situation).
174  // Need to project to ground.
175  //---
176  ossimGpt gp;
177  m_viewGeometry->localToWorld(vp, gp);
178  m_imageGeometry->worldToLocal(gp, ip);
179
180 #if 0 /* Please leave for debug. */
181  cout <<"DEBUG ossimImageViewProjectionTransform::viewToImage:"
182  <<"\n vp: "<<vp
183  <<"\n gp: "<<gp
184  <<"\n ip: "<<ip
185  <<std::endl;
186 #endif
187 }
virtual bool isEqualTo(const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const
Member Data Documentation
◆ m_crossesDateline
bool ossimImageViewProjectionTransform::m_crossesDateline
protected
◆ m_imageGeometry
ossimRefPtr<ossimImageGeometry> ossimImageViewProjectionTransform::m_imageGeometry
protected
◆ m_viewGeometry
ossimRefPtr<ossimImageGeometry> ossimImageViewProjectionTransform::m_viewGeometry
protected
