ossimImageCombiner.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: Garrett Potts
6 //
7 //*************************************************************************
8 // $Id: ossimImageCombiner.cpp 23108 2015-01-27 17:00:20Z okramer $
11 #include <ossim/base/ossimIrect.h>
13 #include <ossim/base/ossimTrace.h>
14
15 using namespace std;
16
18 static ossimTrace traceDebug ("ossimImageCombiner:debug");
19
21  :ossimImageSource(NULL,
22  0,
23  0,
24  false,
25  false),
26  theLargestNumberOfInputBands(0),
27  theInputToPassThrough(0),
28  theHasDifferentInputs(false),
29  theNormTile(NULL),
30  theCurrentIndex(0)
31 {
33  // until something is set we will just set the blank tile
34  // to a 1 band unsigned char type
36 }
38  int numberOfInputs,
39  int numberOfOutputs,
40  bool inputListIsFixedFlag,
41  bool outputListIsFixedFlag)
42  :ossimImageSource(owner,
43  numberOfInputs,
44  numberOfOutputs,
45  inputListIsFixedFlag,
46  outputListIsFixedFlag),
47  theLargestNumberOfInputBands(0),
48  theInputToPassThrough(0),
49  theHasDifferentInputs(false),
50  theNormTile(NULL),
51  theCurrentIndex(0)
52 {
55 }
56
58  :ossimImageSource(NULL,
59  (ossim_uint32)inputSources.size(),
60  0,
61  false,
62  false),
63  theLargestNumberOfInputBands(0),
64  theInputToPassThrough(0),
65  theHasDifferentInputs(false),
66  theNormTile(NULL),
67  theCurrentIndex(0)
68 {
70  for(ossim_uint32 index = 0; index < inputSources.size(); ++index)
71  {
72  connectMyInputTo(index, inputSources[index].get());
73  }
75  initialize();
76 }
77
79 {
81 }
82
84 {
85  static const char* MODULE = "ossimImageCombiner::getBoundingRect";
86  ossimIrect result;
88  {
90  }
91
92  double scale = 1.0/std::pow(2.0, (double)resLevel);
93  ossimDpt scalar(scale, scale);
94  result.makeNan();
95
96  ossim_uint32 inputIndex = 0;
97  ossimImageSource* interface;
98  for(inputIndex = 0;inputIndex < getNumberOfInputs(); ++inputIndex)
99  {
100  interface = PTR_CAST(ossimImageSource, getInput(inputIndex));
101  if(interface)
102  {
103  ossimIrect rect = theFullResBounds[inputIndex];
104  if(result.hasNans())
105  {
106  result = rect;
107  }
108  else if(!rect.hasNans())
109  {
110  if(traceDebug())
111  {
112  CLOG << "rect " << inputIndex << " = " << result << endl;
113  }
114  rect = rect*scale;
115  result = result.combine(rect);
116  }
117  }
118  }
119  if(traceDebug())
120  {
121  CLOG << "resulting bounding rect = " << result << endl;
122  }
123
124  return result;
125 }
126
128 {
130 }
131
133 {
135  {
137  if(temp)
138  {
139  return temp->getOutputScalarType();
140  }
141  }
142
143  return OSSIM_SCALAR_UNKNOWN;
144 }
145
147 {
149  {
151  if(temp)
152  {
153  return temp->getTileWidth();
154  }
155  }
156
157  return 1;
158 }
159
161 {
163  {
165  if(temp)
166  {
167  return temp->getTileHeight();
168  }
169  }
170
171  return 1;
172 }
173
175 {
177  {
179  if(temp)
180  {
181  ossim_uint32 bands = temp->getNumberOfOutputBands();
182  if(band < bands)
183  {
184  return temp->getNullPixelValue(band);
185  }
186  else
187  {
188  return temp->getNullPixelValue(bands-1);
189  }
190  }
191  }
192
193  return 0.0;
194 }
195
197 {
198  const char* MODULE = "ossimImageCombiner::getMinPixelValue";
199
200  if(!getNumberOfInputs())
201  {
202  return ossim::nan();
203  }
204  double result = 1.0/DBL_EPSILON;
205
206  for(ossim_uint32 index = 0; index < getNumberOfInputs();++index)
207  {
209  if(input)
210  {
211  ossim_uint32 bands = input->getNumberOfOutputBands();
212  double temp = 0;
213  if(band < bands)
214  {
215  temp = input->getMinPixelValue(band);
216  }
217  else
218  {
219  temp = input->getMinPixelValue(0);
220  }
221
222  if(temp < result)
