#include <ossimSevenParamDatum.h>
ossimSevenParamDatum (const ossimString &code, const ossimString &name, const ossimEllipsoid *anEllipsoid, ossim_float64 sigmaX, ossim_float64 sigmaY, ossim_float64 sigmaZ, ossim_float64 westLongitude, ossim_float64 eastLongitude, ossim_float64 southLatitude, ossim_float64 northLatitude, ossim_float64 aParam1, ossim_float64 aParam2, ossim_float64 aParam3, ossim_float64 aParam4, ossim_float64 aParam5, ossim_float64 aParam6, ossim_float64 aParam7) | |
ossimGpt | shift (const ossimGpt &aPt) const |
virtual ossimGpt | shiftToWgs84 (const ossimGpt &aPt) const |
virtual ossimGpt | shiftFromWgs84 (const ossimGpt &aPt) const |
virtual ossim_float64 | param1 () const |
virtual ossim_float64 | param2 () const |
virtual ossim_float64 | param3 () const |
virtual ossim_float64 | param4 () const |
virtual ossim_float64 | param5 () const |
virtual ossim_float64 | param6 () const |
virtual ossim_float64 | param7 () const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimDatum (const ossimString &alpha_code, const ossimString &name, const ossimEllipsoid *anEllipsoid, ossim_float64 sigmaX, ossim_float64 sigmaY, ossim_float64 sigmaZ, ossim_float64 westLongitude, ossim_float64 eastLongitude, ossim_float64 southLatitude, ossim_float64 northLatitude) | |
virtual bool | isTheSameAs (const ossimDatum *aDatum) const |
virtual const ossimString & | code () const |
virtual const ossimString & | name () const |
virtual ossim_uint32 | epsgCode () const |
virtual const ossimEllipsoid * | ellipsoid () const |
virtual ossim_float64 | sigmaX () const |
virtual ossim_float64 | sigmaY () const |
virtual ossim_float64 | sigmaZ () const |
virtual ossim_float64 | westLongitude () const |
virtual ossim_float64 | eastLongitude () const |
virtual ossim_float64 | southLatitude () const |
virtual ossim_float64 | northLatitude () const |
virtual bool | isInside (ossim_float64 latitude, ossim_float64 longitude) const |
bool | operator== (const ossimDatum &rhs) const |
bool | operator!= (const ossimDatum &rhs) const |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
Private Attributes | |
ossim_float64 | theParam1 |
ossim_float64 | theParam2 |
ossim_float64 | theParam3 |
ossim_float64 | theParam4 |
ossim_float64 | theParam5 |
ossim_float64 | theParam6 |
ossim_float64 | theParam7 |
TYPE_DATA | |
virtual | ~ossimDatum () |
Only friend ossimDatumFactory is permitted to delete. More... | |
virtual void | molodenskyShift (double a, double da, double f, double df, double dx, double dy, double dz, double Lat_in, double Lon_in, double Hgt_in, double &Lat_out, double &Lon_out, double &Hgt_out) const |
bool | withinMolodenskyRange (const ossimGpt &pt) const |
virtual | ~ossimReferenced () |
ossimString | theCode |
ossim_uint32 | theEpsgCode |
ossimString | theName |
const ossimEllipsoid * | theEllipsoid |
ossim_float64 | theSigmaX |
ossim_float64 | theSigmaY |
ossim_float64 | theSigmaZ |
ossim_float64 | theWestLongitude |
ossim_float64 | theEastLongitude |
ossim_float64 | theSouthLatitude |
ossim_float64 | theNorthLatitude |
TYPE_DATA | |
Definition at line 20 of file ossimSevenParamDatum.h.
inline |
code | new datum code. (input) |
name | Name of the new datum (input) |
SigmaX | Standard error in X in meters (input) |
SigmaY | Standard error in Y in meters (input) |
SigmaZ | Standard error in Z in meters (input) |
southLatitude | Southern edge of validity rectangle in radians(input) |
northLatitude | Northern edge of validity rectangle in radians(input) |
westLongitude | Western edge of validity rectangle in radians (input) |
eastLongitude | Eastern edge of validity rectangle in radians (input) |
param1 | X translation |
param2 | Y translation |
param3 | Z translation |
param4 | X Rotation |
param5 | Y Rotation |
param6 | Z Rotation |
param7 | x,y,z Scale |
Definition at line 41 of file ossimSevenParamDatum.h.
Reimplemented from ossimDatum.
Definition at line 160 of file ossimSevenParamDatum.cpp.
References ossim::almostEqual(), ossimDatum::isEqualTo(), theParam1, theParam2, theParam3, theParam4, theParam5, theParam6, and theParam7.
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinevirtual |
Will shift the ground point relative to this datum.
Implements ossimDatum.
Definition at line 21 of file ossimSevenParamDatum.cpp.
References ossimGpt::datum(), ossimDatum::ellipsoid(), ossimEllipsoid::getA(), ossimEllipsoid::getB(), ossimGpt::height(), ossimGpt::latd(), ossimGpt::lond(), shiftFromWgs84(), and ossimDatum::shiftToWgs84().
Definition at line 100 of file ossimSevenParamDatum.cpp.
References ossimGpt::datum(), ossimGpt::isHgtNan(), ossimGpt::latd(), ossimGpt::lond(), theParam1, theParam2, theParam3, theParam4, theParam5, theParam6, theParam7, ossimEcefPoint::x(), ossimEcefPoint::y(), and ossimEcefPoint::z().
Referenced by shift().
Definition at line 39 of file ossimSevenParamDatum.cpp.
References theParam1, theParam2, theParam3, theParam4, theParam5, theParam6, theParam7, ossimEcefPoint::x(), ossimEcefPoint::y(), and ossimEcefPoint::z().
private |
Definition at line 88 of file ossimSevenParamDatum.h.
Referenced by isEqualTo(), shiftFromWgs84(), and shiftToWgs84().
private |
Definition at line 89 of file ossimSevenParamDatum.h.
private |
Definition at line 90 of file ossimSevenParamDatum.h.
private |
Definition at line 91 of file ossimSevenParamDatum.h.
private |
Definition at line 92 of file ossimSevenParamDatum.h.
private |
Definition at line 93 of file ossimSevenParamDatum.h.
private |
Definition at line 94 of file ossimSevenParamDatum.h.
private |
Definition at line 96 of file ossimSevenParamDatum.h.
