Public Member Functions | Private Attributes | Friends | List of all members
ossimRpfFrameFileIndexSubsection Class Reference
#include <ossimRpfFrameFileIndexSubsection.h>
Inheritance diagram for ossimRpfFrameFileIndexSubsection:
ossimReferenced
 ossimRpfFrameFileIndexSubsection ()
 default constructor More...
 ossimRpfFrameFileIndexSubsection (const ossimRpfFrameFileIndexSubsection &obj)
 copy constructor More...
const ossimRpfFrameFileIndexSubsectionoperator= (const ossimRpfFrameFileIndexSubsection &rhs)
 assignment operator More...
virtual ~ossimRpfFrameFileIndexSubsection ()
ossimErrorCode parseStream (std::istream &in, ossimByteOrder byteOrder)
void writeStream (std::ostream &out)
 Write method. More...
void clearFields ()
std::ostream & print (std::ostream &out) const
void setNumberOfFileIndexRecords (ossim_uint32 numberOfIndexRecords)
void setNumberOfPathnames (ossim_uint32 numberOfPathnames)
const std::vector< ossimRpfFrameFileIndexRecord > & getIndexTable () const
const std::vector< ossimRpfPathnameRecord > & getPathnameTable () const
bool getFrameFileIndexRecordFromFile (const ossimFilename &file, ossimRpfFrameFileIndexRecord &record) const
 Gets the record matching file. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
Private Attributes
std::vector< ossimRpfFrameFileIndexRecordm_indexTable
std::vector< ossimRpfPathnameRecordm_pathnameTable
Friends
std::ostream & operator<< (std::ostream &out, const ossimRpfFrameFileIndexSubsection &data)
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 24 of file ossimRpfFrameFileIndexSubsection.h.
◆ ossimRpfFrameFileIndexSubsection() [1/2]
ossimRpfFrameFileIndexSubsection::ossimRpfFrameFileIndexSubsection ( )
default constructor
Definition at line 26 of file ossimRpfFrameFileIndexSubsection.cpp.
27  :
28  m_indexTable(0),
30 {
31 }
std::vector< ossimRpfPathnameRecord > m_pathnameTable
std::vector< ossimRpfFrameFileIndexRecord > m_indexTable
◆ ossimRpfFrameFileIndexSubsection() [2/2]
ossimRpfFrameFileIndexSubsection::ossimRpfFrameFileIndexSubsection ( const ossimRpfFrameFileIndexSubsection obj)
copy constructor
Definition at line 33 of file ossimRpfFrameFileIndexSubsection.cpp.
35  :
38 {
39 }
◆ ~ossimRpfFrameFileIndexSubsection()
ossimRpfFrameFileIndexSubsection::~ossimRpfFrameFileIndexSubsection ( )
virtual
Definition at line 52 of file ossimRpfFrameFileIndexSubsection.cpp.
53 {
54 }
Member Function Documentation
◆ clearFields()
void ossimRpfFrameFileIndexSubsection::clearFields ( )
Definition at line 102 of file ossimRpfFrameFileIndexSubsection.cpp.
References m_indexTable, and m_pathnameTable.
103 {
104  m_indexTable.clear();
105  m_pathnameTable.clear();
106 }
◆ getFrameFileIndexRecordFromFile()
bool ossimRpfFrameFileIndexSubsection::getFrameFileIndexRecordFromFile ( const ossimFilename file,
ossimRpfFrameFileIndexRecord record
) const
Parameters
fileIn the form of: 003H1U1B.I21
recordThe record to initialize.
Returns
true if matching record found, false if not.
Definition at line 142 of file ossimRpfFrameFileIndexSubsection.cpp.
References m_indexTable.
Referenced by ossimRpfToc::getCorespondingEntry().
144 {
145  bool result = false;
146  std::vector<ossimRpfFrameFileIndexRecord>::const_iterator i = m_indexTable.begin();
147  while ( i != m_indexTable.end() )
148  {
149  if ( (*i).getFilename() == file )
150  {
151  record = (*i);
152  result = true;
153  break;
154  }
155  ++i;
156  }
157  return result;
158 }
◆ getIndexTable()
const std::vector< ossimRpfFrameFileIndexRecord > & ossimRpfFrameFileIndexSubsection::getIndexTable ( ) const
Definition at line 131 of file ossimRpfFrameFileIndexSubsection.cpp.
132 {
133  return m_indexTable;
134 }
◆ getPathnameTable()
const std::vector< ossimRpfPathnameRecord > & ossimRpfFrameFileIndexSubsection::getPathnameTable ( ) const
Definition at line 137 of file ossimRpfFrameFileIndexSubsection.cpp.
