Public Member Functions | List of all members
ossimOptimizableProjection Class Referenceabstract
virtual class enabling projection optimization (can be used for outlier rejection - RANSAC) More...
#include <ossimOptimizableProjection.h>
Inheritance diagram for ossimOptimizableProjection:
ossimBilinearProjection ossimPolynomProjection ossimRpcProjection ossimSensorModel ossimAdjMapModel ossimAlphaSensor ossimApplanixEcefModel ossimApplanixUtmModel ossimCoarseGridModel ossimFcsiModel ossimIpodSensor ossimLandSatModel ossimNitfMapModel ossimplugins::ossimFormosatModel ossimplugins::ossimGeometricSarSensorModel ossimplugins::ossimTileMapModel ossimPpjFrameSensor ossimRpcModel ossimRS1SarModel ossimRsmModel ossimSarModel ossimSkyBoxLearSensor ossimSonomaSensor ossimSpectraboticsRedEdgeModel ossimSpot5Model
 ossimOptimizableProjection ()
 ossimOptimizableProjection (const ossimOptimizableProjection &source)
virtual ~ossimOptimizableProjection ()
virtual ossimOptimizableProjectionoperator= (const ossimOptimizableProjection &source)
virtual bool setupOptimizer (const ossimString &setup)
 setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More...
virtual bool useForward () const =0
virtual ossim_uint32 degreesOfFreedom () const =0
virtual bool needsInitialState () const
 needsInitialState() More...
virtual double optimizeFit (const ossimTieGptSet &tieSet, double *targetVariance=0)=0
Detailed Description
Definition at line 20 of file ossimOptimizableProjection.h.
◆ ossimOptimizableProjection() [1/2]
ossimOptimizableProjection::ossimOptimizableProjection ( )
Construction and init
Definition at line 5 of file ossimOptimizableProjection.cpp.
6 {}
◆ ossimOptimizableProjection() [2/2]
ossimOptimizableProjection::ossimOptimizableProjection ( const ossimOptimizableProjection source)
Definition at line 8 of file ossimOptimizableProjection.cpp.
10 {
11  // nothing to do (copy) in base.
12 }
◆ ~ossimOptimizableProjection()
ossimOptimizableProjection::~ossimOptimizableProjection ( )
virtual
Definition at line 14 of file ossimOptimizableProjection.cpp.
15 {}
Member Function Documentation
◆ degreesOfFreedom()
virtual ossim_uint32 ossimOptimizableProjection::degreesOfFreedom ( ) const
pure virtual
degreesOfFreedom() number of degrees of freedom (eg: 8 for bilinear, 6 for affine, 2 for translation) especially useful when not inheriting from AdjustableParameterInterface
Implemented in ossimSensorModel, ossimRpcProjection, ossimBilinearProjection, and ossimPolynomProjection.
◆ needsInitialState()
bool ossimOptimizableProjection::needsInitialState ( ) const
virtual
needsInitialState()
Returns
This implementation returns false. Sub classes should true if the projection needs to be initialized to be optimized, eg: sensor models.
Reimplemented in ossimSensorModel.
Definition at line 33 of file ossimOptimizableProjection.cpp.
34 {
35  return false;
36 }
◆ operator=()
ossimOptimizableProjection & ossimOptimizableProjection::operator= ( const ossimOptimizableProjection source)
virtual
Definition at line 17 of file ossimOptimizableProjection.cpp.
Referenced by ossimRpcProjection::operator=(), and ossimSensorModel::operator=().
19 {
20  // nothing to do (copy) in base.
21  // if (this != & source)
22  // {
23  // }
24  return *this;
25 }
◆ optimizeFit()
virtual double ossimOptimizableProjection::optimizeFit ( const ossimTieGptSet tieSet,
double *  targetVariance = 0
pure virtual
optimizeFit() adjusts projection to GLOBALLY fit best to ALL tie points (no outlier rejection) can select an optional threshold for accuracy
RETURNS : resulting image error variance of fitted model, or negative value for error
IMPORTANT : the unit for *targetVariance and the returned value is : meters^2 when useForward() is true OR pixel^2 if useForward() is false
◆ setupOptimizer()
bool ossimOptimizableProjection::setupOptimizer ( const ossimString setup)
virtual
Returns
This implementation does nothing and returns false.
Reimplemented in ossimRpcModel, ossimLandSatModel, ossimRpcProjection, ossimplugins::ossimFormosatModel, ossimSpot5Model, ossimApplanixEcefModel, ossimBilinearProjection, ossimSpectraboticsRedEdgeModel, ossimPolynomProjection, and ossimApplanixUtmModel.
Definition at line 27 of file ossimOptimizableProjection.cpp.
29 {
30  return false;
31 }
◆ useForward()
virtual bool ossimOptimizableProjection::useForward ( ) const
pure virtual
