ossim-plugins
cnes
src
erssar
ErsSarRecordHeader.h
Go to the documentation of this file.
1
2
3
// "Copyright Centre National d'Etudes Spatiales"
4
5
// License: LGPL
6
7
// See LICENSE.txt file in the top level directory for more details.
8
9
10
// $Id$
11
12
#ifndef ErsSarRecordHeader_h
13
#define ErsSarRecordHeader_h
14
15
#include<iostream>
16
#include<cstring>
17
18
namespace
ossimplugins
19
20
26
class
ErsSarRecordHeader
27
28
public
32
ErsSarRecordHeader
33
37
virtual
~ErsSarRecordHeader
38
42
ErsSarRecordHeader
const
ErsSarRecordHeader
& rhs);
43
47
ErsSarRecordHeader
operator=
const
ErsSarRecordHeader
& rhs);
51
friend
std::ostream
operator<<
std::ostream
& os,
const
ErsSarRecordHeader
& data);
52
56
friend
std::istream
operator>>
std::istream
& is,
ErsSarRecordHeader
& data);
57
61
unsigned
int
get_rec_seq
62
63
return
_rec_seq
64
65
69
unsigned
char
get_rec_sub1
70
71
return
_rec_sub1
72
73
77
unsigned
char
get_rec_type
78
79
return
_rec_type
80
81
85
unsigned
char
get_rec_sub2
86
87
return
_rec_sub2
88
89
93
unsigned
char
get_rec_sub3
94
95
return
_rec_sub3
96
97
101
unsigned
int
get_length
102
103
return
_length
104
105
protected
106
110
void
SwitchEndian
unsigned
int
& value);
111
115
unsigned
int
_rec_seq
119
unsigned
char
_rec_sub1
123
unsigned
char
_rec_type
127
unsigned
char
_rec_sub2
131
unsigned
char
_rec_sub3
135
unsigned
int
_length
136
private
137
138
139
140
141
142
#endif
ossimplugins::ErsSarRecordHeader::get_rec_sub2
unsigned char get_rec_sub2()
Second record sub-type code.
Definition:
ErsSarRecordHeader.h:85
ossimplugins::ErsSarRecordHeader::_rec_type
unsigned char _rec_type
Record type code.
Definition:
ErsSarRecordHeader.h:123
ossimplugins::ErsSarRecordHeader::_rec_seq
unsigned int _rec_seq
Record sequence number.
Definition:
ErsSarRecordHeader.h:115
ossimplugins::ErsSarRecordHeader::get_rec_sub1
unsigned char get_rec_sub1()
First record sub-type code.
Definition:
ErsSarRecordHeader.h:69
ossimplugins
Definition:
AlosPalsarData.cpp:26
ossimplugins::ErsSarRecordHeader::_length
unsigned int _length
Length of this record (in bytes)
Definition:
ErsSarRecordHeader.h:135
ossimplugins::ErsSarRecordHeader::ErsSarRecordHeader
ErsSarRecordHeader()
Constructor.
Definition:
ErsSarRecordHeader.cpp:18
ossimplugins::ErsSarRecordHeader::~ErsSarRecordHeader
virtual ~ErsSarRecordHeader()
Destructor.
Definition:
ErsSarRecordHeader.cpp:22
ossimplugins::ErsSarRecordHeader::operator=
ErsSarRecordHeader & operator=(const ErsSarRecordHeader &rhs)
Copy operator.
Definition:
ErsSarRecordHeader.cpp:59
This class is able to read a record header.
Definition:
ErsSarRecordHeader.h:26
ossimplugins::ErsSarRecordHeader::_rec_sub1
unsigned char _rec_sub1
Definition:
ErsSarRecordHeader.h:119
ossim::istream
std::basic_istream< char > istream
Base class for char input streams.
Definition:
ossimIosFwd.h:20
ossimplugins::ErsSarRecordHeader::_rec_sub3
unsigned char _rec_sub3
Third record sub-type code.
Definition:
ErsSarRecordHeader.h:131
ossimplugins::ErsSarRecordHeader::get_length
unsigned int get_length()
Definition:
ErsSarRecordHeader.h:101
ossimplugins::ErsSarRecordHeader::operator>>
friend std::istream & operator>>(std::istream &is, ErsSarRecordHeader &data)
This function read a RecordHeader from a stream.
Definition:
ErsSarRecordHeader.cpp:37
ossimplugins::ErsSarRecordHeader::_rec_sub2
unsigned char _rec_sub2
Definition:
ErsSarRecordHeader.h:127
ossimplugins::ErsSarRecordHeader::get_rec_seq
unsigned int get_rec_seq()
Definition:
ErsSarRecordHeader.h:61
ossimplugins::ErsSarRecordHeader::get_rec_type
unsigned char get_rec_type()
Record type code.
Definition:
ErsSarRecordHeader.h:77
ossimplugins::ErsSarRecordHeader::get_rec_sub3
unsigned char get_rec_sub3()
Definition:
ErsSarRecordHeader.h:93
ossimplugins::ErsSarRecordHeader::operator<<
friend std::ostream & operator<<(std::ostream &os, const ErsSarRecordHeader &data)
This function write the RecordHeader in a stream.
Definition:
ErsSarRecordHeader.cpp:26
ossim::ostream
std::basic_ostream< char > ostream
Base class for char output streams.
Definition:
ossimIosFwd.h:23
ossimplugins::ErsSarRecordHeader::SwitchEndian
void SwitchEndian(unsigned int &value)
This function switch the LSB value and the MSB value of the parameter.
Definition:
ErsSarRecordHeader.cpp:69
Generated on Fri Aug 3 2018 08:46:44 for OSSIM - Open Source Software Image Map by
