ossimMpiMasterOverviewSequencer.cpp
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: David Burken
6 //
7 // Description: Class definition for mpi master sequencer for building
8 // overview files.
9 //
10 //----------------------------------------------------------------------------
11 // $Id: ossimMpiMasterOverviewSequencer.cpp 17870 2010-08-12 13:12:32Z sbortman $
12
14 #include <ossim/ossimConfig.h> /* To pick up OSSIM_HAS_MPI. */
15 #include <ossim/base/ossimEndian.h>
16
17 #if OSSIM_HAS_MPI
18 # include <mpi.h>
19 #endif
20
22  :
24  m_rank(0),
25  m_numberOfProcessors(1)
26 {
27 #if OSSIM_HAS_MPI
28  MPI_Comm_rank(MPI_COMM_WORLD, &m_rank);
29  MPI_Comm_size(MPI_COMM_WORLD, &m_numberOfProcessors);
30 #endif
31
32  //---
33  // Since this is the master sequencer it should always be rank 0; else,
34  // we have a coding error. Since we have the getNextTile implemented to
35  // recieve from the slave processes we always start the tile count at 0.
36  //---
38 }
39
41 {
42 }
43
45 {
47 }
48
50 {
52 }
53
55 {
56  if ( m_dirtyFlag )
57  {
58  //---
59  // If this happens we have a coding error. Someone started sequencing
60  // without initializing us properly.
61  //---
63  }
64
65 #if OSSIM_HAS_MPI
66
67  //---
68  // Using mpi. The slaves will send us tiles to be returned by this method.
69  // They will alway be sent in big endian (network byte order) so we must
70  // swap back if the scalar type is not 8 bit and the system byte order is
71  // little endian. We will use the endian pointer itself as a flag to swap.
72  //---
73  ossimEndian* endian = 0;
74  if (m_imageHandler.valid())
75  {
77  {
79  {
80  endian = new ossimEndian();
81  }
82  }
83  }
84
85  int errorValue;
86
87  // Buffer to receive the data from slaves.
88  void* buf = m_tile->getBuf();
89
90  // Total number of tiles to process...
91  ossim_uint32 numberOfTiles = getNumberOfTiles();
92
93  if(m_currentTileNumber >= numberOfTiles)
94  {
96  }
97
98  errorValue = MPI_Recv(buf,
100  MPI_UNSIGNED_CHAR,
102  0,
103  MPI_COMM_WORLD,
104  MPI_STATUS_IGNORE);
105
106  // Data always sent in big endian order.
107  if ( endian )
108  {
109  endian->swap(m_tile->getScalarType(), buf, m_tile->getSize());
110  }
111
112  // Get the output rectangle.
113  ossimIrect outputRect;
114  getOutputTileRectangle(outputRect);
115
116  // Capture the output rectangle.
117  m_tile->setImageRectangle(outputRect);
118
119  // Set the tile status.
120  m_tile->validate();
121
122  // Increment the tile index.
124
125  // cleanup...
126  if ( endian )
127  {
128  delete endian;
129  endian = 0;
130  }
131
132  return m_tile;
133
134 #else
135
136  // Not compiled with mpi.
138
139 #endif /* End of #if OSSIM_HAS_MPI */
140
141 }
bool valid() const
Definition: ossimRefPtr.h:75
ossimRefPtr< ossimImageData > m_tile
ossimRefPtr< ossimImageHandler > m_imageHandler
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
ossim_uint32 getNumberOfTiles() const
bool m_dirtyFlag
Dirty flag - if true, this object is not initialized.
virtual ossim_uint32 getSizeInBytes() const
Returns the total number of bytes for all bands.
unsigned int ossim_uint32
virtual ~ossimMpiMasterOverviewSequencer()
virtual destructor
virtual ossimRefPtr< ossimImageData > getNextTile()
Will allow you to get the next tile in the sequence.
virtual ossim_uint32 getSize() const
Returns the total number of pixels in a tile for all bands.
virtual void setToStartOfSequence()
Will set the internal pointers to the upperleft tile number.
virtual void initialize()
This must be called.
8 bit unsigned integer
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
void getOutputTileRectangle(ossimIrect &outputRect) const
Gets the image rectangle for the output tile for theCurrentTileNumber.
