Public Types | Public Member Functions | Private Member Functions | Private Attributes | List of all members
ossimOpjCompressor Class Reference
#include <ossimOpjCompressor.h>
Public Types
enum  ossimOpjCompressionQuality {
  OPJ_UNKNOWN = 0, OPJ_USER_DEFINED = 1, OPJ_NUMERICALLY_LOSSLESS = 2, OPJ_VISUALLY_LOSSLESS = 3,
  OPJ_LOSSY = 4
 ossimOpjCompressor ()
 default constructor More...
 ~ossimOpjCompressor ()
 destructor More...
void create (std::ostream *os, ossimScalarType scalar, ossim_uint32 bands, const ossimIrect &imageRect, const ossimIpt &tileSize, bool jp2)
 Create method. More...
void openJp2Codestream ()
 Calls "open_codestream" on the m_jp2Target. More...
bool writeTile (ossimImageData *srcTile, ossim_uint32 tileIndex)
 Write tile method. More...
void finish ()
 Finish method. More...
void setQualityType (ossimOpjCompressionQuality type)
 Sets the quality type. More...
ossimOpjCompressionQuality getQualityType () const
void setReversibleFlag (bool reversible)
 Sets the m_reversible flag. More...
bool getReversibleFlag () const
void setAlphaChannelFlag (bool flag)
 Set the writer to add an alpha channel to the output png image. More...
bool getAlphaChannelFlag () const
 Retrieve the writer's setting for whether or not to add an alpha channel to the output png image. More...
void setLevels (ossim_int32 levels)
 Sets the number of levels. More...
ossim_int32 getLevels () const
void setThreads (ossim_int32 threads)
 Sets the number of threads. More...
ossim_int32 getThreads () const
void setOptions (const std::vector< ossimString > &options)
 Sets the options array. More...
void getOptions (std::vector< ossimString > &options) const
 Get the array of options. More...
bool saveState (ossimKeywordlist &kwl, const char *prefix=0) const
 saves the state of the object. More...
bool loadState (const ossimKeywordlist &kwl, const char *prefix=0)
bool setProperty (ossimRefPtr< ossimProperty > property)
 Will set the property whose name matches the argument "property->getName()". More...
ossimRefPtr< ossimPropertygetProperty (const ossimString &name) const
void getPropertyNames (std::vector< ossimString > &propertyNames) const
 Pushes this's names onto the list of property names. More...
bool writeGeotiffBox (std::ostream *stream, const ossimImageGeometry *geom, const ossimIrect &rect, const ossimFilename &tmpFile, ossimPixelType pixelType)
 Writes the geotiff box to the jp2. More...
bool writeGmlBox (std::ostream *stream, const ossimImageGeometry *geom, const ossimIrect &rect)
 Writes the gml box to the jp2. More...
void initOpjCodingParams (bool jp2, const ossimIpt &tileSize, const ossimIrect &imageRect)
int getNumberOfLayers () const
ossimString getQualityTypeString () const
void setQualityTypeString (const ossimString &s)
void initLevels (const ossimIrect &imageRect)
 Set levels, class attribute m_levels and m_parameters->numresolution. More...
void setCodeBlockSize (ossim_int32 xSize, ossim_int32 ySize)
 Set code block size. More...
void setProgressionOrder (OPJ_PROG_ORDER progressionOrder)
 Sets progression order. More...
void setTlmTileCount (ossim_uint32 tilesToWrite)
opj_cparameters_t * createOpjCodingParameters (bool jp2, const ossimIpt &tileSize, const ossimIrect &imageRect) const
opj_codec_t * createOpjCodec (bool jp2) const
opj_stream_t * createOpjStream (std::ostream *os) const
opj_image_t * createOpjImage (ossimScalarType scalar, ossim_uint32 bands, const ossimIrect &imageRect) const
Private Attributes
opj_cparameters_t * m_params
opj_codec_t * m_codec
opj_stream_t * m_stream
opj_image_t * m_image
ossimIrect m_imageRect
 Image rectangle. More...
bool m_reversible
 Lossless or lossy. More...
bool m_alpha
 If true write alpha channel. More...
ossim_int32 m_levels
 Reduced resolution levels. More...
ossim_int32 m_threads
 Number of threads. More...
std::vector< ossimStringm_options
 Container for Opj options. More...
ossimOpjCompressionQuality m_qualityType
Detailed Description
Definition at line 29 of file ossimOpjCompressor.h.
◆ ossimOpjCompressionQuality
Enumerator
OPJ_UNKNOWN
OPJ_USER_DEFINED
OPJ_LOSSY
Definition at line 34 of file ossimOpjCompressor.h.
◆ ossimOpjCompressor()
ossimOpjCompressor::ossimOpjCompressor ( )
default constructor
Definition at line 104 of file ossimOpjCompressor.cpp.
105  :
106  m_params(0),
107  m_codec(0),
108  m_stream(0),
109  m_image(0),
110  m_imageRect(),
111  m_reversible(true),
112  m_alpha(false),
113  m_levels(0),
114  m_threads(1),
115  m_options(),
117 {
118  //---
119  // Uncomment for debug mode:
120  // traceDebug.setTraceFlag(true);
121  //---
122 }
Number of threads.
bool m_reversible
Lossless or lossy.
Image rectangle.
std::vector< ossimString > m_options
bool m_alpha
◆ ~ossimOpjCompressor()
ossimOpjCompressor::~ossimOpjCompressor ( )
destructor
Definition at line 124 of file ossimOpjCompressor.cpp.
References finish().
125 {
126  finish();
127 }
void finish()
Finish method.
Member Function Documentation
◆ create()
void ossimOpjCompressor::create ( std::ostream *  os,
ossim_uint32  bands,
const ossimIrect imageRect,
const ossimIpt tileSize,
bool  jp2
Create method.
Parameters
osStream to write to.
scalarScalar type of source tiles to be fed to compressor.
bandsNumber of bands in source tiles to be fed to compressor.
imageRectThe image rectangle.
tileSizeThe size of a tile.
jp2If true jp2 header and jp2 geotiff block will be written out.
Note
Throws ossimException on error.
Definition at line 129 of file ossimOpjCompressor.cpp.
135 {
136  static const char MODULE[] = "ossimOpjCompressor::create";
137  if ( traceDebug() )
138  {
139  ossimNotify(ossimNotifyLevel_WARN) << MODULE << " entered...\n";
140  }
141
142 #if 0 /* Please leave for debug. (drb) */
143  cout << "levels: " << m_levels
144  << "\nreversible: " << m_reversible
145  << "\nthreads: " << m_threads
146  << "\nscalar: " << scalar
147  << "\nbands: " << bands
148  << "\nimageRect: " << imageRect
149  << "\ntileSize: " << tileSize
150  << "\njp2: " << jp2
151  << endl;
152 #endif
153
154  // In case we were reused.
