Public Member Functions | Protected Member Functions | Protected Attributes | Friends | List of all members
ossimplugins::ErsSarRecordHeader Class Reference
This class is able to read a record header. More...
#include <ErsSarRecordHeader.h>
 ErsSarRecordHeader ()
 Constructor. More...
virtual ~ErsSarRecordHeader ()
 Destructor. More...
 ErsSarRecordHeader (const ErsSarRecordHeader &rhs)
 Copy constructor. More...
ErsSarRecordHeaderoperator= (const ErsSarRecordHeader &rhs)
 Copy operator. More...
unsigned int get_rec_seq ()
 Record sequence number. More...
unsigned char get_rec_sub1 ()
 First record sub-type code. More...
unsigned char get_rec_type ()
 Record type code. More...
unsigned char get_rec_sub2 ()
 Second record sub-type code. More...
unsigned char get_rec_sub3 ()
 Third record sub-type code. More...
unsigned int get_length ()
 Length of this record (in bytes) More...
void SwitchEndian (unsigned int &value)
 This function switch the LSB value and the MSB value of the parameter. More...
unsigned int _rec_seq
unsigned char _rec_sub1
unsigned char _rec_type
unsigned char _rec_sub2
unsigned char _rec_sub3
unsigned int _length
Friends
std::ostream & operator<< (std::ostream &os, const ErsSarRecordHeader &data)
 This function write the RecordHeader in a stream. More...
std::istream & operator>> (std::istream &is, ErsSarRecordHeader &data)
 This function read a RecordHeader from a stream. More...
Detailed Description
Definition at line 26 of file ErsSarRecordHeader.h.
◆ ErsSarRecordHeader() [1/2]
ossimplugins::ErsSarRecordHeader::ErsSarRecordHeader ( )
Constructor.
Definition at line 18 of file ErsSarRecordHeader.cpp.
19 {
20 }
◆ ~ErsSarRecordHeader()
ossimplugins::ErsSarRecordHeader::~ErsSarRecordHeader ( )
virtual
Destructor.
Definition at line 22 of file ErsSarRecordHeader.cpp.
23 {
24 }
◆ ErsSarRecordHeader() [2/2]
ossimplugins::ErsSarRecordHeader::ErsSarRecordHeader ( const ErsSarRecordHeader rhs)
Copy constructor.
Definition at line 50 of file ErsSarRecordHeader.cpp.
50  :
51  _rec_seq(rhs._rec_seq),
52  _rec_sub1(rhs._rec_sub1),
53  _rec_type(rhs._rec_type),
54  _rec_sub2(rhs._rec_sub2),
55  _rec_sub3(rhs._rec_sub3)
56 {
57 }
Record type code.
Member Function Documentation
◆ get_length()
unsigned int ossimplugins::ErsSarRecordHeader::get_length ( )
inline
Definition at line 101 of file ErsSarRecordHeader.h.
References _length.
102  {
103  return _length;
104  };
◆ get_rec_seq()
unsigned int ossimplugins::ErsSarRecordHeader::get_rec_seq ( )
inline
Definition at line 61 of file ErsSarRecordHeader.h.
References _rec_seq.
62  {
63  return _rec_seq;
64  };
◆ get_rec_sub1()
unsigned char ossimplugins::ErsSarRecordHeader::get_rec_sub1 ( )
inline
Definition at line 69 of file ErsSarRecordHeader.h.
References _rec_sub1.
70  {
71  return _rec_sub1;
72  };
◆ get_rec_sub2()
unsigned char ossimplugins::ErsSarRecordHeader::get_rec_sub2 ( )
inline
Definition at line 85 of file ErsSarRecordHeader.h.
References _rec_sub2.
86  {
87  return _rec_sub2;
88  };
◆ get_rec_sub3()
unsigned char ossimplugins::ErsSarRecordHeader::get_rec_sub3 ( )
inline
Definition at line 93 of file ErsSarRecordHeader.h.
References _rec_sub3.
94  {
95  return _rec_sub3;
96  };
◆ get_rec_type()
unsigned char ossimplugins::ErsSarRecordHeader::get_rec_type ( )
inline
Record type code.
