ossimOverviewSequencer.cpp
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // License: LGPL
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Description: Sequencer for building overview files.
8 //
9 //----------------------------------------------------------------------------
10 // $Id: ossimOverviewSequencer.cpp 23377 2015-06-17 18:03:05Z okramer $
11
13 #include <ossim/base/ossimIpt.h>
14 #include <ossim/base/ossimIrect.h>
16 #include <ossim/base/ossimNotify.h>
17 #include <ossim/base/ossimTrace.h>
23
24
25 #ifdef OSSIM_ID_ENABLED
26 static const char OSSIM_ID[] = "$Id: ossimOverviewSequencer.cpp 23377 2015-06-17 18:03:05Z okramer $";
27 #endif
28
29 static ossimTrace traceDebug("ossimOverviewSequencer:debug");
30
32  :
35  m_imageHandler(0),
36  m_maskWriter(0),
37  m_maskFilter(0),
38  m_tile(0),
39  m_areaOfInterest(),
41  m_numberOfTilesHorizontal(0),
42  m_numberOfTilesVertical(0),
43  m_currentTileNumber(0),
44  m_sourceResLevel(0),
45  m_dirtyFlag(true),
46  m_decimationFactor(2),
47  m_resampleType(ossimFilterResampler::ossimFilterResampler_BOX),
48  m_histogram(0),
49  m_histoMode(OSSIM_HISTO_MODE_UNKNOWN),
50  m_histoTileIndex(1),
51  m_scanForMinMax(false),
52  m_scanForMinMaxNull(false),
53  m_minValues(0),
54  m_maxValues(0),
55  m_nulValues(0)
56 {
58
59  if (traceDebug())
60  {
62  << "ossimOverviewSequencer::ossimOverviewSequencer entered..."
63  << "\nmpi rank: "<< ossimMpi::instance()->getRank()
64  << std::endl;
65 #ifdef OSSIM_ID_ENABLED
66  ossimNotify(ossimNotifyLevel_DEBUG)<< "OSSIM_ID: " << OSSIM_ID
67  << std::endl;
68 #endif
69  }
70 }
71
73 {
74  m_imageHandler = 0;
75  m_maskFilter = 0;
76  m_maskWriter = 0;
77  m_tile = 0;
78  m_histogram = 0;
79
80  if (traceDebug())
81  {
83  << "ossimOverviewSequencer::~ossimOverviewSequencer entered..."
84  << "\nmpi rank: " << ossimMpi::instance()->getRank()
85  << std::endl;
86  }
87 }
88
90 {
92 }
93
95 {
97 }
98
100 {
102 }
103
105 {
107  {
108  rect.makeNan(); // not initialized...
109  }
110  else
111  {
114
115  //---
116  // NOTE:
117  // This will add a sample or line if there is a remainder like:
118  // 1025 / 2 = 512 will then become 513. It will be up to the resample
119  // tile method to fill the extra sample correctly.
120  //---
122  {
123  ++width;
124  }
126  {
127  ++height;
128  }
129
130  rect = ossimIrect(0, 0, width-1, height-1);
131  }
132 }
133
135 {
136  m_imageHandler = input;
138  m_dirtyFlag = true;
139
140  if (m_maskWriter.valid())
142 }
143
145 {
146  m_sourceResLevel = level;
148  m_dirtyFlag = true;
149 }
150
152 {
153  return m_histoMode;
154 }
155
157 {
158  m_histoMode = mode;
159  m_dirtyFlag = true;
160 }
161
163 {
164  if ( m_histogram.valid() && m_imageHandler.valid() )
165  {
167  }
168 }
169
171 {
172  if ( m_histogram.valid() )
173  {
175  histo->addHistogram( m_histogram.get() );
176  ossimKeywordlist kwl;
177  histo->saveState(kwl);
178  kwl.write(file.c_str());
179  }
180 }
181
183 {
184  if ( m_dirtyFlag == false )
185  {
186  return; // Already initialized.
187  }
188
189  if ( !m_imageHandler )
190  {
191  return;
192  }
193
194  ossimImageSource* imageSource = m_imageHandler.get();
195  if (m_maskFilter.valid())
196  imageSource = m_maskFilter.get();
197
198  // Check the area of interest and set from image if needed.
199  if ( m_areaOfInterest.hasNans() )
200  {
202  }
203
204  // Check the tile size and set from image if needed.
