ossimPixelFlipper.h
Go to the documentation of this file.
1 //*******************************************************************
2 // Copyright (C) 2002 ImageLinks Inc.
3 //
4 // License: MIT
5 //
6 // See LICENSE.txt file in the top level directory for more details.
7 //
8 // Author: David Burken
9 //
10 // Description:
11 //
12 // Class to scan pixels and flip target dn pixel value to new dn pixel value.
13 // This was written to fix partial null pixels.
14 //
15 //*************************************************************************
16 // $Id: ossimPixelFlipper.h 19728 2011-06-06 21:31:17Z dburken $
17 #ifndef ossimPixelFlipper_HEADER
18 #define ossimPixelFlipper_HEADER
19
22 #include <mutex>
23
38 {
39 public:
40  static const char PF_TARGET_VALUE_KW[];
41  static const char PF_TARGET_RANGE_KW[];
42  static const char PF_REPLACEMENT_VALUE_KW[];
43  static const char PF_REPLACEMENT_MODE_KW[];
44  static const char PF_CLAMP_VALUE_KW[];
45  static const char PF_CLAMP_VALUE_LO_KW[];
46  static const char PF_CLAMP_VALUE_HI_KW[];
47  static const char PF_CLIP_MODE_KW[];
48
82  {
83  REPLACE_BAND_IF_TARGET = 0,
84  REPLACE_BAND_IF_PARTIAL_TARGET = 1,
85  REPLACE_ALL_BANDS_IF_PARTIAL_TARGET = 2,
86  REPLACE_ONLY_FULL_TARGETS = 3,
87  REPLACE_ALL_BANDS_IF_ANY_TARGET = 4,
88  };
89
95  {
96  DISABLED = 0,
97  CLAMPING_LO = 1,
98  CLAMPING_HI = 2,
99  CLAMPING_LO_AND_HI = 3,
100  };
101
102  enum ClipMode
103  {
104  NONE = 0,
105  BOUNDING_RECT = 1,
106  VALID_VERTICES = 2
107  };
108
110  ossimPixelFlipper(ossimObject* owner=NULL);
111
112
114  virtual ossimString getShortName()const;
115
117  virtual void initialize();
118
132  virtual ossimRefPtr<ossimImageData> getTile(const ossimIrect& tile_rect,
133  ossim_uint32 resLevel=0);
134
135  virtual bool saveState(ossimKeywordlist& kwl,
136  const char* prefix=0)const;
137
142  virtual bool loadState(const ossimKeywordlist& kwl,
143  const char* prefix=0);
144
145  virtual ossimScalarType getOutputScalarType() const;
146  virtual ossim_float64 getMaxPixelValue (ossim_uint32 band = 0 ) const;
147  virtual ossim_float64 getMinPixelValue (ossim_uint32 band = 0 ) const;
148
149  virtual std::ostream& print(std::ostream& out) const;
150
155  void setTargetValue(ossim_float64 target_value);
156
163  void setTargetRange(ossim_float64 target_min, ossim_float64 target_max);
164
169  void setReplacementValue(ossim_float64 replacement_value);
170
179  void setClampValue(ossim_float64 clamp_value, bool is_high_clamp_value=true);
180  void setClampValues(ossim_float64 clamp_value_lo, ossim_float64 clamp_value_hi);
181
183  void setReplacementMode(ossimPixelFlipper::ReplacementMode mode);
184
188  bool setReplacementMode(const ossimString& modeString);
189
194  void setClipMode(const ossimString& modeString);
195  void setClipMode(ClipMode mode);
196
197  //ossim_float64 getTargetValue() const;
198  ossim_float64 getReplacementValue() const;
199  //ossim_float64 getClampValue() const;
200  ossimPixelFlipper::ReplacementMode getReplacementMode() const;
201  ossimString getReplacementModeString() const;
202  ossimString getClipModeString() const;
203  ClipMode getClipMode() const;
204
205  virtual ossimRefPtr<ossimProperty> getProperty(const ossimString& name)const;
206  virtual void setProperty(ossimRefPtr<ossimProperty> property);
207  virtual void getPropertyNames(std::vector<ossimString>& propertyNames)const;
208
209
210 protected:
212  virtual ~ossimPixelFlipper();
214  template <class T>
215  void flipPixels(T dummy, ossimImageData *inpuTile, ossim_uint32 resLevel);
216
217  template <class T>
218  void clipTile(T dummy,
219  ossimImageData *inpuTile,
220  ossim_uint32 resLevel);
221
226  bool inRange(ossim_float64 value) const;
227
228  void allocateClipTileBuffer(ossimRefPtr<ossimImageData> inputImage);
229
234
239
245
262
264  mutable std::recursive_mutex theMutex;
265
266  mutable std::vector<ossimPolygon> theValidVertices;
267  mutable std::vector<ossimIrect> theBoundingRects;
268
270
271  TYPE_DATA
272 };
273
274
275 #endif
ossim_float64 theReplacementValue
When target values are defined, this is the value the pixel will assume if the pixel falls within the...
ReplacementMode
Target Replacement Mode:
ClipMode theClipMode
Border Clip mode.
ReplacementMode theReplacementMode
See documentation for ReplacementMode enum above.
For lock and unlock.
ossim_float64 theTargetValueLo
The value range to replace.
virtual ossimString getShortName() const
Definition: ossimObject.cpp:48
ClampingMode
When either a lo and/or hi clamp value is set, the clamping mode will be enabled accordingly and over...
double ossim_float64
ossim_float64 theTargetValueHi
#define TYPE_DATA
Definition: ossimRtti.h:339
unsigned int ossim_uint32
ClampingMode theClampingMode
ossim_float64 theClampValueHi
ossimScalarType
Class to scan pixels and flip target dn value to a replacement dn value.
#define OSSIM_DLL
ossim_float64 theClampValueLo
The range of desired pixel values.
ossimRefPtr< ossimImageData > theClipTileBuffer
std::vector< ossimIrect > theBoundingRects
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
std::vector< ossimPolygon > theValidVertices
