Public Member Functions | List of all members
ossimplugins::VolumeDirFactory Class Reference
This class is a factory able to construct Record base classes. More...
#include <VolumeDirFactory.h>
Inheritance diagram for ossimplugins::VolumeDirFactory:
ossimplugins::RadarSatRecordFactory
 VolumeDirFactory ()
 Contstructor. More...
 ~VolumeDirFactory ()
 Destructor. More...
- Public Member Functions inherited from ossimplugins::RadarSatRecordFactory
 RadarSatRecordFactory ()
 Constructor. More...
 ~RadarSatRecordFactory ()
 Destructor. More...
void RegisterRecord (int id, RadarSatRecord *record)
 Add a new Record type available in this factory. More...
RadarSatRecordInstanciate (int id)
 Instanciates a new Record. More...
Additional Inherited Members
- Protected Attributes inherited from ossimplugins::RadarSatRecordFactory
std::map< int, RadarSatRecord * > _availableRecords
 Contains all the available Records for the factory. More...
Detailed Description
Definition at line 25 of file VolumeDirFactory.h.
◆ VolumeDirFactory()
ossimplugins::VolumeDirFactory::VolumeDirFactory ( )
Contstructor.
Definition at line 21 of file VolumeDirFactory.cpp.
References ossimplugins::RadarSatRecordFactory::RegisterRecord().
22 {
23  RegisterRecord(1, new VolumeDescriptorRecord());
27  RegisterRecord(5, new TextRecord());
28 }
FilePointerRecord SARLeaderFilePointerRecord
FilePointerRecord ImageOptionsFilePointerRecord
FilePointerRecord SARTrailerFilePointerRecord
void RegisterRecord(int id, RadarSatRecord *record)
◆ ~VolumeDirFactory()
ossimplugins::VolumeDirFactory::~VolumeDirFactory ( )
Destructor.
Definition at line 30 of file VolumeDirFactory.cpp.
References ossimplugins::RadarSatRecordFactory::_availableRecords.
31 {
32
33  std::map<int, RadarSatRecord*>::iterator i = _availableRecords.begin();
34
35  while (i != _availableRecords.end())
36  {
37  if ( (*i).second )
38  {
39  delete (*i).second;
40  (*i).second = 0;
41  }
42  ++i;
43  }
44  _availableRecords.clear();
45
46 }
