Public Member Functions | Protected Attributes | List of all members
ossimplugins::IncidenceAngles Class Reference
This class represents Incidence Angles. More...
#include <IncidenceAngles.h>
 IncidenceAngles ()
 Constructor. More...
virtual ~IncidenceAngles ()
 Destructor. More...
 IncidenceAngles (const IncidenceAngles &rhs)
 Copy constructor. More...
IncidenceAnglesoperator= (const IncidenceAngles &rhs)
 Affectation operator. More...
bool saveState (ossimKeywordlist &kwl, const char *prefix=0) const
 Method to save object state to a keyword list. More...
bool loadState (const ossimKeywordlist &kwl, const char *prefix=0)
 Method to the load (recreate) the state of the object from a keyword list. More...
void set_numberOfCornerIncidenceAngles (const ossim_uint32 &numberOfCornerIncidenceAngles)
void set_centerInfoIncidenceAngle (const InfoIncidenceAngle &centerInfoIncidenceAngle)
void set_cornersInfoIncidenceAngle (const std::vector< InfoIncidenceAngle > &cornersInfoIncidenceAngle)
ossim_uint32 _numberOfCornerIncidenceAngles
 Number of incidence angles. More...
InfoIncidenceAngle _centerInfoIncidenceAngle
 Center InfoIncidenceAngle. More...
std::vector< InfoIncidenceAngle_tabCornersInfoIncidenceAngle
 Corners InfoIncidenceAngle. More...
Detailed Description
Definition at line 29 of file IncidenceAngles.h.
◆ IncidenceAngles() [1/2]
ossimplugins::IncidenceAngles::IncidenceAngles ( )
Constructor.
Definition at line 26 of file IncidenceAngles.cpp.
26  :
30 {
31 }
std::vector< InfoIncidenceAngle > _tabCornersInfoIncidenceAngle
◆ ~IncidenceAngles()
ossimplugins::IncidenceAngles::~IncidenceAngles ( )
virtual
Destructor.
Definition at line 33 of file IncidenceAngles.cpp.
34 {
35 }
◆ IncidenceAngles() [2/2]
ossimplugins::IncidenceAngles::IncidenceAngles ( const IncidenceAngles rhs)
Copy constructor.
Definition at line 38 of file IncidenceAngles.cpp.
38  :
39  _numberOfCornerIncidenceAngles(rhs._numberOfCornerIncidenceAngles),
40  _centerInfoIncidenceAngle(rhs._centerInfoIncidenceAngle),
41  _tabCornersInfoIncidenceAngle(rhs._tabCornersInfoIncidenceAngle)
42 {
43 }
Member Function Documentation
◆ loadState()
bool ossimplugins::IncidenceAngles::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
Returns
true if load OK, false on error
Definition at line 80 of file IncidenceAngles.cpp.
References _centerInfoIncidenceAngle, _numberOfCornerIncidenceAngles, _tabCornersInfoIncidenceAngle, ossimString::c_str(), ossimKeywordlist::find(), ossimplugins::InfoIncidenceAngle::loadState(), ossimNotify(), ossimNotifyLevel_WARN, ossimString::toString(), and ossimString::toUInt32().
81 {
82  static const char MODULE[] = "IncidenceAngles::loadState";
83
84  bool result = true;
85
86  ossimString s;
87  const char* lookup = 0;
88
89  std::string pfx("");
90  if (prefix)
91  {
92  pfx = prefix;
93  }
94  pfx += INCIDENCE_ANGLES;
95  pfx += ".";
96
97
98  lookup = kwl.find(pfx.c_str(), NUMBER_OF_CORNER_INCIDENCE_ANGLES);
99
100  if (lookup)
101  {
102  s = lookup;
104  }
105  else
106  {
108  << MODULE << " Keyword not found: " << NUMBER_OF_CORNER_INCIDENCE_ANGLES << " in "<<pfx.c_str()<<" path.\n";
109  result = false;
110  }
111
112  std::string s1 = pfx + CENTER_INCIDENCE_ANGLE;
113
114  result = _centerInfoIncidenceAngle.loadState(kwl, s1.c_str());
115
117  std::string s2 = pfx + CORNERS_INCIDENCE_ANGLE;
118  for (unsigned int i = 0; i < _numberOfCornerIncidenceAngles; ++i)
119  {
120  std::string s3 = s2 + "[" + ossimString::toString(i).c_str() + "]";
121  InfoIncidenceAngle iia;
122  result = iia.loadState(kwl, s3.c_str());
123  _tabCornersInfoIncidenceAngle.push_back(iia);
124  }
126  {
128  << MODULE << " Keyword " << NUMBER_OF_CORNER_INCIDENCE_ANGLES << " is different with the number of ImageNoise nodes \n";
129  }
130
131  return result;
132 }
Numeric to string methods.
ossim_uint32 toUInt32() const
bool loadState(const ossimKeywordlist &kwl, const char *prefix=0)
const char * c_str() const
Definition: ossimString.h:396
◆ operator=()
IncidenceAngles & ossimplugins::IncidenceAngles::operator= ( const IncidenceAngles rhs)
Definition at line 45 of file IncidenceAngles.cpp.
References _centerInfoIncidenceAngle, _numberOfCornerIncidenceAngles, and _tabCornersInfoIncidenceAngle.