223  {
224  result = temp;
225  }
226  }
227  }
228  if(traceDebug())
229  {
230  CLOG << "min pixel returned is = " << result;
231  }
232
233  return result;
234 }
235
237 {
238  const char* MODULE = "ossimImageCombiner::getMaxPixelValue";
239
240  if(!getNumberOfInputs())
241  {
242  return ossim::nan();
243  }
244  double result = -1.0/DBL_EPSILON;
245
246  for(ossim_uint32 idx = 0; idx < getNumberOfInputs();++idx)
247  {
249  if(input)
250  {
251  ossim_uint32 bands = input->getNumberOfOutputBands();
252  double temp = 0;
253  if(band < bands)
254  {
255  temp = input->getMaxPixelValue(band);
256  }
257  else
258  {
259  temp = input->getMaxPixelValue(0);
260  }
261  if(temp > result)
262  {
263  result = temp;
264  }
265  }
266  }
267
268  if(traceDebug())
269  {
270  CLOG << "max pixel returned is = " << result;
271  }
272
273  return result;
274 }
275
277 {
278
281
282  // now find the largest number of bands
283  //
288  theHasDifferentInputs= false;
289  if(size > 0)
290  {
291  for(ossim_uint32 idx = 0; idx < size; ++idx)
292  {
294  if(temp)
295  {
296  ossim_uint32 numberOfBands = temp->getNumberOfOutputBands();
297  if(numberOfBands > theLargestNumberOfInputBands)
298  {
299  theLargestNumberOfInputBands = numberOfBands;
300  }
301  ossimScalarType current = temp->getOutputScalarType();
302  if(current != scalarType)
303  {
304  if(scalarType == OSSIM_SCALAR_UNKNOWN)
305  {
306  scalarType = current;
308  theInputToPassThrough = idx;
309  }
310  else
311  {
312  theHasDifferentInputs = true;
314  {
315  scalarType = current;
317  theInputToPassThrough = idx;
318  }
319  }
320  }
321  }
322  }
323  }
324 }
325
326 bool ossimImageCombiner::loadState(const ossimKeywordlist& kwl, const char* prefix)
327 {
328  bool result = ossimImageSource::loadState(kwl, prefix);
329
330  return result;
331 }
332
334 {
336 }
337
338 // ossimRefPtr<ossimImageData> ossimImageCombiner::getNextTile(ossim_uint32& returnedIdx,
339 // ossim_uint32 idx,
340 // const ossimIpt& tileRect,
341 // ossim_uint32 resLevel)
342 // {
343 // theCurrentIndex = idx;
344 // return getNextTile(returnedIdx, origin, resLevel);
345 // }
346
347 // ossimRefPtr<ossimImageData> ossimImageCombiner::getNextTile(ossim_uint32& returnedIdx,
348 // ossim_uint32 idx,
349 // const ossimIpt& origin,
350 // ossim_uint32 resLevel)
351 // {
352 // theCurrentIndex = idx;
353 // return getNextTile(returnedIdx, origin, resLevel);
354 // }
355
357  const ossim_uint32 startIdx,
358  const ossimIrect& tileRect,
359  ossim_uint32 resLevel)
360 {
361  theCurrentIndex = startIdx;
362  return getNextTile(returnedIdx, tileRect, resLevel);
363 }
364
365 // ossimRefPtr<ossimImageData> ossimImageCombiner::getNextTile(ossim_uint32& returnedIdx,
366 // const ossimIpt& origin,
367 // ossim_uint32 resLevel)
368 // {
369 // ossim_int32 w = getTileWidth();
370 // ossim_int32 h = getTileHeight();
371
372 // return getNextTile(returnedIndex,
373 // ossimIrect(origin.x,
374 // origin.y,
375 // origin.x + w-1,
376 // origin.y + h-1),
377 // resLevel);
378 // }
379
381  const ossimIrect& tileRect,
382  ossim_uint32 resLevel)
383 {
385  if ( theCurrentIndex >= size)
386  {
387  return 0;
388  }
389
391  {
393  }
394
395  ossimImageSource* temp = 0;
396  ossimRefPtr<ossimImageData> result = 0;
398
399  double scale = 1.0/std::pow(2.0, (double)resLevel);
400  ossimDpt scalar(scale, scale);
401
402  while( (theCurrentIndex<size) && !result)
403  {
405  if(!rect.hasNans())
406  {
407  rect = rect * scalar;
408  temp = PTR_CAST(ossimImageSource,
410
411  if(rect.intersects(tileRect)&&temp)
412  {
413  result = temp->getTile(tileRect, resLevel);
414  status = (result.valid() ?
