ossimMaxMosaic.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 // Copyright (C) 2005 SANZ Inc.
3 //
4 // License: LGPL
5 //
6 // See LICENSE.txt file in the top level directory for more details.
7 //
8 // Author: Kenneth Melero (kmelero@sanz.com)
9 //
10 // Description: This combiner is designed to "float" the maximum pixel value
11 // of all inputs to top of the mosaic output.
12 //
13 //*************************************************************************
14 // $Id: ossimMaxMosaic.cpp 23257 2015-04-13 16:57:14Z dburken $
15
19 #include <ossim/base/ossimTrace.h>
20
21 static const ossimTrace traceDebug("ossimMaxMosaic:debug");
22
23 using namespace std;
24
28  theTile(NULL)
29 {
30 }
31
33  : ossimImageCombiner(inputSources),
34  theTile(NULL)
35 {
36 }
37
38
40 {
41 }
42
44  const ossimIrect& tileRect,
45  ossim_uint32 resLevel)
46 {
47  long size = getNumberOfInputs();
48  ossim_uint32 layerIdx = 0;
49  // If there is only one in the mosaic then just return it.
50  if(size == 1)
51  {
52  return getNextTile(layerIdx, 0, tileRect, resLevel);
53  }
54
55  ossimIpt origin = tileRect.ul();
56  ossim_uint32 w = tileRect.width();
57  ossim_uint32 h = tileRect.height();
58
59  if(!theTile.valid())
60  {
61  // First time through...
62  allocate();
63
64  // If we still don't have a buffer then we will leave.
65  if(!theTile.valid())
66  {
68  }
69  }
70
71  ossim_uint32 tileW = theTile->getWidth();
72  ossim_uint32 tileH = theTile->getHeight();
73  if((w != tileW)||
74  (h != tileH))
75  {
76  theTile->setWidth(w);
77  theTile->setHeight(h);
78  if((w*h)!=(tileW*tileH))
79  {
81  }
82  }
83  theTile->setOrigin(origin);
84
85  //---
86  // General Note:
87  //
88  // Note: I will not check for disabled or enabled since we have
89  // no clear way to handle this within a mosaic. The default will be
90  // to do a simple a A over B type mosaic. Derived classes should
91  // check for the enabled and disabled and always
92  // use this default implementation if they are disabled.
93  //---
94  theTile->setOrigin(origin);
95  theTile->makeBlank();
96  switch(theTile->getScalarType())
97  {
98  case OSSIM_UCHAR:
99  {
100  if(!hasDifferentInputs())
101  {
102  return combine(static_cast<ossim_uint8>(0),
103  tileRect,
104  resLevel);
105  }
106  else
107  {
108  return combineNorm(static_cast<ossim_uint8>(0),
109  tileRect,
110  resLevel);
111  }
112  }
113  case OSSIM_SINT8:
114  {
115  if(!hasDifferentInputs())
116  {
117  return combine(static_cast<ossim_sint8>(0),
118  tileRect,
119  resLevel);
120  }
121  else
122  {
123  return combineNorm(static_cast<ossim_sint8>(0),
124  tileRect,
125  resLevel);
126  }
127  }
128  case OSSIM_FLOAT:
130  {
131  if(!hasDifferentInputs())
132  {
133  return combine(static_cast<float>(0),
134  tileRect,
135  resLevel);
136  }
137  else
138  {
139  return combineNorm(static_cast<float>(0),
140  tileRect,
141  resLevel);
142  }
143  }
144  case OSSIM_USHORT16:
145  case OSSIM_USHORT11:
146  case OSSIM_USHORT12:
147  case OSSIM_USHORT13:
148  case OSSIM_USHORT14:
149  case OSSIM_USHORT15:
150  {
151  if(!hasDifferentInputs())
152  {
153  return combine(static_cast<ossim_uint16>(0),
154  tileRect,
155  resLevel);
156  }
157  else
158  {
159  return combineNorm(static_cast<ossim_uint16>(0),
160  tileRect,
161  resLevel);
162  }
163  }
164  case OSSIM_SSHORT16:
165  {
166  if(!hasDifferentInputs())
167  {
168  return combine(static_cast<ossim_sint16>(0),
169  tileRect,
