24 #include <kdu_region_decompressor.h> 25 #include <kdu_compressed.h> 26 #include <kdu_threads.h> 35 dims.pos.x = rect.
ul().
x;
36 dims.pos.y = rect.
ul().
y;
37 dims.size.x =
static_cast<int>(rect.
width());
38 dims.size.y =
height());
45 dims.pos.x + dims.size.x - 1,
46 dims.pos.y + dims.size.y - 1);
50 kdu_core::kdu_dims& region,
52 kdu_core::kdu_dims& clipRegion)
58 if ( codestream.exists() )
60 codestream.apply_input_restrictions(
61 0, 0, discard_levels, 0, NULL, kdu_core::KDU_WANT_OUTPUT_COMPONENTS);
63 kdu_core::kdu_dims dims;
64 codestream.get_dims(0, dims);
65 if ( region.intersects(dims) )
67 clipRegion = region.intersection(dims);
76 std::vector<ossimIrect>& imageDims,
77 std::vector<ossimIrect>& tileDims)
84 if ( codestream.exists() )
86 kdu_core::kdu_coords tileIdx(0, 0);
94 codestream.apply_input_restrictions(
100 kdu_core::KDU_WANT_OUTPUT_COMPONENTS);
102 kdu_core::kdu_dims dims;
103 codestream.get_dims(0, dims);
109 imageDims.push_back(imageRect);
113 kdu_core::kdu_dims mappedRegion;
114 codestream.map_region(0, dims, mappedRegion,
true);
116 kdu_core::kdu_tile tile = codestream.open_tile(tileIdx);
119 codestream.get_tile_dims( tile.get_tile_idx(), 0, dims );
127 tileDims.push_back(tileRect);
140 codestream.apply_input_restrictions(
146 kdu_core::KDU_WANT_OUTPUT_COMPONENTS);
149 if ( (imageDims.size() != tileDims.size()) ||
150 (tileDims.size() != levels+1) )
165 kdu_core::kdu_codestream& codestream,
167 kdu_core::kdu_thread_env* threadEnv,
168 kdu_core::kdu_thread_queue* threadQueue,
173 if ( channelMapping && destTile && codestream.exists())
177 kdu_core::kdu_dims region;
180 kdu_core::kdu_dims clipRegion;
186 if (region != clipRegion)
195 int max_layers = INT_MAX;
196 kdu_core::kdu_coords expand_numerator(1,1);
197 kdu_core::kdu_coords expand_denominator(1,1);
199 kdu_core::kdu_component_access_mode access_mode =
200 kdu_core::KDU_WANT_OUTPUT_COMPONENTS;
201 bool fastest =
false;
204 kdu_supp::kdu_region_decompressor krd;
205 if ( krd.start( codestream,
220 std::string e =
"kdu_region_decompressor::start error!";
224 bool expand_monochrome =
false;
226 kdu_core::kdu_coords buffer_origin;
229 int row_gap = region.size.x;
230 int suggested_increment =
static_cast<int>(destTile->
getSize());
231 int max_region_pixels = suggested_increment;
232 kdu_core::kdu_dims incomplete_region = clipRegion;
233 kdu_core::kdu_dims new_region;
234 bool measure_row_gap_in_pixels =
true;
237 int precision_bits = (SCALAR !=
OSSIM_SINT16) ? codestream.get_bit_depth(0,
true) : 0;
244 std::vector<kdu_core::kdu_byte*> channel_bufs(BANDS);
250 while ( !incomplete_region.is_empty() )
252 if ( krd.process( &channel_bufs.front(),
262 measure_row_gap_in_pixels ) ==
false )
269 if( threadEnv && threadQueue )
275 threadEnv->join(threadQueue,
true);
292 std::vector<kdu_core::kdu_uint16*> channel_bufs(BANDS);
295 channel_bufs[band] =
static_cast<kdu_core::kdu_uint16*
299 while ( !incomplete_region.is_empty() )
305 if ( krd.process( &channel_bufs.front(),
315 measure_row_gap_in_pixels ) ==
false )
322 if( threadEnv && threadQueue )
328 threadEnv->join(threadQueue,
true);
348 std::vector<ossim_float32*> channel_bufs(BANDS);
354 while ( !incomplete_region.is_empty() )
360 if ( krd.process( &channel_bufs.front(),
370 measure_row_gap_in_pixels ) )
376 if( threadEnv && threadQueue )
382 threadEnv->join(threadQueue,
true);
396 << __FILE__ <<
