Public Member Functions | Protected Attributes | Friends | List of all members
ossimplugins::AlosPalsarMapProjectionData Class Reference
This class is able to read the SAR leader data set summary record of the leader file. More...
#include <AlosPalsarMapProjectionData.h>
Inheritance diagram for ossimplugins::AlosPalsarMapProjectionData:
ossimplugins::AlosPalsarRecord
 AlosPalsarMapProjectionData ()
 Constructor. More...
virtual ~AlosPalsarMapProjectionData ()
 Destructor. More...
 AlosPalsarMapProjectionData (const AlosPalsarMapProjectionData &rhs)
 Copy constructor. More...
AlosPalsarMapProjectionDataoperator= (const AlosPalsarMapProjectionData &rhs)
 Copy operator. More...
AlosPalsarRecordInstanciate ()
 This function is able to create a new instance of the class. More...
AlosPalsarRecordClone ()
 This function is able to create a new instance of the class initialised with the data of the calling instance. More...
void Read (std::istream &is)
 Read the class data from a stream. More...
void Write (std::ostream &os)
 Write the class to a stream. More...
std::string get_map_proj_des () const
 map_proj_des More...
int get_num_pix_in_line () const
 num_pix_in_line More...
int get_num_lines () const
 num_lines More...
double get_nom_interpixel_dist () const
 nom_interpixel_dist More...
double get_nom_interline_dist () const
 nom_interline_dist More...
double get_orientation_at_center () const
 orientation_at_center More...
double get_orbit_incl () const
 orbit_incl More...
double get_asc_node_long () const
 asc_node_long More...
double get_platform_heading () const
 platform_heading More...
std::string get_name_of_ref_ellipsoid () const
 name_of_ref_ellipsoid More...
double get_semi_maj_axis () const
 semi_maj_axis More...
double get_semi_min_axis () const
 semi_min_axis More...
double get_first_line_first_pixel_lat () const
 first_line_first_pixel _lat More...
double get_first_line_first_pixel_lon () const
 first_line_first_pixel_lon More...
double get_first_line_last_pixel_lat () const
 first_line_last_pixel _lat More...
double get_first_line_last_pixel_lon () const
 first_line_last_pixel_lon More...
double get_last_line_last_pixel_lat () const
 last_line_last_pixel_lat More...
double get_last_line_last_pixel_lon () const
 last_line_last_pixel_lon More...
double get_last_line_first_pixel_lat () const
 last_line_first_pixel_lat More...
double get_last_line_first_pixel_lon () const
 last_line_first_pixel_lon More...
- Public Member Functions inherited from ossimplugins::AlosPalsarRecord
 AlosPalsarRecord (std::string mnemonic)
virtual ~AlosPalsarRecord ()
 Destructor. More...
 AlosPalsarRecord (const AlosPalsarRecord &rhs)
std::string get_mnemonic ()
std::string _map_proj_des
int _num_pix_in_line
int _num_lines
 num_lines More...
double _nom_interpixel_dist
double _nom_interline_dist
double _orientation_at_center
double _orbit_incl
 orbit_incl More...
double _asc_node_long
double _platform_heading
std::string _name_of_ref_ellipsoid
double _semi_maj_axis
double _semi_min_axis
double _first_line_first_pixel_lat
 first_line_first_pixel_lat More...
double _first_line_first_pixel_lon
double _first_line_last_pixel_lat
 first_line_last_pixel_lat More...
double _first_line_last_pixel_lon
double _last_line_last_pixel_lat
double _last_line_last_pixel_lon
double _last_line_first_pixel_lat
double _last_line_first_pixel_lon
- Protected Attributes inherited from ossimplugins::AlosPalsarRecord
std::string _mnemonic
Friends
std::ostream & operator<< (std::ostream &os, const AlosPalsarMapProjectionData &data)
 This function write the AlosPalsarMapProjectionData in a stream. More...
std::istream & operator>> (std::istream &is, AlosPalsarMapProjectionData &data)
 This function read a AlosPalsarMapProjectionData from a stream. More...
