Public Member Functions | Protected Attributes | Friends | List of all members
ossimplugins::DataHistogramProcessedData Class Reference
This class is able to read a data histogram record - Processed data. More...
#include <DataHistogramProcessedData.h>
Inheritance diagram for ossimplugins::DataHistogramProcessedData:
ossimplugins::RadarSatRecord
 DataHistogramProcessedData ()
 Constructor. More...
virtual ~DataHistogramProcessedData ()
 Destructor. More...
 DataHistogramProcessedData (const DataHistogramProcessedData &rhs)
 Copy constructor. More...
DataHistogramProcessedDataoperator= (const DataHistogramProcessedData &rhs)
 Copy operator. More...
RadarSatRecordInstanciate ()
 This function is able to create a new instance of the class. More...
RadarSatRecordClone ()
 This function is able to create a new instance of the class initialised with the data of the calling instance. More...
void Read (std::istream &is)
 Reads the class data from a stream. More...
void Write (std::ostream &os)
 Writes the class to a stream. More...
int get_rec_seq ()
 Record sequence number. More...
int get_sar_chn ()
 SAR channel indicator. More...
int get_ntab ()
 Number of histogram table data sets in this record. More...
int get_ltab ()
 Histogram table data set size. More...
DataHistogramRecord get_histogram1 ()
 Histogram data record #1. More...
DataHistogramRecord get_histogram2 ()
 Histogram data record #2. More...
- Public Member Functions inherited from ossimplugins::RadarSatRecord
 RadarSatRecord (std::string mnemonic)
virtual ~RadarSatRecord ()
 Destructor. More...
 RadarSatRecord (const RadarSatRecord &rhs)
std::string get_mnemonic ()
int _rec_seq
int _sar_chn
int _ntab
int _ltab
DataHistogramRecord _histogram1
DataHistogramRecord _histogram2
- Protected Attributes inherited from ossimplugins::RadarSatRecord
std::string _mnemonic
Friends
std::ostream & operator<< (std::ostream &os, const DataHistogramProcessedData &data)
 This function writes the DataHistogramProcessedData in a stream. More...
std::istream & operator>> (std::istream &is, DataHistogramProcessedData &data)
 This function reads a DataHistogramProcessedData from a stream. More...
Detailed Description
Warning
There is an error in the documentation for the spare at the end of the record. They say 3 bytes (A3) but they also say that the spare is on the bytes 16917, 16918, 16919 and 16920. In the data files I have, I need to use a spare of 4 bytes.
Definition at line 30 of file DataHistogramProcessedData.h.
◆ DataHistogramProcessedData() [1/2]
ossimplugins::DataHistogramProcessedData::DataHistogramProcessedData ( )
Constructor.
Definition at line 16 of file DataHistogramProcessedData.cpp.
Referenced by Clone(), and Instanciate().
16  : RadarSatRecord("pdr16_hist_rec")
17 {
18 }
RadarSatRecord(std::string mnemonic)
Constructor.
◆ ~DataHistogramProcessedData()
ossimplugins::DataHistogramProcessedData::~DataHistogramProcessedData ( )
virtual
Destructor.
Definition at line 20 of file DataHistogramProcessedData.cpp.
21 {
22 }
◆ DataHistogramProcessedData() [2/2]
ossimplugins::DataHistogramProcessedData::DataHistogramProcessedData ( const DataHistogramProcessedData rhs)
Copy constructor.
Definition at line 72 of file DataHistogramProcessedData.cpp.
72  :
73  RadarSatRecord(rhs),
74  _rec_seq(rhs._rec_seq),
75  _sar_chn(rhs._sar_chn),
76  _ntab(rhs._ntab),
77  _ltab(rhs._ltab),
78  _histogram1(rhs._histogram1),
79  _histogram2(rhs._histogram2)
80 {
81
82 }
Constructor.
int _ntab
Member Function Documentation
◆ Clone()
RadarSatRecord* ossimplugins::DataHistogramProcessedData::Clone ( )
inlinevirtual
Implements ossimplugins::RadarSatRecord.
Definition at line 73 of file DataHistogramProcessedData.h.
References DataHistogramProcessedData().
74  {
75  return new DataHistogramProcessedData(*this);
76  };
◆ get_histogram1()
DataHistogramRecord ossimplugins::DataHistogramProcessedData::get_histogram1 ( )
inline
Definition at line 128 of file DataHistogramProcessedData.h.
References _histogram1.
129  {
130  return _histogram1;
131  };
◆ get_histogram2()
DataHistogramRecord ossimplugins::DataHistogramProcessedData::get_histogram2 ( )
inline
Definition at line 136 of file DataHistogramProcessedData.h.
References _histogram2.
137  {
138  return _histogram2;
139  };
◆ get_ltab()
int ossimplugins::DataHistogramProcessedData::get_ltab ( )
inline
Definition at line 120 of file DataHistogramProcessedData.h.