205  if ( m_tileSize.hasNans() )
206  {
207  m_tileSize.x = imageSource->getTileWidth();
208  m_tileSize.y = imageSource->getTileHeight();
209  }
210
211  // Update m_numberOfTilesHorizontal and m_numberOfTilesVertical.
213
214  // Start on first tile.
216
217  // Use this factory constructor as it copies the min/max/nulls from the image handler.
219  create( 0, imageSource->getNumberOfOutputBands(), imageSource);
220
221  if(m_tile.valid())
222  {
223  // Set the width and height.
224  m_tile->setWidthHeight(static_cast<ossim_uint32>(m_tileSize.x),
225  static_cast<ossim_uint32>(m_tileSize.y) );
226  // Initialize tile buffer.
227  m_tile->initialize();
228  }
229
231  {
233
234  m_histogram->create(imageSource);
235
237  {
238  m_histoTileIndex = 1; // Sample every tile.
239  }
240  else
241  {
242  const ossim_float64 PIXEL_TO_SAMPLE = 100.0 * 256.0 * 256.0; // 100 256x256 tiles.
244
245  if (traceDebug())
246  {
248  << "pixels: " << pixels << "\n"
249  << "PIXEL_TO_SAMPLE: " << PIXEL_TO_SAMPLE << "\n";
250  }
251
252  if (pixels > PIXEL_TO_SAMPLE)
253  {
254  m_histoTileIndex = ossim::round<ossim_uint32>(pixels/PIXEL_TO_SAMPLE);
255  }
256  else
257  {
258  m_histoTileIndex = 1; // Sample every tile.
259  }
260  }
261  }
262  else
263  {
264  m_histogram = 0;
265  }
266
267
269  {
270  //---
271  // The methods ossimImageData::computeMinMaxNullPix and computeMinMaxPix
272  // will resize and set min to max, max to min and null to max if the arrays passed in
273  // are empty.
274  //---
276  }
277
278  m_dirtyFlag = false;
279
280  if (traceDebug())
281  {
283  << "aoi: " << m_areaOfInterest
284  << "\ntile size: " << m_tileSize
285  << "\ntiles wide: " << m_numberOfTilesHorizontal
286  << "\ntiles high: " << m_numberOfTilesVertical
287  << "\nsource rlevel: " << m_sourceResLevel
288  << "\ndecimation factor: " << m_decimationFactor
289  << "\nresamp type: " << m_resampleType
290  << "\nscan for min max: " << (m_scanForMinMax?"true\n":"false\n")
291  << "\nscan for min, max null: " << (m_scanForMinMaxNull?"true\n":"false\n")
292  << "\nhisto mode: " << m_histoMode << "\n";
294  {
296  << "Sampling every " << m_histoTileIndex << " tile(s) for histogram.\n";
297  }
298  }
299 }
300
302 {
304 }
305
307 {
308  if ( m_dirtyFlag )
309  {
311  }
312
313  // Get the rectangle to grab from the image.
314  ossimIrect inputRect;
315  getInputTileRectangle(inputRect);
316
317  // Get the output rectangle.
318  ossimIrect outputRect;
319  getOutputTileRectangle(outputRect);
320
321  // Capture the output rectangle.
322  m_tile->setImageRectangle(outputRect);
323
324  // Start with a blank tile.
325  m_tile->makeBlank();
326
327  // Grab the input tile.
328  ossimRefPtr<ossimImageData> inputTile;
329  if (m_maskFilter.valid())
330  {
331  inputTile = m_maskFilter->getTile(inputRect, m_sourceResLevel);
332
333  // Check for errors reading tile and set our error status for callers.
334  if ( m_maskFilter->hasError() )
335  {
336  setErrorStatus();
337  }
338  }
339  else
340  {
341  inputTile = m_imageHandler->getTile(inputRect, m_sourceResLevel);
342
343  // Check for errors reading tile and set our error status for callers.
