ossimImageSourceFilter Class Reference
#include <ossimImageSourceFilter.h>
Inheritance diagram for ossimImageSourceFilter:
ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced ossim3x3ConvolutionFilter ossimAnnotationSource ossimAOD ossimAtCorrRemapper ossimBandAverageFilter ossimBandClipFilter ossimBandLutFilter ossimBandSelector ossimBrightnessContrastSource ossimBrightnessMatch ossimCacheTileSource ossimCastTileSourceFilter ossimConvolutionFilter1D ossimConvolutionSource ossimDespeckleFilter ossimDilationFilter ossimEdgeFilter ossimElevRemapper ossimErosionFilter ossimFftFilter ossimGammaRemapper ossimGridRemapSource ossimHistogramMatchFilter ossimHistoMatchRemapper ossimHsiRemapper ossimHsiToRgbSource ossimHsvToRgbSource ossimImageGaussianFilter ossimImageRenderer ossimImageSharpenFilter ossimImageSourceHistogramFilter ossimImageToPlaneNormalFilter ossimIndexToRgbLutFilter ossimIntensityAdjustmentFilter ossimJpegYCbCrToRgbSource ossimKMeansFilter ossimLinearStretchRemapper ossimMeanMedianFilter ossimNBandToIndexFilter ossimNullPixelFlip ossimPixelFlipper ossimPointCloudUtilityFilter ossimPolyCutter ossimRectangleCutFilter ossimRgbToGreyFilter ossimRgbToHsiSource ossimRgbToHsvSource ossimRgbToIndexFilter ossimRgbToJpegYCbCrSource ossimRLevelFilter ossimScalarRemapper ossimScaleFilter ossimShiftFilter ossimSICDToDetectedImage ossimSlopeFilter ossimSubImageTileSource ossimTableRemapper ossimTiledImagePatch ossimTrimFilter ossimValueAssignImageSourceFilter ossimVectorRenderer ossimWatermarkFilter
Public Member Functions
virtual void initialize ()
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual ~ossimReferenced ()
Protected Attributes
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
Detailed Description
Definition at line 20 of file ossimImageSourceFilter.h.
◆ ossimImageSourceFilter() [1/3]
ossimImageSourceFilter::ossimImageSourceFilter ( ossimObject owner = NULL)
Definition at line 24 of file ossimImageSourceFilter.cpp.
25  : ossimImageSource(owner,
26  1, // number of inputs
27  0, // number of outputs
28  true, // input's fixed
29  false), // outputs ar not fixed
30  theInputConnection(NULL)
31 {
33 }
virtual bool addListener(ossimListener *listener)
ossimImageSource(ossimObject *owner=0)
◆ ossimImageSourceFilter() [2/3]
ossimImageSourceFilter::ossimImageSourceFilter ( ossimImageSource inputSource)
Definition at line 35 of file ossimImageSourceFilter.cpp.
References ossimListenerManager::addListener(), and ossimConnectableObject::connectMyInputTo().
36  : ossimImageSource(NULL,
37  1,
38  0,
39  true,
40  false),
41  theInputConnection(inputSource)
42 {
43  if(inputSource)
44  {
45  connectMyInputTo(0, inputSource);
46  }
48 }
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
◆ ossimImageSourceFilter() [3/3]
ossimImageSourceFilter::ossimImageSourceFilter ( ossimObject owner,
Definition at line 50 of file ossimImageSourceFilter.cpp.
References ossimListenerManager::addListener(), ossimConnectableObject::connectMyOutputTo(), and ossimConnectableObject::theInputObjectList.
52  : ossimImageSource(owner,
53  1,
54  0,
55  true,
56  false),
57  theInputConnection(inputSource)
58 {
59  if(inputSource)
60  {
61  theInputObjectList[0] = inputSource;
62  inputSource->connectMyOutputTo(this, false);
63  }
65 }
virtual ossim_int32 connectMyOutputTo(ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true)
Will try to connect this objects output to the passed in object.
ConnectableObjectList theInputObjectList
Holds a list of input objects.
◆ ~ossimImageSourceFilter()
ossimImageSourceFilter::~ossimImageSourceFilter ( )
protectedvirtual
Member Function Documentation
◆ canConnectMyInputTo()
bool ossimImageSourceFilter::canConnectMyInputTo ( ossim_int32  myInputIndex,
const ossimConnectableObject object
) const
virtual
required to be overriden by derived classes
Implements ossimConnectableObject.
Reimplemented in ossimImageSourceHistogramFilter.
Definition at line 113 of file ossimImageSourceFilter.cpp.
References PTR_CAST.
