Public Member Functions | Private Member Functions | Private Attributes | List of all members
ossimOpjJp2Writer Class Reference
#include <ossimOpjJp2Writer.h>
Inheritance diagram for ossimOpjJp2Writer:
ossimImageFileWriter ossimImageWriter ossimProcessInterface ossimConnectableObjectListener ossimOutputSource ossimListener ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
 ossimOpjJp2Writer ()
 ossimOpjJp2Writer (const ossimString &typeName)
virtual ~ossimOpjJp2Writer ()
virtual void getImageTypeList (std::vector< ossimString > &imageTypeList) const
 void getImageTypeList(std::vector<ossimString>& imageTypeList)const More...
virtual bool isOpen () const
virtual bool open ()
virtual void close ()
 saves the state of the object. More...
 Will set the property whose name matches the argument "property->getName()". More...
 Pushes this's names onto the list of property names. More...
virtual ossimString getExtension () const
 Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More...
virtual bool getOutputHasInternalOverviews (void) const
 Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More...
bool hasImageType (const ossimString &imageType) const
virtual bool writeStream ()
 Method to write the image to a stream. More...
virtual bool setOutputStream (std::ostream &stream)
 Sets the output stream to write to. More...
- Public Member Functions inherited from ossimImageFileWriter
 ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0)
 The writer will own the sequencer. More...
virtual ~ossimImageFileWriter ()
virtual void setTileSize (const ossimIpt &tileSize)
 Sets the output image tiling size if supported by the writer. More...
virtual bool writeEnviHeaderFile ()
 Will write an envi header file. More...
virtual bool writeErsHeaderFile ()
 Will write an ER Mapper header file. More...
virtual bool writeExternalGeometryFile ()
 Will write an external geometry file. More...
virtual bool writeFgdcFile ()
 Will write an fgdc file. More...
virtual bool writeHistogramFile ()
 Returns true on success, false on error. More...
virtual bool writeJpegWorldFile ()
 Will write a jpeg world file. More...
virtual bool writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false)
 Write out an ossim overview file from the source_file. More...
virtual bool writeReadmeFile ()
 Will write a readme file. More...
virtual bool writeTiffWorldFile ()
 Will write a world file. More...
virtual bool writeWorldFile ()
virtual bool writeMetaDataFiles ()
 Convenience method that calls meta data write methods that are flagged to be called. More...
virtual void setAreaOfInterest (const ossimIrect &inputRect)
virtual void changeSequencer (ossimImageSourceSequencer *sequencer)
 Sets the sequencer and connects it to the input of this. More...
virtual ossimImageSourceSequencergetSequencer ()
virtual void initialize ()
 Initialize method. More...
virtual bool execute ()
 Calls: writeFile() writeMetaDataFiles() More...
virtual bool setOutputStream (ossimRefPtr< ossimOStream > stream)
virtual ossimRefPtr< ossimOStreamgetOutputStream () const
 Method to return the stream attached to output. More...
virtual void setOutputImageType (ossim_int32 type)
virtual void setOutputImageType (const ossimString &type)
virtual ossim_int32 getOutputImageType () const
virtual ossimString getOutputImageTypeString () const
virtual void setOutputName (const ossimString &outputName)
virtual void setFilename (const ossimFilename &file)
virtual bool canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const
virtual bool getWriteImageFlag () const
 Control flags... More...
virtual bool getWriteHistogramFlag () const
virtual bool getWriteOverviewFlag () const
virtual bool getScaleToEightBitFlag () const
virtual bool getWriteEnviHeaderFlag () const
virtual bool getWriteErsHeaderFlag () const
virtual bool getWriteExternalGeometryFlag () const
virtual bool getWriteFgdcFlag () const
virtual bool getWriteJpegWorldFileFlag () const
virtual bool getWriteReadmeFlag () const
virtual bool getWriteTiffWorldFileFlag () const
virtual bool getWriteWorldFileFlag () const
virtual void setWriteImageFlag (bool flag)
virtual void setWriteOverviewFlag (bool flag)
virtual void setWriteHistogramFlag (bool flag)
virtual void setScaleToEightBitFlag (bool flag)
virtual void setWriteEnviHeaderFlag (bool flag)
virtual void setWriteErsHeaderFlag (bool flag)
virtual void setWriteExternalGeometryFlag (bool flag)
virtual void setWriteFgdcFlag (bool flag)
virtual void setWriteJpegWorldFile (bool flag)
virtual void setWriteReadme (bool flag)
virtual void setWriteTiffWorldFile (bool flag)
virtual void setWriteWorldFile (bool flag)
virtual ossim_uint16 getOverviewCompressType () const
virtual ossim_int32 getOverviewJpegCompressQuality () const
virtual void setOverviewCompressType (ossim_uint16 type)
virtual void setOverviewJpegCompressQuality (ossim_int32 quality)
 Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More...