155  finish();
156
157  if ( !os )
158  {
159  std::string errMsg = MODULE;
160  errMsg += " ERROR: Null stream passed to method!";
161  throw ossimException(errMsg);
162  }
163
164  if ( !os->good() )
165  {
166  std::string errMsg = MODULE;
167  errMsg += " ERROR: Stream state has error!";
168  throw ossimException(errMsg);
169  }
170
171  if ( ossim::getActualBitsPerPixel(scalar) > 31 )
172  {
173  // Data is not reversible.
174  if ( m_reversible )
175  {
176  std::string errMsg = MODULE;
177  errMsg += " ERROR: Reversible processing not possible with 32 bit data!";
178  throw ossimException(errMsg);
179  }
180  }
181
182  // Store for tile clip.
183  m_imageRect = imageRect;
184
185  m_stream = createOpjStream( os );
186  if ( !m_stream )
187  {
188  std::string errMsg = MODULE;
189  errMsg += " ERROR: OPJ stream creation failed!";
190  throw ossimException(errMsg);
191  }
192
193  // Requests the insertion of TLM (tile-part-length) marker.
194  // setTlmTileCount(tilesToWrite);
195
196  // Set up stream:
197  initOpjCodingParams( jp2, tileSize, imageRect );
198  if ( !m_params )
199  {
200  std::string errMsg = MODULE;
201  errMsg += " ERROR: coding parameters creation failed!";
202  throw ossimException(errMsg);
203  }
204
205  m_codec = createOpjCodec( jp2 );
206  if ( !m_codec )
207  {
208  std::string errMsg = MODULE;
209  errMsg += " ERROR: code creation failed!";
210  throw ossimException(errMsg);
211  }
212
213  // Set rates rates/distorsion
214  // parameters->cp_disto_alloc = 1;
215
216  // ossim::print( cout, *m_params );
217
218  if (m_alpha)
219  {
220  if ( (bands != 1) && (bands != 3) )
221  {
222  m_alpha = false;
223  if ( traceDebug() )
224  {
226  << "Alpha channel being unset! Can only be used with "
227  << "one or three band data.\n"
228  << "Source image bands: " << bands << "\n";
229  }
230  }
231  }
232
233  // Create an image without allocating memory(for tile based).
234  m_image = createOpjImage( scalar, bands, imageRect );
235  if ( !m_image )
236  {
237  std::string errMsg = MODULE;
238  errMsg += " ERROR: Unsupported input image type!";
239  throw ossimException(errMsg);
240  }
241
242  if ( !opj_setup_encoder( m_codec, m_params, m_image) )
243  {
244  std::string errMsg = MODULE;
245  errMsg += " ERROR: opj_setup_encoder failed!";
246  throw ossimException(errMsg);
247  }
248
249  // openJp2Codestream();
250
251  if ( traceDebug() )
252  {
254
256  << MODULE << " exiting...\n";
257  }
258 }
void finish()
Finish method.
Number of threads.
opj_stream_t * createOpjStream(std::ostream *os) const
OSSIM_DLL ossim_uint32 getActualBitsPerPixel(ossimScalarType scalarType)
Get actual bits per pixel for a given scalar type.
void initOpjCodingParams(bool jp2, const ossimIpt &tileSize, const ossimIrect &imageRect)
bool m_reversible
Lossless or lossy.
Image rectangle.
std::ostream & print(std::ostream &out, kdu_core::kdu_codestream &cs)
Convenience print method for kdu_codestream.
opj_image_t * createOpjImage(ossimScalarType scalar, ossim_uint32 bands, const ossimIrect &imageRect) const
bool m_alpha
opj_codec_t * createOpjCodec(bool jp2) const
◆ createOpjCodec()
opj_codec_t * ossimOpjCompressor::createOpjCodec ( bool  jp2) const
private
Definition at line 1132 of file ossimOpjCompressor.cpp.
References ossim::opj_error_callback(), ossim::opj_info_callback(), and ossim::opj_warning_callback().
1133 {
1134  opj_codec_t* codec = 0;
1135  if ( jp2 )
1136  {
1137  codec = opj_create_compress(OPJ_CODEC_JP2);
1138  }
1139  else
1140  {
1141  codec = opj_create_compress(OPJ_CODEC_J2K);
1142  }
1143
1144  if ( codec )
1145  {
1146  // Catch events using our callbacks and give a local context.
1147  opj_set_info_handler (codec, ossim::opj_info_callback, 00);
1148  opj_set_warning_handler(codec, ossim::opj_warning_callback,00);
1149  opj_set_error_handler (codec, ossim::opj_error_callback, 00);
1150  }
1151  return codec;
1152
1153 } // End: opj_codec_t* createOpjCodec()
void opj_warning_callback(const char *msg, void *)
Callback method for warnings.
void opj_info_callback(const char *msg, void *)
Callback method for info.
void opj_error_callback(const char *msg, void *)
Callback method for errors.
◆ createOpjCodingParameters()
opj_cparameters_t* ossimOpjCompressor::createOpjCodingParameters ( bool  jp2,
) const
private
◆ createOpjImage()
opj_image_t * ossimOpjCompressor::createOpjImage ( ossimScalarType  scalar,
ossim_uint32  bands,
) const
private
Definition at line 1187 of file ossimOpjCompressor.cpp.
References ossim::getActualBitsPerPixel(), ossim::getBitsPerPixel(), ossimIrect::height(), ossim::isSigned(), and ossimIrect::width().
1190 {
1191  opj_image_t* image = 0;
1192
1193  // image component definitions:
1194  opj_image_cmptparm_t* imageParams = new opj_image_cmptparm_t[bands];
1195  opj_image_cmptparm_t* imageParam = imageParams;
1196  for (ossim_uint32 i = 0; i < bands; ++i)
1197  {
1198  imageParam->dx = 1;
1199  imageParam->dy = 1;
1200  imageParam->h = imageRect.height();
1201  imageParam->w = imageRect.width();
1202  imageParam->sgnd = (OPJ_UINT32)ossim::isSigned(scalar);
1203  imageParam->prec = ossim::getActualBitsPerPixel(scalar);
1204  imageParam->bpp = ossim::getBitsPerPixel(scalar);
1205  imageParam->x0 = 0;
1206  imageParam->y0 = 0;
1207  ++imageParam;
1208  }
1209
1210  OPJ_COLOR_SPACE clrspc;
1211  if ( bands == 3 )
1212  {
1213  clrspc = OPJ_CLRSPC_SRGB;
1214  }
1215  else // if ( bands == 1 )
1216  {
1217  // Anything other than 3 band. Not sure if this is correct way yet?(drb)
1218  clrspc = OPJ_CLRSPC_GRAY;
1219  }
1220
1221  if ( clrspc != OPJ_CLRSPC_UNKNOWN )
1222  {
1223  image = opj_image_tile_create( bands, imageParams, clrspc );
1224  if ( image )
1225  {
1226  image->x0 = 0;
1227  image->y0 = 0;
1228  image->x1 = imageRect.width();
1229  image->y1 = imageRect.height();
1230  image->color_space = clrspc;
1231  }
1232  }
1233
1234  delete [] imageParams;
1235  imageParams = 0;
1236
1237  if ( traceDebug() )
1238  {
1240  << "ossimOpjCompressor::createOpjImage DEBUG:\n";
1241  if ( image )
1242  {
1244  }
1245  else
1246  {
1248  << "ossimOpjCompressor::createOpjImage DEBUG image not created!"