344  if ( m_imageHandler->hasError() )
345  {
346  setErrorStatus();
347  }
348  }
349
350  if ( hasError() )
351  {
353  << "ossimOverviewSequencer::getNextTile ERROR:"
354  << "\nError set reading tile: " << m_currentTileNumber << std::endl;
355  if ( inputTile.valid() )
356  {
357  inputTile->makeBlank();
358  }
359  }
360  else if ( inputTile.valid() )
361  {
362  if ( m_scanForMinMaxNull )
363  {
365  }
366  else if ( m_scanForMinMax )
367  {
369  }
370
373  {
374  if (traceDebug())
375  {
377  << "ossimOverviewSequencer::getNextTile DEBUG:"
378  << "\npopulating histogram for tile: " << m_currentTileNumber
379  << "\n";
380  }
381  inputTile->populateHistogram(m_histogram);
382  }
383
384  if ( (inputTile->getDataObjectStatus() == OSSIM_PARTIAL) ||
385  (inputTile->getDataObjectStatus() == OSSIM_FULL ) )
386  {
387  // Resample the tile.
388  resampleTile(inputTile.get());
389  m_tile->validate();
390
391  // Scan the resampled pixels for bogus values to be masked out (if masking enabled)
392  if (m_maskWriter.valid())
394  }
395  }
396  else
397  {
399  << "ossimOverviewSequencer::getNextTile DEBUG:"
400  << "\nRequest failed for input rect: " << inputRect
401  << "\nRes level: " << m_sourceResLevel << std::endl;
402  }
403
404  // Increment the tile index.
406
407  return m_tile;
408 }
409
411 {
412 }
413
415 {
416  return true;
417 }
418
420 {
421  return m_tileSize;
422 }
423
425 {
426  m_tileSize = tileSize;
428  m_dirtyFlag = true;
429 }
430
433 {
434  m_resampleType = resampleType;
435 }
436
438 {
439  m_scanForMinMax = flag;
440 }
441
443 {
444  return m_scanForMinMax;
445 }
446
448 {
449  m_scanForMinMaxNull = flag;
450 }
451
453 {
454  return m_scanForMinMaxNull;
455 }
456
458 {
459  m_minValues.clear();
460  m_maxValues.clear();
461  m_nulValues.clear();
462 }
463
464 bool ossimOverviewSequencer::writeOmdFile(const std::string& file)
465 {
466  static const char M[] = "ossimOverviewSequencer::writeOmdFile";
467  if ( traceDebug() )
468  {
469  ossimNotify(ossimNotifyLevel_DEBUG) << M << " entered...\nfile: " << file << endl;
470  }
471
472  //---
473  // This method writes an omd file to disk. Typically called after sequencing trough tile that
474  // were scanned for min, max, and potentially null values.
475  // Since this can be called without a scan there is extra logic in here to initialize values
476  // if so. Also there are sanity checks for cases where there is no null value, i.e. a
477  // full tile, in which case assumptions have to be made...
478  //---
479
480  bool result = false;
481  if ( file.size() && m_imageHandler.valid() )
482  {
485  const ossim_float64 DEFAULT_NULL = ossim::defaultNull(SCALAR);
486
487  if ( traceDebug() )
488  {
490  << "Original array values:\n";
491  std::vector<ossim_float64>::const_iterator i = m_minValues.begin();
492  ossim_int32 band = 0;
493  while ( i < m_minValues.end() )
494  {
496  << "min[" << band++ << "]: " << *i << "\n";
497  ++i;
498  }
499  i = m_maxValues.begin();
500  band = 0;
501  while ( i < m_maxValues.end() )
502  {
504  << "max[" << band++ << "]: " << *i << "\n";
505  ++i;
506  }
507  i = m_nulValues.begin();
508  band = 0;
509  while ( i < m_nulValues.end() )
510  {
512  << "nul[" << band++ << "]: " << *i << "\n";
513  ++i;
514  }
515  }
516
517  if ( (m_scanForMinMax == true) || (m_nulValues.size() != BANDS) )
518  {
519  // Only scanned for min and max so set the null.
520  if (m_nulValues.size() != BANDS)
521  {
522  m_nulValues.resize(BANDS);
523  }
524  for (ossim_uint32 band = 0; band < BANDS; ++band)
525  {
527  }
528  }
529  else if ( m_scanForMinMaxNull == true )
530  {
531  //---
532  // The arrays (sizes) should be set if we did the scan.
533  // Note that scanning for null only works if there IS a null in the image; hence, the
534  // extra sanity checks as if there are no null then the null gets set to the real min.
535  //
536  // This is very dangerous code as it makes assumptions (drb)...