115 {
116
117  return ((PTR_CAST(ossimImageSource, object)||!object) && ( inputIndex == 0 ) );
118 }
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
◆ connectInputEvent()
void ossimImageSourceFilter::connectInputEvent ( ossimConnectionEvent event)
virtual
Reimplemented from ossimConnectableObjectListener.
Reimplemented in ossimImageRenderer, ossimHistogramMatchFilter, ossimImageGaussianFilter, ossimImageSharpenFilter, and ossimImageSourceHistogramFilter.
Definition at line 120 of file ossimImageSourceFilter.cpp.
Referenced by ossimImageSharpenFilter::connectInputEvent(), ossimImageGaussianFilter::connectInputEvent(), and ossimHistogramMatchFilter::connectInputEvent().
121 {
122  if(traceDebug())
123  {
124  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimImageSourceFilter::connectInputEvent: ";
125
126  if(getInput())
127  {
128  ossimNotify(ossimNotifyLevel_DEBUG) << "to" << getInput()->getClassName() << std::endl;
129  }
130  else
131  {
132  ossimNotify(ossimNotifyLevel_DEBUG) << "to NULL" << std::endl;
133  }
134  }
136  initialize();
137  if(traceDebug())
138  {
140  {
141  ossimNotify(ossimNotifyLevel_DEBUG) << "theInputConnection was set to " << getInput()->getClassName() << std::endl;
142  }
143  else
144  {
145  ossimNotify(ossimNotifyLevel_DEBUG) << "theInputConnection was set to NULL" << std::endl;
146  }
147  ossimNotify(ossimNotifyLevel_DEBUG) << "Leaving ossimImageSourceFilter::connectInput" << std::endl;
148  }
149 }
virtual ossimString getClassName() const
Definition: ossimObject.cpp:64
◆ disconnectInputEvent()
void ossimImageSourceFilter::disconnectInputEvent ( ossimConnectionEvent event)
virtual
Reimplemented in ossimImageRenderer, ossimHistogramMatchFilter, ossimImageGaussianFilter, and ossimImageSharpenFilter.
Definition at line 150 of file ossimImageSourceFilter.cpp.
Referenced by ossimImageSharpenFilter::disconnectInputEvent(), ossimImageGaussianFilter::disconnectInputEvent(), and ossimHistogramMatchFilter::disconnectInputEvent().
151 {
152  if(traceDebug())
153  {
154  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimImageSourceFilter::disconnectInputEvent" << std::endl;
155  }
157  initialize();
158  if(traceDebug())
159  {
160  ossimNotify(ossimNotifyLevel_DEBUG) << "Leaving ossimImageSourceFilter::disconnectInput" << std::endl;
161  }
162 }
◆ getNumberOfInputBands()
ossim_uint32 ossimImageSourceFilter::getNumberOfInputBands ( ) const
virtual
Returns the number of bands available from the input.
Implements ossimImageSource.
Reimplemented in ossimBandSelector.
Definition at line 74 of file ossimImageSourceFilter.cpp.
References ossimImageSource::getNumberOfOutputBands(), and theInputConnection.
Referenced by ossimKMeansFilter::allocate(), ossimBandLutFilter::allocate(), ossimHistogramRemapper::buildAutoLinearMinMaxTableTemplate(), ossimHistogramRemapper::buildAutoLinearPercentileTableTemplate(), ossimHistogramRemapper::buildLinearTable(), ossimHistogramRemapper::buildLinearTableStdFromMean(), ossimKMeansFilter::computeKMeans(), ossimHistogramRemapper::getHighClipPoint(), ossimHistogramRemapper::getHighNormalizedClipPoint(), ossimHistogramRemapper::getLowClipPoint(), ossimHistogramRemapper::getLowNormalizedClipPoint(), ossimHistogramRemapper::getMaxOutputValue(), ossimHistogramRemapper::getMidPoint(), ossimHistogramRemapper::getMinOutputValue(), ossimBandSelector::getNumberOfInputBands(), ossimHsiRemapper::getNumberOfOutputBands(), ossimBandSelector::getNumberOfOutputBands(), ossimKMeansFilter::getTile(), ossimBandLutFilter::getTile(), ossimKMeansFilter::initialize(), ossimHistogramRemapper::initializeClips(), ossimBandLutFilter::initializeLut(), ossimHistogramRemapper::initializeMinMaxOutput(), ossimKMeansFilter::saveState(), ossimHistogramRemapper::setHighClipPoint(), ossimHistogramRemapper::setHighNormalizedClipPoint(), ossimHistogramRemapper::setLowClipPoint(), ossimHistogramRemapper::setLowNormalizedClipPoint(), ossimHistogramRemapper::setMaxOutputValue(), ossimHistogramRemapper::setMidPoint(), ossimHistogramRemapper::setMinOutputValue(), and ossimHistogramRemapper::setupTable().