1249  << std::endl;
1250  }
1251  }
1252
1253  return image;
1254
1255 } // End: ossimOpjCompressor::createOpjImage( ... )
ossim_uint32 height() const
Definition: ossimIrect.h:487
OSSIM_DLL bool isSigned(ossimScalarType scalarType)
unsigned int ossim_uint32
ossim_uint32 width() const
Definition: ossimIrect.h:500
OSSIM_DLL ossim_uint32 getBitsPerPixel(ossimScalarType scalarType)
Get bits per pixel for a given scalar type.
◆ createOpjStream()
opj_stream_t * ossimOpjCompressor::createOpjStream ( std::ostream *  os) const
private
Definition at line 1155 of file ossimOpjCompressor.cpp.
1156 {
1157  opj_stream_t* stream = 0;
1158  if ( os )
1159  {
1160  // stream = opj_stream_create_default_file_stream("test.jp2", OPJ_FALSE);
1161
1162
1163  // OPJ stream:
1164  // stream = opj_stream_create(OPJ_J2K_STREAM_CHUNK_SIZE, OPJ_FALSE);
1165  // stream = opj_stream_create(512, OPJ_FALSE);
1166  // stream = opj_stream_create_default_file_stream("test.jp2", OPJ_FALSE); // false = output.
1167  stream = opj_stream_create(1048576, OPJ_FALSE);
1168  if ( stream )
1169  {
1170  // cout << "stream good..." << endl;
1171
1172  // Set OPJ user stream:
1173  opj_stream_set_user_data(stream, os, ossim_opj_free_user_ostream_data);
1174
1175  // Set callbacks:
1176  // opj_stream_set_read_function(m_stream, ossim_opj_stream_read);
1177  // opj_stream_set_read_function(stream, ossim_opj_imagedata_read);
1178  opj_stream_set_write_function(stream, ossim_opj_ostream_write);
1179  opj_stream_set_skip_function(stream, ossim_opj_ostream_skip);
1180  opj_stream_set_seek_function(stream, ossim_opj_ostream_seek);
1181  }
1182  }
1183  return stream;
1184
1185 } // End: ossimOpjCompressor::createOpjStream()
◆ finish()
void ossimOpjCompressor::finish ( )
Finish method.
Every call to "create" should be matched by a "finish". Note the destructor calls finish.
Definition at line 311 of file ossimOpjCompressor.cpp.
References m_codec, m_image, and m_stream.
Referenced by ~ossimOpjCompressor().
312 {
313  if ( m_stream )
314  {
315  // Every opj_start_compress must have an end.
316  opj_end_compress( m_codec, m_stream );
317
318  opj_stream_destroy( m_stream );
319  m_stream = 0;
320  }
321  if ( m_codec )
322  {
323  opj_destroy_codec( m_codec );
324  m_codec = 0;
325  }
326  if ( m_image )
327  {
328  opj_image_destroy( m_image );
329  m_image = 0;
330  }
331 }
◆ getAlphaChannelFlag()
bool ossimOpjCompressor::getAlphaChannelFlag ( ) const
Returns
true if the writer is configured to create an alpha channel.
Definition at line 374 of file ossimOpjCompressor.cpp.
References m_alpha.
375 {
376  return m_alpha;
377 }
bool m_alpha
◆ getLevels()
ossim_int32 ossimOpjCompressor::getLevels ( ) const
Returns
The number of levels.
Definition at line 387 of file ossimOpjCompressor.cpp.
References m_levels.
388 {
389  return m_levels;
390 }
◆ getNumberOfLayers()
int ossimOpjCompressor::getNumberOfLayers ( ) const
private
Definition at line 1019 of file ossimOpjCompressor.cpp.
References m_params.
1020 {
1021  return m_params->tcp_numlayers;
1022 }
◆ getOptions()
void ossimOpjCompressor::getOptions ( std::vector< ossimString > &  options) const
Parameters
optionsArray to initialize.
◆ getProperty()
ossimRefPtr< ossimProperty > ossimOpjCompressor::getProperty ( const ossimString name) const
Parameters
nameName of property to return.
Returns
A pointer to a property object which matches "name".
Definition at line 476 of file ossimOpjCompressor.cpp.
References ossimKeywordNames::COMPRESSION_QUALITY_KW, and getQualityTypeString().
478 {
480
482  {
483  // property value
485
486  if ( (value == COMPRESSION_QUALITY[ossimOpjCompressor::OPJ_USER_DEFINED] ) ||
487  (value == COMPRESSION_QUALITY[ossimOpjCompressor::OPJ_UNKNOWN])
488  )
489  {
490  value = COMPRESSION_QUALITY[ossimOpjCompressor::OPJ_NUMERICALLY_LOSSLESS];
491  }
492
493  // constraint list
494  vector<ossimString> constraintList;
495  constraintList.push_back(COMPRESSION_QUALITY[ossimOpjCompressor::
497  constraintList.push_back(COMPRESSION_QUALITY[ossimOpjCompressor::
499  constraintList.push_back(COMPRESSION_QUALITY[ossimOpjCompressor::
500  OPJ_LOSSY]);
501
502  p = new ossimStringProperty(name,
503  value,
504  false, // not editable
505  constraintList);
506  }
507  else if (name == LEVELS_KW)
508  {
510  }
511  else if (name == REVERSIBLE_KW)
512  {
513  p = new ossimBooleanProperty(name, m_reversible);
514  }
515  else if (name == ADD_ALPHA_CHANNEL_KW)
516  {
517  p = new ossimBooleanProperty(name, m_alpha);
518  }
519  else if (name == THREADS_KW)
520  {
522  }
523
524  return p;
525 }
Number of threads.
Numeric to string methods.
bool m_reversible
Lossless or lossy.
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
bool m_alpha
ossimString getQualityTypeString() const
static const char * COMPRESSION_QUALITY_KW
◆ getPropertyNames()
void ossimOpjCompressor::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
Parameters
propertyNamesarray to add this's property names to.
Definition at line 527 of file ossimOpjCompressor.cpp.
References ossimKeywordNames::COMPRESSION_QUALITY_KW.
