ossimplugins::HermiteInterpolator Class Reference
Abstract interpolator. More...
#include <HermiteInterpolator.h>
Public Member Functions
 HermiteInterpolator ()
 Constructor. More...
 HermiteInterpolator (int nbrPoints, double *x, double *y, double *dy)
 Constructor with initializations. More...
 ~HermiteInterpolator ()
 Destructor. More...
 HermiteInterpolator (const HermiteInterpolator &rhs)
 Copy constructor. More...
HermiteInterpolatoroperator= (const HermiteInterpolator &rhs)
 Affectation operator. More...
int Interpolate (double x, double &y, double &dy) const
 This function performs the interpolation for the abscissa x. More...
int Interpolate (double x, double &y) const
Protected Member Functions
void Clear ()
int Precompute () const
Protected Attributes
int theNPointsAvailable
double * theXValues
double * theYValues
double * thedYValues
double * prodC
double * sumC
bool isComputed
Detailed Description
See also
Interpolate
Definition at line 26 of file HermiteInterpolator.h.
◆ HermiteInterpolator() [1/3]
ossimplugins::HermiteInterpolator::HermiteInterpolator ( )
◆ HermiteInterpolator() [2/3]
ossimplugins::HermiteInterpolator::HermiteInterpolator ( int  nbrPoints,
double *  x,
double *  y,
double *  dy
Parameters
nbrPointsNumber of points used to perform the interpolation
xValues of the points abscissa
yValues of the points
dyValues of the differential coefficients
Todo:
Verifier que l'interpolateur n'ai pas besoin ques les abscisses soitent strictement croissantes
Definition at line 33 of file HermiteInterpolator.cpp.
References thedYValues, theNPointsAvailable, theXValues, theYValues, x, and y.
33  :
34  theNPointsAvailable(nbrPoints),
35  prodC(NULL),
36  sumC(NULL),
37  isComputed(false)
38 {
39  if(x != NULL)
40  {
41  theXValues = new double[theNPointsAvailable];
42  for (int i=0;i<theNPointsAvailable;i++)
43  {
44  theXValues[i] = x[i];
45  }
46  }
47  else
48  {
49  theXValues = NULL;
50  }
51
52  if(y != NULL)
53  {
54  theYValues = new double[theNPointsAvailable];
55  for (int i=0;i<theNPointsAvailable;i++)
56  {
57  theYValues[i] = y[i];
58  }
59  }
60  else
61  {
62  theYValues = NULL;
63  }
64
65  if(dy != NULL)
66  {
67  thedYValues = new double[theNPointsAvailable];
68  for (int i=0;i<theNPointsAvailable;i++)
69  {
70  thedYValues[i] = dy[i];
71  }
72  }
73  else
74  {
75  thedYValues = NULL;
76  }
77
78  for (int i = 1 ; i < theNPointsAvailable ; i++)
79  {
84  /*
85  * Les abscisses ne sont pas croissantes
86  */
87 // if (theXValues[i] <= theXValues[i-1])
88 // std::cerr << "WARNING: Hermite interpolation assumes increasing x values" << std::endl;
89  assert(theXValues[i] > theXValues[i-1]);
90  }
91 }
ossim_uint32 x
ossim_uint32 y
◆ ~HermiteInterpolator()
ossimplugins::HermiteInterpolator::~HermiteInterpolator ( )
Destructor.
Definition at line 93 of file HermiteInterpolator.cpp.
References Clear().
◆ HermiteInterpolator() [3/3]
ossimplugins::HermiteInterpolator::HermiteInterpolator ( const HermiteInterpolator rhs)
Copy constructor.
Definition at line 98 of file HermiteInterpolator.cpp.
References thedYValues, theNPointsAvailable, theXValues, and theYValues.
