ossimLasReader.h
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // File: ossimLasReader.h
4 //
5 // License: MIT
6 //
7 // See LICENSE.txt file in the top level directory for more details.
8 //
9 // Author: David Burken
10 //
11 //----------------------------------------------------------------------------
12 // $Id$
13 #ifndef ossimLasReader_HEADER
14 #define ossimLasReader_HEADER 1
15
17 #include <ossim/base/ossimDpt.h>
18 #include <ossim/base/ossimRefPtr.h>
23 #include <mutex>
24
25 class ossimLasHdr;
27
34 {
35 public:
36
39
41  virtual ~ossimLasReader();
42
55  virtual bool open();
56
64  virtual bool isOpen()const;
65
69  virtual void close();
70
77  ossim_uint32 resLevel=0);
78
91  virtual bool getTile(ossimImageData* result, ossim_uint32 resLevel=0);
92
100  virtual ossim_uint32 getNumberOfInputBands() const;
101
112  virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel = 0) const;
113
124  virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel = 0) const;
125
136  virtual ossim_uint32 getImageTileWidth() const;
137
148  virtual ossim_uint32 getImageTileHeight() const;
149
151  virtual ossim_uint32 getTileWidth() const;
152
154  virtual ossim_uint32 getTileHeight() const;
155
158
163  virtual void getEntryList(std::vector<ossim_uint32>& entryList) const;
164
166  virtual ossim_uint32 getCurrentEntry() const;
167
172  virtual bool setCurrentEntry(ossim_uint32 entryIdx);
173
175  virtual ossimString getShortName() const;
176
178  virtual ossimString getLongName() const;
179
186
188  virtual double getMinPixelValue(ossim_uint32 band=0) const;
189
191  virtual double getMaxPixelValue(ossim_uint32 band=0) const;
192
194  virtual double getNullPixelValue(ossim_uint32 band=0) const;
195
200  virtual bool saveState(ossimKeywordlist& kwl, const char* prefix=0)const;
201
206  virtual bool loadState(const ossimKeywordlist& kwl, const char* prefix=0);
207
217  virtual void setProperty(ossimRefPtr<ossimProperty> property);
218
223  virtual ossimRefPtr<ossimProperty> getProperty(const ossimString& name) const;
224
229  virtual void getPropertyNames(std::vector<ossimString>& propertyNames) const;
230
233
234  virtual ossim_uint32 getNumberOfOutputBands() const;
235
236 protected:
242  virtual void completeOpen();
243
244 private:
245
250  class Bucket
251  {
252  public:
253  Bucket(): a(0.0), c(0), red(0), green(0), blue(0) {}
254
255  void add(const ossim_float64& point) { a += point; ++c; }
256  ossim_float64 getValue() const { return ( c ? a/c : -99999.0 ); }
257  void setRed(const ossim_uint16& value) { red = value; }
258  void setGreen(const ossim_uint16& value) { green = value; }
259  void setBlue(const ossim_uint16& value) { blue = value; }
260  void setIntensity(const ossim_uint16& value) { intensity = value; }
261  ossim_uint16 getRed() const { return red; }
262  ossim_uint16 getGreen() const { return green; }
263  ossim_uint16 getBlue() const { return blue; }
264  ossim_uint16 getIntensity() const { return intensity; }
265
266  ossim_float64 a; // accumulation
267  ossim_uint32 c; // count
272  };
273
274  bool init();
275
276  void initValues(); // m_ul, m_lr, m_minZ
277  bool initProjection();
278  void initTile();
279  void initUnits(const ossimKeywordlist& geomKwl);
280  bool parseVarRecords();
281
286
288  void getScale(ossimDpt& scale, ossim_uint32 resLevel) const;
289
291  void setGsd( const ossim_float64& gsd );
292
293  void convertToMeters(ossim_float64& value) const;
294
299
310  std::mutex m_mutex;
311  bool m_scan; // Scan for bounds at open.
314 TYPE_DATA
315 };
316
317 inline bool ossimLasReader::isOpen()const
318 {
319  return ( m_str.is_open() && m_hdr );
320 }
321
323 {
324  if ( value )
325  {
327  value = m_unitConverter->getMeters();
328  }
329 }
330
331 #endif /* #ifndef ossimLasReader_HEADER */
ossim_float64 m_minZ
Gets bands.
Close method.
ossimRefPtr< ossimImageData > m_tile
ossimUnitConversionTool * m_unitConverter
ossimLasReader()
default constructor
std::ifstream m_str
ossimUnitType
void convertToMeters(ossim_float64 &value) const
std::basic_ifstream< char > ifstream
Class for char input file streams.
Definition: ossimIosFwd.h:44
void setGsd(const ossim_float64 &gsd)
Sets m_gsd data member and projection if projection is set.
Container class to hold accumulated point data.
void setValue(double value, ossimUnitType unitType=OSSIM_METERS)
void setBlue(const ossim_uint16 &value)
void getScale(ossimDpt &scale, ossim_uint32 resLevel) const
Get the scale for resLevel.
virtual bool open()
open method.
virtual bool isOpen() const
is open method.
bool initFromExternalMetadata()
Looks for external FGDC text file to initialize projection from.
Set propterty method.
void setRed(const ossim_uint16 &value)
Get propterty method.
void setIntensity(const ossim_uint16 &value)
unsigned short ossim_uint16
ossim_float64 m_maxZ
ossim_uint8 m_entry
ossimScalarType getOutputScalarType() const
double ossim_float64
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel=0)
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab fr...
Gets tile width.
ossimLasPointRecordInterface * getNewPointRecord() const
Returns a point of type.
#define TYPE_DATA
Definition: ossimRtti.h:339
Gets tile height.
void initUnits(const ossimKeywordlist &geomKwl)
unsigned int ossim_uint32
void setGreen(const ossim_uint16 &value)
ossimUnitType m_units
ossimScalarType
void add(const ossim_float64 &point)
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const
Gets lines.
Get propterty names.
virtual ossim_uint32 getNumberOfDecimationLevels() const
This class defines an abstract Handler which all image handlers(loaders) should derive from...
Will complete the opening process.
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const
Gets samples.
OSSIM Interface for LAS point record types.
ossimLasHdr * m_hdr
virtual destructor
std::mutex m_mutex
unsigned char ossim_uint8
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
Gets entry list.
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
ossimRefPtr< ossimProjection > m_proj
OSSIM LAS LIDAR reader.