" " << __LINE__ <<
" Unhandle scalar: " 405 if ( krd.finish() == false )
408 << __FILE__ <<
" " << __LINE__
409 <<
"kdu_region_decompressor::proces error!\n";
424 catch ( kdu_core::kdu_exception exc )
427 if ( threadEnv != 0 )
429 threadEnv->handle_exception(exc);
432 e <<
"Caught exception from kdu_region_decompressor: " << exc <<
"\n";
435 catch ( std::bad_alloc& )
437 if ( threadEnv != 0 )
439 threadEnv->handle_exception(KDU_MEMORY_EXCEPTION);
442 "Caught exception from kdu_region_decompressor: std::bad_alloc";
448 "Caught unhandled exception from kdu_region_decompressor";
466 if (destTile->
write(f))
469 <<
"wrote: " << f << std::endl;
483 kdu_core::kdu_thread_env* threadEnv,
484 kdu_core::kdu_thread_queue* threadQueue,
489 if ( destTile && codestream.exists())
493 kdu_core::kdu_dims region;
496 kdu_core::kdu_dims clipRegion;
502 if (region != clipRegion)
511 kdu_supp::kdu_channel_mapping* mapping = 0;
512 int max_layers = INT_MAX;
513 kdu_core::kdu_coords expand_numerator(1,1);
514 kdu_core::kdu_coords expand_denominator(1,1);
516 kdu_core::kdu_component_access_mode access_mode =
517 kdu_core::KDU_WANT_OUTPUT_COMPONENTS;
518 bool fastest =
false;
529 int single_component = band;
532 kdu_supp::kdu_region_decompressor krd;
534 if ( krd.start( codestream,
549 std::string e =
553 vector<int> channel_offsets(1);
554 channel_offsets[0] = 0;
556 kdu_core::kdu_coords buffer_origin;
559 int row_gap = region.size.x;
560 int suggested_increment =
getSize());
561 int max_region_pixels = suggested_increment;
562 kdu_core::kdu_dims incomplete_region = clipRegion;
563 kdu_core::kdu_dims new_region;
564 bool measure_row_gap_in_pixels =
true;
567 int precision_bits = (SCALAR !=
true) : 0;
574 kdu_core::kdu_byte* buffer = destTile->
getUcharBuf(band);
576 while ( !incomplete_region.is_empty() )
578 if ( krd.process( buffer,
579 &channel_offsets.front(),
588 measure_row_gap_in_pixels ) )
594 if( threadEnv && threadQueue)
600 threadEnv->join(threadQueue,
true);
617 kdu_core::kdu_uint16* buffer =
618 static_cast<kdu_core::kdu_uint16*
>(destTile->
getBuf(band));
620 while ( !incomplete_region.is_empty() )
626 if ( krd.process( buffer,
627 &channel_offsets.front(),
636 measure_row_gap_in_pixels ) ==
false )
646 if( threadEnv && threadQueue)
648 threadEnv->join(threadQueue,
true);
670 while ( !incomplete_region.is_empty() )
676 if ( krd.process( buffer,
677 &channel_offsets.front(),
686 measure_row_gap_in_pixels ) ==
false )
692 if( threadEnv && threadQueue)
698 threadEnv->join(threadQueue,
true);
713 << __FILE__ <<
" " << __LINE__ <<
" Unhandle scalar: " 722 if ( krd.finish() == false )
726 << __FILE__ <<
" " << __LINE__
727 <<
" kdu_region_decompressor::proces error!" << std::endl;
745 catch ( kdu_core::kdu_exception exc )
748 if ( threadEnv != 0 )
750 threadEnv->handle_exception(exc);
753 e <<
"\n";
757 catch ( std::bad_alloc& )
759 if ( threadEnv != 0 )
761 threadEnv->handle_exception(KDU_MEMORY_EXCEPTION);
764 "Caught exception from kdu_region_decompressor: std::bad_alloc";
770 "Caught unhandled exception from kdu_region_decompressor";
788 if (destTile->
write(f))
791 <<
820 p = MINP + RANGE * p;
821 p = (p < MAXP ? (p > MINP ? p : MINP) : MAXP);
840 p = MINP + RANGE * p;
841 p = (p < MAXP ? (p > MINP ? p : MINP) : MAXP);
853 << __FILE__ <<
" " << __LINE__ <<
" Unhandle scalar: " 862 out <<
"codestream debug:" 863 <<
"exists: " << (cs.exists()?