529 {
530  propertyNames.push_back(ossimKeywordNames::COMPRESSION_QUALITY_KW);
531  propertyNames.push_back(LEVELS_KW);
532  propertyNames.push_back(REVERSIBLE_KW);
533  propertyNames.push_back(THREADS_KW);
534 }
◆ getQualityType()
ossimOpjCompressor::ossimOpjCompressionQuality ossimOpjCompressor::getQualityType ( ) const
Returns
The quality type setting.
Definition at line 353 of file ossimOpjCompressor.cpp.
References m_qualityType.
354 {
355  return m_qualityType;
356
357 }
◆ getQualityTypeString()
ossimString ossimOpjCompressor::getQualityTypeString ( ) const
private
Definition at line 1024 of file ossimOpjCompressor.cpp.
Referenced by getProperty(), and saveState().
1025 {
1026  return COMPRESSION_QUALITY[m_qualityType];
1027 }
◆ getReversibleFlag()
bool ossimOpjCompressor::getReversibleFlag ( ) const
Returns
The reversible flag.
Definition at line 364 of file ossimOpjCompressor.cpp.
References m_reversible.
365 {
366  return m_reversible;
367 }
bool m_reversible
Lossless or lossy.
◆ getThreads()
ossim_int32 ossimOpjCompressor::getThreads ( ) const
Returns
The number of threads.
Definition at line 400 of file ossimOpjCompressor.cpp.
References m_threads.
401 {
402  return m_threads;
403 }
Number of threads.
◆ initLevels()
void ossimOpjCompressor::initLevels ( const ossimIrect imageRect)
private
Number of wavelet decomposition levels, or stages. May not exceed 32. Opj Default is 6 (0 - 5)
Parameters
Definition at line 1066 of file ossimOpjCompressor.cpp.
References ossim::computeLevels(), m_levels, and m_params.
1067 {
1068  //---
1069  // Number of wavelet decomposition levels, or stages. May not exceed 32.
1070  // Default is 6 (r0 - r5)
1071  //---
1072  if ( m_levels == 0 )
1073  {
1075  if (m_levels == 0)
1076  {
1077  m_levels = 1; // Must have at least one.
1078  }
1079  }
1080  if ( (m_levels < 1) || (m_levels > 32) )
1081  {
1082  m_levels = 6;
1083  }
1084
1085  m_params->numresolution = m_levels;
1086 }
OSSIM_DLL ossim_uint32 computeLevels(const ossimIrect &rect)
Computes the number of decimation levels to get to the overview stop dimension.
int ossim_int32
◆ initOpjCodingParams()
void ossimOpjCompressor::initOpjCodingParams ( bool  jp2,
private
Definition at line 809 of file ossimOpjCompressor.cpp.
812 {
813  static const char MODULE[] = "ossimOpjCompressor::initOpjCodingParams";
814  if ( traceDebug() )
815  {
816  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
817  }
818
819  if ( m_params )
820  {
821  delete m_params;
822  }
823
824  m_params = new opj_cparameters_t();
825
826  // Set encoding parameters to default values.
827  opj_set_default_encoder_parameters( m_params );
828
829  // Output format: 0: J2K, 1: JP2, 2: JPT
830  m_params->cod_format = jp2 ? 1 : 0;
831
832  // std::string outfile = "test.jp2";
833  // strncpy(m_params->outfile, outfile.data(), outfile.size());
834
835  //---
836  // Shall we do an Multi-component Transformation(MCT) ?
837  // 0:no_mct;1:rgb->ycc;2:custom mct
838  //---
839
840  // Set the tiles size:
841  m_params->cp_tx0 = 0;
842  m_params->cp_ty0 = 0;
843  m_params->cp_tdx = tileSize.x;
844  m_params->cp_tdy = tileSize.y;
845  m_params->tile_size_on = OPJ_TRUE;
846
847  // No mct.
848  m_params->tcp_mct = 0;
849
850  //---
851  // Number of resolutions:
852  // This sets m_levels if not set and
853  // m_params->numresolution.
854  //---
855  initLevels( imageRect );
856
857  // Set the block size. Note 64x64 is the current kakadu default.
858  setCodeBlockSize( 64, 64 );
859
860  //---
861  // Set progression order to use. Note LRCP is the current opj default.
862  // L=layer; R=resolution C=component; P=position
863  //
864  // OPJ_LRCP, OPJ_RLCP, OPJ_RPCL, PCRL, CPRL */
865  //---
866  setProgressionOrder( OPJ_LRCP );
867
868  // total pixels
869  const ossim_float64 TP = imageRect.area();
870
871  if ( traceDebug() )
872  {
874  << "quality type: " << getQualityTypeString() << endl;
875  }
876
877  //---
878  // Rate is a ratio of desired bytes / total bytes. So if you
879  // want 4 bits per pixels it's total_pixels * 4 / 8 or
880  // total_pixels * 4 * 0.125.
881  //---
882
883  // Allocation by rate/distortion.
884  m_params->cp_disto_alloc = 1;
885
886  switch (m_qualityType)
887  {
889  {
890  // cout << "ossimOpjCompressor::OPJ_NUMERICALLY_LOSSLESS..." << endl;
891
892  // W5X3 Kernel
893  setReversibleFlag(true);
894
895  // Tmp drb...
896  m_params->tcp_numlayers = 1;
897  m_params->tcp_rates[0] = 1;
898
899 #if 0
900
901  m_params->tcp_numlayers = 20;
902
903  m_params->tcp_rates[0] = std::ceil( TP * 0.03125 * 0.125 );
904  m_params->tcp_rates[1] = std::ceil( TP * 0.0625 * 0.125 );
905  m_params->tcp_rates[2] = std::ceil( TP * 0.125 * 0.125 );
906  m_params->tcp_rates[3] = std::ceil( TP * 0.25 * 0.125 );
907  m_params->tcp_rates[4] = std::ceil( TP * 0.5 * 0.125 );
908  m_params->tcp_rates[5] = std::ceil( TP * 0.6 * 0.125 );
909  m_params->tcp_rates[6] = std::ceil( TP * 0.7 * 0.125 );
910  m_params->tcp_rates[7] = std::ceil( TP * 0.8 * 0.125 );
911  m_params->tcp_rates[8] = std::ceil( TP * 0.9 * 0.125 );
912  m_params->tcp_rates[9] = std::ceil( TP * 1.0 * 0.125 );
913  m_params->tcp_rates[10] = std::ceil( TP * 1.1 * 0.125 );
914  m_params->tcp_rates[11] = std::ceil( TP * 1.2 * 0.125 );
915  m_params->tcp_rates[12] = std::ceil( TP * 1.3 * 0.125 );
916  m_params->tcp_rates[13] = std::ceil( TP * 1.5 * 0.125 );
917  m_params->tcp_rates[14] = std::ceil( TP * 1.7 * 0.125 );
918  m_params->tcp_rates[15] = std::ceil( TP * 2.0 * 0.125 );
919  m_params->tcp_rates[16] = std::ceil( TP * 2.3 * 0.125 );
920  m_params->tcp_rates[17] = std::ceil( TP * 2.8 * 0.125 );
921  m_params->tcp_rates[18] = std::ceil( TP * 3.5 * 0.125 );
922
923  //---
924  // Indicate that the final quality layer should include all
925  // compressed bits.
