58 os << setprecision(precision);
120 is.get(buf, SZ,
128 std::string::size_type pos = os.
find(
129 if (pos != std::string::npos)
155 is.get(buf, SZ,
184 is.get(buf, SZ,
void toPoint(const std::string &s)
Initializes this point from string.
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
double nan()
bool contains(char aChar) const
std::string toString(ossim_uint32 precision=15) const
To string method.
ossim_float64 hgt
Height in meters above the ellipsiod.
void changeDatum(const ossimDatum *datum)
This will actually perform a shift.
unsigned int ossim_uint32
std::string::iterator erase(std::string::iterator p)
Erases the character at position p.
ossim_float64 toFloat64() const
static ossimDatumFactory * instance()
std::ostream & operator<<(std::ostream &out, const ossimDpt3d &rhs)
std::basic_istringstream< char > istringstream
Class for char input memory streams.
ossimDpt3d(const double &aX=0, const double &aY=0, const double &aZ=0)
std::string::size_type find(const std::string &s, std::string::size_type pos=0) const
Searches for s as a substring of *this, beginning at character pos of *this.
std::basic_ostream< char > ostream
Base class for char output streams.
bool isnan(const float &v)