"true":
"false");
866 const int BANDS = cs.get_num_components(
true);
867 out <<
"\ncomponents: " << BANDS;
868 for (
int i = 0; i < BANDS; ++i)
870 kdu_core::kdu_dims dims;
871 cs.get_dims(i, dims,
true);
872 out <<
"\nbit_depth[" << i <<
"]: " << cs.get_bit_depth(i,
true)
873 <<
"\nsigned[" << i <<
"]: " << cs.get_signed(i,
true)
874 <<
"\ndims[" << i <<
877 out <<
"\nlevels: " << cs.get_min_dwt_levels();
885 print(out, dims.pos);
887 print(out, dims.size);
894 out <<
"(" << coords.x <<
", " << coords.y <<
virtual const ossim_float64 * getMaxPix() const
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
virtual const ossim_uint8 * getUcharBuf() const
ossim_uint32 height() const
Numeric to string methods.
const ossimIpt & ul() const
std::ostream & print(H5::H5File *file, std::ostream &out)
Print method.
virtual bool write(const ossimFilename &f) const
Writes tile to stream.
std::ostream & print(std::ostream &out, kdu_core::kdu_codestream &cs)
Convenience print method for kdu_codestream.
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
virtual ossimIrect getImageRectangle() const
ossim_uint32 width() const
void unNormalizeTile(ossimImageData *result)
Un-normalizes float tile from kdu_region_decompressor::process method.
virtual const ossim_float32 * getFloatBuf() const
virtual const ossim_float64 * getMinPix() const
bool clipRegionToImage(kdu_core::kdu_codestream &codestream, kdu_core::kdu_dims ®ion, int discard_levels, kdu_core::kdu_dims &clipRegion)
Sets clipRegion from region, and image dimensions for level.
virtual void makeBlank()
void getDims(const ossimIrect &rect, kdu_core::kdu_dims &dims)
Convenience method to convert ossimIrect to kdu_dims.
bool copyRegionToTile(kdu_supp::kdu_channel_mapping *channelMapping, kdu_core::kdu_codestream &codestream, int discard_levels, kdu_core::kdu_thread_env *threadEnv, kdu_core::kdu_thread_queue *threadQueue, ossimImageData *destTile)
Copies region from codestream to tile at a given rlevel.
virtual ossim_uint32 getSize() const
Returns the total number of pixels in a tile for all bands.
void getRect(const kdu_core::kdu_dims &dims, ossimIrect &rect)
Convenience method to convert kdu_core::kdu_dims to ossimIrect.
bool getCodestreamDimensions(kdu_core::kdu_codestream &codestream, std::vector< ossimIrect > &imageDims, std::vector< ossimIrect > &tileDims)
Gets image and tile dimensions from codestream for each resolution level (rlevel).
std::basic_ostream< char > ostream
Base class for char output streams.