415  result->getDataObjectStatus():OSSIM_NULL);
416  if((status == OSSIM_NULL)||
417  (status == OSSIM_EMPTY))
418  {
419  result = 0;
420  }
421  }
422  else
423  {
424  status = OSSIM_NULL;
425  result = 0;
426  }
427  }
428  else
429  {
430  status = OSSIM_NULL;
431  result = NULL;
432  }
433
434  // Go to next source.
435  ++theCurrentIndex;
436  }
437  returnedIdx = theCurrentIndex;
438  if(result.valid())
439  {
440  --returnedIdx;
441  }
442
443  return result;
444 }
445
446
448  const ossim_uint32 startIdx,
449  ossimImageData* tile,
450  ossim_uint32 resLevel)
451 {
452  if (!tile)
453  return false;
454
456  theCurrentIndex = startIdx;
457
460
461  ossimImageSource* temp = 0;
463
464  double scale = 1.0/std::pow(2.0, (double)resLevel);
465  ossimDpt scalar(scale, scale);
466
467  while( (theCurrentIndex<size))
468  {
470  if(!rect.hasNans())
471  {
472  rect = rect * scalar;
473  temp = PTR_CAST(ossimImageSource,
475
476  if(rect.intersects(tile->getImageRectangle()) && temp)
477  {
478  temp->getTile(tile, resLevel);
479  status = tile->getDataObjectStatus();
480  if((status != OSSIM_NULL) && (status != OSSIM_EMPTY))
481  {
482  break;
483  }
484  }
485  }
486
487  // Go to next source.
488  ++theCurrentIndex;
489  }
490
491  returnedIdx = theCurrentIndex;
492  if((status == OSSIM_NULL) || (status == OSSIM_EMPTY))
493  {
494  --returnedIdx;
495  return false;
496  }
497
498  return true;
499 }
500
501
502 // ossimRefPtr<ossimImageData> ossimImageCombiner::getNextNormTile(ossim_uint32& returnedIdx,
503 // ossim_uint32 index,
504 // const ossimIpt& origin,
505 // ossim_uint32 resLevel)
506 // {
507 // theCurrentIndex = index;
508 // return getNextNormTile(returnedIdx, origin, resLevel);
509 // }
510
512  const ossim_uint32 startIdx,
513  const ossimIrect& tileRect,
514  ossim_uint32 resLevel)
515 {
516  theCurrentIndex = startIdx;
517  return getNextNormTile(returnedIdx, tileRect, resLevel);
518 }
519
520 // ossimRefPtr<ossimImageData> ossimImageCombiner::getNextNormTile(ossim_uint32& returnedIdx,
521 // const ossimIpt& origin,
522 // ossim_uint32 resLevel)
523 // {
524 // ossim_int32 w = getTileWidth();
525 // ossim_int32 h = getTileHeight();
526
527 // return getNextNormTile(returnedIdx,
528 // ossimIrect(origin.x,
529 // origin.y,
530 // origin.x + w-1,
531 // origin.y + h-1),
532 // resLevel);
533 // }
534
535
537  const ossimIrect& tileRect,
538  ossim_uint32 resLevel)
539 {
541
542  if(theCurrentIndex >= size)
543  {
544  return 0;
545  }
546
547  if(!theNormTile)
548  {
549  theNormTile = new ossimImageData(this,
552  }
553
554  ossimRefPtr<ossimImageData> result = getNextTile(returnedIdx, tileRect, resLevel);
555
556  if(result.valid())
557  {
559  result->getNumberOfBands());
560  result->copyTileToNormalizedBuffer((float*)theNormTile->getBuf());
561
563  result = theNormTile;
564  }
565
566  return result;
567 }
568
570  ossim_uint32 resLevel)const
571 {
573  {
575  }
576  double scale = 1.0/std::pow(2.0, (double)resLevel);
577  ossimDpt scalar(scale, scale);
578  ossim_uint32 result = 0;
579  ossim_uint32 maxIndex = getNumberOfInputs();
580  for(ossim_uint32 inputIndex = 0; inputIndex < maxIndex; ++inputIndex)
581  {
582  if(!theFullResBounds[inputIndex].hasNans())
583  {
584  ossimIrect boundingRect = theFullResBounds[inputIndex] * scalar;
585  if(rect.intersects(boundingRect))
586  {
587  ++result;
588  }
589  }
590  }
591
592  return result;
593 }
594
595 void ossimImageCombiner::getOverlappingImages(std::vector<ossim_uint32>& result,
596  const ossimIrect& rect,
597  ossim_uint32 resLevel)const
598 {
600  {
602  }
603  double scale = 1.0/std::pow(2.0, (double)resLevel);
604  ossimDpt scalar(scale, scale);
605
606  ossim_uint32 inputIndex;
607  ossimIrect boundingRect;
608  for(inputIndex = 0; inputIndex < getNumberOfInputs(); ++inputIndex)
609  {
610  if(!theFullResBounds[inputIndex].hasNans())
611  {
612  boundingRect = theFullResBounds[inputIndex]*scalar;
613  if(rect.intersects(boundingRect))
614  {
615  result.push_back(inputIndex);
616  }
617  }
618  }
619 }
620
622 {
623  initialize();
624 }
625
627 {
