This class is able to read the SAR leader file descriptor record of the leader file.
This class is able to read a data histogram record - Processed data.
This class is able to read a data quality record.
~LeaderFactory()
Destructor.
LeaderFactory()
Contstructor.
This class is able to read a data histogram record - Signal data.
This class is able to read a radiometric data record.
This class is able to read a Radiometric Compensation data record.
This class is able to read a Detailed processing parameters record.
std::map< int, RadarSatRecord * > _availableRecords
Contains all the available Records for the factory.
This class is able to read the SAR leader data set summary record of the leader file.
This class is able to read a Attitude data record.
void RegisterRecord(int id, RadarSatRecord *record)
Add a new Record type available in this factory.
