28 os <<
"map_proj_des:" << data.
_map_proj_des.c_str() << std::endl;
32 os <<
"num_lines:" << data.
_num_lines << std::endl;
40 os <<
"orbit_incl:" << data.
_orbit_incl << std::endl;
128 is.read(buf772, 772);
155 is.read(buf420, 420);
163 _map_proj_des(rhs._map_proj_des),
164 _num_pix_in_line(rhs._num_pix_in_line),
165 _num_lines(rhs._num_lines),
166 _nom_interpixel_dist(rhs._nom_interpixel_dist),
167 _nom_interline_dist(rhs._nom_interline_dist),
168 _orientation_at_center(rhs._orientation_at_center),
169 _orbit_incl(rhs._orbit_incl),
170 _asc_node_long(rhs._asc_node_long),
171 _platform_heading(rhs._platform_heading),
172 _name_of_ref_ellipsoid(rhs._name_of_ref_ellipsoid),
173 _semi_maj_axis(rhs._semi_maj_axis),
174 _semi_min_axis(rhs._semi_min_axis),
175 _first_line_first_pixel_lat(rhs._first_line_first_pixel_lat),
176 _first_line_first_pixel_lon(rhs._first_line_first_pixel_lon),
177 _first_line_last_pixel_lat(rhs._first_line_last_pixel_lat),
178 _first_line_last_pixel_lon(rhs._first_line_last_pixel_lon),
179 _last_line_last_pixel_lat(rhs._last_line_last_pixel_lat),
180 _last_line_last_pixel_lon(rhs._last_line_last_pixel_lon),
181 _last_line_first_pixel_lat(rhs._last_line_first_pixel_lat),
182 _last_line_first_pixel_lon(rhs._last_line_first_pixel_lon)
double _orbit_incl
orbit_incl
int _num_pix_in_line
num_pix_in_line
AlosPalsarMapProjectionData & operator=(const AlosPalsarMapProjectionData &rhs)
Copy operator.
double _first_line_last_pixel_lat
double _semi_min_axis
semi_min_axis
double _last_line_last_pixel_lon
This class is able to read the SAR leader data set summary record of the leader file.
double _last_line_first_pixel_lat
double _nom_interline_dist
nom_interline_dist
virtual ~AlosPalsarMapProjectionData()
Destructor.
double _first_line_last_pixel_lon
This class is the base class of all the record classes.
std::string _map_proj_des
map_proj_des
double _asc_node_long
asc_node_long
std::ostream & operator<<(std::ostream &os, const AlosPalsarData &data)
double _orientation_at_center
double _nom_interpixel_dist
nom_interpixel_dist
double _first_line_first_pixel_lon
std::string _name_of_ref_ellipsoid
std::istream & operator>>(std::istream &is, AlosPalsarData &data)
double _last_line_first_pixel_lon
double _platform_heading
platform_heading
double _semi_maj_axis
semi_maj_axis
std::basic_istream< char > istream
Base class for char input streams.
double _last_line_last_pixel_lat
double _first_line_first_pixel_lat
Constructor.
std::basic_ostream< char > ostream
Base class for char output streams.