75 {
77  {
79  }
80
81  return 0;
82 }
◆ getOutputBandList()
void ossimImageSourceFilter::getOutputBandList ( std::vector< ossim_uint32 > &  bandList) const
virtual
Returns the input connection's output band list. If not connected calls ossimImageSource::getOutputBandList.
Definition at line 191 of file ossimImageSourceFilter.cpp.
References ossimImageSource::getOutputBandList(), and theInputConnection.
Referenced by ossimHistogramRemapper::getHistogramBand().
192 {
194  {
195  return theInputConnection->getOutputBandList(bandList);
196  }
197
198  return ossimImageSource::getOutputBandList(bandList);
199 }
virtual void getOutputBandList(std::vector< ossim_uint32 > &bandList) const
Initializes bandList.
◆ getProperty()
ossimRefPtr< ossimProperty > ossimImageSourceFilter::getProperty ( const ossimString name) const
virtual
Reimplemented in ossimPixelFlipper, ossimMapCompositionSource, ossimBandSelector, ossimWatermarkFilter, ossimImageRenderer, ossimNBandToIndexFilter, ossimHistogramMatchFilter, ossimScalarRemapper, ossimPolyCutter, ossimBrightnessContrastSource, ossimGdalOgrVectorAnnotation, ossimMeanMedianFilter, ossimSlopeFilter, ossimCastTileSourceFilter, ossimConvolutionFilter1D, ossimCacheTileSource, ossimImageGaussianFilter, ossimFftFilter, ossimImageToPlaneNormalFilter, ossimEdgeFilter, ossimSICDToDetectedImage, ossimDilationFilter, ossimHsiRemapper, ossim3x3ConvolutionFilter, ossimTrimFilter, ossimImageSharpenFilter, ossimErosionFilter, ossimBrightnessMatch, and ossimDespeckleFilter.
Definition at line 206 of file ossimImageSourceFilter.cpp.
References ossimImageSource::getProperty().
Referenced by ossimDespeckleFilter::getProperty(), ossimBrightnessMatch::getProperty(), ossimTrimFilter::getProperty(), ossim3x3ConvolutionFilter::getProperty(), ossimSICDToDetectedImage::getProperty(), ossimEdgeFilter::getProperty(), ossimFftFilter::getProperty(), ossimImageToPlaneNormalFilter::getProperty(), ossimCastTileSourceFilter::getProperty(), ossimConvolutionFilter1D::getProperty(), ossimSlopeFilter::getProperty(), ossimGdalOgrVectorAnnotation::getProperty(), ossimBrightnessContrastSource::getProperty(), ossimPolyCutter::getProperty(), ossimHistogramMatchFilter::getProperty(), ossimImageRenderer::getProperty(), and ossimBandSelector::getProperty().
207 {
208  return ossimImageSource::getProperty(name);
209
210 }
◆ getPropertyNames()
void ossimImageSourceFilter::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Reimplemented in ossimPixelFlipper, ossimMapCompositionSource, ossimWatermarkFilter, ossimBandSelector, ossimImageRenderer, ossimHistogramMatchFilter, ossimNBandToIndexFilter, ossimScalarRemapper, ossimPolyCutter, ossimBrightnessContrastSource, ossimGdalOgrVectorAnnotation, ossimMeanMedianFilter, ossimSlopeFilter, ossimCastTileSourceFilter, ossimConvolutionFilter1D, ossimCacheTileSource, ossimTrimFilter, ossimFftFilter, ossimImageGaussianFilter, ossimImageToPlaneNormalFilter, ossimEdgeFilter, ossimSICDToDetectedImage, ossimDilationFilter, ossimHsiRemapper, ossim3x3ConvolutionFilter, ossimImageSharpenFilter, ossimErosionFilter, ossimBrightnessMatch, and ossimDespeckleFilter.
Definition at line 212 of file ossimImageSourceFilter.cpp.
References ossimImageSource::getPropertyNames().