537  //---
538  if ( (m_minValues.size() == BANDS) &&
539  (m_maxValues.size() == BANDS) &&
540  (m_nulValues.size() == BANDS) )
541  {
542  switch(SCALAR)
543  {
544  case OSSIM_UINT8:
545  case OSSIM_SINT8:
546  case OSSIM_UINT16:
547  case OSSIM_USHORT11:
548  case OSSIM_USHORT12:
549  case OSSIM_USHORT13:
550  case OSSIM_USHORT14:
551  case OSSIM_USHORT15:
552  case OSSIM_UINT32:
553  {
554  // All of these should have a null of 0.
555  for (ossim_uint32 band = 0; band < BANDS; ++band)
556  {
557  if ( m_nulValues[band] > DEFAULT_NULL )
558  {
559  if ( m_nulValues[band] < m_minValues[band] )
560  {
561  m_minValues[band] = m_nulValues[band];
562  }
563  m_nulValues[band] = DEFAULT_NULL;
564  }
565  }
566  break;
567  }
568  case OSSIM_SINT16:
569  {
570  for (ossim_uint32 band = 0; band < BANDS; ++band)
571  {
572  if ( ( m_nulValues[band] != DEFAULT_NULL ) && // -32768
573  ( m_nulValues[band] != -32767.0 ) &&
574  ( m_nulValues[band] != -32766.0 ) &&
575  ( m_nulValues[band] != -9999.0 ) )
576  {
577  if ( ( m_nulValues[band] > -9999.0 ) &&
578  ( m_nulValues[band] < m_minValues[band] ) )
579  {
580  m_minValues[band] = m_nulValues[band];
581  }
582  m_nulValues[band] = DEFAULT_NULL;
583  }
584  }
585  break;
586  }
587  case OSSIM_SINT32:
588  {
589  for (ossim_uint32 band = 0; band < BANDS; ++band)
590  {
591  if ( ( m_nulValues[band] != DEFAULT_NULL ) &&
592  ( m_nulValues[band] != -32768.0 ) && // Common null
593  ( m_nulValues[band] != -32767.0 ) && // The other common null.
594  ( m_nulValues[band] != -32766.0 ) &&
595  ( m_nulValues[band] != -9999.0 ) &&
596  ( m_nulValues[band] != -99999.0 ) )
597  {
598  if ( ( m_nulValues[band] > -9999.0 ) &&
599  ( m_nulValues[band] < m_minValues[band] ) )
600  {
601  m_minValues[band] = m_nulValues[band];
602  }
603  m_nulValues[band] = DEFAULT_NULL;
604  }
605  }
606  break;
607  }
608  case OSSIM_FLOAT32:
609  case OSSIM_FLOAT64:
610  {
611  for (ossim_uint32 band = 0; band < BANDS; ++band)
612  {
613  if ( ( m_nulValues[band] != DEFAULT_NULL ) &&
614  ( m_nulValues[band] != -32768.0 ) &&
615  ( m_nulValues[band] != -32767.0 ) &&
616  ( m_nulValues[band] != -32766.0 ) &&
617  ( m_nulValues[band] != -9999.0 ) &&
618  ( m_nulValues[band] != -99999.0 ) )
619  {
620  if ( ( m_nulValues[band] > -9999 ) &&
621  ( m_nulValues[band] < m_minValues[band] ) )
622  {
623  m_minValues[band] = m_nulValues[band];
624  }
625  m_nulValues[band] = DEFAULT_NULL;
626  }
627  }
628  break;
629  }
632  {
633  for (ossim_uint32 band = 0; band < BANDS; ++band)
634  {
635  if ( ( m_nulValues[band] != DEFAULT_NULL ) &&
636  ( m_nulValues[band] > 0.0) )
637  {
638  if ( m_nulValues[band] < m_minValues[band] )
639  {
640  m_minValues[band] = m_nulValues[band];
641  }
642  m_nulValues[band] = 0.0;
643  }
644  }
645  break;
646  }
648  default:
649  {
650  if(traceDebug())
651  {
653  << __FILE__ << ":" << __LINE__
654  << " " << M << "\nUnhandled scalar type: " << SCALAR << std::endl;
655  }
656  break;
657  }
658
659  } // End: switch(SCALAR)
660
661  } // Matches: if ( (m_minValues.size() == BANDS) &&...
662  else
663  {
664  // ERROR!
666  << M << "ERROR:\nMin, max and null array sizes bad! No omd file will be written."
