The factory registry for overview builders. More...
#include <ossimOverviewBuilderFactoryRegistry.h>
virtual ossimObject * | createObject (const ossimString &typeName) const |
virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
ossimOverviewBuilderBase * | createBuilder (const ossimString &typeName) const |
Creates a builder from a string. More... | |
virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
Method to populate a list of supported types of all factories registered to this registry. More... | |
virtual | ~ossimObjectFactory () |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimFactoryListInterface () | |
void | addFactory (ossimOverviewBuilderFactoryBase *factory) |
This is for backward compatability and calls registerFactory for simple adds. More... | |
bool | isFactoryRegistered (ossimOverviewBuilderFactoryBase *factory) const |
Public access method to determine if a factory is already registered to this list. More... | |
void | registerFactory (ossimOverviewBuilderFactoryBase *factory, bool pushToFrontFlag=false) |
Will register a factory to the factory list. More... | |
void | unregisterFactory (ossimOverviewBuilderFactoryBase *factory) |
Will remove the factory from the registry. More... | |
void | unregisterFactory (const ossimString &factoryTypeName) |
Will remove the factory from the registry by name. More... | |
void | unregisterAllFactories () |
Will remove all factories from the registry. More... | |
void | registerFactoryToFront (ossimOverviewBuilderFactoryBase *factory) |
Inserts the factory to the front of the list. More... | |
void | registerFactoryBefore (ossimOverviewBuilderFactoryBase *factory, ossimOverviewBuilderFactoryBase *beforeThisFactory) |
Will insert the factory before the beforeThisFactory. More... | |
void | getAllTypeNamesFromRegistry (std::vector< ossimString > &typeList) const |
Will add all object types the factories can allocate. More... | |
ossimObject * | createObjectFromRegistry (const ossimString &typeName) const |
This is the base object return for all objects in the system. More... | |
ossimObject * | createObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const |
ossimOverviewBuilderBase * | createNativeObjectFromRegistry (const ossimString &typeName) const |
This is a helper method that calls the createObject and makes sure that the returned object is of the NativeType base type this registry supports. More... | |
ossimOverviewBuilderBase * | createNativeObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const |
static ossimOverviewBuilderFactoryRegistry * | instance () |
instance method for access to theInstance pointer. More... | |
Private Member Functions | |
ossimOverviewBuilderFactoryRegistry () | |
default constructor hidden from use More... | |
ossimOverviewBuilderFactoryRegistry (const ossimOverviewBuilderFactoryRegistry &obj) | |
copy constructor hidden from use More... | |
void | operator= (const ossimOverviewBuilderFactoryRegistry &rhs) |
operator= hidden from use. More... | |
Static Private Attributes | |
static ossimOverviewBuilderFactoryRegistry * | m_instance = 0 |
The static instance of this class. More... | |
typedef std::vector< ossimOverviewBuilderFactoryBase *> | FactoryListType |
typedef ossimOverviewBuilderFactoryBase | FactoryType |
typedef ossimOverviewBuilderBase | NativeReturnType |
virtual | ~ossimReferenced () |
bool | findFactory (ossimOverviewBuilderFactoryBase *factory) const |
Utility to find a factory in the list. More... | |
std::mutex | m_factoryListMutex |
FactoryListType | m_factoryList |
Typical usage: std::vector<ossimString> typeList; ossimOverviewBuilderFactoryRegistry::instance()->getTypeNameList(typeList); ossimOverviewBuilderBase* builder = ossimOverviewBuilderFactoryRegistry::instance()->createBuilder( someStringFromTypeList);
Definition at line 33 of file ossimOverviewBuilderFactoryRegistry.h.
private |
Definition at line 80 of file ossimOverviewBuilderFactoryRegistry.cpp.
References m_instance.
Referenced by instance().
private |
Definition at line 85 of file ossimOverviewBuilderFactoryRegistry.cpp.
ossimOverviewBuilderBase * ossimOverviewBuilderFactoryRegistry::createBuilder | ( | const ossimString & | typeName | ) | const |
This should match a string from the getTypeNameList() method.
Definition at line 56 of file ossimOverviewBuilderFactoryRegistry.cpp.
References ossimFactoryListInterface< ossimOverviewBuilderFactoryBase, ossimOverviewBuilderBase >::m_factoryList.
Referenced by createObject().
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 29 of file ossimOverviewBuilderFactoryRegistry.cpp.
Creates and object given a keyword list.
Definition at line 34 of file ossimOverviewBuilderFactoryRegistry.cpp.
References createBuilder(), ossimString::empty(), ossimKeywordlist::find(), ossimSource::loadState(), ossimRefPtr< T >::release(), and ossimRefPtr< T >::valid().
Example:
ossimTiffOverviewNearest ossimTiffOverviewBox
typeList | List of ossimStrings to add to. |
Definition at line 75 of file ossimOverviewBuilderFactoryRegistry.cpp.
Referenced by ossimImageUtil::outputOverviewWriterTypes(), and ossimInfo::printOverviewTypes().
static |
Definition at line 19 of file ossimOverviewBuilderFactoryRegistry.cpp.
References ossimObjectFactoryRegistry::instance(), m_instance, ossimOverviewBuilderFactoryRegistry(), and ossimFactoryListInterface< T, NativeType >::registerFactory().
Referenced by ossimInit::initializeDefaultFactories(), ossimSharedLibraryFinalize(), ossimSharedLibraryInitialize(), ossimImageUtil::outputOverviewWriterTypes(), and ossimInfo::printOverviewTypes().
private |
Definition at line 91 of file ossimOverviewBuilderFactoryRegistry.cpp.
staticprivate |
Definition at line 87 of file ossimOverviewBuilderFactoryRegistry.h.
Referenced by instance(), and ossimOverviewBuilderFactoryRegistry().
