Public Member Functions | Static Public Member Functions | Protected Attributes | List of all members
ossimSmacCallibrationSystem Class Reference
Proecedure for compensation of aerial camera lens distortion as computed by the Simultaneous Multiframe Analytical Calibration (SMAC) System: More...
#include <ossimSmacCallibrationSystem.h>
Inheritance diagram for ossimSmacCallibrationSystem:
ossimLensDistortion ossim2dTo2dTransform ossimObject ossimReferenced
 ossimSmacCallibrationSystem (const ossimDpt &callibratedCenter=ossimDpt(0.0, 0.0))
 ossimSmacCallibrationSystem (double k0, double k1, double k2, double k3, double k4, double p1, double p2, double p3, double p4, const ossimDpt &callibratedCenter=ossimDpt(0.0, 0.0))
 ossimSmacCallibrationSystem (const ossimSmacCallibrationSystem &src)
const double * symmetricRadialDistortionCoefficients () const
void setSymmetricRadialDistortionCoefficients (double k0, double k1, double k2, double k3, double k4)
const double * decenteringDistortionCoefficients () const
void setDecenteringDistortionCoefficients (double p1, double p2, double p3, double p4)
const double * radialDistortionCoefficients () const
virtual void undistort (const ossimDpt &input, ossimDpt &output) const
- Public Member Functions inherited from ossimLensDistortion
 ossimLensDistortion (const ossimDpt &callibratedCenter=ossimDpt(0, 0))
void setCenter (const ossimDpt &center)
const ossimDptgetCenter () const
virtual void forward (const ossimDpt &input, ossimDpt &output) const
virtual void inverse (const ossimDpt &input, ossimDpt &output)
virtual void distort (const ossimDpt &input, ossimDpt &output) const
- Public Member Functions inherited from ossim2dTo2dTransform
virtual void forward (ossimDpt &modify_this) const
virtual void inverse (const ossimDpt &input, ossimDpt &output) const
virtual void inverse (ossimDpt &modify_this) const
virtual const ossim2dTo2dTransformoperator= (const ossim2dTo2dTransform &rhs)
virtual ossimDpt getOrigin () const
 Generic print method. More...
void setConvergenceThreshold (const double &new_threshold)
void setMaxIterations (int new_max_iters)
void setDxDy (const ossimDpt &dxdy)
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static void test ()
double _symmetricRadialDistortionCoefficients [5]
 The coeeficients are arranged index 0..N-1 where 0 refers to K'0 ... More...
double _decenteringDistortionCoefficients [4]
 The coeeficients are arranged index 0..N-1 where 0 refers to P1 ... More...
- Protected Attributes inherited from ossimLensDistortion
ossimDpt theCenter
- Protected Attributes inherited from ossim2dTo2dTransform
double theConvergenceThreshold
int theMaxIterations
ossimDpt theDxDy
Additional Inherited Members
- Protected Member Functions inherited from ossim2dTo2dTransform
 ossim2dTo2dTransform ()
virtual ~ossim2dTo2dTransform ()
virtual ~ossimReferenced ()
Detailed Description
  TRANSLATION TO POINT OF SYMMETRY:
  All measured points (x0, y0) requiring a distortion correction must be first referenced to the principal point of
  autocollimation (PPA) at (0,0) as are the calibrated fiducials. Once the measured points are in the PPA reference frame, they
  then must be translated to the calibrated point of symmetry (POS), (Xp, Yp).
X = X0 - Xp
Y = Y0 - Yp
  Once X and Y are found we need to obtain the radial distance R:
      R = sqrt(X^2 + Y^2)
  SYMMETRIC RADIAL DISTORTION:
  To compute the correction for the symmetric radial distortion (DXr, DYr)
DXr = X(K'0 + K'1*R^2 + K'2*R^4 + K'3*R^6 + K'4*R^8);
DXr = Y(K'0 + K'1*R^2 + K'2*R^4 + K'3*R^6 + K'4*R^8);
  DECENTERING DISTORTION:
  To compute the correction for decentering distortion (DXd, DYd) of the measured point use
  the coefficients of the decentering distortion (P1, .. P4) in the following formula
DXd = (1 + P3*R^2 + P4R^4)*(P1*(R^2 + 2*X^2) + 2*P2*X*Y)
DYd = (1 + P3*R^2 + P4R^4)*(2P1*X*Y + P2*(R^2 + 2*Y^2))
  FINAL CORRECTED COORDINATES:
  Adding the symmetric radial and decentering distortion corrections to the
  translation of the measured point results in a corrected final x and y-coordinate
  for the measured point (Xc, Yc).
Xc = X + DXr + DXd
Yc = Y + DYr + DYd
Definition at line 59 of file ossimSmacCallibrationSystem.h.
◆ ossimSmacCallibrationSystem() [1/3]
ossimSmacCallibrationSystem::ossimSmacCallibrationSystem ( const ossimDpt callibratedCenter = ossimDpt(0.0, 0.0))
inline
Definition at line 62 of file ossimSmacCallibrationSystem.h.
63  :ossimLensDistortion(callibratedCenter)
64  {
74  }
double _decenteringDistortionCoefficients[4]
double _symmetricRadialDistortionCoefficients[5]
The coeeficients are arranged index 0..N-1 where 0 refers to K&#39;0 ...
ossimLensDistortion(const ossimDpt &callibratedCenter=ossimDpt(0, 0))
◆ ossimSmacCallibrationSystem() [2/3]
ossimSmacCallibrationSystem::ossimSmacCallibrationSystem ( double  k0,
double  k1,
double  k2,
double  k3,
double  k4,
double  p1,
double  p2,
double  p3,
double  p4,
const ossimDpt callibratedCenter = ossimDpt(0.0,0.0)
inline
Definition at line 75 of file ossimSmacCallibrationSystem.h.