Detailed Description
Definition at line 28 of file AlosPalsarMapProjectionData.h.
◆ AlosPalsarMapProjectionData() [1/2]
ossimplugins::AlosPalsarMapProjectionData::AlosPalsarMapProjectionData ( )
Constructor.
Definition at line 18 of file AlosPalsarMapProjectionData.cpp.
Referenced by Clone(), and Instanciate().
18  : AlosPalsarRecord("map_proj_data_rec")
19  {
20  }
AlosPalsarRecord(std::string mnemonic)
Constructor.
◆ ~AlosPalsarMapProjectionData()
ossimplugins::AlosPalsarMapProjectionData::~AlosPalsarMapProjectionData ( )
virtual
Destructor.
Definition at line 22 of file AlosPalsarMapProjectionData.cpp.
23  {
24  }
◆ AlosPalsarMapProjectionData() [2/2]
ossimplugins::AlosPalsarMapProjectionData::AlosPalsarMapProjectionData ( const AlosPalsarMapProjectionData rhs)
Copy constructor.
Definition at line 161 of file AlosPalsarMapProjectionData.cpp.
161  :
162  AlosPalsarRecord(rhs),
163  _map_proj_des(rhs._map_proj_des),
164  _num_pix_in_line(rhs._num_pix_in_line),
165  _num_lines(rhs._num_lines),
166  _nom_interpixel_dist(rhs._nom_interpixel_dist),
167  _nom_interline_dist(rhs._nom_interline_dist),
168  _orientation_at_center(rhs._orientation_at_center),
169  _orbit_incl(rhs._orbit_incl),
170  _asc_node_long(rhs._asc_node_long),
171  _platform_heading(rhs._platform_heading),
172  _name_of_ref_ellipsoid(rhs._name_of_ref_ellipsoid),
173  _semi_maj_axis(rhs._semi_maj_axis),
174  _semi_min_axis(rhs._semi_min_axis),
175  _first_line_first_pixel_lat(rhs._first_line_first_pixel_lat),
176  _first_line_first_pixel_lon(rhs._first_line_first_pixel_lon),
177  _first_line_last_pixel_lat(rhs._first_line_last_pixel_lat),
178  _first_line_last_pixel_lon(rhs._first_line_last_pixel_lon),
179  _last_line_last_pixel_lat(rhs._last_line_last_pixel_lat),
180  _last_line_last_pixel_lon(rhs._last_line_last_pixel_lon),
181  _last_line_first_pixel_lat(rhs._last_line_first_pixel_lat),
182  _last_line_first_pixel_lon(rhs._last_line_first_pixel_lon)
183  {}
Constructor.
Member Function Documentation
◆ Clone()
AlosPalsarRecord* ossimplugins::AlosPalsarMapProjectionData::Clone ( )
inlinevirtual
Implements ossimplugins::AlosPalsarRecord.
Definition at line 72 of file AlosPalsarMapProjectionData.h.
References AlosPalsarMapProjectionData().
73  {
74  return new AlosPalsarMapProjectionData(*this);
75  };
◆ get_asc_node_long()
double ossimplugins::AlosPalsarMapProjectionData::get_asc_node_long ( ) const
inline
asc_node_long
Definition at line 145 of file AlosPalsarMapProjectionData.h.
References _asc_node_long.
146  {
147  return _asc_node_long;
148  };
◆ get_first_line_first_pixel_lat()
double ossimplugins::AlosPalsarMapProjectionData::get_first_line_first_pixel_lat ( ) const
inline
Definition at line 180 of file AlosPalsarMapProjectionData.h.
References _first_line_first_pixel_lat.
181  {
183  };
◆ get_first_line_first_pixel_lon()
double ossimplugins::AlosPalsarMapProjectionData::get_first_line_first_pixel_lon ( ) const
inline
Definition at line 187 of file AlosPalsarMapProjectionData.h.