Referenced by ossimDespeckleFilter::getPropertyNames(), ossimBrightnessMatch::getPropertyNames(), ossimImageSharpenFilter::getPropertyNames(), ossim3x3ConvolutionFilter::getPropertyNames(), ossimHsiRemapper::getPropertyNames(), ossimSICDToDetectedImage::getPropertyNames(), ossimEdgeFilter::getPropertyNames(), ossimImageToPlaneNormalFilter::getPropertyNames(), ossimImageGaussianFilter::getPropertyNames(), ossimFftFilter::getPropertyNames(), ossimCastTileSourceFilter::getPropertyNames(), ossimConvolutionFilter1D::getPropertyNames(), ossimSlopeFilter::getPropertyNames(), ossimBrightnessContrastSource::getPropertyNames(), ossimPolyCutter::getPropertyNames(), ossimNBandToIndexFilter::getPropertyNames(), ossimHistogramMatchFilter::getPropertyNames(), ossimImageRenderer::getPropertyNames(), ossimBandSelector::getPropertyNames(), and ossimMapCompositionSource::getPropertyNames().
213 {
214  ossimImageSource::getPropertyNames(propertyNames);
215 }
◆ initialize()
void ossimImageSourceFilter::initialize ( )
virtual
Reimplemented in ossimMapCompositionSource, ossimIndexToRgbLutFilter, ossimBandLutFilter, ossimPixelFlipper, ossimAtCorrGridRemapper, ossimKMeansFilter, ossimBandSelector, ossimPiecewiseRemapper, ossimBandAverageFilter, ossimWatermarkFilter, ossimMultiBandHistogramTileSource, ossimSubImageTileSource, ossimBrightnessContrastSource, ossimRgbToIndexFilter, ossimNBandToIndexFilter, ossimBandClipFilter, ossimHistogramRemapper, ossimValueAssignImageSourceFilter, ossimConvolutionFilter1D, ossimMeanMedianFilter, ossimScaleFilter, ossimAnnotationSource, ossimIntensityAdjustmentFilter, ossimLinearStretchRemapper, ossimImageRenderer, ossimConvolutionSource, ossimImageToPlaneNormalFilter, ossimTableRemapper, ossimImageGaussianFilter, ossimRectangleCutFilter, ossimHsiRemapper, ossimSlopeFilter, ossimPolyCutter, ossimHistogramMatchFilter, ossimShiftFilter, ossimTiledImagePatch, ossimSICDToDetectedImage, ossimCacheTileSource, ossimRgbToGreyFilter, ossimAOD, ossimAtCorrRemapper, ossimEdgeFilter, ossimHistogramThreshholdFilter, ossimHistoMatchRemapper, ossim3x3ConvolutionFilter, ossimGammaRemapper, ossimHistogramEqualization, ossimNullPixelFlip, ossimHsiToRgbSource, ossimImageSharpenFilter, ossimRgbToHsiSource, ossimRgbToHsvSource, ossimBrightnessMatch, ossimEastingNorthingCutter, ossimTrimFilter, ossimFftFilter, ossimHsvToRgbSource, ossimScalarRemapper, ossimDespeckleFilter, ossimElevRemapper, ossimDilationFilter, ossimJpegYCbCrToRgbSource, ossimCastTileSourceFilter, and ossimErosionFilter.
Definition at line 84 of file ossimImageSourceFilter.cpp.
References ossimConnectableObject::getInput(), PTR_CAST, and theInputConnection.
Referenced by ossimImageSourceHistogramFilter::connectInputEvent(), ossimCastTileSourceFilter::initialize(), ossimErosionFilter::initialize(), ossimJpegYCbCrToRgbSource::initialize(), ossimDilationFilter::initialize(), ossimDespeckleFilter::initialize(), ossimFftFilter::initialize(), ossimHsiToRgbSource::initialize(), ossimRgbToHsiSource::initialize(), ossimRgbToHsvSource::initialize(), ossimImageSharpenFilter::initialize(), ossimHistogramEqualization::initialize(), ossimHistogramThreshholdFilter::initialize(), ossimAOD::initialize(), ossimEdgeFilter::initialize(), ossimRgbToGreyFilter::initialize(), ossimCacheTileSource::initialize(), ossimSICDToDetectedImage::initialize(), ossimHistogramMatchFilter::initialize(), ossimTiledImagePatch::initialize(), ossimPolyCutter::initialize(), ossimHsiRemapper::initialize(), ossimImageGaussianFilter::initialize(), ossimTableRemapper::initialize(), ossimConvolutionSource::initialize(), ossimImageRenderer::initialize(), ossimIntensityAdjustmentFilter::initialize(), ossimLinearStretchRemapper::initialize(), ossimAnnotationSource::initialize(), ossimScaleFilter::initialize(), ossimMeanMedianFilter::initialize(), ossimValueAssignImageSourceFilter::initialize(), ossimBandClipFilter::initialize(), ossimNBandToIndexFilter::initialize(), ossimRgbToIndexFilter::initialize(), ossimBrightnessContrastSource::initialize(), ossimSubImageTileSource::initialize(), ossimMultiBandHistogramTileSource::initialize(), ossimWatermarkFilter::initialize(), ossimBandAverageFilter::initialize(), ossimKMeansFilter::initialize(), ossimPixelFlipper::initialize(), ossimBandLutFilter::initialize(), ossimIndexToRgbLutFilter::initialize(), and ossimImageRenderer::refreshEvent().