References _ltab.
121  {
122  return _ltab;
123  };
◆ get_ntab()
int ossimplugins::DataHistogramProcessedData::get_ntab ( )
inline
Definition at line 112 of file DataHistogramProcessedData.h.
References _ntab.
113  {
114  return _ntab;
115  };
int _ntab
◆ get_rec_seq()
int ossimplugins::DataHistogramProcessedData::get_rec_seq ( )
inline
Definition at line 97 of file DataHistogramProcessedData.h.
References _rec_seq.
98  {
99  return _rec_seq;
100  };
◆ get_sar_chn()
int ossimplugins::DataHistogramProcessedData::get_sar_chn ( )
inline
Definition at line 104 of file DataHistogramProcessedData.h.
References _sar_chn.
105  {
106  return _sar_chn;
107  };
◆ Instanciate()
RadarSatRecord* ossimplugins::DataHistogramProcessedData::Instanciate ( )
inlinevirtual
Definition at line 65 of file DataHistogramProcessedData.h.
66  {
67  return new DataHistogramProcessedData();
68  };
◆ operator=()
DataHistogramProcessedData & ossimplugins::DataHistogramProcessedData::operator= ( const DataHistogramProcessedData rhs)
Copy operator.
Definition at line 84 of file DataHistogramProcessedData.cpp.
References _histogram1, _histogram2, _ltab, _ntab, _rec_seq, and _sar_chn.
85 {
86  _histogram1 = rhs._histogram1;
87  _histogram2 = rhs._histogram2;
88  _sar_chn = rhs._sar_chn;
89  _rec_seq = rhs._rec_seq;
90  _ntab = rhs._ntab;
91  _ltab = rhs._ltab;
92  return *this;
93 }
int _ntab
◆ Read()
void ossimplugins::DataHistogramProcessedData::Read ( std::istream &  is)
inlinevirtual
Definition at line 81 of file DataHistogramProcessedData.h.
82  {
83  is>>*this;
84  };
◆ Write()
void ossimplugins::DataHistogramProcessedData::Write ( std::ostream &  os)
inlinevirtual
Definition at line 89 of file DataHistogramProcessedData.h.
90  {
91  os<<*this;
92  };
◆ operator<<
std::ostream& operator<< ( std::ostream &  os,
const DataHistogramProcessedData data
friend
Definition at line 24 of file DataHistogramProcessedData.cpp.
25 {
26  os<<"rec_seq:"<<data._rec_seq<<std::endl;
27
28  os<<"sar_chn:"<<data._sar_chn<<std::endl;
29
30  os<<"ntab:"<<data._ntab<<std::endl;
31
32  os<<"ltab:"<<data._ltab<<std::endl;
33
34  os<<data._histogram1<<std::endl;
35
36  os<<data._histogram2<<std::endl;
37
38  return os;
39 }
◆ operator>>
std::istream& operator>> ( std::istream &  is,
friend
Definition at line 41 of file DataHistogramProcessedData.cpp.
42 {
43  char buff[33];
44  buff[32] = '\0';
45
46  is.read(buff,4);
47  buff[4] = '\0';
48  data._rec_seq = atoi(buff);
49
50  is.read(buff,4);
51  buff[4] = '\0';
52  data._sar_chn = atoi(buff);
53
54  is.read(buff,8);
55  buff[8] = '\0';
56  data._ntab = atoi(buff);
57
58  is.read(buff,8);
59  buff[8] = '\0';
60  data._ltab = atoi(buff);
61
62  is>>data._histogram1;
63
64  is>>data._histogram2;
65
66  char tmp[5];
67  tmp[4] = '\0';
68  is.read(tmp, 4);
69  return is;
70 }
Member Data Documentation
◆ _histogram1
DataHistogramRecord ossimplugins::DataHistogramProcessedData::_histogram1
protected
Definition at line 161 of file DataHistogramProcessedData.h.
Referenced by get_histogram1(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _histogram2
DataHistogramRecord ossimplugins::DataHistogramProcessedData::_histogram2
protected
Definition at line 165 of file DataHistogramProcessedData.h.
Referenced by get_histogram2(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _ltab
int ossimplugins::DataHistogramProcessedData::_ltab
protected
Definition at line 157 of file DataHistogramProcessedData.h.
Referenced by get_ltab(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _ntab
int ossimplugins::DataHistogramProcessedData::_ntab
protected
Definition at line 153 of file DataHistogramProcessedData.h.
Referenced by get_ntab(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _rec_seq
int ossimplugins::DataHistogramProcessedData::_rec_seq
protected
Definition at line 139 of file DataHistogramProcessedData.h.
Referenced by get_rec_seq(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _sar_chn
int ossimplugins::DataHistogramProcessedData::_sar_chn
protected
Definition at line 148 of file DataHistogramProcessedData.h.
Referenced by get_sar_chn(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