926  //---
927  // m_params->tcp_rates[19] = OSSIM_DEFAULT_MAX_PIX_SINT32; // KDU_LONG_MAX;
928  m_params->tcp_rates[19] = std::ceil( TP * 4.0 * 0.125 );
929
930 #endif
931
932  break;
933  }
935  {
936  // W9X7 kernel:
937  setReversibleFlag(false);
938
939  m_params->tcp_numlayers = 19;
940
941  m_params->tcp_rates[0] = std::ceil( TP * 0.03125 * 0.125 );
942  m_params->tcp_rates[1] = std::ceil( TP * 0.0625 * 0.125 );
943  m_params->tcp_rates[2] = std::ceil( TP * 0.125 * 0.125 );
944  m_params->tcp_rates[3] = std::ceil( TP * 0.25 * 0.125 );
945  m_params->tcp_rates[4] = std::ceil( TP * 0.5 * 0.125 );
946  m_params->tcp_rates[5] = std::ceil( TP * 0.6 * 0.125 );
947  m_params->tcp_rates[6] = std::ceil( TP * 0.7 * 0.125 );
948  m_params->tcp_rates[7] = std::ceil( TP * 0.8 * 0.125 );
949  m_params->tcp_rates[8] = std::ceil( TP * 0.9 * 0.125 );
950  m_params->tcp_rates[9] = std::ceil( TP * 1.0 * 0.125 );
951  m_params->tcp_rates[10] = std::ceil( TP * 1.1 * 0.125 );
952  m_params->tcp_rates[11] = std::ceil( TP * 1.2 * 0.125 );
953  m_params->tcp_rates[12] = std::ceil( TP * 1.3 * 0.125 );
954  m_params->tcp_rates[13] = std::ceil( TP * 1.5 * 0.125 );
955  m_params->tcp_rates[14] = std::ceil( TP * 1.7 * 0.125 );
956  m_params->tcp_rates[15] = std::ceil( TP * 2.0 * 0.125 );
957  m_params->tcp_rates[16] = std::ceil( TP * 2.3 * 0.125 );
958  m_params->tcp_rates[17] = std::ceil( TP * 2.8 * 0.125 );
959  m_params->tcp_rates[18] = std::ceil( TP * 3.5 * 0.125 );
960  break;
961  }
963  {
964  // W9X7 kernel:
965  setReversibleFlag(false);
966
967  m_params->tcp_numlayers = 10;
968
969  m_params->tcp_rates[0] = std::ceil( TP * 0.03125 * 0.125 );
970  m_params->tcp_rates[1] = std::ceil( TP * 0.0625 * 0.125 );
971  m_params->tcp_rates[2] = std::ceil( TP * 0.125 * 0.125 );
972  m_params->tcp_rates[3] = std::ceil( TP * 0.25 * 0.125 );
973  m_params->tcp_rates[4] = std::ceil( TP * 0.5 * 0.125 );
974  m_params->tcp_rates[5] = std::ceil( TP * 0.6 * 0.125 );
975  m_params->tcp_rates[6] = std::ceil( TP * 0.7 * 0.125 );
976  m_params->tcp_rates[7] = std::ceil( TP * 0.8 * 0.125 );
977  m_params->tcp_rates[8] = std::ceil( TP * 0.9 * 0.125 );
978  m_params->tcp_rates[9] = std::ceil( TP * 1.0 * 0.125 );
979  break;
980  }
981
982  default:
983  {
984  m_params->tcp_numlayers = 1;
985  m_params->tcp_rates[0] = 1.0;
986
987  if (traceDebug())
988  {
990  << "unspecified quality type\n";
991  }
992  }
993
994  } // matches: switch (m_qualityType)
995
996
997
998  //---
999  // Set reversible flag, note, this controls the kernel.
1000  // W5X3(default) if reversible = true, W9X7 if reversible is false.
1001  //---
1002  m_params->irreversible = !m_reversible;
1003
1004  if ( traceDebug() )
1005  {
1007  << "m_reversible: " << m_reversible
1008  << "\nm_levels: " << m_levels << "\n";
1009
1011  }
1012
1013  if ( traceDebug() )
1014  {
1015  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
1016  }
1017 }
void setProgressionOrder(OPJ_PROG_ORDER progressionOrder)
bool m_reversible
Lossless or lossy.
double ossim_float64
void initLevels(const ossimIrect &imageRect)
void setReversibleFlag(bool reversible)
ossim_int32 y
Definition: ossimIpt.h:142
ossim_uint32 area() const
Definition: ossimIrect.h:396
ossim_int32 x
Definition: ossimIpt.h:141
void setCodeBlockSize(ossim_int32 xSize, ossim_int32 ySize)
◆ loadState()
bool ossimOpjCompressor::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
Definition at line 579 of file ossimOpjCompressor.cpp.
References ossimKeywordNames::COMPRESSION_QUALITY_KW, ossimKeywordlist::find(), and setQualityTypeString().
581 {
582  const char* value = 0;
583
584  value = kwl.find(prefix, ossimKeywordNames::COMPRESSION_QUALITY_KW);
585  if(value)
586  {
588  }
589
590  value = kwl.find(prefix, LEVELS_KW);
591  if(value)
592  {
593  m_levels = ossimString(value).toInt32();
594  }
595
596  value = kwl.find(prefix, REVERSIBLE_KW);
597  if(value)
598  {
599  setReversibleFlag(ossimString(value).toBool());
600  }
601
602  value = kwl.find(prefix, ADD_ALPHA_CHANNEL_KW);
603  if(value)
604  {
605  m_alpha = ossimString(value).toBool();
606  }
607
608  value = kwl.find(prefix, THREADS_KW);
609  if(value)
610  {
611  m_threads = ossimString(value).toInt32();
612  }
613
614  ossimString searchKey;
615  if (prefix)
616  {
617  searchKey = prefix;
618  }
619  searchKey += "option";
620  ossim_uint32 nOptions = kwl.numberOf(searchKey);
621  for (ossim_uint32 i = 0; i < nOptions; ++i)
622  {
623  ossimString key = searchKey;
624  key += ossimString::toString(i);
625
626  const char* lookup = kwl.find(key.c_str());
627  if (lookup)
628  {
629  m_options.push_back(ossimString(lookup));
630  }
631  }
632
633  return true;
634 }
ossim_uint32 numberOf(const char *str) const
Number of threads.
ossim_int32 toInt32() const
bool toBool() const
String to numeric methods.
void setQualityTypeString(const ossimString &s)
bool m_alpha
const char * c_str() const
Definition: ossimString.h:396
◆ openJp2Codestream()
void ossimOpjCompressor::openJp2Codestream ( )
Note: Only valid if create method was called with jp2 = true.
