Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossimPngReaderFactory Class Reference
Factory for PNG image reader. More...
#include <ossimPngReaderFactory.h>
Inheritance diagram for ossimPngReaderFactory:
ossimImageHandlerFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimPngReaderFactory ()
 virtual destructor More...
virtual ossimImageHandleropen (const ossimFilename &fileName, bool openOverview=true) const
 open that takes a file name. More...
virtual ossimImageHandleropen (const ossimKeywordlist &kwl, const char *prefix=0) const
 open that takes a keyword list and prefix. More...
virtual ossimRefPtr< ossimImageHandleropen (std::shared_ptr< ossim::istream > &str, const ossimString &connectionString, bool openOverview) const
 Open method that takes a stream. More...
virtual ossimObjectcreateObject (const ossimString &typeName) const
 createObject that takes a class name (ossimPngReader) More...
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
 Creates and object given a keyword list and prefix. More...
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
 Adds ossimPngWriter to the typeList. More...
virtual void getSupportedExtensions (ossimImageHandlerFactoryBase::UniqueStringList &extensionList) const
 Method to add supported extension to the list, like "png". More...
virtual void getImageHandlersBySuffix (ImageHandlerList &result, const ossimString &ext) const
virtual void getImageHandlersByMimeType (ImageHandlerList &result, const ossimString &mimeType) const
- Public Member Functions inherited from ossimImageHandlerFactoryBase
virtual ossimRefPtr< ossimImageHandleropen (std::shared_ptr< ossim::istream > &str, const std::string &connectionString, bool openOverview=true) const
virtual ossimRefPtr< ossimImageHandleropen (std::shared_ptr< ossim::ImageHandlerState > state) const
virtual ossimRefPtr< ossimImageHandleropenOverview (const ossimFilename &file) const
 Open overview that takes a file name. More...
virtual ossimRefPtr< ossimImageHandleropenOverview (std::shared_ptr< ossim::istream > &str, const ossimString &connectionString) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimPngReaderFactoryinstance ()
 static method to return instance (the only one) of this class. More...
 hidden from use default constructor More...
 ossimPngReaderFactory (const ossimPngReaderFactory &)
 hidden from use copy constructor More...
void operator= (const ossimPngReaderFactory &)
virtual ~ossimReferenced ()
static ossimPngReaderFactorytheInstance = 0
 static instance of this class More...
Additional Inherited Members
- Public Types inherited from ossimImageHandlerFactoryBase
typedef UniqueList< ossimStringUniqueStringList
typedef std::vector< ossimRefPtr< ossimImageHandler > > ImageHandlerList
Detailed Description
Definition at line 22 of file ossimPngReaderFactory.h.
◆ ~ossimPngReaderFactory()
ossimPngReaderFactory::~ossimPngReaderFactory ( )
virtual
virtual destructor
Definition at line 29 of file ossimPngReaderFactory.cpp.
References theInstance.
30 {
31  theInstance = 0;
32 }
static ossimPngReaderFactory * theInstance
◆ ossimPngReaderFactory() [1/2]
ossimPngReaderFactory::ossimPngReaderFactory ( )
protected
Definition at line 188 of file ossimPngReaderFactory.cpp.
Referenced by instance().
188 {}
◆ ossimPngReaderFactory() [2/2]
ossimPngReaderFactory::ossimPngReaderFactory ( const ossimPngReaderFactory )
protected
Definition at line 190 of file ossimPngReaderFactory.cpp.
190 {}
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimPngReaderFactory::createObject ( const ossimString typeName) const
virtual
Parameters
typeNameShould be "ossimPngReader".
Returns
pointer to image writer on success, NULL on failure.
Implements ossimObjectFactory.
Definition at line 140 of file ossimPngReaderFactory.cpp.
References ossimRefPtr< T >::release().
142 {
143  ossimRefPtr<ossimObject> result = 0;
144  if(typeName == "ossimPngReader")
145  {
146  result = new ossimPngReader;
147  }
148  return result.release();
149 }
T * release()
Definition: ossimRefPtr.h:93
◆ createObject() [2/2]
ossimObject * ossimPngReaderFactory::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Parameters
kwlThe keyword list.
prefixthe keyword list prefix.
Returns
pointer to image handler on success, NULL on failure.
Definition at line 151 of file ossimPngReaderFactory.cpp.
References open().
153 {
154  return this->open(kwl, prefix);
155 }
virtual ossimImageHandler * open(const ossimFilename &fileName, bool openOverview=true) const
◆ getImageHandlersByMimeType()
void ossimPngReaderFactory::getImageHandlersByMimeType ( ossimImageHandlerFactoryBase::ImageHandlerList result,
const ossimString mimeType
) const
virtual
Reimplemented from ossimImageHandlerFactoryBase.
Definition at line 178 of file ossimPngReaderFactory.cpp.
References ossimString::downcase(), and ossimString::push_back().