170  resLevel);
171  }
172  else
173  {
174  return combineNorm(static_cast<ossim_sint16>(0),
175  tileRect,
176  resLevel);
177  }
178  }
179  case OSSIM_SINT32:
180  {
181  if(!hasDifferentInputs())
182  {
183  return combine(static_cast<ossim_sint32>(0),
184  tileRect,
185  resLevel);
186  }
187  else
188  {
189  return combineNorm(static_cast<ossim_sint32>(0),
190  tileRect,
191  resLevel);
192  }
193  }
194  case OSSIM_UINT32:
195  {
196  if(!hasDifferentInputs())
197  {
198  return combine(static_cast<ossim_uint32>(0),
199  tileRect,
200  resLevel);
201  }
202  else
203  {
204  return combineNorm(static_cast<ossim_uint32>(0),
205  tileRect,
206  resLevel);
207  }
208  }
209  case OSSIM_DOUBLE:
211  {
212  if(!hasDifferentInputs())
213  {
214  return combine(static_cast<double>(0),
215  tileRect,
216  resLevel);
217  }
218  else
219  {
220  return combineNorm(static_cast<double>(0),
221  tileRect,
222  resLevel);
223  }
224  }
226  default:
227  {
229  << "Scalar type = " << theTile->getScalarType()
230  << " Not supported by ossimMaxMosaic" << endl;
231  }
232  }
233
235 }
236
238 {
240  theTile = NULL;
241 }
242
244 {
245  theTile = NULL;
246
247  if( (getNumberOfInputs() > 0) && getInput(0) )
248  {
250  theTile->initialize();
251  }
252 }
253
255  const char* prefix)const
256 {
257  return ossimImageCombiner::saveState(kwl, prefix);
258 }
259
261  const char* prefix)
262 {
263  return ossimImageCombiner::loadState(kwl, prefix);
264 }
265
267  T,// dummy template variable
268  const ossimIrect& tileRect,
269  ossim_uint32 resLevel)
270 {
271  ossim_uint32 layerIdx = 0;
272  ossimRefPtr<ossimImageData> destination = theTile;
273
274  ossimRefPtr<ossimImageData> currentImageData =
275  getNextNormTile(layerIdx, 0, tileRect, resLevel);
276
277  if(!currentImageData)
278  {
279  return currentImageData;
280  }
281
282  std::vector<float*> srcBands(theLargestNumberOfInputBands);
283  std::vector<float> srcBandsNullPix(theLargestNumberOfInputBands);
284  std::vector<T*> destBands(theLargestNumberOfInputBands);
285  std::vector<T> destBandsNullPix(theLargestNumberOfInputBands);
286  std::vector<T> destBandsMinPix(theLargestNumberOfInputBands);
287  std::vector<T> destBandsMaxPix(theLargestNumberOfInputBands);
288  //float** srcBands = new float*[theLargestNumberOfInputBands];
289  //float* srcBandsNullPix = new float[theLargestNumberOfInputBands];
290  //T** destBands = new T*[theLargestNumberOfInputBands];
291  //T* destBandsNullPix = new T[theLargestNumberOfInputBands];
292  //T* destBandsMinPix = new T[theLargestNumberOfInputBands];
293  //T* destBandsMaxPix = new T[theLargestNumberOfInputBands];
294
295  ossim_uint32 band;
296  ossim_uint32 upperBound = destination->getWidth()*destination->getHeight();
297  ossim_uint32 minNumberOfBands = currentImageData->getNumberOfBands();
298  for(band = 0; band < minNumberOfBands; ++band)
299  {
300  srcBands[band] = static_cast<float*>(currentImageData->getBuf(band));
301  srcBandsNullPix[band] = static_cast<float>(currentImageData->getNullPix(band));
302
303  destBands[band] = static_cast<T*>(theTile->getBuf(band));
304  destBandsNullPix[band] = static_cast<T>(theTile->getNullPix(band));
305  destBandsMinPix[band] = static_cast<T>(theTile->getMinPix(band));
306  destBandsMaxPix[band] = static_cast<T>(theTile->getMaxPix(band));
307  }
308  // if the src is smaller than the destination in number
309  // of bands we will just duplicate the last band.