46 {
47  _numberOfCornerIncidenceAngles = rhs._numberOfCornerIncidenceAngles;
48  _centerInfoIncidenceAngle = rhs._centerInfoIncidenceAngle;
49  _tabCornersInfoIncidenceAngle = rhs._tabCornersInfoIncidenceAngle;
50  return *this;
51 }
◆ print()
std::ostream & ossimplugins::IncidenceAngles::print ( std::ostream &  out) const
virtual
METHOD: print() Fulfills base-class pure virtual. Dumps contents of object to ostream.
Definition at line 135 of file IncidenceAngles.cpp.
References _centerInfoIncidenceAngle, _numberOfCornerIncidenceAngles, _tabCornersInfoIncidenceAngle, ossimKeywordlist::add(), ossimString::c_str(), ossimplugins::InfoIncidenceAngle::saveState(), and ossimString::toString().
136 {
137  out << setprecision(15) << setiosflags(ios::fixed)
138  << "\n IncidentAngles class data members:\n";
139
140  const char* prefix = 0;
141  ossimKeywordlist kwl;
142  ossimString pfx;
143  pfx += INCIDENCE_ANGLES;
144  ossimString s = pfx + "." + NUMBER_OF_CORNER_INCIDENCE_ANGLES;
145  kwl.add(prefix, s.c_str(), _numberOfCornerIncidenceAngles);
146
147  ossimString s1 = pfx + "." + CENTER_INCIDENCE_ANGLE;
149
150  ossimString s2 =pfx + "." + CORNERS_INCIDENCE_ANGLE;
151  for (unsigned int i = 0; i < _tabCornersInfoIncidenceAngle.size(); ++i)
152  {
153  ossimString s3 = s2 + "[" + ossimString::toString(i) + "]";
154  _tabCornersInfoIncidenceAngle[i].saveState(kwl, s3.c_str());
155  }
156  out << kwl;
157
158  return out;
159 }
bool saveState(ossimKeywordlist &kwl, const char *prefix=0) const
◆ saveState()
bool ossimplugins::IncidenceAngles::saveState ( ossimKeywordlist kwl,
) const
Parameters
kwlKeyword list to save to.
prefixadded to keys when saved.
Returns
Definition at line 53 of file IncidenceAngles.cpp.
54 {
55  std::string pfx("");
56  std::string pfx2("");
57  if (prefix)
58  {
59  pfx = prefix;
60  }
61  pfx += INCIDENCE_ANGLES;
62  pfx2 = pfx;
63  pfx2 += ".";
64
65  kwl.add(pfx2.c_str(), NUMBER_OF_CORNER_INCIDENCE_ANGLES, _numberOfCornerIncidenceAngles);
66
67  std::string s = pfx + "." + CENTER_INCIDENCE_ANGLE;
68  _centerInfoIncidenceAngle.saveState(kwl, s.c_str());
69
70  std::string s2 =pfx + "." + CORNERS_INCIDENCE_ANGLE;
71  for (unsigned int i = 0; i < _tabCornersInfoIncidenceAngle.size(); ++i)
72  {
73  std::string s3 = s2 + "[" + ossimString::toString(i).c_str() + "]";
74  _tabCornersInfoIncidenceAngle[i].saveState(kwl, s3.c_str());
75  }
76
77  return true;
78 }
◆ set_centerInfoIncidenceAngle()
void ossimplugins::IncidenceAngles::set_centerInfoIncidenceAngle ( const InfoIncidenceAngle centerInfoIncidenceAngle)
inline
Definition at line 76 of file IncidenceAngles.h.
77  {
78  _centerInfoIncidenceAngle = centerInfoIncidenceAngle;
79  }
◆ set_cornersInfoIncidenceAngle()
void ossimplugins::IncidenceAngles::set_cornersInfoIncidenceAngle ( const std::vector< InfoIncidenceAngle > &  cornersInfoIncidenceAngle)
inline
Definition at line 80 of file IncidenceAngles.h.
81  {
82  _tabCornersInfoIncidenceAngle = cornersInfoIncidenceAngle;
83  }
◆ set_numberOfCornerIncidenceAngles()
void ossimplugins::IncidenceAngles::set_numberOfCornerIncidenceAngles ( const ossim_uint32 numberOfCornerIncidenceAngles)
inline
Definition at line 72 of file IncidenceAngles.h.
73  {
74  _numberOfCornerIncidenceAngles = numberOfCornerIncidenceAngles;
75  }
Member Data Documentation
◆ _centerInfoIncidenceAngle
InfoIncidenceAngle ossimplugins::IncidenceAngles::_centerInfoIncidenceAngle
protected
Definition at line 94 of file IncidenceAngles.h.
Referenced by loadState(), operator=(), print(), and saveState().
◆ _numberOfCornerIncidenceAngles
ossim_uint32 ossimplugins::IncidenceAngles::_numberOfCornerIncidenceAngles
protected
Definition at line 90 of file IncidenceAngles.h.
◆ _tabCornersInfoIncidenceAngle
std::vector<InfoIncidenceAngle> ossimplugins::IncidenceAngles::_tabCornersInfoIncidenceAngle
protected
Definition at line 98 of file IncidenceAngles.h.
