This class is a factory able to construct Record base classes given the id of the wanted record. More...
#include <RadarSatRecordFactory.h>
RadarSatRecordFactory () | |
Constructor. More... | |
~RadarSatRecordFactory () | |
Destructor. More... | |
void | RegisterRecord (int id, RadarSatRecord *record) |
Add a new Record type available in this factory. More... | |
RadarSatRecord * | Instanciate (int id) |
Instanciates a new Record. More... | |
Protected Attributes | |
std::map< int, RadarSatRecord * > | _availableRecords |
Contains all the available Records for the factory. More... | |
Definition at line 26 of file RadarSatRecordFactory.h.
ossimplugins::RadarSatRecordFactory::RadarSatRecordFactory | ( | ) |
ossimplugins::RadarSatRecordFactory::~RadarSatRecordFactory | ( | ) |
RadarSatRecord * ossimplugins::RadarSatRecordFactory::Instanciate | ( | int | id | ) |
id | Id of the Record we want to instanciate |
Definition at line 24 of file RadarSatRecordFactory.cpp.
References _availableRecords, and ossimplugins::RadarSatRecord::Instanciate().
Referenced by ossimplugins::ossimRadarSatModel::open(), and ossimplugins::operator>>().
void ossimplugins::RadarSatRecordFactory::RegisterRecord | ( | int | id, |
RadarSatRecord * | record | ||
record | Record to add in the factory |
id | Id of the new available Record |
Definition at line 37 of file RadarSatRecordFactory.cpp.
References _availableRecords.
Referenced by ossimplugins::DataFactory::DataFactory(), ossimplugins::LeaderFactory::LeaderFactory(), ossimplugins::TrailerFactory::TrailerFactory(), and ossimplugins::VolumeDirFactory::VolumeDirFactory().
protected |
Definition at line 55 of file RadarSatRecordFactory.h.
Referenced by Instanciate(), RegisterRecord(), ossimplugins::DataFactory::~DataFactory(), ossimplugins::LeaderFactory::~LeaderFactory(), ossimplugins::TrailerFactory::~TrailerFactory(), and ossimplugins::VolumeDirFactory::~VolumeDirFactory().