References m_pathnameTable.
138 {
139  return m_pathnameTable;
140 }
◆ operator=()
const ossimRpfFrameFileIndexSubsection & ossimRpfFrameFileIndexSubsection::operator= ( const ossimRpfFrameFileIndexSubsection rhs)
assignment operator
Definition at line 41 of file ossimRpfFrameFileIndexSubsection.cpp.
43 {
44  if ( this != &rhs )
45  {
48  }
49  return *this;
50 }
◆ parseStream()
ossimErrorCode ossimRpfFrameFileIndexSubsection::parseStream ( std::istream &  in,
Definition at line 56 of file ossimRpfFrameFileIndexSubsection.cpp.
References ossim::byteOrder(), m_indexTable, m_pathnameTable, ossimErrorCodes::OSSIM_ERROR, and ossimErrorCodes::OSSIM_OK.
Referenced by ossimRpfHeader::getNewFileIndexSubsection().
58 {
60
61  if(in && (m_indexTable.size()>0))
62  {
63  ossim_uint32 index;
64  for(index = 0;
65  (index < m_indexTable.size()) && (result == ossimErrorCodes::OSSIM_OK);
66  ++index)
67  {
68  result = m_indexTable[index].parseStream(in, byteOrder);
69  }
70  for(index = 0;
71  (index < m_pathnameTable.size()) && (result ==ossimErrorCodes::OSSIM_OK);
72  ++index)
73  {
74  result = m_pathnameTable[index].parseStream(in, byteOrder);
75  }
76  }
77  else
78  {
80  }
81
82  return result;
83 }
ossim_int32 ossimErrorCode
static const ossimErrorCode OSSIM_OK
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
static const ossimErrorCode OSSIM_ERROR
unsigned int ossim_uint32
◆ print()
std::ostream & ossimRpfFrameFileIndexSubsection::print ( std::ostream &  out) const
Definition at line 108 of file ossimRpfFrameFileIndexSubsection.cpp.
Referenced by operator<<().
109 {
110  copy(m_indexTable.begin(),
111  m_indexTable.end(),
112  std::ostream_iterator<ossimRpfFrameFileIndexRecord>(out, "\n"));
113  copy(m_pathnameTable.begin(),
114  m_pathnameTable.end(),
115  std::ostream_iterator<ossimRpfPathnameRecord>(out, "\n"));
116  return out;
117 }
◆ setNumberOfFileIndexRecords()
void ossimRpfFrameFileIndexSubsection::setNumberOfFileIndexRecords ( ossim_uint32  numberOfIndexRecords)
Definition at line 119 of file ossimRpfFrameFileIndexSubsection.cpp.
121 {
122  m_indexTable.resize(numberOfIndexRecords);
123 }
◆ setNumberOfPathnames()
void ossimRpfFrameFileIndexSubsection::setNumberOfPathnames ( ossim_uint32  numberOfPathnames)
Definition at line 125 of file ossimRpfFrameFileIndexSubsection.cpp.
126 {
127  m_pathnameTable.resize(numberOfPathnames);
128 }
◆ writeStream()
void ossimRpfFrameFileIndexSubsection::writeStream ( std::ostream &  out)
Write method.
Parameters
outStream to write to.
Definition at line 85 of file ossimRpfFrameFileIndexSubsection.cpp.
86 {
87  std::vector<ossimRpfFrameFileIndexRecord>::iterator indexIter = m_indexTable.begin();
88  while ( indexIter != m_indexTable.end() )
89  {
90  (*indexIter).writeStream(out);
91  ++indexIter;
92  }
93
94  std::vector<ossimRpfPathnameRecord>::iterator pathIter = m_pathnameTable.begin();
95  while ( pathIter != m_pathnameTable.end() )
96  {
97  (*pathIter).writeStream(out);
98  ++pathIter;
99  }
100 }
◆ operator<<
std::ostream& operator<< ( std::ostream &  out,
const ossimRpfFrameFileIndexSubsection data
friend
Definition at line 21 of file ossimRpfFrameFileIndexSubsection.cpp.
22 {
23  return data.print(out);
24 }
std::ostream & print(std::ostream &out) const
Member Data Documentation
◆ m_indexTable
std::vector<ossimRpfFrameFileIndexRecord> ossimRpfFrameFileIndexSubsection::m_indexTable
private
◆ m_pathnameTable
std::vector<ossimRpfPathnameRecord> ossimRpfFrameFileIndexSubsection::m_pathnameTable
private