85 {
87 }
◆ loadState()
bool ossimImageSourceFilter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Reimplemented in ossimHistogramRemapper, ossimEsriShapeFileFilter, ossimMapCompositionSource, ossimIndexToRgbLutFilter, ossimPixelFlipper, ossimHistogramMatchFilter, ossimScaleFilter, ossimBandLutFilter, ossimBandSelector, ossimPiecewiseRemapper, ossimAtCorrGridRemapper, ossimWatermarkFilter, ossimKMeansFilter, ossimGeoPolyCutter, ossimAnnotationSource, ossimBandAverageFilter, ossimBrightnessContrastSource, ossimMeanMedianFilter, ossimTiledImagePatch, ossimGridRemapSource, ossimRgbToIndexFilter, ossimNBandToIndexFilter, ossimGdalOgrVectorAnnotation, ossimImageRenderer, ossimMultiBandHistogramTileSource, ossimScalarRemapper, ossimSubImageTileSource, ossimRLevelFilter, ossimValueAssignImageSourceFilter, ossimConvolutionFilter1D, ossimBandClipFilter, ossimSlopeFilter, ossimGeoAnnotationSource, ossimHsiRemapper, ossimDilationFilter, ossimCastTileSourceFilter, ossimVectorRenderer, ossimTableRemapper, ossimFftFilter, ossimImageGaussianFilter, ossimLinearStretchRemapper, ossimCacheTileSource, ossimEdgeFilter, ossimRgbToGreyFilter, ossimPolyCutter, ossimErosionFilter, ossimRectangleCutFilter, ossimHistoMatchRemapper, ossim3x3ConvolutionFilter, ossimConvolutionSource, ossimImageToPlaneNormalFilter, ossimAOD, ossimAtCorrRemapper, ossimGammaRemapper, ossimElevRemapper, ossimImageSharpenFilter, ossimBrightnessMatch, ossimHistogramEqualization, ossimHistogramThreshholdFilter, ossimTrimFilter, ossimImageSourceHistogramFilter, ossimVpfAnnotationSource, ossimDespeckleFilter, and ossimEastingNorthingCutter.
Definition at line 89 of file ossimImageSourceFilter.cpp.
References ossimImageSource::loadState().
Referenced by ossimTrimFilter::loadState(), ossimBrightnessMatch::loadState(), ossimImageSharpenFilter::loadState(), ossim3x3ConvolutionFilter::loadState(), ossimRectangleCutFilter::loadState(), ossimRgbToGreyFilter::loadState(), ossimEdgeFilter::loadState(), ossimFftFilter::loadState(), ossimTableRemapper::loadState(), ossimCastTileSourceFilter::loadState(), ossimSlopeFilter::loadState(), ossimBandClipFilter::loadState(), ossimConvolutionFilter1D::loadState(), ossimValueAssignImageSourceFilter::loadState(), ossimRgbToIndexFilter::loadState(), ossimTiledImagePatch::loadState(), ossimAnnotationSource::loadState(), ossimBrightnessContrastSource::loadState(), ossimGeoPolyCutter::loadState(), ossimKMeansFilter::loadState(), ossimWatermarkFilter::loadState(), ossimBandSelector::loadState(), ossimScaleFilter::loadState(), ossimHistogramMatchFilter::loadState(), and ossimPixelFlipper::loadState().
91 {
92  bool result = ossimImageSource::loadState(kwl, prefix);
93
94  // make sure we have 1 input.
95  //setNumberOfInputs(1);
96
97  // we will fix the input
98  //if(!theInputListIsFixedFlag)
99  // {
100  // theInputListIsFixedFlag = true;
101  // }
102
103  return result;
104 }
◆ propertyEvent()
void ossimImageSourceFilter::propertyEvent ( ossimPropertyEvent event)
virtual
Reimplemented in ossimImageRenderer, ossimScalarRemapper, and ossimCastTileSourceFilter.
Definition at line 163 of file ossimImageSourceFilter.cpp.