667  << std::endl;
668  }
669
670  } // Matches: else if ( m_scanForMinMaxNull == true )
671  else
672  {
673  // Get the values from the image handler.
674  if (m_minValues.size() != BANDS)
675  {
676  m_minValues.resize(BANDS);
677  for (ossim_uint32 band = 0; band < BANDS; ++band)
678  {
680  }
681  }
682  if (m_maxValues.size() != BANDS)
683  {
684  m_maxValues.resize(BANDS);
685  for (ossim_uint32 band = 0; band < BANDS; ++band)
686  {
688  }
689  }
690  if (m_nulValues.size() != BANDS)
691  {
692  m_nulValues.resize(BANDS);
693  for (ossim_uint32 band = 0; band < BANDS; ++band)
694  {
696  }
697  }
698  }
699
700  // Last size check as the m_scanForMinMaxNull block could have failed.
701  if ( ( m_minValues.size() == BANDS ) &&
702  ( m_maxValues.size() == BANDS ) &&
703  ( m_nulValues.size() == BANDS ) )
704  {
705  // Write the omd file:
706  ossimKeywordlist kwl;
707  if( ossimFilename(file).exists())
708  {
709  // Pick up existing omd file.
710  kwl.addFile(file.c_str());
711  }
712  ossimImageMetaData metaData(SCALAR, BANDS);
713  for(ossim_uint32 band = 0; band < BANDS; ++band)
714  {
715  metaData.setMinPix(band, m_minValues[band]);
716  metaData.setMaxPix(band, m_maxValues[band]);
717  metaData.setNullPix(band, m_nulValues[band]);
718  }
719  // Save to keyword list.
720  metaData.saveState(kwl);
721
722  // Write to disk.
723  result = kwl.write(file.c_str());
724  if ( result )
725  {
726  ossimNotify(ossimNotifyLevel_NOTICE) << "Wrote file: " << file << "\n";
727  }
728  else
729  {
730  ossimNotify(ossimNotifyLevel_WARN) << "ERROR writing file: " << file << "\n";
731  }
732  }
733
734  if ( traceDebug() )
735  {
737  << "Final array values:\n";
738  std::vector<ossim_float64>::const_iterator i = m_minValues.begin();
739  ossim_int32 band = 0;
740  while ( i < m_minValues.end() )
741  {
743  << "min[" << band++ << "]: " << *i << "\n";
744  ++i;
745  }
746  i = m_maxValues.begin();
747  band = 0;
748  while ( i < m_maxValues.end() )
749  {
751  << "max[" << band++ << "]: " << *i << "\n";
752  ++i;
753  }
754  i = m_nulValues.begin();
755  band = 0;
756  while ( i < m_nulValues.end() )
757  {
759  << "nul[" << band++ << "]: " << *i << "\n";
760  ++i;
761  }
762  }
763
764  } // Matches: if ( file && m_imageHandler.valid() )
765
766  if ( traceDebug() )
767  {
768  ossimNotify(ossimNotifyLevel_DEBUG) << M << " exit status" << (result?"true\n":"false\n");
769  }
770
771  return result;
772 }
773
775 {
776  if (!m_imageHandler) return;
777
778  getOutputTileRectangle(inputRect);
779  inputRect = inputRect * m_decimationFactor;
780
781 #if 0
782  if (traceDebug())
783  {
785  << "ossimOverviewSequencer::getInputTileRectangle DEBUG:"
786  << "input rect: " << inputRect << std::endl;
787  }
788 #endif
789 }
790
792  ossimIrect& outputRect) const
793 {
794  // Get the row and column.
797
798  ossimIpt pt;
799
800  // Set the upper left.
801  pt.y = row * m_tileSize.y;
802  pt.x = col * m_tileSize.x;
803  outputRect.set_ul(pt);
804
805  // Set the lower right.
806  pt.y = pt.y + m_tileSize.y - 1;
807  pt.x = pt.x + m_tileSize.x - 1;
808  outputRect.set_lr(pt);
809
810 #if 0
811  if (traceDebug())
812  {
814  << "ossimOverviewSequencer::getOutputTileRectangle DEBUG:"
815  << "output rect: " << outputRect << std::endl;
816  }
817 #endif
818 }
819
821 {
823  {
826  m_dirtyFlag = true;
827  }
828  else
829  {
830  // Get the output rectangle.
