10 #ifndef ossimPointCloudRecord_HEADER 11 #define ossimPointCloudRecord_HEADER 31 ReturnNumber = 0x0010,
32 NumberOfReturns = 0x0020,
72 const std::map<FIELD_CODES, ossim_float32>&
getFieldMap()
const {
return m_fieldMap; }
const std::map< FIELD_CODES, ossim_float32 > & getFieldMap() const
ossimReferenced allows for shared object ref counting if the reference count ever gets to 0 or less i...
ossim_uint32 getPointId() const
ostream & operator<<(ostream &out, const ossimAxes &axes)
unsigned int ossim_uint32
ossimReferenced & operator=(const ossimReferenced &)
const ossimGpt & getPosition() const
Returns the 3D position vector in the dataset's coodinate reference system (available from the ossimP...
void setPosition(const ossimGpt &p)
void setPointId(ossim_uint32 id)
std::basic_ostream< char > ostream
Base class for char output streams.
std::map< FIELD_CODES, ossim_float32 > m_fieldMap
