#include <ossimImageHandlerFactoryBase.h>
Classes | |
class | UniqueList |
Public Types | |
typedef UniqueList< ossimString > | UniqueStringList |
typedef std::vector< ossimRefPtr< ossimImageHandler > > | ImageHandlerList |
virtual ossimImageHandler * | open (const ossimFilename &fileName, bool openOverview=true) const =0 |
virtual ossimImageHandler * | open (const ossimKeywordlist &kwl, const char *prefix=0) const =0 |
virtual ossimRefPtr< ossimImageHandler > | open (std::shared_ptr< ossim::istream > &str, const std::string &connectionString, bool openOverview=true) const |
Open method that takes a stream. More... | |
virtual ossimRefPtr< ossimImageHandler > | open (std::shared_ptr< ossim::ImageHandlerState > state) const |
virtual ossimRefPtr< ossimImageHandler > | openOverview (const ossimFilename &file) const |
Open overview that takes a file name. More... | |
virtual ossimRefPtr< ossimImageHandler > | openOverview (std::shared_ptr< ossim::istream > &str, const ossimString &connectionString) const |
virtual void | getImageHandlersBySuffix (ImageHandlerList &result, const ossimString &ext) const |
virtual void | getImageHandlersByMimeType (ImageHandlerList &result, const ossimString &mimeType) const |
virtual void | getSupportedExtensions (ossimImageHandlerFactoryBase::UniqueStringList &extensionList) const =0 |
virtual | ~ossimObjectFactory () |
virtual ossimObject * | createObject (const ossimString &typeName) const =0 |
virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const =0 |
virtual void | getTypeNameList (std::vector< ossimString > &typeList) const =0 |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
virtual | ~ossimReferenced () |
Definition at line 27 of file ossimImageHandlerFactoryBase.h.
typedef std::vector<ossimRefPtr<ossimImageHandler> > ossimImageHandlerFactoryBase::ImageHandlerList |
Definition at line 63 of file ossimImageHandlerFactoryBase.h.
Definition at line 62 of file ossimImageHandlerFactoryBase.h.
Reimplemented in ossimKakaduReaderFactory, ossimPngReaderFactory, ossimOpjReaderFactory, ossimJpeg12ReaderFactory, ossimKakaduJpipHandlerFactory, ossimGeoPdfReaderFactory, ossimMrSidReaderFactory, ossimSqliteReaderFactory, ossimImageHandlerFactory, ossimGdalFactory, and ossimPointCloudImageHandlerFactory.
Definition at line 19 of file ossimImageHandlerFactoryBase.cpp.
Definition at line 14 of file ossimImageHandlerFactoryBase.cpp.
pure virtual |
Implemented in ossimKakaduReaderFactory, ossimPngReaderFactory, ossimOpjReaderFactory, ossimplugins::ossimPluginReaderFactory, ossimH5ReaderFactory, ossimHdf5PluginHandlerFactory, ossimJpeg12ReaderFactory, ossimGeoPdfReaderFactory, ossimKakaduJpipHandlerFactory, ossimMrSidReaderFactory, ossimSqliteReaderFactory, ossimImageHandlerFactory, ossimKmlSuperOverlayReaderFactory, ossimGdalFactory, and ossimPointCloudImageHandlerFactory.
pure virtual |
Implemented in ossimplugins::ossimPluginReaderFactory, ossimH5ReaderFactory, ossimHdf5PluginHandlerFactory, ossimPngReaderFactory, ossimGeoPdfReaderFactory, ossimJpeg12ReaderFactory, ossimKakaduJpipHandlerFactory, ossimKakaduReaderFactory, ossimMrSidReaderFactory, ossimSqliteReaderFactory, ossimGdalFactory, ossimOpjReaderFactory, ossimKmlSuperOverlayReaderFactory, ossimImageHandlerFactory, and ossimPointCloudImageHandlerFactory.
pure virtual |
Implemented in ossimplugins::ossimPluginReaderFactory, ossimH5ReaderFactory, ossimHdf5PluginHandlerFactory, ossimJpeg12ReaderFactory, ossimKakaduReaderFactory, ossimPngReaderFactory, ossimGeoPdfReaderFactory, ossimKakaduJpipHandlerFactory, ossimMrSidReaderFactory, ossimSqliteReaderFactory, ossimOpjReaderFactory, ossimKmlSuperOverlayReaderFactory, ossimGdalFactory, ossimImageHandlerFactory, and ossimPointCloudImageHandlerFactory.
This implementation returns an ossimRefPtr with a null pointer.
str | Open stream to image. |
connectionString | |
openOverview | If true attempt to open overview file. |
Reimplemented in ossimKakaduReaderFactory, and ossimImageHandlerFactory.
Definition at line 40 of file ossimImageHandlerFactoryBase.cpp.
Reimplemented in ossimImageHandlerFactory.
Definition at line 48 of file ossimImageHandlerFactoryBase.cpp.
This default implementation returns a null ref pointer. Derived factories that have overview readers should override.
file | File to open. |
Reimplemented in ossimKakaduReaderFactory, ossimImageHandlerFactory, ossimOpjReaderFactory, ossimGdalFactory, and ossimPointCloudImageHandlerFactory.
Definition at line 24 of file ossimImageHandlerFactoryBase.cpp.
Referenced by ossimHdf5PluginHandlerFactory::open(), ossimplugins::ossimPluginReaderFactory::open(), and ossimPngReaderFactory::open().
connectionString |
Reimplemented in ossimKakaduReaderFactory.
Definition at line 53 of file ossimImageHandlerFactoryBase.cpp.