831  ossimIrect rect;
833
835  static_cast<ossim_uint32>( rect.width() / m_tileSize.x );
837  static_cast<ossim_uint32>( rect.height() / m_tileSize.y );
838
839  if (rect.width() % m_tileSize.x)
840  {
842  }
843  if (rect.height() % m_tileSize.y)
844  {
846  }
847  }
848 }
849
851 {
853  {
854  case OSSIM_UINT8:
855  {
856  resampleTile(inputTile, ossim_uint8(0));
857  break;
858  }
859
860  case OSSIM_USHORT11:
861  case OSSIM_USHORT12:
862  case OSSIM_USHORT13:
863  case OSSIM_USHORT14:
864  case OSSIM_USHORT15:
865  case OSSIM_UINT16:
866  {
867  resampleTile(inputTile, ossim_uint16(0));
868  break;
869  }
870  case OSSIM_SINT16:
871  {
872  resampleTile(inputTile, ossim_sint16(0));
873  break;
874  }
875
876  case OSSIM_UINT32:
877  {
878  resampleTile(inputTile, ossim_uint32(0));
879  break;
880  }
881
882  case OSSIM_SINT32:
883  {
884  resampleTile(inputTile, ossim_sint32(0));
885  break;
886  }
887
888  case OSSIM_FLOAT32:
889  {
890  resampleTile(inputTile, ossim_float32(0.0));
891  break;
892  }
893
895  case OSSIM_FLOAT64:
896  {
897  resampleTile(inputTile, ossim_float64(0.0));
898  break;
899  }
900  default:
902  << "ossimOverviewSequencer::resampleTile Unknown pixel type!"
903  << std::endl;
904  return;
905
906  } // End of "switch(m_imageHandler->getOutputScalarType())"
907 }
908
909 template <class T>
910 void ossimOverviewSequencer::resampleTile(const ossimImageData* inputTile, T /* dummy */ )
911 {
912 #if 0
913  if (traceDebug())
914  {
916  << "ossimOverviewSequencer::resampleTile DEBUG: "
917  << "\ncurrent tile: " << m_currentTileNumber
918  << "\ninput tile:\n" << *inputTile
919  << "output tile:\n" << *(m_tile.get())
920  << endl;
921  }
922 #endif
923
924  const ossim_uint32 BANDS = m_tile->getNumberOfBands();
925  const ossim_uint32 LINES = m_tile->getHeight();
926  const ossim_uint32 SAMPS = m_tile->getWidth();
927  const ossim_uint32 INPUT_WIDTH = m_decimationFactor*m_tileSize.x;
928
929  T nullPixel = 0;
930  ossim_float64 weight = 0.0;
931  ossim_float64 value = 0.0;
932  ossim_uint32 sampOffset = 0;
933
935  {
936  for (ossim_uint32 band=0; band<BANDS; ++band)
937  {
938  const T* s = static_cast<const T*>(inputTile->getBuf(band)); // source
939  T* d = static_cast<T*>(m_tile->getBuf(band)); // destination
940
941  nullPixel = static_cast<T>(inputTile->getNullPix(band));
942  weight = 0.0;
943  value = 0.0;
944
945  for (ossim_uint32 i=0; i<LINES; ++i)
946  {
947  for (ossim_uint32 j=0; j<SAMPS; ++j)
948  {
949  sampOffset = j*m_decimationFactor;
950
951  weight = 1.0;
952  value = *(s + i*m_decimationFactor*INPUT_WIDTH + sampOffset);
953
954  if(weight)
955  {
956  d[j] = static_cast<T>( value/weight );
957  }
958  else
959  {
960  d[j] = nullPixel;
961  }
962
963  } // End of sample loop.
964
965  d += m_tileSize.x;
966
967  } // End of line loop.
968
969  } // End of band loop.