References _first_line_first_pixel_lon.
188  {
190  };
◆ get_first_line_last_pixel_lat()
double ossimplugins::AlosPalsarMapProjectionData::get_first_line_last_pixel_lat ( ) const
inline
Definition at line 194 of file AlosPalsarMapProjectionData.h.
References _first_line_last_pixel_lat.
195  {
197  };
◆ get_first_line_last_pixel_lon()
double ossimplugins::AlosPalsarMapProjectionData::get_first_line_last_pixel_lon ( ) const
inline
Definition at line 201 of file AlosPalsarMapProjectionData.h.
References _first_line_last_pixel_lon.
202  {
204  };
◆ get_last_line_first_pixel_lat()
double ossimplugins::AlosPalsarMapProjectionData::get_last_line_first_pixel_lat ( ) const
inline
Definition at line 222 of file AlosPalsarMapProjectionData.h.
References _last_line_first_pixel_lat.
223  {
225  };
◆ get_last_line_first_pixel_lon()
double ossimplugins::AlosPalsarMapProjectionData::get_last_line_first_pixel_lon ( ) const
inline
Definition at line 229 of file AlosPalsarMapProjectionData.h.
References _last_line_first_pixel_lon.
230  {
232  };
◆ get_last_line_last_pixel_lat()
double ossimplugins::AlosPalsarMapProjectionData::get_last_line_last_pixel_lat ( ) const
inline
Definition at line 208 of file AlosPalsarMapProjectionData.h.
References _last_line_last_pixel_lat.
209  {
211  };
◆ get_last_line_last_pixel_lon()
double ossimplugins::AlosPalsarMapProjectionData::get_last_line_last_pixel_lon ( ) const
inline
Definition at line 215 of file AlosPalsarMapProjectionData.h.
References _last_line_last_pixel_lon.
216  {
218  };
◆ get_map_proj_des()
std::string ossimplugins::AlosPalsarMapProjectionData::get_map_proj_des ( ) const
inline
map_proj_des
Definition at line 96 of file AlosPalsarMapProjectionData.h.
References _map_proj_des.
97  {
98  return _map_proj_des;
99  };
◆ get_name_of_ref_ellipsoid()
std::string ossimplugins::AlosPalsarMapProjectionData::get_name_of_ref_ellipsoid ( ) const
inline
Definition at line 159 of file AlosPalsarMapProjectionData.h.
References _name_of_ref_ellipsoid.
160  {
161  return _name_of_ref_ellipsoid;
162  };
◆ get_nom_interline_dist()
double ossimplugins::AlosPalsarMapProjectionData::get_nom_interline_dist ( ) const
inline
nom_interline_dist
Definition at line 124 of file AlosPalsarMapProjectionData.h.
References _nom_interline_dist.
125  {
126  return _nom_interline_dist;
127  };
◆ get_nom_interpixel_dist()
double ossimplugins::AlosPalsarMapProjectionData::get_nom_interpixel_dist ( ) const
inline
nom_interpixel_dist
Definition at line 117 of file AlosPalsarMapProjectionData.h.
References _nom_interpixel_dist.
118  {
119  return _nom_interpixel_dist;
120  };
◆ get_num_lines()
int ossimplugins::AlosPalsarMapProjectionData::get_num_lines ( ) const
inline
num_lines
Definition at line 110 of file AlosPalsarMapProjectionData.h.
References _num_lines.
111  {
112  return _num_lines;
113  };
◆ get_num_pix_in_line()
int ossimplugins::AlosPalsarMapProjectionData::get_num_pix_in_line ( ) const
inline
num_pix_in_line
Definition at line 103 of file AlosPalsarMapProjectionData.h.
References _num_pix_in_line.
104  {
105  return _num_pix_in_line;
106  };
◆ get_orbit_incl()
double ossimplugins::AlosPalsarMapProjectionData::get_orbit_incl ( ) const
inline
orbit_incl
Definition at line 138 of file AlosPalsarMapProjectionData.h.