 Overrides base "removeListener". More...
virtual void setPixelType (ossimPixelType type)
 If "point" the coordinate tie points are relative to the center of the pixel. More...
virtual void setPixelType (const ossimString &type)
virtual ossimPixelType getPixelType () const
virtual void getPixelTypeString (ossimString &type) const
- Public Member Functions inherited from ossimImageWriter
 ossimImageWriter (ossimObject *owner=NULL)
 ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed)
virtual ~ossimImageWriter ()
virtual bool setViewingRect (const ossimIrect &aRect)
virtual ossimIrect getAreaOfInterest () const
- Public Member Functions inherited from ossimOutputSource
 ossimOutputSource (ossimObject *owner=NULL)
 ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true)
virtual ~ossimOutputSource ()
virtual bool open (const ossimString &outputName)
virtual const ossimStringgetOutputName ()
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
- Public Member Functions inherited from ossimProcessInterface
 ossimProcessInterface ()
virtual void abort ()
bool needsAborting () const
bool isAborted () const
bool isExecuting () const
void enableEvents ()
void disableEvents ()
 ProcessEvent. More...
virtual void refreshEvent (ossimRefreshEvent &)
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
bool writeGeotiffBox (std::ostream *stream, ossimOpjCompressor *compressor)
bool writeGmlBox (std::ostream *stream, ossimOpjCompressor *compressor)
void copyData (const std::streamoff &pos, ossim_uint32 size, std::vector< ossim_uint8 > &data) const
 Hack to copy bytes to vector so we can re-write them. More...
virtual bool writeFile ()
 Writes the file to disk or a stream. More...
Private Attributes
std::ostream * m_outputStream
bool m_ownsStreamFlag
bool m_overviewFlag
ossimOpjCompressorm_compressor
bool m_do_geojp2
bool m_do_gmljp2
Additional Inherited Members
- Public Types inherited from ossimProcessInterface
enum  ossimProcessStatus {
- Protected Member Functions inherited from ossimImageFileWriter
bool writeWorldFile (const ossimFilename &file)
 Common world file writer method. More...
virtual ~ossimReferenced ()
- Protected Attributes inherited from ossimImageFileWriter
ossimRefPtr< ossimImageSourceSequencertheInputConnection
ossimRefPtr< ossimViewControllertheViewController
ossimListenertheProgressListener
ossimFilename theFilename
ossimString theOutputImageType
bool theWriteImageFlag
bool theWriteOverviewFlag
bool theWriteHistogramFlag
bool theScaleToEightBitFlag
ossim_uint16 theOverviewCompressType
ossim_int32 theOverviewJpegCompressQuality
bool theWriteEnviHeaderFlag
 External meta data writer flags. More...
bool theWriteErsHeaderFlag
bool theWriteExternalGeometryFlag
bool theWriteFgdcFlag
bool theWriteJpegWorldFileFlag
bool theWriteReadmeFlag
bool theWriteTiffWorldFileFlag
bool theWriteWorldFileFlag
bool theAutoCreateDirectoryFlag
ossimUnitType theLinearUnits
 If not a geographic projection this allows the user to set the linear units of the output tag to be: More...
ossimPixelType thePixelType
 OSSIM_PIXEL_IS_POINT = 0, OSSIM_PIXEL_IS_AREA = 1. More...
- Protected Attributes inherited from ossimImageWriter
ossimIrect theAreaOfInterest
- Protected Attributes inherited from ossimOutputSource
ossimString theOutputName
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
- Protected Attributes inherited from ossimProcessInterface
double thePercentComplete
ossimString theMessage
bool theEventFlag
bool theListenerEnableFlag
Detailed Description
Definition at line 24 of file ossimOpjJp2Writer.h.
◆ ossimOpjJp2Writer() [1/2]
ossimOpjJp2Writer::ossimOpjJp2Writer ( )
◆ ossimOpjJp2Writer() [2/2]
ossimOpjJp2Writer::ossimOpjJp2Writer ( const ossimString typeName)
◆ ~ossimOpjJp2Writer()
virtual ossimOpjJp2Writer::~ossimOpjJp2Writer ( )
virtual
Member Function Documentation
◆ close()
virtual void ossimOpjJp2Writer::close ( )
virtual
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implements ossimOutputSource.