970
971  }
972  else // ossimFilterResampler::ossimFilterResampler_BOX
973  {
974  ossim_uint32 lineOffset1 = 0;
975  ossim_uint32 lineOffset2 = 0;
976  ossim_float64 ul = 0.0;
977  ossim_float64 ur = 0.0;
978  ossim_float64 ll = 0.0;
979  ossim_float64 lr = 0.0;
980
981  for (ossim_uint32 band=0; band<BANDS; ++band)
982  {
983  const T* s = static_cast<const T*>(inputTile->getBuf(band)); // source
984  T* d = static_cast<T*>(m_tile->getBuf(band)); // destination
985
986  nullPixel = static_cast<T>(inputTile->getNullPix(band));
987  weight = 0.0;
988  value = 0.0;
989
990  for (ossim_uint32 i=0; i<LINES; ++i)
991  {
992  lineOffset1 = i*m_decimationFactor*INPUT_WIDTH;
993  lineOffset2 = (i*m_decimationFactor+1)*INPUT_WIDTH;
994
995  for (ossim_uint32 j=0; j<SAMPS; ++j)
996  {
997  sampOffset = j*m_decimationFactor;
998
999  weight = 0.0;
1000  value = 0.0;
1001
1002  //---
1003  // Grab four pixels from the source, average, and assign
1004  // to output.
1005  //---
1006  ul = *(s + lineOffset1 + sampOffset);
1007  ur = *(s + lineOffset1 + sampOffset + 1);
1008  ll = *(s + lineOffset2 + sampOffset);
1009  lr = *(s + lineOffset2 + sampOffset + 1);
1010
1011  if(ul != nullPixel)
1012  {
1013  ++weight;
1014  value += ul;
1015  }
1016  if(ur != nullPixel)
1017  {
1018  ++weight;
1019  value += ur;
1020  }
1021  if(ll != nullPixel)
1022  {
1023  ++weight;
1024  value += ll;
1025  }
1026  if(lr != nullPixel)
1027  {
1028  ++weight;
1029  value += lr;
1030  }
1031
1032  if(weight)
1033  {
1034  d[j] = static_cast<T>( value/weight );
1035  }
1036  else
1037  {
1038  d[j] = nullPixel;
1039  }
1040
1041  } // End of sample loop.
1042
1043  d += m_tileSize.x;
1044
1045  } // End of line loop.
1046
1047  } // End of band loop.
1048  }
1049 }
1050
1052  ossimMaskFilter* mask_filter)
1053 {
1054  m_maskWriter = mask_writer;
1055  m_maskFilter = mask_filter;
1056 }
8 bit signed integer
void setScanForMinMaxNull(bool flag)
Turn on/off scan for min, max, null flag.
std::vector< ossim_float64 > m_maxValues
ossim_uint32 getNumberOfTilesHorizontal() const
ossimHistogramMode
ossim_int32 m_decimationFactor
TODO make this handle any decimation.
64 bit floating point
16 bit unsigned integer
ossim_uint32 m_histoTileIndex
Used to determine which tiles to accumulate a histogram from.
virtual void populateHistogram(ossimRefPtr< ossimMultiBandHistogram > histo)
virtual void setWidthHeight(ossim_uint32 w, ossim_uint32 h)
bool addFile(const char *file)
virtual void computeMinMaxPix(std::vector< ossim_float64 > &minBands, std::vector< ossim_float64 > &maxBands) const
If the minBands and maxBands are empty or not equal to the imageData&#39;s current number of bands it wil...
ossimOverviewSequencer()
default constructor
bool valid() const
Definition: ossimRefPtr.h:75
ossimRefPtr< ossimImageData > m_tile
ossimReferenced allows for shared object ref counting if the reference count ever gets to 0 or less i...
float ossim_float32
ossimRefPtr< ossimImageHandler > m_imageHandler
ossim_uint32 height() const
Definition: ossimIrect.h:487
ossimRefPtr< ossimBitMaskWriter > m_maskWriter
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
std::vector< ossim_float64 > m_nulValues
virtual void getOutputImageRectangle(ossimIrect &rect) const
Gets the zero-based image rectangle for the output reduced resolution data set (rrds).
std::vector< ossim_float64 > m_minValues
Arrays o hold the min value for each band for scan min/max methods.
16 bit signed integer
ossim_uint32 getNumberOfTilesVertical() const
ossim_uint32 getNumberOfTiles() const
32 bit floating point
unsigned short ossim_uint16
32 bit unsigned integer
virtual bool write(const char *file, const char *comment=0) const
Methods to dump the ossimKeywordlist to a file on disk.
virtual void initialize()
Initialize the data buffer.
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel=0)
Main entry point for the algorithm.
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
virtual void computeMinMaxNulPix(std::vector< ossim_float64 > &minBands, std::vector< ossim_float64 > &maxBands, std::vector< ossim_float64 > &nulBands) const
Scans tile for min, max, nulls.