Definition at line 77 of file ErsSarRecordHeader.h.
References _rec_type.
78  {
79  return _rec_type;
80  };
Record type code.
◆ operator=()
ErsSarRecordHeader & ossimplugins::ErsSarRecordHeader::operator= ( const ErsSarRecordHeader rhs)
Copy operator.
Definition at line 59 of file ErsSarRecordHeader.cpp.
References _rec_seq, _rec_sub1, _rec_sub2, _rec_sub3, and _rec_type.
60 {
61  _rec_seq = rhs._rec_seq;
62  _rec_sub1 = rhs._rec_sub1;
63  _rec_type = rhs._rec_type;
64  _rec_sub2 = rhs._rec_sub2;
65  _rec_sub3 = rhs._rec_sub3;
66  return *this;
67 }
Record type code.
◆ SwitchEndian()
void ossimplugins::ErsSarRecordHeader::SwitchEndian ( unsigned int &  value)
protected
Definition at line 69 of file ErsSarRecordHeader.cpp.
Referenced by ossimplugins::operator>>().
70 {
71  char buffer[4];
72  char res[4];
73
74  memcpy(buffer, &value, 4);
75  res[0] = buffer[3];
76  res[1] = buffer[2];
77  res[2] = buffer[1];
78  res[3] = buffer[0];
79
80  memcpy(&value, res, 4);
81 }
◆ operator<<
std::ostream& operator<< ( std::ostream &  os,
const ErsSarRecordHeader data
friend
Definition at line 26 of file ErsSarRecordHeader.cpp.
27 {
28  os << "record_sequence_number:" << data._rec_seq << std::endl;
29  os << "first_record_sub-type:" << (int)data._rec_sub1 << std::endl;
30  os << "record_type_code:" << (int)data._rec_type << std::endl;
31  os << "second_record_sub-type:" << (int)data._rec_sub2 << std::endl;
32  os << "third_record_sub-type:" << (int)data._rec_sub3 << std::endl;
33  os << "length:" << data._length << std::endl;
34  return os;
35 }
◆ operator>>
std::istream& operator>> ( std::istream &  is,
friend
Definition at line 37 of file ErsSarRecordHeader.cpp.
38 {
39  is.read((char*)&(data._rec_seq), 4);
40  data.SwitchEndian(data._rec_seq);
41  is.read((char*)&(data._rec_sub1), 1);
42  is.read((char*)&(data._rec_type), 1);
43  is.read((char*)&(data._rec_sub2), 1);
44  is.read((char*)&(data._rec_sub3), 1);
45  is.read((char*)&(data._length), 4);
46  data.SwitchEndian(data._length);
47  return is;
48 }
Member Data Documentation
◆ _length
unsigned int ossimplugins::ErsSarRecordHeader::_length
protected
Definition at line 135 of file ErsSarRecordHeader.h.
Referenced by get_length(), ossimplugins::operator<<(), and ossimplugins::operator>>().
◆ _rec_seq
unsigned int ossimplugins::ErsSarRecordHeader::_rec_seq
protected
Definition at line 115 of file ErsSarRecordHeader.h.
Referenced by get_rec_seq(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _rec_sub1
unsigned char ossimplugins::ErsSarRecordHeader::_rec_sub1
protected
Definition at line 119 of file ErsSarRecordHeader.h.
Referenced by get_rec_sub1(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _rec_sub2
unsigned char ossimplugins::ErsSarRecordHeader::_rec_sub2
protected
Definition at line 127 of file ErsSarRecordHeader.h.
Referenced by get_rec_sub2(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _rec_sub3
unsigned char ossimplugins::ErsSarRecordHeader::_rec_sub3
protected
Definition at line 131 of file ErsSarRecordHeader.h.
Referenced by get_rec_sub3(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _rec_type
unsigned char ossimplugins::ErsSarRecordHeader::_rec_type
protected
Record type code.
Definition at line 123 of file ErsSarRecordHeader.h.
Referenced by get_rec_type(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