References _orbit_incl.
139  {
140  return _orbit_incl;
141  };
◆ get_orientation_at_center()
double ossimplugins::AlosPalsarMapProjectionData::get_orientation_at_center ( ) const
inline
Definition at line 131 of file AlosPalsarMapProjectionData.h.
References _orientation_at_center.
132  {
133  return _orientation_at_center;
134  };
◆ get_platform_heading()
double ossimplugins::AlosPalsarMapProjectionData::get_platform_heading ( ) const
inline
platform_heading
Definition at line 152 of file AlosPalsarMapProjectionData.h.
References _platform_heading.
153  {
154  return _platform_heading;
155  };
◆ get_semi_maj_axis()
double ossimplugins::AlosPalsarMapProjectionData::get_semi_maj_axis ( ) const
inline
semi_maj_axis
Definition at line 166 of file AlosPalsarMapProjectionData.h.
References _semi_maj_axis.
167  {
168  return _semi_maj_axis;
169  };
◆ get_semi_min_axis()
double ossimplugins::AlosPalsarMapProjectionData::get_semi_min_axis ( ) const
inline
semi_min_axis
Definition at line 173 of file AlosPalsarMapProjectionData.h.
References _semi_min_axis.
174  {
175  return _semi_min_axis;
176  };
◆ Instanciate()
AlosPalsarRecord* ossimplugins::AlosPalsarMapProjectionData::Instanciate ( )
inlinevirtual
Definition at line 64 of file AlosPalsarMapProjectionData.h.
65  {
66  return new AlosPalsarMapProjectionData();
67  };
◆ operator=()
AlosPalsarMapProjectionData & ossimplugins::AlosPalsarMapProjectionData::operator= ( const AlosPalsarMapProjectionData rhs)
Copy operator.
Definition at line 185 of file AlosPalsarMapProjectionData.cpp.
References _asc_node_long, _first_line_first_pixel_lat, _first_line_first_pixel_lon, _first_line_last_pixel_lat, _first_line_last_pixel_lon, _last_line_first_pixel_lat, _last_line_first_pixel_lon, _last_line_last_pixel_lat, _last_line_last_pixel_lon, _map_proj_des, _name_of_ref_ellipsoid, _nom_interline_dist, _nom_interpixel_dist, _num_lines, _num_pix_in_line, _orbit_incl, _orientation_at_center, _platform_heading, _semi_maj_axis, and _semi_min_axis.
186  {
187  _map_proj_des = rhs._map_proj_des;
188  _num_pix_in_line = rhs._num_pix_in_line;
189  _num_lines = rhs._num_lines;
190  _nom_interpixel_dist = rhs._nom_interpixel_dist;
191  _nom_interline_dist = rhs._nom_interline_dist;
192  _orientation_at_center = rhs._orientation_at_center;
193  _orbit_incl = rhs._orbit_incl;
194  _asc_node_long = rhs._asc_node_long;
195  _platform_heading = rhs._platform_heading;
196  _name_of_ref_ellipsoid = rhs._name_of_ref_ellipsoid;
197  _semi_maj_axis = rhs._semi_maj_axis;
198  _semi_min_axis = rhs._semi_min_axis;
199  _first_line_first_pixel_lat = rhs._first_line_first_pixel_lat;
200  _first_line_first_pixel_lon = rhs._first_line_first_pixel_lon;
201  _first_line_last_pixel_lat = rhs._first_line_last_pixel_lat;
202  _first_line_last_pixel_lon = rhs._first_line_last_pixel_lon;
203  _last_line_last_pixel_lat = rhs._last_line_last_pixel_lat;
204  _last_line_last_pixel_lon = rhs._last_line_last_pixel_lon;
205  _last_line_first_pixel_lat = rhs._last_line_first_pixel_lat;
206  _last_line_first_pixel_lon = rhs._last_line_first_pixel_lon;
207
208  return *this;
209  }
◆ Read()
void ossimplugins::AlosPalsarMapProjectionData::Read ( std::istream &  is)
inlinevirtual
Definition at line 80 of file AlosPalsarMapProjectionData.h.
