#include <ossimThreeParamDatum.h>
ossimThreeParamDatum (const ossimString &code, const ossimString &name, const ossimEllipsoid *anEllipsoid, ossim_float64 sigmaX, ossim_float64 sigmaY, ossim_float64 sigmaZ, ossim_float64 westLongitude, ossim_float64 eastLongitude, ossim_float64 southLatitude, ossim_float64 northLatitude, ossim_float64 param1, ossim_float64 param2, ossim_float64 param3) | |
virtual | ~ossimThreeParamDatum () |
virtual ossimGpt | shift (const ossimGpt &aPt) const |
virtual ossimGpt | shiftToWgs84 (const ossimGpt &aPt) const |
virtual ossimGpt | shiftFromWgs84 (const ossimGpt &aPt) const |
virtual ossim_float64 | param1 () const |
virtual ossim_float64 | param2 () const |
virtual ossim_float64 | param3 () const |
virtual ossim_float64 | param4 () const |
virtual ossim_float64 | param5 () const |
virtual ossim_float64 | param6 () const |
virtual ossim_float64 | param7 () const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimDatum (const ossimString &alpha_code, const ossimString &name, const ossimEllipsoid *anEllipsoid, ossim_float64 sigmaX, ossim_float64 sigmaY, ossim_float64 sigmaZ, ossim_float64 westLongitude, ossim_float64 eastLongitude, ossim_float64 southLatitude, ossim_float64 northLatitude) | |
virtual bool | isTheSameAs (const ossimDatum *aDatum) const |
virtual const ossimString & | code () const |
virtual const ossimString & | name () const |
virtual ossim_uint32 | epsgCode () const |
virtual const ossimEllipsoid * | ellipsoid () const |
virtual ossim_float64 | sigmaX () const |
virtual ossim_float64 | sigmaY () const |
virtual ossim_float64 | sigmaZ () const |
virtual ossim_float64 | westLongitude () const |
virtual ossim_float64 | eastLongitude () const |
virtual ossim_float64 | southLatitude () const |
virtual ossim_float64 | northLatitude () const |
virtual bool | isInside (ossim_float64 latitude, ossim_float64 longitude) const |
bool | operator== (const ossimDatum &rhs) const |
bool | operator!= (const ossimDatum &rhs) const |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
Protected Attributes | |
ossim_float64 | theParam1 |
ossim_float64 | theParam2 |
ossim_float64 | theParam3 |
TYPE_DATA | |
ossimString | theCode |
ossim_uint32 | theEpsgCode |
ossimString | theName |
const ossimEllipsoid * | theEllipsoid |
ossim_float64 | theSigmaX |
ossim_float64 | theSigmaY |
ossim_float64 | theSigmaZ |
ossim_float64 | theWestLongitude |
ossim_float64 | theEastLongitude |
ossim_float64 | theSouthLatitude |
ossim_float64 | theNorthLatitude |
TYPE_DATA | |
virtual | ~ossimDatum () |
Only friend ossimDatumFactory is permitted to delete. More... | |
virtual void | molodenskyShift (double a, double da, double f, double df, double dx, double dy, double dz, double Lat_in, double Lon_in, double Hgt_in, double &Lat_out, double &Lon_out, double &Hgt_out) const |
bool | withinMolodenskyRange (const ossimGpt &pt) const |
virtual | ~ossimReferenced () |
Definition at line 18 of file ossimThreeParamDatum.h.
inline |
code | new datum code. (input) |
name | Name of the new datum (input) |
SigmaX | Standard error in X in meters (input) |
SigmaY | Standard error in Y in meters (input) |
SigmaZ | Standard error in Z in meters (input) |
southLatitude | Southern edge of validity rectangle in radians(input) |
northLatitude | Northern edge of validity rectangle in radians(input) |
westLongitude | Western edge of validity rectangle in radians (input) |
eastLongitude | Eastern edge of validity rectangle in radians (input) |
param1 | X translation |
param2 | Y translation |
param3 | Z translation |
Definition at line 35 of file ossimThreeParamDatum.h.
inlinevirtual |
Definition at line 55 of file ossimThreeParamDatum.h.
Reimplemented from ossimDatum.
Definition at line 148 of file ossimThreeParamDatum.cpp.
References ossim::almostEqual(), ossimDatum::isEqualTo(), theParam1, theParam2, and theParam3.
inlinevirtual |
Implements ossimDatum.
Definition at line 65 of file ossimThreeParamDatum.h.
Referenced by shiftFromWgs84(), and shiftToWgs84().
inlinevirtual |
Definition at line 66 of file ossimThreeParamDatum.h.
inlinevirtual |
Definition at line 67 of file ossimThreeParamDatum.h.
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinevirtual |
Will shift a ground point to this datum. If they are the same datum then nothing happens.
Reimplemented in ossimWgs84Datum, ossimWgs72Datum, ossimNadconNasDatum, and ossimNadconNarDatum.
Definition at line 131 of file ossimThreeParamDatum.cpp.
References ossimDatum::code(), ossimGpt::datum(), ossimGpt::height(), ossimGpt::latd(), ossimGpt::lond(), shiftFromWgs84(), and ossimDatum::shiftToWgs84().
Referenced by ossimNadconNarDatum::shift(), and ossimNadconNasDatum::shift().
Reimplemented in ossimWgs84Datum, and ossimWgs72Datum.
Definition at line 77 of file ossimThreeParamDatum.cpp.
References ossim::almostEqual(), ossimDatum::ellipsoid(), ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::height(), ossimGpt::isHgtNan(), ossimGpt::latd(), ossimGpt::latr(), ossimGpt::lond(), ossimGpt::lonr(), ossimDatum::molodenskyShift(), param1(), param2(), param3(), theParam1, theParam2, theParam3, ossimDatum::withinMolodenskyRange(), ossimEcefPoint::x(), ossimEcefPoint::y(), and ossimEcefPoint::z().
Referenced by shift().
Definition at line 22 of file ossimThreeParamDatum.cpp.
References ossim::almostEqual(), ossimGpt::datum(), ossimDatum::ellipsoid(), ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::height(), ossimGpt::isHgtNan(), ossimGpt::latd(), ossimGpt::latr(), ossimGpt::lond(), ossimGpt::lonr(), ossimDatum::molodenskyShift(), param1(), param2(), param3(), theParam1, theParam2, theParam3, ossimDatum::withinMolodenskyRange(), ossimEcefPoint::x(), ossimEcefPoint::y(), and ossimEcefPoint::z().
protected |
Definition at line 77 of file ossimThreeParamDatum.h.
Referenced by isEqualTo(), shiftFromWgs84(), and shiftToWgs84().
protected |
Definition at line 78 of file ossimThreeParamDatum.h.
protected |
Definition at line 79 of file ossimThreeParamDatum.h.
protected |
Definition at line 81 of file ossimThreeParamDatum.h.
