16 #ifndef ossimImageHandler_HEADER 17 #define ossimImageHandler_HEADER 1 41 OSSIM_OVERVIEW_COMPRESSION_NONE= 0,
45 OSSIM_OVERVIEW_COMPRESSION_PACKBITS
71 virtual bool openOverview();
82 virtual bool openOverview(
const ossimFilename& overview_file);
89 virtual void closeOverview();
101 virtual bool hasOverviews()
const;
121 virtual ossimFilename createDefaultHistogramFilename()
const;
126 virtual ossimFilename createDefaultValidVerticesFilename()
const;
137 virtual bool writeValidImageVertices(
const std::vector<ossimIpt>& vertices,
146 virtual bool openValidVertices(
const ossimFilename& vertices_file);
153 virtual bool openValidVertices();
165 virtual bool open() = 0;
180 virtual bool open(std::shared_ptr<ossim::ImageHandlerState> state);
185 virtual void close();
192 virtual bool isOpen()
const=0;
204 virtual bool buildHistogram(
217 virtual bool buildAllHistograms(
226 virtual bool buildOverview(ossimImageHandlerOverviewCompressionType compressionType = OSSIM_OVERVIEW_COMPRESSION_NONE,
229 bool includeFullResFlag=
false);
237 virtual bool buildAllOverviews(ossimImageHandlerOverviewCompressionType compressionType = OSSIM_OVERVIEW_COMPRESSION_NONE,
240 bool includeFullResFlag=
false);
250 ossimImageHandlerOverviewCompressionType compressionType = OSSIM_OVERVIEW_COMPRESSION_NONE,
253 bool includeFullResFlag=
false);
399 const char* prefix=0)
const;
406 const char* prefix=0);
417 virtual bool isValidRLevel(
ossim_uint32 resLevel)
const;
445 virtual bool isBandSelector()
const;
458 virtual bool setOutputBandList(
const std::vector<ossim_uint32>& band_list);
468 virtual bool setOutputToInputBandList();
475 virtual bool isIdentityBandList(
const std::vector<ossim_uint32>& bandList )
const;
484 virtual bool isImageTiled()
const;
502 virtual bool hasMetaData()
const;
506 virtual bool hasLut()
const;
514 virtual void loadMetaData();
589 std::string& name )
const;
596 virtual void getEntryList(std::vector<ossim_uint32>& entryList)
const;
606 virtual void getEntryNames(std::vector<ossimString>& entryNames)
const;
619 bool useEntryIndex()
const;
635 virtual void getPropertyNames(std::vector<ossimString>& propertyNames)
const;
666 bool set_e0_prefix=
false)
const;
684 void getFilenameWithThisExt(
const ossimString& ext,
692 bool getOpenOverviewFlag()
const;
701 void setOpenOverviewFlag(
bool flag);
706 virtual void setSupplementaryDirectory(
const ossimFilename& dir);
711 virtual const ossimFilename& getSupplementaryDirectory()
const;
733 virtual bool getRgbBandList(std::vector<ossim_uint32>& bandList)
const;
737 std::shared_ptr<T>
getStateAs(){
return dynamic_pointer_cast<T> (m_state);}
739 std::shared_ptr<const T>
getStateAs()
const{
const T> (m_state);}
740 std::shared_ptr<ossim::ImageHandlerState>
getState(){
return m_state;}
741 std::shared_ptr<const ossim::ImageHandlerState>
getState()
const{
return m_state;}
742 void setState(std::shared_ptr<ossim::ImageHandlerState> state){m_state = state;}
781 bool initVertices(
const char* file);
789 virtual void completeOpen();
805 virtual void establishDecimationFactors();
817 virtual bool setOutputBandList(
const std::vector<ossim_uint32>& inBandList,
818 std::vector<ossim_uint32>& outBandList);
856 std::shared_ptr<ossim::ImageHandlerState>
m_state;
This will return the bounding rect of the source.
ossimRefPtr< ossimImageGeometry > theGeometry
ossimFilename theImageFile
void setState(std::shared_ptr< ossim::ImageHandlerState > state)
std::vector< ossimDpt > theDecimationFactors
std::shared_ptr< ossim::ImageHandlerState > m_state
bool theOpenOverviewFlag
If true opening of overviews will be attempted.
std::shared_ptr< ossim::ImageHandlerState > getState()
virtual ossim_uint32 getNumberOfDecimationLevels() const
Will return the number of resolution levels.
std::shared_ptr< const ossim::ImageHandlerState > getState() const
ossimFilename theSupplementaryDirectory
ossimPixelType thePixelType
std::shared_ptr< T > getStateAs()
virtual void setImageGeometry(const ossimImageGeometry *geom)
Default implementation sets geometry of the first input to the geometry specified.
virtual void saveImageGeometry() const
Default method to call input's saveImageGeometry.
virtual void getValidImageVertices(std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const
ordering specifies how the vertices should be arranged.
unsigned int ossim_uint32
ossimPixelType getPixelType() const
Returns the raster pixel alignment type.
vector< ossimIpt > theValidImageVertices
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
ossimImageMetaData theMetaData
ossimRefPtr< ossimImageHandler > theOverview
This class defines an abstract Handler which all image handlers(loaders) should derive from...
void setImageID(const ossimString &id)
Sets the image ID in case it is externally generated.
ossimFilename theOverviewFile
virtual void initialize()=0
ossimRefPtr< ossimNBandLutDataObject > theLut
virtual bool canConnectMyInputTo(ossim_int32 myInputIndex, const ossimConnectableObject *object) const =0
required to be overriden by derived classes
virtual void getDecimationFactor(ossim_uint32 resLevel, ossimDpt &result) const
Will return the decimation factor for the given resolution level.
const ossimString & getImageID() const
Fetches the image ID.
std::shared_ptr< const T > getStateAs() const
virtual void getDecimationFactors(std::vector< ossimDpt > &decimations) const
Will return an array of all decimations for each resolution level.
ossim_uint32 theStartingResLevel
theStartingResLevel If set to something other than zero(default) this is indicative that the reader i...