81  {
82  is >> *this;
83  };
◆ Write()
void ossimplugins::AlosPalsarMapProjectionData::Write ( std::ostream &  os)
inlinevirtual
Definition at line 88 of file AlosPalsarMapProjectionData.h.
89  {
90  os << *this;
91  };
◆ operator<<
std::ostream& operator<< ( std::ostream &  os,
const AlosPalsarMapProjectionData data
friend
Definition at line 26 of file AlosPalsarMapProjectionData.cpp.
27  {
28  os << "map_proj_des:" << data._map_proj_des.c_str() << std::endl;
29
30  os << "num_pix_in_line:" << data._num_pix_in_line << std::endl;
31
32  os << "num_lines:" << data._num_lines << std::endl;
33
34  os << "nom_interpixel_dist:" << data._nom_interpixel_dist << std::endl;
35
36  os << "nom_interline_dist:" << data._nom_interline_dist << std::endl;
37
38  os << "orientation_at_center:" << data._orientation_at_center << std::endl;
39
40  os << "orbit_incl:" << data._orbit_incl << std::endl;
41
42  os << "asc_node_long:" << data._asc_node_long << std::endl;
43
44  os << "platform_heading:" << data._platform_heading << std::endl;
45
46  os << "name_of_ref_ellipsoid:" << data._name_of_ref_ellipsoid.c_str() << std::endl;
47
48  os << "semi_maj_axis:" << data._semi_maj_axis << std::endl;
49
50  os << "semi_min_axis:" << data._semi_min_axis << std::endl;
51
52  os << "first_line_first_pixel_lat:" << data._first_line_first_pixel_lat << std::endl;
53
54  os << "first_line_first_pixel_lon:" << data._first_line_first_pixel_lon << std::endl;
55
56  os << "first_line_last_pixel_lat:" << data._first_line_last_pixel_lat << std::endl;
57
58  os << "first_line_last_pixel_lon:" << data._first_line_last_pixel_lon << std::endl;
59
60  os << "last_line_last_pixel_lat:" << data._last_line_last_pixel_lat << std::endl;
61
62  os << "last_line_last_pixel_lon:" << data._last_line_last_pixel_lon << std::endl;
63
64  os << "last_line_first_pixel_lat:" << data._last_line_first_pixel_lat << std::endl;
65
66  os << "last_line_first_pixel_lon:" << data._last_line_first_pixel_lon << std::endl;
67
68  return os;
69
70  }
◆ operator>>
std::istream& operator>> ( std::istream &  is,
friend
Definition at line 72 of file AlosPalsarMapProjectionData.cpp.