Definition at line 260 of file ossimOpjCompressor.cpp.
261 {
262  //---
263  // Start compression...
264  // Matching "opj_end_compress" is in ossimOpjCompressor::finish().
265  //---
266  if ( !opj_start_compress(m_codec, m_image, m_stream) )
267  {
268  std::string errMsg = "ossimOpjCompressor::openJp2Codestream ERROR: opj_start_compress failed!";
269  throw ossimException(errMsg);
270  }
271 }
◆ saveState()
bool ossimOpjCompressor::saveState ( ossimKeywordlist kwl,
) const
Definition at line 536 of file ossimOpjCompressor.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::COMPRESSION_QUALITY_KW, and getQualityTypeString().
538 {
539  kwl.add( prefix,
541  getQualityTypeString().c_str(),
542  true );
543
544  kwl.add( prefix,
545  LEVELS_KW,
547  true );
548
549  kwl.add( prefix,
550  REVERSIBLE_KW,
552  true );
553
554  kwl.add( prefix,
555  ADD_ALPHA_CHANNEL_KW,
557  true );
558
559  kwl.add( prefix,
560  THREADS_KW,
562  true );
563
564  std::vector<ossimString>::size_type size = m_options.size();
565  for (ossim_uint32 i = 0; i < size; ++i)
566  {
567  ossimString key = "option";
568  key += ossimString::toString(i);
569
570  kwl.add( prefix,
571  key.c_str(),
572  m_options[i].c_str(),
573  true );
574  }
575
576  return true;
577 }
Number of threads.
bool m_reversible
Lossless or lossy.
yy_size_t size
bool m_alpha
◆ setAlphaChannelFlag()
void ossimOpjCompressor::setAlphaChannelFlag ( bool  flag)
Parameters
flagtrue to create an alpha channel.
Definition at line 369 of file ossimOpjCompressor.cpp.
References m_alpha.
370 {
371  m_alpha = flag;
372 }
bool m_alpha
◆ setCodeBlockSize()
void ossimOpjCompressor::setCodeBlockSize ( ossim_int32  xSize,
ossim_int32  ySize
private
Nominal code-block dimensions (must be powers of 2 no less than 4 and no greater than 1024). Opj Default block dimensions are {64,64}
Parameters
xSize
ySize
Definition at line 1088 of file ossimOpjCompressor.cpp.
1090 {
1091  if ( m_params )
1092  {
1093  //---
1094  // Nominal code-block dimensions (must be powers of 2 no less than 4 and
1095  // no greater than 1024).
1096  // Default block dimensions are {64,64}
1097  //---
1098  m_params->cblockw_init = xSize;
1099  m_params->cblockh_init = ySize;
1100  }
1101 }
◆ setLevels()
void ossimOpjCompressor::setLevels ( ossim_int32  levels)
This must be positive and at least 1. Default = 6 ( r0 - r5 )
Parameters
levelsLevels to set.
Definition at line 379 of file ossimOpjCompressor.cpp.
380 {
381  if (levels)
382  {
383  m_levels = levels;
384  }
385 }
◆ setOptions()
void ossimOpjCompressor::setOptions ( const std::vector< ossimString > &  options)
These get passed to the generic kdu_params::parse_string method. Note this adds options to the list. Does not zero out existing options.
Parameters
optionsArray of options to add.
Definition at line 405 of file ossimOpjCompressor.cpp.
References m_options.
406 {
407  std::vector<ossimString>::const_iterator i = options.begin();
408  while ( i != options.end() )
409  {
410  m_options.push_back( (*i) );
411  ++i;
412  }
413 }
◆ setProgressionOrder()
void ossimOpjCompressor::setProgressionOrder ( OPJ_PROG_ORDER  progressionOrder)
private
Default progression order (may be overridden by Porder). The four character identifiers have the following interpretation: L=layer; R=resolution; C=component; P=position. The first character in the identifier refers to the index which progresses most slowly, while the last refers to the index which progresses most quickly. [Default is LRCP] Enumerations: (LRCP=0,RLCP=1,RPCL=2,PCRL=3,CPRL=4)
Parameters
corderThe progression order which should be one of the above enumerations.
Definition at line 1103 of file ossimOpjCompressor.cpp.
1104 {
1105  if ( m_params )
1106  {
1107  //---
1108  // Default progression order (may be overridden by Porder).
1109  // The four character identifiers have the following interpretation:
1110  // L=layer; R=resolution; C=component; P=position.
1111  // The first character in the identifier refers to the index which
1112  // progresses most slowly, while the last refers to the index which
1113  // progresses most quickly. [Default is LRCP]
1114  // Enumerations: (LRCP=0,RLCP=1,RPCL=2,PCRL=3,CPRL=4)
1115  //---
1116  m_params->prog_order = progressionOrder;
1117  }
1118 }
◆ setProperty()
bool ossimOpjCompressor::setProperty ( ossimRefPtr< ossimProperty property)
Parameters
propertyObject containing property to set.
Returns
true if property was consumed, false if not.
Definition at line 415 of file ossimOpjCompressor.cpp.
References ossimRefPtr< T >::valid().
416 {
417  bool consumed = false;
418
419  if ( property.valid() )
420  {
421  ossimString key = property->getName();
422
423  if ( traceDebug() )
424  {
426  << "ossimOpjCompressor::setProperty DEBUG:"
427  << "\nkey: " << key
428  << " values: " << property->valueToString() << std::endl;
429  }
430
432  {
433  setQualityTypeString(property->valueToString());
434  consumed = true;
435  }
436  else if ( (key == LEVELS_KW) || (key == "Clevels") )
437  {
438  m_levels = property->valueToString().toInt32();
439  consumed = true;
440  }
441  else if( (key == REVERSIBLE_KW) || (key == "Creversible") )
442  {
443  setReversibleFlag(property->valueToString().toBool());
444  consumed = true;
445  }
446  else if (key == ADD_ALPHA_CHANNEL_KW)
447  {
448  m_alpha = property->valueToString().toBool();
449  consumed = true;
450  }
451  else if ( key == THREADS_KW)
452  {
453  m_threads = property->valueToString().toInt32();
454  consumed = true;
455  }
456  else if ( (key == "Clayers") ||
457  (key == "Cprecincts") )
458  {
459  // Generic options passed through kdu_params::parse_string.
460
461  // Make in the form of "key=value" for kdu_params::parse_string.
462  ossimString option = key;
463  option += "=";
464  option += property->valueToString();
465
466  // Add to list.