310  for(;band < theLargestNumberOfInputBands; ++band)
311  {
312  srcBands[band] = static_cast<float*>(srcBands[minNumberOfBands - 1]);
313  srcBandsNullPix[band] = static_cast<float>(currentImageData->getNullPix(minNumberOfBands - 1));
314
315  destBands[band] = static_cast<T*>(theTile->getBuf(band));
316  destBandsNullPix[band] = static_cast<T>(theTile->getNullPix(band));
317  destBandsMinPix[band] = static_cast<T>(theTile->getMinPix(band));
318  destBandsMaxPix[band] = static_cast<T>(theTile->getMaxPix(band));
319  }
320  // most of the time we will not overlap so let's
321  // copy the first tile into destination and check later.
322  //
323  ossim_uint32 tempBandIdx = 0;
324  for(band = 0; band < theTile->getNumberOfBands();++band)
325  {
326  if(band < currentImageData->getNumberOfBands())
327  {
329  (float*)currentImageData->getBuf(band));
330  ++tempBandIdx;
331  }
332  else
333  {
334  if(tempBandIdx)
335  {
337  (float*)currentImageData->getBuf(tempBandIdx-1));
338  }
339  }
340  }
341  destination->validate();
342
343  currentImageData = getNextNormTile(layerIdx, tileRect, resLevel);
344
345  while(currentImageData.valid())
346  {
347  ossim_uint32 minNumberOfBands = currentImageData->getNumberOfBands();
348  ossimDataObjectStatus currentStatus = currentImageData->getDataObjectStatus();
349  ossimDataObjectStatus destinationStatus = destination->getDataObjectStatus();
350
351  if(destinationStatus == OSSIM_FULL)
352  {
353  return destination;
354  }
355  for(band = 0; band < minNumberOfBands; ++band)
356  {
357  srcBands[band] = static_cast<float*>(currentImageData->getBuf(band));
358  srcBandsNullPix[band] = static_cast<float>(currentImageData->getNullPix(band));
359  }
360  // if the src is smaller than the destination in number
361  // of bands we will just duplicate the last band.
362  for(;band < theLargestNumberOfInputBands; ++band)
363  {
364  srcBands[band] = srcBands[minNumberOfBands - 1];
365  srcBandsNullPix[band] = static_cast<T>(currentImageData->getNullPix(minNumberOfBands - 1));
366  }
367
368  if((destinationStatus == OSSIM_EMPTY)&&
369  (currentStatus != OSSIM_EMPTY)&&
370  (currentStatus != OSSIM_NULL))
371  {
372  ossim_uint32 upperBound = destination->getWidth()*destination->getHeight();
373  for(band=0; band < theLargestNumberOfInputBands; ++band)
374  {
375  float delta = destBandsMaxPix[band] - destBandsMinPix[band];
376  float minP = destBandsMinPix[band];
377  for(ossim_uint32 offset = 0; offset < upperBound; ++offset)
378  {
379  destBands[band][offset] = (T)( minP + delta*srcBands[band][offset]);
380  }
381  }
382  }
383  else if((destinationStatus == OSSIM_PARTIAL)&&
384  (currentStatus != OSSIM_EMPTY)&&
385  (currentStatus != OSSIM_NULL))
386  {
387  for(band = 0; band < theLargestNumberOfInputBands; ++band)
388  {
389
390  float delta = destBandsMaxPix[band] - destBandsMinPix[band];
391  float minP = destBandsMinPix[band];
392  for(ossim_uint32 offset = 0;
393  offset < upperBound;
394  ++offset)
395  {
396
397  if(destBands[band][offset] == destBandsNullPix[band])
398  {
399  destBands[band][offset] = (T)(minP + delta*srcBands[band][offset]);
400  }
401  }
402  }
403  }
404  destination->validate();
405
406  currentImageData = getNextNormTile(layerIdx, tileRect, resLevel);
407  }
408  // Cleanup...