628  initialize();
629 }
630
632 {
633  initialize();
634 }
635
637 {
638  initialize();
639 }
640
642 {
643  return theHasDifferentInputs;
644 }
645
647  const char* prefix) const
648 {
649  return ossimImageSource::saveState(kwl, prefix);
650 }
651
653  const ossimConnectableObject* object)const
654 {
655  return (object&& PTR_CAST(ossimImageSource, object));
656 }
657
659 {
660
661  ossim_uint32 inputSize = getNumberOfInputs();
662
663  if(inputSize)
664  {
665  ossimImageSource* tempInterface=0;
666  if(theFullResBounds.size() != inputSize)
667  {
668  theFullResBounds.resize(inputSize);
669  }
670  for(ossim_uint32 inputIndex = 0; inputIndex < inputSize; ++inputIndex)
671  {
672  tempInterface = PTR_CAST(ossimImageSource, getInput(inputIndex));
673  if(tempInterface)
674  {
675  theFullResBounds[inputIndex] = tempInterface->getBoundingRect();
676  }
677  else
678  {
679  theFullResBounds[inputIndex].makeNan();
680  }
681  }
683  }
684  else
685  {
686  theFullResBounds.clear();
687  }
688 }
virtual void propertyEvent(ossimPropertyEvent &event)
virtual void connectInputEvent(ossimConnectionEvent &event)
virtual bool addListener(ossimListener *listener)
This will return the bounding rect of the source.
ossim_uint32 theInputToPassThrough
#define CLOG
Definition: ossimTrace.h:23
virtual bool canConnectMyInputTo(ossim_int32 inputIndex, const ossimConnectableObject *object) const
required to be overriden by derived classes
virtual ossim_uint32 getNumberOfInputBands() const
Returns the number of bands available from the input.
This will be a base for all combiners.
bool valid() const
Definition: ossimRefPtr.h:75
double nan()
Definition: ossimCommon.h:135
virtual void disconnectInputEvent(ossimConnectionEvent &event)
virtual ossimRefPtr< ossimImageData > getNextNormTile(ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual void getOverlappingImages(std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const
Used to populate the result with the index of the overlapping images.
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
ossim_uint32 theCurrentIndex
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
virtual void initialize()
Initialize the data buffer.
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
virtual ossimRefPtr< ossimImageData > getNextTile(ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
#define RTTI_DEF2(cls, name, b1, b2)
Definition: ossimRtti.h:493
std::vector< ossimRefPtr< ossimConnectableObject > > ConnectableObjectList
ossim_uint32 theLargestNumberOfInputBands
yy_size_t size
virtual void setImageRectangleAndBands(const ossimIrect &rect, ossim_uint32 numberOfBands)
std::vector< ossimIrect > theFullResBounds
unsigned int ossim_uint32
ossimRefPtr< ossimImageData > theNormTile
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
virtual ossimIrect getImageRectangle() const
virtual void copyTileToNormalizedBuffer(ossim_float64 *buf) const
Copies entire tile to buf passed in.
OSSIM_DLL ossim_uint32 scalarSizeInBytes(ossimScalarType scalarType)
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
#define DBL_EPSILON
virtual ossim_uint32 getNumberOfOverlappingImages(const ossimIrect &rect, ossim_uint32 resLevel=0) const
Used to retrieve the number of overlapping images withint the given rect.
virtual bool hasDifferentInputs() const
ossimScalarType
return status
void makeNan()
Definition: ossimIrect.h:329
virtual ossim_uint32 getNumberOfInputs() const
Returns the number of input objects.
virtual void refreshEvent(ossimRefreshEvent &event)
virtual void setDataObjectStatus(ossimDataObjectStatus status) const
Full list found in ossimConstants.h.
bool hasNans() const
Definition: ossimIrect.h:337
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
Definitions for data object status.
virtual bool saveState(ossimKeywordlist &kwl, const char *prefix=NULL) const
ossimIrect combine(const ossimIrect &rect) const
Definition: ossimIrect.cpp:543
virtual void updateRects()
This will go through and precompute the bounding rects of each input image.
int ossim_int32
virtual bool removeListener(ossimListener *listener)