467  m_options.push_back(option);
468
469  consumed = true;
470  }
471  }
472
473  return consumed;
474 }
virtual void valueToString(ossimString &valueResult) const =0
bool valid() const
Definition: ossimRefPtr.h:75
Number of threads.
bool m_alpha
◆ setQualityType()
void ossimOpjCompressor::setQualityType ( ossimOpjCompressionQuality  type)
Parameters
typeSee enumeration for types.
Definition at line 333 of file ossimOpjCompressor.cpp.
References m_qualityType, OPJ_LOSSY, OPJ_VISUALLY_LOSSLESS, and setReversibleFlag().
334 {
335  m_qualityType = type;
336
337  //---
338  // Set the reversible flag for appropriate type.
339  // Not sure what to set for unknown and user defined but visually lossless
340  // and lossy need to set the reversible flag to false.
341  //---
344  {
345  setReversibleFlag(false);
346  }
347  else
348  {
349  setReversibleFlag(true);
350  }
351 }
◆ setQualityTypeString()
void ossimOpjCompressor::setQualityTypeString ( const ossimString s)
private
Definition at line 1029 of file ossimOpjCompressor.cpp.
References ossimString::downcase().
Referenced by loadState().
1030 {
1031  ossimString type = s;
1032  type.downcase();
1033
1034  if ( type == COMPRESSION_QUALITY[ossimOpjCompressor::OPJ_UNKNOWN] )
1035  {
1037  }
1038  else if ( type == COMPRESSION_QUALITY[ossimOpjCompressor::OPJ_USER_DEFINED] )
1039  {
1041  }
1042  else if ( type == COMPRESSION_QUALITY[ossimOpjCompressor::OPJ_NUMERICALLY_LOSSLESS] )
1043  {
1045  }
1046  else if ( type == COMPRESSION_QUALITY[ossimOpjCompressor::OPJ_VISUALLY_LOSSLESS] )
1047  {
1049  }
1050  else if (type == "lossy")
1051  {
1053  }
1054  else
1055  {
1056  if ( traceDebug() )
1057  {
1059  << "ossimOpjCompressor::setQualityTypeString DEBUG"
1060  << "\nUnhandled quality type: " << type
1061  << std::endl;
1062  }
1063  }
1064 }
void setQualityType(ossimOpjCompressionQuality type)
◆ setReversibleFlag()
void ossimOpjCompressor::setReversibleFlag ( bool  reversible)
If set to true the compression will be lossless; if not, lossy. Default is lossless.
Parameters
reversibleFlag to set.
Definition at line 359 of file ossimOpjCompressor.cpp.
Referenced by setQualityType().
360 {
361  m_reversible = reversible;
362 }
bool m_reversible
Lossless or lossy.
◆ setThreads()
void ossimOpjCompressor::setThreads ( ossim_int32  threads)
This must be positive and at least 1. Default = 1 thread.
Parameters
threadsThe number of threads.
Definition at line 392 of file ossimOpjCompressor.cpp.
393 {
394  if (threads)
395  {
396  m_threads = threads;
397  }
398 }
Number of threads.
◆ setTlmTileCount()
void ossimOpjCompressor::setTlmTileCount ( ossim_uint32  tilesToWrite)
private
Definition at line 1120 of file ossimOpjCompressor.cpp.
1121 {
1122  //---
1123  // Identifies the maximum number of tile-parts which will be written to the
1124  // code-stream for each tile.
1125  //
1126  // See Opj kdu_params.h "Macro = `ORGgen_tlm'" for more.
1127  //---
1128  // ossimString s = "ORGgen_tlm=1";
1129  // m_codestream.access_siz()->parse_string( s.c_str() );
1130 }
◆ writeGeotiffBox()
bool ossimOpjCompressor::writeGeotiffBox ( std::ostream *  stream,
const ossimImageGeometry geom,
const ossimIrect rect,
const ossimFilename tmpFile,
Parameters
streamThe stream to write to.
geomOutput image geometry.
rectOutput rectangle (view rect).
tmpFileTemp file written out.
pixelTypeOSSIM_PIXEL_IS_POINT(0) or OSSIM_PIXEL_IS_AREA(1)
Definition at line 636 of file ossimOpjCompressor.cpp.
References ossim::byteOrder(), ossimRefPtr< T >::get(), ossimImageGeometry::getProjection(), OSSIM_LITTLE_ENDIAN, ossimEndian::swap(), ossimRefPtr< T >::valid(), and ossimGeoTiff::writeJp2GeotiffBox().
641 {
642  // cout << "ossimOpjCompressor::writeGeotiffBox entered..." << endl;
643
644
645  bool result = false;
646
647  if ( stream && geom )
648  {
651  if ( proj.valid() )
652  {
653  //---
654  // Make a temp file. No means currently write a tiff straight to
655  // memory.
656  //---
657
658  // Buffer to hold the tiff box.
659  std::vector<ossim_uint8> buf;
660
661  // Write to buffer.
663  rect,
664  proj.get(),
665  buf,
666  pixelType) )
667  {
668  //---
669  // JP2 box type uuid in ascii expressed as an int.
670  // "u(75), u(75), i(69), d(64)"
671  //---
672  const ossim_uint8 UUID[4] =
673  {
674  0x75, 0x75, 0x69, 0x64
675  };
676
677  ossim_uint32 lbox = buf.size() + 8;
678
679  // cout << "gbox tellp: " << stream->tellp() << endl;
680  // cout << "lbox: " << lbox << endl;
681
683  {
684  ossimEndian endian;
685  endian.swap( lbox );
686  }
687
688  stream->write( (char*)&lbox, 4 ); // LBox
689
690  stream->write((const char*)UUID, 4); // TBox
691
692  // DBox: geotiff
693  stream->write((const char*)&buf.front(), (std::streamsize)buf.size());
694
695  result = true;
696
697  // cout << "wrote box!!!" << endl;
698  }
699  }
700  }
701
702  return result;
703
704 } // End: ossimOpjCompressor::writeGeotiffBox
bool valid() const
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
static bool writeJp2GeotiffBox(const ossimFilename &tmpFile, const ossimIrect &rect, const ossimProjection *proj, std::vector< ossim_uint8 > &buf, ossimPixelType pixelType)
Writes a geotiff box to a buffer.
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
unsigned char ossim_uint8
◆ writeGmlBox()
bool ossimOpjCompressor::writeGmlBox ( std::ostream *  stream,
Parameters
Definition at line 706 of file ossimOpjCompressor.cpp.
References ossim::byteOrder(), ossimGmlSupportData::initialize(), OSSIM_LITTLE_ENDIAN, ossimEndian::swap(), and ossimGmlSupportData::write().