#define OSSIM_DEFAULT_TILE_WIDTH
Retuns the min pixel value.
void set_ul(const ossimIpt &pt)
Definition: ossimIrect.h:589
ossimFilterResampler::ossimFilterResamplerType m_resampleType
Currently only handles NEAREST_NEIGHBOR and BOX (default = BOX)
void setMinPix(ossim_uint32 band, double pix)
double ossim_float64
virtual void setToStartOfSequence()
Will set the internal pointers to the upperleft tile number.
bool m_dirtyFlag
Dirty flag - if true, this object is not initialized.
ossimRefPtr< ossimMaskFilter > m_maskFilter
void updateTileDimensions()
Updates theNumberOfTilesHorizontal and theNumberOfTilesVertical.
void resampleTile(const ossimImageData *inputTile)
Resamples a patch of data.
void writeHistogram()
Write histogram method.
bool exists() const
void setTileSize(const ossimIpt &pt)
updated the tile size.
signed short ossim_sint16
32 bit signed integer
OSSIM_DLL double defaultNull(ossimScalarType scalarType)
bool m_scanForMinMax
Control flags for min, max, null scanning.
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
ossimRefPtr< ossimMultiBandHistogram > m_histogram
signed int ossim_sint32
virtual void addHistogram(ossimMultiBandHistogram *histo)
virtual ossimRefPtr< ossimImageData > getNextTile()
Will allow you to get the next tile in the sequence.
ossim_uint32 m_sourceResLevel
This is the resolution level to build overviews from.
Class for computing a mask from an input image source and writing the mask file to disk...
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
bool saveState(ossimKeywordlist &kwl, const char *prefix=0) const
ossim_uint32 width() const
Definition: ossimIrect.h:500
ossimScalarType
void setImageHandler(ossimImageHandler *input)
Sets the input source or connection.
void generateMask(ossimRefPtr< ossimImageData > tile, ossim_uint32 rLevel)
Given a source&#39;s tile, derives the alpha mask and saves it in buffer for later writing to disk...
virtual void makeBlank()
int getRank() const
Definition: ossimMpi.cpp:140
void set_lr(const ossimIpt &pt)
Definition: ossimIrect.h:623
void clearMinMaxNullArrays()
Clears out the arrays from a scan for min, max, nulls.
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
ossim_int32 y
Definition: ossimIpt.h:142
void makeNan()
Definition: ossimIrect.h:329
void setScanForMinMax(bool flag)
Turn on/off scan for min max flag.
void setSourceLevel(ossim_uint32 level)
Sets the input source resolution to decimate from.
virtual void slaveProcessTiles()
This implementation does nothing.
#define OSSIM_DEFAULT_TILE_HEIGHT
virtual ~ossimOverviewSequencer()
virtual destructor
const char * c_str() const
Definition: ossimString.h:396
void getInputTileRectangle(ossimIrect &inputRect) const
Gets the image rectangle for the input tile for theCurrentTileNumber.
ossimHistogramMode m_histoMode
bool hasNans() const
Definition: ossimIrect.h:337
void setHistogramMode(ossimHistogramMode mode)
Sets the histogram accumulation mode.
ossim_int32 x
Definition: ossimIpt.h:141
ossimHistogramMode getHistogramMode() const
Gets the histogram accumulation mode.
8 bit unsigned integer
bool writeOmdFile(const std::string &file)
Writes an ossim metadata(omd) file with min, max, null values.
Definition: ossimIpt.h:58
void setBitMaskObjects(ossimBitMaskWriter *mask_writer, ossimMaskFilter *mask_filter)
Enabled the generation of an alpha (bit) mask such that any full or partial null pixels will be maske...
virtual ossim_uint32 getNumberOfInputBands() const =0
void create(const ossimImageSource *input)
ossimFilename getFilenameWithThisExtension(const ossimString &ext, bool set_e0_prefix=false) const
Returns the image file with extension set using supplentary directory for dirname if set...
static ossimMpi * instance()
Definition: ossimMpi.cpp:27
void getOutputTileRectangle(ossimIrect &outputRect) const
Gets the image rectangle for the output tile for theCurrentTileNumber.
void setMaxPix(ossim_uint32 band, double pix)
unsigned char ossim_uint8
void setResampleType(ossimFilterResampler::ossimFilterResamplerType resampleType)
Sets the resampling type.
This must be called.
void setNullPix(ossim_uint32 band, double pix)
int ossim_int32