98  :
99  theNPointsAvailable(rhs.theNPointsAvailable),
100  prodC(NULL),
101  sumC(NULL),
102  isComputed(false)
103 {
104  if(rhs.theXValues != NULL)
105  {
106  theXValues = new double[theNPointsAvailable];
107  for (int i=0;i<theNPointsAvailable;i++)
108  {
109  theXValues[i] = rhs.theXValues[i];
110  }
111  }
112  else
113  {
114  theXValues = NULL;
115  }
116
117  if(rhs.theYValues != NULL)
118  {
119  theYValues = new double[theNPointsAvailable];
120  for (int i=0;i<theNPointsAvailable;i++)
121  {
122  theYValues[i] = rhs.theYValues[i];
123  }
124  }
125  else
126  {
127  theYValues = NULL;
128  }
129
130  if(rhs.thedYValues != NULL)
131  {
132  thedYValues = new double[theNPointsAvailable];
133  for (int i=0;i<theNPointsAvailable;i++)
134  {
135  thedYValues[i] = rhs.thedYValues[i];
136  }
137  }
138  else
139  {
140  thedYValues = NULL;
141  }
142 }
Member Function Documentation
◆ Clear()
void ossimplugins::HermiteInterpolator::Clear ( )
protected
Definition at line 320 of file HermiteInterpolator.cpp.
References isComputed, prodC, sumC, thedYValues, theNPointsAvailable, theXValues, and theYValues.
Referenced by operator=(), and ~HermiteInterpolator().
321 {
322  if (theXValues != NULL)
323  {
324  delete[] theXValues;
325  theXValues = NULL;
326  }
327
328  if (theYValues != NULL)
329  {
330  delete[] theYValues;
331  theYValues = NULL;
332  }
333
334  if (thedYValues != NULL)
335  {
336  delete[] thedYValues;
337  thedYValues = NULL;
338  }
339
340  if (prodC != NULL)
341  {
342  delete[] prodC;
343  prodC = NULL;
344  }
345
346  if (sumC != NULL)
347  {
348  delete[] sumC;
349  prodC = NULL;
350  }
351  isComputed = false;
353 }
◆ Interpolate() [1/2]
int ossimplugins::HermiteInterpolator::Interpolate ( double  x,
double &  y,
double &  dy
) const
Parameters
xAbscissa of the interpolation
y[out] value of the point at the abscissa x
dy[out] value of the differential coefficient at abscissa x
Returns
Different of 0 if an error occurs
Definition at line 194 of file HermiteInterpolator.cpp.
References abs, isComputed, Precompute(), prodC, sumC, thedYValues, theNPointsAvailable, theXValues, theYValues, x, and y.
Referenced by ossimplugins::PlatformPosition::Interpolate().
195 {
196  //NOTE assume that x is increasing
197
198  // Not enough points to interpolate
199  if (theNPointsAvailable < 2) return -1;
200
201  y = 0.0;
202  dy = 0.0;
203
204  double epsilon = 0.0000000000001;
205
206  //Precompute useful value if they are not available
207  if (!isComputed)
208  {
209  Precompute();
210  }
211
212  for (int i = 0; i < theNPointsAvailable; i++)
213  {
214  double si = 0.0;
215  double hi = 1.0;
216  double ui = 0; //derivative computation
217  double r = x - theXValues[i];
218
219  // check if the point is on the list
220  if ( std::abs(r) < epsilon )
221  {
222  y = theYValues[i];
223  dy = thedYValues[i];
224  return 0;
225  }
226
227  for (int j = 0; j < theNPointsAvailable; j++)
228  {
229  if (j != i)
230  {
231  hi = hi * (x - theXValues[j]);
232  ui = ui + 1 / (x - theXValues[j]);//derivative computation
233  }
234  }
235  hi *= prodC[i];
236  si = sumC[i];
237
238  double f = 1.0 - 2.0 * r * si;
239
240  y += (theYValues[i] * f + thedYValues[i] * r) * hi * hi;
241
242  ui *= hi;//derivative computation
243
244  double fp = 2.0 * hi * (ui * (1.0 - 2.0 * si * r) - hi * si);//derivative computation
245  double d = hi * (hi + 2.0 * r * ui);//derivative computation
246
247  dy += fp * theYValues[i] + d * thedYValues[i];//derivative computation
248
249  }
250
251  return 0;
252 }
ossim_uint32 x
ossim_uint32 y
#define abs(a)
Definition: auxiliary.h:74
◆ Interpolate() [2/2]
double &  y
) const
Parameters
Returns
Definition at line 257 of file HermiteInterpolator.cpp.
References isComputed, Precompute(), prodC, sumC, thedYValues, theNPointsAvailable, theXValues, theYValues, x, and y.