◆ copyData()
void ossimOpjJp2Writer::copyData ( const std::streamoff &  pos,
ossim_uint32  size,
std::vector< ossim_uint8 > &  data
) const
private
Hack for inserting geotiff and gml boxes in front of jp2c codestream block.
◆ getClassName()
virtual ossimString ossimOpjJp2Writer::getClassName ( ) const
virtual
Returns
"ossimOpjReader"
◆ getExtension()
virtual ossimString ossimOpjJp2Writer::getExtension ( ) const
virtual
Parameters
imageTypestring representing image type.
Returns
the 3-letter string extension.
Reimplemented from ossimImageFileWriter.
◆ getImageTypeList()
virtual void ossimOpjJp2Writer::getImageTypeList ( std::vector< ossimString > &  imageTypeList) const
virtual
Appends this writer image types to list "imageTypeList".
This writer has types "ossim_opj_jp2", "ossim_opj_geojp2", and "ossim_opj_gmljp2".
Parameters
imageTypeListstl::vector<ossimString> list to append to.
Implements ossimImageFileWriter.
◆ getLongName()
virtual ossimString ossimOpjJp2Writer::getLongName ( ) const
virtual
Returns
"ossim open jpeg writer"
◆ getOutputHasInternalOverviews()
virtual bool ossimOpjJp2Writer::getOutputHasInternalOverviews ( void  ) const
virtual
Returns
true if the output of the writer will have internal overviews. The default is false.
◆ getProperty()
virtual ossimRefPtr<ossimProperty> ossimOpjJp2Writer::getProperty ( const ossimString name) const
virtual
Parameters
nameName of property to return.
Returns
A pointer to a property object which matches "name".
◆ getPropertyNames()
virtual void ossimOpjJp2Writer::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Parameters
propertyNamesarray to add this's property names to.
◆ getShortName()
virtual ossimString ossimOpjJp2Writer::getShortName ( ) const
virtual
Returns
"ossim_openjpeg_writer"
◆ hasImageType()
bool ossimOpjJp2Writer::hasImageType ( const ossimString imageType) const
virtual
Parameters
imageType
Returns
true if "imagetype" is one of: "image/jp2" or "image/j2k" "ossim_opj_jp2", ossim_opj_geojp2", or "ossim_opj_gmljp2"
◆ isOpen()
virtual bool ossimOpjJp2Writer::isOpen ( ) const
virtual
◆ loadState()
virtual bool ossimOpjJp2Writer::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
◆ open()
virtual bool ossimOpjJp2Writer::open ( )
virtual
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
◆ saveState()
virtual bool ossimOpjJp2Writer::saveState ( ossimKeywordlist kwl,
) const
virtual
◆ setOutputStream()
virtual bool ossimOpjJp2Writer::setOutputStream ( std::ostream &  stream)
virtual
The stream will not be closed/deleted by this object.
Parameters
outputThe stream to write to.
◆ setProperty()
virtual void ossimOpjJp2Writer::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Parameters
propertyObject containing property to set.
◆ writeFile()
virtual bool ossimOpjJp2Writer::writeFile ( )
privatevirtual
Returns
◆ writeGeotiffBox()
bool ossimOpjJp2Writer::writeGeotiffBox ( std::ostream *  stream,
ossimOpjCompressor compressor
private
◆ writeGmlBox()
bool ossimOpjJp2Writer::writeGmlBox ( std::ostream *  stream,
private
◆ writeStream()
virtual bool ossimOpjJp2Writer::writeStream ( )
virtual
Returns
Member Data Documentation
◆ m_compressor
ossimOpjCompressor* ossimOpjJp2Writer::m_compressor
private
Definition at line 168 of file ossimOpjJp2Writer.h.
◆ m_do_geojp2
bool ossimOpjJp2Writer::m_do_geojp2
private
Definition at line 169 of file ossimOpjJp2Writer.h.
◆ m_do_gmljp2
bool ossimOpjJp2Writer::m_do_gmljp2
private
Definition at line 170 of file ossimOpjJp2Writer.h.
◆ m_outputStream
std::ostream* ossimOpjJp2Writer::m_outputStream
private
Definition at line 165 of file ossimOpjJp2Writer.h.
◆ m_overviewFlag
bool ossimOpjJp2Writer::m_overviewFlag
private
Definition at line 167 of file ossimOpjJp2Writer.h.
◆ m_ownsStreamFlag
bool ossimOpjJp2Writer::m_ownsStreamFlag
private
Definition at line 166 of file ossimOpjJp2Writer.h.
The documentation for this class was generated from the following file:
