ossimOpjJp2Writer.h
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // License: See top level LICENSE.txt file
4 //
5 // Author: David Burken
6 //
7 // Description: OSSIM Open JPEG (j2k) writer.
8 //
9 //----------------------------------------------------------------------------
10 // $Id: ossimOpjJp2Writer.h 11652 2007-08-24 17:14:15Z dburken $
11 #ifndef ossimOpjJp2Writer_HEADER
12 #define ossimOpjJp2Writer_HEADER 1
13
14 #include <ossim/base/ossimRtti.h>
18 #include <ossim/base/ossimRefPtr.h>
21
22 class ossimOpjCompressor;
23
25 {
26 public:
27
28  /* default constructor */
30
31  /*
32  * constructor with typeName
33  * if typeName=="ossim_opj_geojp2", only write geotiff header
34  * if typeName=="ossim_opj_gmljp2", only write gmljp2 header
35  * else, write both headers
36  */
37  ossimOpjJp2Writer( const ossimString& typeName );
38
39  /* virtual destructor */
40  virtual ~ossimOpjJp2Writer();
41
43  virtual ossimString getShortName() const;
44
46  virtual ossimString getLongName() const;
47
49  virtual ossimString getClassName() const;
50
60  virtual void getImageTypeList(std::vector<ossimString>& imageTypeList)const;
61
62  virtual bool isOpen()const;
63
64  virtual bool open();
65
66  virtual void close();
67
71  virtual bool saveState(ossimKeywordlist& kwl,
72  const char* prefix=0)const;
73
78  virtual bool loadState(const ossimKeywordlist& kwl,
79  const char* prefix=0);
80
87  virtual void setProperty(ossimRefPtr<ossimProperty> property);
88
94  virtual ossimRefPtr<ossimProperty> getProperty(const ossimString& name)const;
95
101  virtual void getPropertyNames(std::vector<ossimString>& propertyNames) const;
102
111  virtual ossimString getExtension() const;
112
120  virtual bool getOutputHasInternalOverviews( void ) const;
121
128  bool hasImageType(const ossimString& imageType) const;
129
135  virtual bool writeStream();
136
144  virtual bool setOutputStream(std::ostream& stream);
145
146 private:
147
148  bool writeGeotiffBox(std::ostream* stream, ossimOpjCompressor* compressor);
149  bool writeGmlBox(std::ostream* stream, ossimOpjCompressor* compressor);
150
155  void copyData( const std::streamoff& pos,
157  std::vector<ossim_uint8>& data ) const;
158
163  virtual bool writeFile();
164
171
172  TYPE_DATA
173
174 };
175
176 #endif /* #ifndef ossimOpjVoid Writer_HEADER */
virtual bool isOpen() const
Writes the file to disk or a stream.
bool writeGmlBox(std::ostream *stream, ossimOpjCompressor *compressor)
Pure virtual base class for image file writers.
Pushes this&#39;s names onto the list of property names.
Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for...
yy_size_t size
virtual bool getOutputHasInternalOverviews(void) const
Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nit...
#define TYPE_DATA
Definition: ossimRtti.h:339
unsigned int ossim_uint32
bool hasImageType(const ossimString &imageType) const
Method to write the image to a stream.
Will set the property whose name matches the argument "property->getName()".
void copyData(const std::streamoff &pos, ossim_uint32 size, std::vector< ossim_uint8 > &data) const
Hack to copy bytes to vector so we can re-write them.
ossimOpjCompressor * m_compressor
bool writeGeotiffBox(std::ostream *stream, ossimOpjCompressor *compressor)
std::ostream * m_outputStream
virtual bool open()
virtual bool setOutputStream(std::ostream &stream)
Sets the output stream to write to.
virtual void getImageTypeList(std::vector< ossimString > &imageTypeList) const
saves the state of the object.
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