78  :ossimLensDistortion(callibratedCenter)
79  {
80  setSymmetricRadialDistortionCoefficients(k0, k1, k2, k3, k4);
85  }
void setSymmetricRadialDistortionCoefficients(double k0, double k1, double k2, double k3, double k4)
◆ ossimSmacCallibrationSystem() [3/3]
ossimSmacCallibrationSystem::ossimSmacCallibrationSystem ( const ossimSmacCallibrationSystem src)
inline
Definition at line 86 of file ossimSmacCallibrationSystem.h.
References _decenteringDistortionCoefficients, and _symmetricRadialDistortionCoefficients.
87  {
94  }
Member Function Documentation
◆ decenteringDistortionCoefficients()
const double* ossimSmacCallibrationSystem::decenteringDistortionCoefficients ( ) const
inline
Definition at line 111 of file ossimSmacCallibrationSystem.h.
112  {
114  }
◆ dup()
virtual ossimObject* ossimSmacCallibrationSystem::dup ( ) const
inlinevirtual
Definition at line 95 of file ossimSmacCallibrationSystem.h.
96  {
97  return new ossimSmacCallibrationSystem(*this);
98  }
ossimSmacCallibrationSystem(const ossimDpt &callibratedCenter=ossimDpt(0.0, 0.0))
◆ radialDistortionCoefficients()
const double* ossimSmacCallibrationSystem::radialDistortionCoefficients ( ) const
inline
Definition at line 122 of file ossimSmacCallibrationSystem.h.
123  {
125  }
◆ setDecenteringDistortionCoefficients()
void ossimSmacCallibrationSystem::setDecenteringDistortionCoefficients ( double  p1,
double  p2,
double  p3,
double  p4
inline
Definition at line 115 of file ossimSmacCallibrationSystem.h.
116  {
121  }
◆ setSymmetricRadialDistortionCoefficients()
void ossimSmacCallibrationSystem::setSymmetricRadialDistortionCoefficients ( double  k0,
double  k1,
double  k2,
double  k3,
double  k4
inline
Definition at line 103 of file ossimSmacCallibrationSystem.h.
104  {
110  }
◆ symmetricRadialDistortionCoefficients()
const double* ossimSmacCallibrationSystem::symmetricRadialDistortionCoefficients ( ) const
inline
Definition at line 99 of file ossimSmacCallibrationSystem.h.
100  {
102  }
◆ test()
void ossimSmacCallibrationSystem::test ( )
static
Definition at line 46 of file ossimSmacCallibrationSystem.cpp.
References ossimLensDistortion::distort(), and undistort().
47 {
48  // this example was grabbed from a sample callibration report;
49  double k0 = -.2165e-3;
50  double k1 = .4230e-7;
51  double k2 = -.1652e-11;
52  double k3 = .2860e-19;
53  double k4 = .5690e-26;
54  double p1 = -.1483e-6;
55  double p2 = .1558e-6;
56  double p3 = -.1464e-18;
57  double p4 = .1233e-38;
58
59  ossimSmacCallibrationSystem smac(k0, k1, k2, k3, k4,
60  p1, p2, p3, p4,
61  ossimDpt(.003, -.001));
62  ossimDpt output;
63  smac.undistort(ossimDpt(62.142, -62.336), output);
64  std::cout << "Input: " << ossimDpt(62.142, -62.336) << std::endl;
65  std::cout << "Output should be close to x = 62.136 and y = -62.332 <====> " << output << std::endl;
66  ossimDpt input = output;
67  std::cout << "Now test the inverse!" << std::endl;
68  smac.distort(input, output);
69
70  std::cout << "Inverse should be close to " << ossimDpt(62.142, -62.336) << " <=====> " << output << std::endl;
71 }
Proecedure for compensation of aerial camera lens distortion as computed by the Simultaneous Multif...
◆ undistort()
void ossimSmacCallibrationSystem::undistort ( const ossimDpt input,
ossimDpt output
) const
virtual
Implements ossimLensDistortion.
Definition at line 19 of file ossimSmacCallibrationSystem.cpp.
References _decenteringDistortionCoefficients, _symmetricRadialDistortionCoefficients, ossimLensDistortion::theCenter, ossimDpt::x, x, ossimDpt::y, and y.
Referenced by test().
20 {
21  double x = input.x - theCenter.x;
22  double y = input.y - theCenter.y;
23  double x2 = x*x;
24  double y2 = y*y;
25  double r = std::sqrt(x2 + y2);
26  double r2 = r*r;
27  double r4 = r2*r2;
28  double r6 = r2*r4;
29  double r8 = r4*r4;
35  double DXr = x*(sum);
36  double DYr = y*(sum);
41
42  output.x = x + DXr + DXd;
43  output.y = y + DYr + DYd;
44 }
ossim_uint32 x
ossim_uint32 y
double y
Definition: ossimDpt.h:165
double x
Definition: ossimDpt.h:164
Member Data Documentation
◆ _decenteringDistortionCoefficients
double ossimSmacCallibrationSystem::_decenteringDistortionCoefficients[4]
protected
PN
Definition at line 140 of file ossimSmacCallibrationSystem.h.
Referenced by ossimSmacCallibrationSystem(), and undistort().
◆ _symmetricRadialDistortionCoefficients
double ossimSmacCallibrationSystem::_symmetricRadialDistortionCoefficients[5]
protected
K'(n-1)
Definition at line 134 of file ossimSmacCallibrationSystem.h.