409  // delete [] srcBands;
410  // delete [] srcBandsNullPix;
411  // delete [] destBands;
412  // delete [] destBandsNullPix;
413  // delete [] destBandsMinPix;
414  // delete [] destBandsMaxPix;
415
416  return destination;
417 }
418
420  T,// dummy template variable
421  const ossimIrect& tileRect,
422  ossim_uint32 resLevel)
423 {
424  ossim_uint32 layerIdx = 0;
425  ossimRefPtr<ossimImageData> destination = theTile;
426
427  ossimRefPtr<ossimImageData> currentImageData = getNextTile(layerIdx, 0, tileRect, resLevel);
428  if(!currentImageData)
429  {
430  return currentImageData;
431  }
432
433  T** srcBands = new T*[theLargestNumberOfInputBands];
434  T* srcBandsNullPix = new T[theLargestNumberOfInputBands];
435  T** destBands = new T*[theLargestNumberOfInputBands];
436  T* destBandsNullPix = new T[theLargestNumberOfInputBands];
437
438  ossim_uint32 band;
439  ossim_uint32 upperBound = destination->getWidth()*destination->getHeight();
440  ossim_uint32 bandIndex = 0;
441
442  ossim_uint32 offset=0;
443  ossim_uint32 minNumberOfBands = currentImageData->getNumberOfBands();
444  for(band = 0; band < minNumberOfBands; ++band)
445  {
446  srcBands[band] = static_cast<T*>(currentImageData->getBuf(band));
447  destBands[band] = static_cast<T*>(theTile->getBuf(band));
448  srcBandsNullPix[band] = static_cast<T>(currentImageData->getNullPix(band));
449  destBandsNullPix[band] = static_cast<T>(theTile->getNullPix(band));
450  }
451  // if the src is smaller than the destination in number
452  // of bands we will just duplicate the last band.
453  for(;band < theLargestNumberOfInputBands; ++band)
454  {
455  srcBands[band] = static_cast<T*>(srcBands[minNumberOfBands - 1]);
456  destBands[band] = static_cast<T*>(theTile->getBuf(band));
457  srcBandsNullPix[band] = static_cast<T>(currentImageData->getNullPix(minNumberOfBands - 1));
458  destBandsNullPix[band] = static_cast<T>(theTile->getNullPix(band));
459  }
460  // most of the time we will not overlap so let's
461  // copy the first tile into destination and check later.
462  //
463  for(band = 0; band < theTile->getNumberOfBands();++band)
464  {
465  T* destBand = destBands[band];
466  T* srcBand = srcBands[band];
467  if(destBand&&srcBand)
468  {
469  for(offset = 0; offset < upperBound;++offset)
470  {
471  *destBand = *srcBand;
472  ++srcBand; ++destBand;
473  }
474  }
475  }
476  destination->setDataObjectStatus(currentImageData->getDataObjectStatus());
477
478  currentImageData = getNextTile(layerIdx,
479  tileRect,
480  resLevel);
481
482  while(currentImageData.valid())
483  {
484  ossim_uint32 minNumberOfBands = currentImageData->getNumberOfBands();
485  ossimDataObjectStatus currentStatus = currentImageData->getDataObjectStatus();
486  ossimDataObjectStatus destinationStatus = destination->getDataObjectStatus();
487
488  for(band = 0; band < minNumberOfBands; ++band)
489  {
490  srcBands[band] = static_cast<T*>(currentImageData->getBuf(band));
491  srcBandsNullPix[band] = static_cast<T>(currentImageData->getNullPix(band));
492  }
493  // if the src is smaller than the destination in number
494  // of bands we will just duplicate the last band.
