14 #ifndef ossimMapProjection_HEADER 15 #define ossimMapProjection_HEADER 1 65 const double& heightAboveEllipsoid,
68 virtual void lineSampleToEastingNorthing(
const ossimDpt& liineSample,
71 virtual void eastingNorthingToLineSample(
const ossimDpt& eastingNorthing,
74 virtual void eastingNorthingToWorld(
79 virtual double getFalseEasting()
const;
82 virtual double getFalseNorthing()
const;
90 virtual double getStandardParallel1()
const;
98 virtual double getStandardParallel2()
const;
100 virtual void update();
115 virtual double getA()
const;
116 virtual double getB()
const;
117 virtual double getF()
const;
125 virtual const ossimDpt& getDecimalDegreesPerPixel()
const;
127 virtual const ossimDpt& getUlEastingNorthing()
const;
128 virtual const ossimGpt& getUlGpt()
const;
132 virtual bool isGeographic()
const;
147 virtual void applyScale(
const ossimDpt& scale,
bool recenterTiePoint);
153 virtual void setAB(
double a,
double b);
160 virtual void setDatum(
const ossimDatum* datum);
170 virtual void setOrigin(
const ossimGpt& origin);
172 virtual void setMetersPerPixel(
const ossimDpt& gsd);
173 virtual void setDecimalDegreesPerPixel(
174 virtual void setUlTiePoints(
const ossimGpt& gpt);
175 virtual void setUlTiePoints(
const ossimDpt& eastingNorthing);
176 virtual void setUlEastingNorthing(
const ossimDpt& ulEastingNorthing);
177 virtual void setUlGpt(
const ossimGpt& ulGpt);
185 const char* prefix=0)
const;
192 const char* prefix=0);
206 virtual void computeDegreesPerPixel();
214 virtual void computeMetersPerPixel();
216 void setMatrix(
double rotation,
220 void setMatrixScale(
const ossimDpt& scale);
222 void setMatrixRotation(
double rotation);
224 void setMatrixTranslation(
const ossimDpt& translation);
251 void snapTiePointToOrigin();
253 void setElevationLookupFlag(
bool flag);
254 bool getElevationLookupFlag()
const;
257 return theModelTransformUnitType;
261 theModelTransformUnitType = unit;
302 void updateFromTransform();
ossimMatrix4x4 theModelTransform
ossimUnitType getModelTransformUnitType() const
ossimDpt theUlEastingNorthing
Hold tie point as easting northing.
virtual ossimGpt inverse(const ossimDpt &pp) const
ossimGpt theUlGpt
Hold tie point in decimal degrees.
ossimMatrix4x4 theInverseModelTransform
bool theElevationLookupFlag
virtual bool isEqualTo(const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const
virtual bool operator==(const ossimProjection &projection) const =0
ossimDpt theMetersPerPixel
Holds the number of meters per pixel.
bool hasModelTransform() const
ossimUnitType theModelTransformUnitType
virtual ossimDpt getMetersPerPixel() const =0
virtual void lineSampleHeightToWorld(const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const =0
unsigned int ossim_uint32
ossimUnitType theProjectionUnits
Linear units of the projection as indicated in the projection's specification:
const ossimEllipsoid & getEllipsoid() const
ossim_uint32 thePcsCode
Projection Coordinate System(PCS) code.
ossimUnitType getProjectionUnits() const
OSSIM considers all map projection coordinates (including false eastings and northings) to be in mete...
virtual ossimGpt origin() const =0
virtual ossimDpt forward(const ossimGpt &wp) const
ossimDpt theDegreesPerPixel
Hold the decimal degrees per pixel.
void setModelTransformUnitType(ossimUnitType unit)
ossimEllipsoid theEllipsoid
This method verifies that the projection parameters match the current pcs code.
ossimDpt theFalseEastingNorthing
Hold the false easting northing.
virtual void lineSampleToWorld(const ossimDpt &lineSampPt, ossimGpt &worldPt) const =0
void setProjectionUnits(ossimUnitType units)
virtual void worldToLineSample(const ossimGpt &worldPoint, ossimDpt &lineSampPt) const =0
virtual bool isAffectedByElevation() const
Implementation of pure virtual ossimProjection::isAffectedByElevation method.
std::basic_ostream< char > ostream
Base class for char output streams.
const ossimDatum * theDatum
This is only set if we want to have built in datum shifting.