258 {
259  //NOTE assume that x is increasing
260
261  // Not enough points to interpolate
262  if (theNPointsAvailable < 2) return -1;
263
264  y = 0.0;
265
266  //Precompute useful value if they are not available
267  if (!isComputed)
268  {
269  Precompute();
270  }
271
272  for (int i = 0; i < theNPointsAvailable; i++)
273  {
274  double si = 0.0;
275  double hi = 1.0;
276  double r = x - theXValues[i];
277
278  for (int j = 0; j < theNPointsAvailable; j++)
279  {
280  if (j != i)
281  {
282  hi = hi * (x - theXValues[j]);
283  }
284  }
285  hi *= prodC[i];
286  si = sumC[i];
287
288  double f = 1.0 - 2.0 * r * si;
289
290  y += (theYValues[i] * f + thedYValues[i] * r) * hi * hi;
291
292  }
293
294  return 0;
295 }
ossim_uint32 x
ossim_uint32 y
◆ operator=()
HermiteInterpolator & ossimplugins::HermiteInterpolator::operator= ( const HermiteInterpolator rhs)
Definition at line 144 of file HermiteInterpolator.cpp.
References Clear(), isComputed, prodC, sumC, thedYValues, theNPointsAvailable, theXValues, and theYValues.
145 {
146  Clear();
147  theNPointsAvailable = rhs.theNPointsAvailable;
148  isComputed = false;
149  if(rhs.theXValues != NULL)
150  {
151  theXValues = new double[theNPointsAvailable];
152  for (int i=0;i<theNPointsAvailable;i++)
153  {
154  theXValues[i] = rhs.theXValues[i];
155  }
156  }
157  else
158  {
159  theXValues = NULL;
160  }
161
162  if(rhs.theYValues != NULL)
163  {
164  theYValues = new double[theNPointsAvailable];
165  for (int i=0;i<theNPointsAvailable;i++)
166  {
167  theYValues[i] = rhs.theYValues[i];
168  }
169  }
170  else
171  {
172  theYValues = NULL;
173  }
174
175  if(rhs.thedYValues != NULL)
176  {
177  thedYValues = new double[theNPointsAvailable];
178  for (int i=0;i<theNPointsAvailable;i++)
179  {
180  thedYValues[i] = rhs.thedYValues[i];
181  }
182  }
183  else
184  {
185  thedYValues = NULL;
186  }
187  prodC = NULL;
188  sumC = NULL;
189
190  return *this;
191 }
◆ Precompute()
int ossimplugins::HermiteInterpolator::Precompute ( ) const
protected
Definition at line 297 of file HermiteInterpolator.cpp.
References isComputed, prodC, sumC, theNPointsAvailable, and theXValues.
Referenced by Interpolate().
298 {
299  prodC = new double[theNPointsAvailable];
300  sumC= new double[theNPointsAvailable];
301
302  for (int i = 0; i < theNPointsAvailable; i++)
303  {
304  prodC[i] = 1;
305  sumC[i] = 0;
306  for (int j = 0; j < theNPointsAvailable; j++)
307  {
308  if (j != i)
309  {
310  double v = 1.0 / (theXValues[i] - theXValues[j]);
311  prodC[i] *= v;
312  sumC[i] += v;
313  }
314  }
315  }
316  isComputed = true;
317  return 0;
318 }
Member Data Documentation
◆ isComputed
bool ossimplugins::HermiteInterpolator::isComputed
mutableprotected
Definition at line 85 of file HermiteInterpolator.h.
Referenced by Clear(), Interpolate(), operator=(), and Precompute().
◆ prodC
double* ossimplugins::HermiteInterpolator::prodC
mutableprotected
Definition at line 83 of file HermiteInterpolator.h.
◆ sumC
double* ossimplugins::HermiteInterpolator::sumC
mutableprotected
Definition at line 84 of file HermiteInterpolator.h.
◆ thedYValues
double* ossimplugins::HermiteInterpolator::thedYValues
protected
Definition at line 81 of file HermiteInterpolator.h.
Referenced by Clear(), HermiteInterpolator(), Interpolate(), and operator=().
◆ theNPointsAvailable
int ossimplugins::HermiteInterpolator::theNPointsAvailable
protected
Definition at line 78 of file HermiteInterpolator.h.
Referenced by Clear(), HermiteInterpolator(), Interpolate(), operator=(), and Precompute().
◆ theXValues
double* ossimplugins::HermiteInterpolator::theXValues
protected
Definition at line 79 of file HermiteInterpolator.h.
◆ theYValues
double* ossimplugins::HermiteInterpolator::theYValues
protected
Definition at line 80 of file HermiteInterpolator.h.