164 {
165  if(traceDebug())
166  {
167  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimImageSourceFilter::propertyEvent DEBUG: Entering..." << std::endl;
168  }
169  initialize();
170
171  if(traceDebug())
172  {
173  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimImageSourceFilter::propertyEvent DEBUG: Leaving..." << std::endl;
174  }
175 }
◆ refreshEvent()
void ossimImageSourceFilter::refreshEvent ( ossimRefreshEvent event)
virtual
Definition at line 177 of file ossimImageSourceFilter.cpp.
Referenced by ossimImageRenderer::refreshEvent().
178 {
179  if(traceDebug())
180  {
181  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimImageSourceFilter::refreshEvent " << std::endl;
182  }
183  initialize();
184
185  if(traceDebug())
186  {
187  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimImageSourceFilter::refreshEvent " << std::endl;
188  }
189 }
◆ saveState()
bool ossimImageSourceFilter::saveState ( ossimKeywordlist kwl,
) const
virtual
Reimplemented in ossimHistogramRemapper, ossimEsriShapeFileFilter, ossimMapCompositionSource, ossimHistogramMatchFilter, ossimIndexToRgbLutFilter, ossimPixelFlipper, ossimBandLutFilter, ossimScaleFilter, ossimAtCorrGridRemapper, ossimBandSelector, ossimKMeansFilter, ossimPiecewiseRemapper, ossimBrightnessContrastSource, ossimTiledImagePatch, ossimGeoPolyCutter, ossimWatermarkFilter, ossimBandAverageFilter, ossimGridRemapSource, ossimAnnotationSource, ossimMeanMedianFilter, ossimMultiBandHistogramTileSource, ossimSubImageTileSource, ossimRgbToIndexFilter, ossimGdalOgrVectorAnnotation, ossimNBandToIndexFilter, ossimRLevelFilter, ossimImageRenderer, ossimBandClipFilter, ossimConvolutionFilter1D, ossimScalarRemapper, ossimValueAssignImageSourceFilter, ossimSlopeFilter, ossimFftFilter, ossimImageGaussianFilter, ossimCacheTileSource, ossimGeoAnnotationSource, ossimLinearStretchRemapper, ossimDilationFilter, ossimEdgeFilter, ossimHsiRemapper, ossimCastTileSourceFilter, ossimVectorRenderer, ossimTableRemapper, ossim3x3ConvolutionFilter, ossimImageToPlaneNormalFilter, ossimRectangleCutFilter, ossimImageSharpenFilter, ossimRgbToGreyFilter, ossimErosionFilter, ossimPolyCutter, ossimBrightnessMatch, ossimElevRemapper, ossimHistogramEqualization, ossimConvolutionSource, ossimHistogramThreshholdFilter, ossimImageSourceHistogramFilter, ossimTrimFilter, ossimVpfAnnotationSource, ossimDespeckleFilter, and ossimEastingNorthingCutter.
Definition at line 106 of file ossimImageSourceFilter.cpp.
References ossimImageSource::saveState().
Referenced by ossimTrimFilter::saveState(), ossimImageSourceHistogramFilter::saveState(), ossimElevRemapper::saveState(), ossimBrightnessMatch::saveState(), ossimRgbToGreyFilter::saveState(), ossimRectangleCutFilter::saveState(), ossim3x3ConvolutionFilter::saveState(), ossimTableRemapper::saveState(), ossimCastTileSourceFilter::saveState(), ossimEdgeFilter::saveState(), ossimFftFilter::saveState(), ossimSlopeFilter::saveState(), ossimValueAssignImageSourceFilter::saveState(), ossimConvolutionFilter1D::saveState(), ossimBandClipFilter::saveState(), ossimRgbToIndexFilter::saveState(), ossimSubImageTileSource::saveState(), ossimAnnotationSource::saveState(), ossimTiledImagePatch::saveState(), ossimBrightnessContrastSource::saveState(), ossimKMeansFilter::saveState(), ossimBandSelector::saveState(), ossimAtCorrGridRemapper::saveState(), ossimScaleFilter::saveState(), ossimPixelFlipper::saveState(), and ossimHistogramMatchFilter::saveState().
108 {
109  return ossimImageSource::saveState(kwl, prefix);
110 }
◆ setProperty()
void ossimImageSourceFilter::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Reimplemented in ossimPixelFlipper, ossimMapCompositionSource, ossimWatermarkFilter, ossimBandSelector, ossimImageRenderer, ossimNBandToIndexFilter, ossimScalarRemapper, ossimHistogramMatchFilter, ossimPolyCutter, ossimBrightnessContrastSource, ossimGdalOgrVectorAnnotation, ossimMeanMedianFilter, ossimSlopeFilter, ossimCastTileSourceFilter, ossimConvolutionFilter1D, ossimCacheTileSource, ossimFftFilter, ossimImageGaussianFilter, ossimImageToPlaneNormalFilter, ossimEdgeFilter, ossimTrimFilter, ossimSICDToDetectedImage, ossimDilationFilter, ossimHsiRemapper, ossim3x3ConvolutionFilter, ossimImageSharpenFilter, ossimErosionFilter, ossimBrightnessMatch, and ossimDespeckleFilter.