495  for(;band < theLargestNumberOfInputBands; ++band)
496  {
497  srcBands[band] = srcBands[minNumberOfBands - 1];
498  srcBandsNullPix[band] = static_cast<T>(currentImageData->getNullPix(minNumberOfBands - 1));
499  }
500
501  if((destinationStatus == OSSIM_PARTIAL)&&
502  (currentStatus != OSSIM_EMPTY)&&
503  (currentStatus != OSSIM_NULL))
504  {
505  for(bandIndex = 0; bandIndex < theLargestNumberOfInputBands; ++bandIndex)
506  {
507
508  for(ossim_uint32 offset = 0;
509  offset < upperBound;
510  ++offset)
511  {
512  if(srcBands[bandIndex][offset] > destBands[bandIndex][offset])
513  {
514  destBands[bandIndex][offset] = srcBands[bandIndex][offset];
515  }
516  }
517  }
518  }
519  else
520  {
521  ossim_uint32 upperBound = destination->getWidth()*destination->getHeight();
522  for(ossim_uint32 band=0; band < theLargestNumberOfInputBands; ++band)
523  {
524  for(ossim_uint32 offset = 0; offset < upperBound; ++offset)
525  {
526  if(srcBands[band][offset] > destBands[band][offset])
527  {
528  destBands[band][offset] = srcBands[band][offset];
529  }
530  }
531  }
532  }
533
534  destination->validate();
535
536  currentImageData = getNextTile(layerIdx,tileRect, resLevel);
537  }
538  // Cleanup...
539  delete [] srcBands;
540  delete [] srcBandsNullPix;
541  delete [] destBands;
542  delete [] destBandsNullPix;
543  return destination;
544 }
545
547 {
548  return ossimString("ossimMaxMosaic");
549 }
550
552 {
553  return ossimString("Max Mosaic");
554 }
555
557 {
558  return ossimString("Combiner which puts maximum dn value on image.");
559 }
8 bit signed integer
virtual ossimString getLongName() const
virtual const ossim_float64 * getMaxPix() const
This will be a base for all combiners.
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossimRefPtr< ossimImageData > getNextNormTile(ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
ossim_uint32 height() const
Definition: ossimIrect.h:487
virtual void initialize()
const ossimIpt & ul() const
Definition: ossimIrect.h:274
32 bit unsigned integer
Initialize the data buffer.
void allocate()
Called on first getTile, will initialize all data needed.
ossimRefPtr< ossimImageData > combine(T, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual void setHeight(ossim_uint32 height)
virtual ossimRefPtr< ossimImageData > getNextTile(ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
std::vector< ossimRefPtr< ossimConnectableObject > > ConnectableObjectList
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &origin, ossim_uint32 resLevel=0)
virtual ossimString getDescription() const
ossim_uint32 theLargestNumberOfInputBands
yy_size_t size
32 bit signed integer
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
virtual void setWidth(ossim_uint32 width)
virtual ~ossimMaxMosaic()
virtual void copyNormalizedBufferToTile(ossim_float64 *buf)
Copies buf passed in to tile.
ossim_uint32 width() const
Definition: ossimIrect.h:500
virtual bool hasDifferentInputs() const
virtual void setOrigin(const ossimIpt &origin)
virtual const ossim_float64 * getMinPix() const
virtual void makeBlank()
ossimRefPtr< ossimImageData > combineNorm(T, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual ossim_uint32 getNumberOfInputs() const
Returns the number of input objects.
virtual void setDataObjectStatus(ossimDataObjectStatus status) const
Full list found in ossimConstants.h.
#define RTTI_DEF1(cls, name, b1)
Definition: ossimRtti.h:485
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
Definitions for data object status.
virtual bool saveState(ossimKeywordlist &kwl, const char *prefix=NULL) const
32 bit floating point
virtual ossimString getShortName() const
16 bit unsigned iteger
64 bit floating point
16 bit signed integer
An image mosaic is a simple combiner that will just do a simple mosaic.
8 bit unsigned iteger
