12 #ifndef DataHistogramProcessedData_h 13 #define DataHistogramProcessedData_h This class is able to read a data histogram record - Processed data.
DataHistogramRecord get_histogram2()
Histogram data record #2.
friend std::ostream & operator<<(std::ostream &os, const DataHistogramProcessedData &data)
This function writes the DataHistogramProcessedData in a stream.
This class is able to read a data histogram record.
friend std::istream & operator>>(std::istream &is, DataHistogramProcessedData &data)
This function reads a DataHistogramProcessedData from a stream.
int get_ltab()
Histogram table data set size.
int get_rec_seq()
Record sequence number.
DataHistogramRecord _histogram2
void Write(std::ostream &os)
Writes the class to a stream.
This class is the base class of all the record classes.
int _ltab
DataHistogramProcessedData & operator=(const DataHistogramProcessedData &rhs)
Copy operator.
void Read(std::istream &is)
Reads the class data from a stream.
RadarSatRecord * Clone()
This function is able to create a new instance of the class initialised with the data of the calling ...
virtual ~DataHistogramProcessedData()
Destructor.
int _sar_chn
SAR channel indicator.
int get_ntab()
Number of histogram table data sets in this record.
std::basic_istream< char > istream
Base class for char input streams.
DataHistogramRecord get_histogram1()
Histogram data record #1.
DataHistogramRecord _histogram1
int _ntab
Constructor.
int _rec_seq
int get_sar_chn()
std::basic_ostream< char > ostream
Base class for char output streams.
RadarSatRecord * Instanciate()
This function is able to create a new instance of the class.