Definition at line 201 of file ossimImageSourceFilter.cpp.
References ossimImageSource::setProperty().
Referenced by ossimDespeckleFilter::setProperty(), ossimBrightnessMatch::setProperty(), ossim3x3ConvolutionFilter::setProperty(), ossimSICDToDetectedImage::setProperty(), ossimEdgeFilter::setProperty(), ossimTrimFilter::setProperty(), ossimImageToPlaneNormalFilter::setProperty(), ossimFftFilter::setProperty(), ossimCastTileSourceFilter::setProperty(), ossimConvolutionFilter1D::setProperty(), ossimSlopeFilter::setProperty(), ossimGdalOgrVectorAnnotation::setProperty(), ossimBrightnessContrastSource::setProperty(), ossimPolyCutter::setProperty(), ossimHistogramMatchFilter::setProperty(), ossimImageRenderer::setProperty(), ossimBandSelector::setProperty(), and ossimMapCompositionSource::setProperty().
202 {
204 }
Member Data Documentation
◆ theInputConnection
ossimImageSource* ossimImageSourceFilter::theInputConnection
protected
Definition at line 62 of file ossimImageSourceFilter.h.
Referenced by ossimRgbToHsiSource::allocate(), ossimDespeckleFilter::allocate(), ossimHistogramEqualization::allocate(), ossimConvolutionSource::allocate(), ossimAOD::allocate(), ossim3x3ConvolutionFilter::allocate(), ossimSICDToDetectedImage::allocate(), ossimRgbToGreyFilter::allocate(), ossimLinearStretchRemapper::allocate(), ossimCacheTileSource::allocate(), ossimTableRemapper::allocate(), ossimConvolutionFilter1D::allocate(), ossimValueAssignImageSourceFilter::allocate(), ossimPolyCutter::allocate(), ossimBrightnessContrastSource::allocate(), ossimNBandToIndexFilter::allocate(), ossimScaleFilter::allocate(), ossimBandLutFilter::allocate(), ossimIndexToRgbLutFilter::allocate(), ossimHsiRemapper::allocate(), ossimWatermarkFilter::allocate(), ossimImageRenderer::allocate(), ossimBandSelector::checkPassThrough(), ossimBandAverageFilter::checkWeights(), ossimMapCompositionSource::computeBorderRects(), ossimHistogramRemapper::computeHistogram(), ossimBrightnessMatch::computeInputBrightness(), ossim3x3ConvolutionFilter::computeNullMinMax(), ossimConvolutionFilter1D::computeNullMinMax(), ossimImageSourceHistogramFilter::connectInputEvent(), ossimImageRenderer::connectInputEvent(), ossimIntensityAdjustmentFilter::createAndPopulateGrid(), ossimImageRenderer::disconnectInputEvent(), ossimCacheTileSource::fillTile(), ossimImageRenderer::fillTile(), ossimBandSelector::getBandSelectableImageHandler(), ossimPolyCutter::getBoundingRect(), ossimAnnotationSource::getBoundingRect(), ossimSubImageTileSource::getBoundingRect(), ossimImageRenderer::getBoundingRect(), ossimRLevelFilter::getBoundingRect(), ossimMapCompositionSource::getBoundingRect(), ossimCacheTileSource::getCacheId(), ossimRLevelFilter::getDecimationFactor(), ossimRLevelFilter::getImageGeometry(), ossimScaleFilter::getImageGeometry(), ossimImageRenderer::getImageGeometry(), ossimCastTileSourceFilter::getMaxPixelValue(), ossimBandAverageFilter::getMaxPixelValue(), ossimBandSelector::getMaxPixelValue(), ossimCastTileSourceFilter::getMinPixelValue(), ossimBandAverageFilter::getMinPixelValue(), ossimBandSelector::getMinPixelValue(), ossimCastTileSourceFilter::getNullPixelValue(), ossimBandSelector::getNullPixelValue(), getNumberOfInputBands(), ossimAnnotationSource::getNumberOfOutputBands(), getOutputBandList(), ossimBandSelector::getOutputBandList(), ossimCastTileSourceFilter::getOutputScalarType(), ossimAnnotationSource::getOutputScalarType(), ossimPixelFlipper::getOutputScalarType(), ossimBandSelector::getRgbBandList(), ossimHsvToRgbSource::getTile(), ossimIntensityAdjustmentFilter::getTile(), ossimRgbToHsiSource::getTile(), ossimRgbToHsvSource::getTile(), ossimRgbToJpegYCbCrSource::getTile(), ossimHsiToRgbSource::getTile(), ossimCastTileSourceFilter::getTile(), ossimImageToPlaneNormalFilter::getTile(), ossimJpegYCbCrToRgbSource::getTile(), ossimHistogramThreshholdFilter::getTile(), ossimHistogramEqualization::getTile(), ossimBrightnessMatch::getTile(), ossimDespeckleFilter::getTile(), ossimMultiBandHistogramTileSource::getTile(), ossimTrimFilter::getTile(), ossimImageSharpenFilter::getTile(), ossimSICDToDetectedImage::getTile(), ossim3x3ConvolutionFilter::getTile(), ossimHistoMatchRemapper::getTile(), ossimRgbToGreyFilter::getTile(), ossimBrightnessContrastSource::getTile(), ossimGammaRemapper::getTile(), ossimHistogramMatchFilter::getTile(), ossimAOD::getTile(), ossimPolyCutter::getTile(), ossimBandSelector::getTile(), ossimMapCompositionSource::getTile(), ossimRectangleCutFilter::getTile(), ossimTableRemapper::getTile(), ossimShiftFilter::getTile(), ossimLinearStretchRemapper::getTile(), ossimAnnotationSource::getTile(), ossimImageGaussianFilter::getTile(), ossimSlopeFilter::getTile(), ossimConvolutionSource::getTile(), ossimBandAverageFilter::getTile(), ossimHsiRemapper::getTile(), ossimScaleFilter::getTile(), ossimNBandToIndexFilter::getTile(), ossimValueAssignImageSourceFilter::getTile(), ossimRgbToIndexFilter::getTile(), ossimConvolutionFilter1D::getTile(), ossimSubImageTileSource::getTile(), ossimHistogramRemapper::getTile(), ossimTiledImagePatch::getTile(), ossimBandClipFilter::getTile(), ossimKMeansFilter::getTile(), ossimRLevelFilter::getTile(), ossimWatermarkFilter::getTile(), ossimGridRemapSource::getTile(), ossimPiecewiseRemapper::getTile(), ossimBandLutFilter::getTile(), ossimIndexToRgbLutFilter::getTile(), ossimPixelFlipper::getTile(), ossimImageRenderer::getTileAtResLevel(), ossimSubImageTileSource::getValidImageVertices(), ossimImageRenderer::getValidImageVertices(), ossimMapCompositionSource::getViewingRect(), ossimElevRemapper::initialize(), ossimTrimFilter::initialize(), ossimGammaRemapper::initialize(), ossimHistoMatchRemapper::initialize(), ossimAtCorrRemapper::initialize(), ossimTiledImagePatch::initialize(), initialize(), ossimSlopeFilter::initialize(), ossimRectangleCutFilter::initialize(), ossimTableRemapper::initialize(), ossimImageToPlaneNormalFilter::initialize(), ossimIntensityAdjustmentFilter::initialize(), ossimLinearStretchRemapper::initialize(), ossimAnnotationSource::initialize(), ossimBandClipFilter::initialize(), ossimWatermarkFilter::initialize(), ossimBandAverageFilter::initialize(), ossimKMeansFilter::initialize(), ossimAtCorrGridRemapper::initialize(), ossimBandLutFilter::initialize(), ossimIndexToRgbLutFilter::initialize(), ossimMapCompositionSource::initialize(), ossimImageRenderer::initializeBoundingRects(), ossimBandLutFilter::initializeLut(), ossimMapCompositionSource::inputMapProjection(), ossimPixelFlipper::inRange(), ossimNBandToIndexFilter::isSourceEnabled(), ossimBandSelector::outputBandsWithinInputRange(), ossimImageRenderer::refreshEvent(), ossimScaleFilter::runFilterTemplate(), ossimHistogramRemapper::setMaxOutputValue(), ossimHistogramRemapper::setMinOutputValue(), ossimBandSelector::setOutputBandList(), ossimRectangleCutFilter::setRectangle(), ossimAOD::verifyEnabled(), ossimGammaRemapper::verifyEnabled(), ossimAtCorrRemapper::verifyEnabled(), ossimHsiRemapper::verifyEnabled(), and ~ossimImageSourceFilter().