709 {
710  // cout << "ossimOpjCompressor::writeGmlBox entered..." << endl;
711
712  bool result = false;
713
714  if ( stream && geom )
715  {
717
718  if ( gml->initialize( geom, rect ) )
719  {
720  const ossim_uint8 ASOC_BOX_ID[4] =
721  {
722  0x61, 0x73, 0x6F, 0x63
723  };
724
725  const ossim_uint8 LBL_BOX_ID[4] =
726  {
727  0x6C, 0x62, 0x6C, 0x20
728  };
729
730  const ossim_uint8 XML_BOX_ID[4] =
731  {
732  0x78, 0x6D, 0x6C, 0x20
733  };
734
735  // Write the xml to a stream.
736  ostringstream xmlStr;
737  if ( gml->write( xmlStr ) )
738  {
739  ossim_uint32 xmlDataSize = xmlStr.str().size();
740
741  // Set the 1st asoc box size and type
742  ossim_uint32 boxSize = xmlDataSize + 17 + 8 + 8 + 8 + 8 + 8 + 8;
744  {
745  ossimEndian endian;
746  endian.swap( boxSize );
747  }
748  stream->write((char*)&boxSize, 4); // 1st asoc size
749  stream->write((const char*)ASOC_BOX_ID, 4); // 1st asoc type
750
751  // Set the 1st lbl box size, type, and data
752  boxSize = 8 + 8;
754  {
755  ossimEndian endian;
756  endian.swap( boxSize );
757  }
758  stream->write((char*)&boxSize, 4); // 1st lbl size
759  stream->write((const char*)LBL_BOX_ID, 4); // 1st lbl type
760  stream->write("gml.data", 8); // 1st lbl data
761
762  // Set the 2nd asoc box size and type
763  boxSize = xmlDataSize + 17 + 8 + 8 + 8;
765  {
766  ossimEndian endian;
767  endian.swap( boxSize );
768  }
769  stream->write((char*)&boxSize, 4); // 2nd asoc size
770  stream->write((const char*)ASOC_BOX_ID, 4); // 2nd asoc type
771
772  // Set the 2nd lbl box size, type, and data
773  boxSize = 17 + 8;
775  {
776  ossimEndian endian;
777  endian.swap( boxSize );
778  }
779  stream->write((char*)&boxSize, 4); // 2nd lbl size
780  stream->write((const char*)LBL_BOX_ID, 4); // 2nd lbl type
781  stream->write("gml.root-instance", 17); // 2nd lbl data
782
783  // Set the xml box size, type, and data
784  boxSize = xmlDataSize + 8;
786  {
787  ossimEndian endian;
788  endian.swap( boxSize );
789  }
790  stream->write((char*)&boxSize, 4); // xml size
791  stream->write((const char*)XML_BOX_ID, 4); // xml type
792  stream->write(xmlStr.str().data(), xmlDataSize); // xml data
793
794  result = true;
795
796  //cout << "wrote gml box!!!" << endl;
797  }
798  }
799
800  // cleanup:
801  delete gml;
802  gml = 0;
803  }
804
805  return result;
806
807 } // End: ossimOpjCompressor::writeGmlBox
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
bool write(std::ostream &os)
Write xml doc to stream.
GML support data class.
bool initialize(const ossimImageGeometry *geom, const ossimIrect &rect)
Initializes gml block from geometry file.
◆ writeTile()
bool ossimOpjCompressor::writeTile ( ossimImageData srcTile,
Write tile method.
Writes tiles stream provided to create method. Note that tiles should be fed to compressor in left to right, top to bottom order.
Parameters
srcTileThe source tile to write.
tileIndexIndex starting at 0. Currently must be sequential.
Returns
Definition at line 273 of file ossimOpjCompressor.cpp.
References ossimDataObject::getDataObjectStatus(), ossimImageData::getDataSizeInBytes(), ossimImageData::getImageRectangle(), ossimImageData::getUcharBuf(), m_codec, m_stream, OSSIM_NULL, ossimNotify(), and ossimNotifyLevel_WARN.
275 {
276  bool result = false;
277
278  if ( srcTile )
279  {
280  if (srcTile->getDataObjectStatus() != OSSIM_NULL)
281  {
282  ossimIrect tileRect = srcTile->getImageRectangle();
283
284  // Write the tile out:
285  if ( opj_write_tile( m_codec,
286  tileIndex,
287  srcTile->getUcharBuf(),
288  srcTile->getDataSizeInBytes(),
289  m_stream ) )
290  {
291  result = true;
292  }
293  else
294  {
296  << "ossimOpjCompressor::writeTile ERROR on tile index: "
297  << tileIndex << std::endl;
298  }
299  }
300  else
301  {
303  << "ossimOpjCompressor::writeTile ERROR null tile passed in!" << endl;
304  }
305  }
306
307  return result;
308
309 } // End: ossimOpjCompressor::writeTile
virtual const ossim_uint8 * getUcharBuf() const
virtual ossimIrect getImageRectangle() const
virtual ossim_uint32 getDataSizeInBytes() const
Member Data Documentation
◆ m_alpha
bool ossimOpjCompressor::m_alpha
private
Definition at line 311 of file ossimOpjCompressor.h.
Referenced by getAlphaChannelFlag(), and setAlphaChannelFlag().
◆ m_codec
opj_codec_t* ossimOpjCompressor::m_codec
private
Definition at line 294 of file ossimOpjCompressor.h.
Referenced by finish(), openJp2Codestream(), and writeTile().
◆ m_image
opj_image_t* ossimOpjCompressor::m_image
private
Definition at line 297 of file ossimOpjCompressor.h.
Referenced by finish(), and openJp2Codestream().
◆ m_imageRect
ossimIrect ossimOpjCompressor::m_imageRect
private
Image rectangle.
Used for clip in writeTile.
Definition at line 305 of file ossimOpjCompressor.h.
◆ m_levels
ossim_int32 ossimOpjCompressor::m_levels
private
Definition at line 314 of file ossimOpjCompressor.h.
Referenced by getLevels(), initLevels(), and setLevels().
◆ m_options
std::vector<ossimString> ossimOpjCompressor::m_options
private
Definition at line 320 of file ossimOpjCompressor.h.
Referenced by setOptions().
◆ m_params
opj_cparameters_t* ossimOpjCompressor::m_params
private
◆ m_qualityType
ossimOpjCompressionQuality ossimOpjCompressor::m_qualityType
private
Definition at line 322 of file ossimOpjCompressor.h.
Referenced by getQualityType(), and setQualityType().
◆ m_reversible
bool ossimOpjCompressor::m_reversible
private
Lossless or lossy.
Definition at line 308 of file ossimOpjCompressor.h.
Referenced by getReversibleFlag(), and setReversibleFlag().
◆ m_stream
opj_stream_t* ossimOpjCompressor::m_stream
private
Definition at line 295 of file ossimOpjCompressor.h.
◆ m_threads
ossim_int32 ossimOpjCompressor::m_threads
private
Number of threads.
Definition at line 317 of file ossimOpjCompressor.h.
Referenced by getThreads(), and setThreads().