73  {
74  char buf16[17];
75  buf16[16] = '\0';
76  char buf32[33];
77  buf32[32] = '\0';
78  // char buf8[9];
79  // buf8[8] = '\0';
80  // char buf4[5];
81  // buf4[4] = '\0';
82
83  is.read(buf16, 16);
84
85  is.read(buf32, 32);
86  data._map_proj_des = buf32;
87
88  is.read(buf16, 16);
89  data._num_pix_in_line = atoi(buf16);
90
91  is.read(buf16, 16);
92  data._num_lines = atoi(buf16);
93
94  is.read(buf16, 16);
95  data._nom_interpixel_dist = atof(buf16);
96
97  is.read(buf16, 16);
98  data._nom_interline_dist = atof(buf16);
99
100  is.read(buf16, 16);
101  data._orientation_at_center = atof(buf16);
102
103  is.read(buf16, 16);
104  data._orbit_incl = atof(buf16);
105
106  is.read(buf16, 16);
107  data._asc_node_long = atof(buf16);
108
109  is.read(buf16, 16);
110
111  is.read(buf16, 16);
112
113  is.read(buf16, 16);
114
115  is.read(buf16, 16);
116  data._platform_heading = atof(buf16);
117
118  is.read(buf32, 32);
119  data._name_of_ref_ellipsoid = buf32;
120
121  is.read(buf16, 16);
122  data._semi_maj_axis = atof(buf16);
123
124  is.read(buf16, 16);
125  data._semi_min_axis = atof(buf16);
126
127  char buf772[772];
128  is.read(buf772, 772);
129
130  is.read(buf16, 16);
131  data._first_line_first_pixel_lat = atof(buf16);
132
133  is.read(buf16, 16);
134  data._first_line_first_pixel_lon = atof(buf16);
135
136  is.read(buf16, 16);
137  data._first_line_last_pixel_lat = atof(buf16);
138
139  is.read(buf16, 16);
140  data._first_line_last_pixel_lon = atof(buf16);
141
142  is.read(buf16, 16);
143  data._last_line_last_pixel_lat = atof(buf16);
144
145  is.read(buf16, 16);
146  data._last_line_last_pixel_lon = atof(buf16);
147
148  is.read(buf16, 16);
149  data._last_line_first_pixel_lat = atof(buf16);
150
151  is.read(buf16, 16);
152  data._last_line_first_pixel_lon = atof(buf16);
153
154  char buf420[420];
155  is.read(buf420, 420);
156
157  return is;
158  }
Member Data Documentation
◆ _asc_node_long
double ossimplugins::AlosPalsarMapProjectionData::_asc_node_long
protected
◆ _first_line_first_pixel_lat
double ossimplugins::AlosPalsarMapProjectionData::_first_line_first_pixel_lat
protected
◆ _first_line_first_pixel_lon
double ossimplugins::AlosPalsarMapProjectionData::_first_line_first_pixel_lon
protected
◆ _first_line_last_pixel_lat
double ossimplugins::AlosPalsarMapProjectionData::_first_line_last_pixel_lat
protected
◆ _first_line_last_pixel_lon
double ossimplugins::AlosPalsarMapProjectionData::_first_line_last_pixel_lon
protected
◆ _last_line_first_pixel_lat
double ossimplugins::AlosPalsarMapProjectionData::_last_line_first_pixel_lat
protected
◆ _last_line_first_pixel_lon
double ossimplugins::AlosPalsarMapProjectionData::_last_line_first_pixel_lon
protected
◆ _last_line_last_pixel_lat
double ossimplugins::AlosPalsarMapProjectionData::_last_line_last_pixel_lat
protected
◆ _last_line_last_pixel_lon
double ossimplugins::AlosPalsarMapProjectionData::_last_line_last_pixel_lon
protected
◆ _map_proj_des
std::string ossimplugins::AlosPalsarMapProjectionData::_map_proj_des
protected
◆ _name_of_ref_ellipsoid
std::string ossimplugins::AlosPalsarMapProjectionData::_name_of_ref_ellipsoid
protected
◆ _nom_interline_dist
double ossimplugins::AlosPalsarMapProjectionData::_nom_interline_dist
protected
◆ _nom_interpixel_dist
double ossimplugins::AlosPalsarMapProjectionData::_nom_interpixel_dist
protected
◆ _num_lines
int ossimplugins::AlosPalsarMapProjectionData::_num_lines
protected
◆ _num_pix_in_line
int ossimplugins::AlosPalsarMapProjectionData::_num_pix_in_line
protected
◆ _orbit_incl
double ossimplugins::AlosPalsarMapProjectionData::_orbit_incl
protected
◆ _orientation_at_center
double ossimplugins::AlosPalsarMapProjectionData::_orientation_at_center
protected
◆ _platform_heading
double ossimplugins::AlosPalsarMapProjectionData::_platform_heading
protected
◆ _semi_maj_axis
double ossimplugins::AlosPalsarMapProjectionData::_semi_maj_axis
protected
◆ _semi_min_axis
double ossimplugins::AlosPalsarMapProjectionData::_semi_min_axis
protected