180 {
181  ossimString testExt = mimeType.downcase();
182  if(testExt == "image/png")
183  {
184  result.push_back(new ossimPngReader);
185  }
186 }
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
◆ getImageHandlersBySuffix()
void ossimPngReaderFactory::getImageHandlersBySuffix ( ossimImageHandlerFactoryBase::ImageHandlerList result,
const ossimString ext
) const
virtual
Definition at line 168 of file ossimPngReaderFactory.cpp.
170 {
171  ossimString testExt = ext.downcase();
172  if(ext == "png")
173  {
174  result.push_back(new ossimPngReader);
175  }
176 }
◆ getSupportedExtensions()
void ossimPngReaderFactory::getSupportedExtensions ( ossimImageHandlerFactoryBase::UniqueStringList extensionList) const
virtual
Parameters
extensionListThe list to add to.
Implements ossimImageHandlerFactoryBase.
Definition at line 162 of file ossimPngReaderFactory.cpp.
References ossimImageHandlerFactoryBase::UniqueList< T >::push_back().
164 {
165  extensionList.push_back(ossimString("png"));
166 }
◆ getTypeNameList()
void ossimPngReaderFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
Parameters
typeListList to add to.
Definition at line 157 of file ossimPngReaderFactory.cpp.
158 {
159  typeList.push_back(ossimString("ossimPngReader"));
160 }
◆ instance()
ossimPngReaderFactory * ossimPngReaderFactory::instance ( )
static
Returns
pointer to instance of this class.
Definition at line 34 of file ossimPngReaderFactory.cpp.
References ossimPngReaderFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize().
35 {
36  if(!theInstance)
37  {
39  }
40  return theInstance;
41 }
◆ open() [1/3]
ossimImageHandler * ossimPngReaderFactory::open ( const ossimFilename fileName,
bool  openOverview = true
) const
virtual
Parameters
fileThe file to open.
openOverviewIf true image handler will attempt to open overview. default = true
Returns
Definition at line 43 of file ossimPngReaderFactory.cpp.
Referenced by createObject().
45 {
46  if(traceDebug())
47  {
49  << "ossimPngReaderFactory::open(filename) DEBUG: entered..."
50  << "\ntrying ossimPngReader"
51  << std::endl;
52  }
53
56  if(reader->open(fileName) == false)
57  {
58  reader = 0;
59  }
60
61  if(traceDebug())
62  {
64  << "ossimPngReaderFactory::open(filename) DEBUG: leaving..."
65  << std::endl;
66  }
67
68  return reader.release();
69 }
virtual bool open()=0
Pure virtual open.
void setOpenOverviewFlag(bool flag)
Sets theOpenOverviewFlag.
virtual ossimRefPtr< ossimImageHandler > openOverview(const ossimFilename &file) const
T * release()
◆ open() [2/3]
ossimImageHandler * ossimPngReaderFactory::open ( const ossimKeywordlist kwl,
) const
virtual
Parameters
Returns
Definition at line 71 of file ossimPngReaderFactory.cpp.
73 {
74  if(traceDebug())
75  {
77  << "ossimPngReaderFactory::open(kwl, prefix) DEBUG: entered..."
78  << "Trying ossimPngReader"
79  << std::endl;
80  }
81
83  if(reader->loadState(kwl, prefix) == false)
84  {
85  reader = 0;
86  }
87
88  if(traceDebug())
89  {
91  << "ossimPngReaderFactory::open(kwl, prefix) DEBUG: leaving..."
92  << std::endl;
93  }
94
95  return reader.release();
96 }
T * release()
◆ open() [3/3]
ossimRefPtr< ossimImageHandler > ossimPngReaderFactory::open ( std::shared_ptr< ossim::istream > &  str,
const ossimString connectionString,
bool  openOverview
) const
virtual
Parameters
strOpen stream to image.
connectionString
openOverviewIf true attempt to open overview file.
Returns
ossimImageHandler
Definition at line 98 of file ossimPngReaderFactory.cpp.
References ossimRefPtr< T >::get(), ossimPngReader::open(), ossimImageHandlerFactoryBase::openOverview(), and ossimImageHandler::setOpenOverviewFlag().
102 {
104
105  // PNG:
108  if ( ih->open( str, connectionString ) )
109  {
110  result = ih.get();
111  }
112  else
113  {
114  // Reset the stream for downstream code.
115  str->seekg(0, std::ios_base::beg);
116  str->clear();
117  }
118
119  return result;
120 }
virtual bool open(std::shared_ptr< ossim::istream > &str, const std::string &connectionString)
This open takes a stream and stores/captures the shared pointer on success.
◆ operator=()
void ossimPngReaderFactory::operator= ( const ossimPngReaderFactory )
protected
Definition at line 192 of file ossimPngReaderFactory.cpp.
192 {}
Member Data Documentation
◆ theInstance
ossimPngReaderFactory * ossimPngReaderFactory::theInstance = 0
staticprotected
Definition at line 132 of file ossimPngReaderFactory.h.
Referenced by instance(), and ~ossimPngReaderFactory().
