Public Types | Public Member Functions | Protected Attributes | Friends | List of all members
ossimPointRecord Class Reference
#include <ossimPointRecord.h>
Inheritance diagram for ossimPointRecord:
ossimReferenced
Public Types
enum  FIELD_CODES {
  Intensity = 0x0008, ReturnNumber = 0x0010, NumberOfReturns = 0x0020, Red = 0x0040,
  Green = 0x0080, Blue = 0x0100, GpsTime = 0x0200, Infrared = 0x0400,
  All = 0x0777
 ossimPointRecord (ossim_uint32 fields_code=0)
 ossimPointRecord (const ossimPointRecord &pcr)
 ossimPointRecord (const ossimGpt &pos)
 ~ossimPointRecord ()
 Creates a point record with fields set to null values. More...
ossimPointRecordoperator= (const ossimPointRecord &pcr)
ossim_uint32 getPointId () const
void setPointId (ossim_uint32 id)
const ossimGptgetPosition () const
 Returns the 3D position vector in the dataset's coodinate reference system (available from the ossimPointCloudSource object. More...
void setPosition (const ossimGpt &p)
virtual bool hasFields (ossim_uint32 code_mashup) const
 Argument can be mash-up of OR'd codes for check of multiple fields. More...
virtual ossim_uint32 getFieldCode () const
 Returns mash-up of OR'd codes of multiple fields being stored. More...
ossim_float32 getField (FIELD_CODES fc) const
 Return the float value of the requested field. More...
const std::map< FIELD_CODES, ossim_float32 > & getFieldMap () const
void setField (FIELD_CODES fc, ossim_float32 value)
void clear ()
 Initializes point to undefined state: More...
bool isValid () const
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
ossim_uint32 m_pointId
ossimGpt m_position
std::map< FIELD_CODES, ossim_float32m_fieldMap
Friends
std::ostream & operator<< (std::ostream &ostr, const ossimPointRecord &p)
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 23 of file ossimPointRecord.h.
◆ FIELD_CODES
Enumerator
Intensity
ReturnNumber
NumberOfReturns
Red
Green
Blue
GpsTime
Infrared
All
Definition at line 28 of file ossimPointRecord.h.
29  {
30  Intensity = 0x0008, // float 32
31  ReturnNumber = 0x0010, // unsigned int 32
32  NumberOfReturns = 0x0020, // unsigned int 32
33  Red = 0x0040, // float 32
34  Green = 0x0080, // float 32
35  Blue = 0x0100, // float 32
36  GpsTime = 0x0200, // unsigned long Unix epoch (microsec from 01/01/1970)
37  Infrared = 0x0400, // float 32
38  All = 0x0777
39  };
◆ ossimPointRecord() [1/3]
ossimPointRecord::ossimPointRecord ( ossim_uint32  fields_code = 0)
Definition at line 12 of file ossimPointRecord.cpp.
References Blue, GpsTime, Green, Infrared, Intensity, m_fieldMap, ossim::nan(), NumberOfReturns, Red, and ReturnNumber.
13  : m_pointId(0)
14 {
15  if (field_code & Intensity)
17  if (field_code & ReturnNumber)
19  if (field_code & NumberOfReturns)
21  if (field_code & Red)
23  if (field_code & Green)
25  if (field_code & Blue)
27  if (field_code & GpsTime)
29  if (field_code & Infrared)
31 }
double nan()
Definition: ossimCommon.h:135
std::map< FIELD_CODES, ossim_float32 > m_fieldMap
◆ ossimPointRecord() [2/3]
ossimPointRecord::ossimPointRecord ( const ossimPointRecord pcr)
Definition at line 33 of file ossimPointRecord.cpp.
34  : m_pointId(pcr.m_pointId),
37 {
38 }
◆ ossimPointRecord() [3/3]
ossimPointRecord::ossimPointRecord ( const ossimGpt pos)
Definition at line 40 of file ossimPointRecord.cpp.
41  : m_pointId(0),
42  m_position(pos)
43 {
44 }
◆ ~ossimPointRecord()
ossimPointRecord::~ossimPointRecord ( )
Definition at line 46 of file ossimPointRecord.cpp.
47 {
48 }
Member Function Documentation
◆ clear()
void ossimPointRecord::clear ( )
Definition at line 167 of file ossimPointRecord.cpp.
References m_pointId.
168 {
169  m_pointId = 0;
170 }
◆ getField()
ossim_float32 ossimPointRecord::getField ( FIELD_CODES  fc) const
Definition at line 98 of file ossimPointRecord.cpp.
References m_fieldMap, and ossim::nan().
Referenced by ossimPointCloudImageHandler::addSample(), ossimPdalReader::establishMinMax(), ossimPointBlock::getFieldMax(), ossimPointBlock::getFieldMin(), ossimPointCloudHandler::normalizeBlock(), ossimPdalReader::parsePointView(), and ossimPointCloudImageHandler::setCurrentEntry().
99 {
100  std::map<FIELD_CODES, ossim_float32>::const_iterator v = m_fieldMap.find(fc);
101  if (v == m_fieldMap.end())
102  return ossim::nan();
103  return v->second;
104 }
double nan()
◆ getFieldCode()
ossim_uint32 ossimPointRecord::getFieldCode ( ) const
inlinevirtual
Definition at line 74 of file ossimPointRecord.cpp.
References Blue, GpsTime, Green, Infrared, Intensity, m_fieldMap, NumberOfReturns, Red, and ReturnNumber.
Referenced by ossimPointBlock::addPoint(), and ossimPdalReader::establishMinMax().
75 {
76  ossim_uint32 field_code = 0;
77
78  if (m_fieldMap.find(Intensity) != m_fieldMap.end())
79  field_code |= Intensity;
80  if (m_fieldMap.find(ReturnNumber) != m_fieldMap.end())
81  field_code |= ReturnNumber;
82  if (m_fieldMap.find(NumberOfReturns) != m_fieldMap.end())
83  field_code |= NumberOfReturns;
84  if (m_fieldMap.find(Red) != m_fieldMap.end())
85  field_code |= Red;
86  if (m_fieldMap.find(Green) != m_fieldMap.end())
87  field_code |= Green;
88  if (m_fieldMap.find(Blue) != m_fieldMap.end())
89  field_code |= Blue;
90  if (m_fieldMap.find(GpsTime) != m_fieldMap.end())
91  field_code |= GpsTime;
92  if (m_fieldMap.find(Infrared) != m_fieldMap.end())
93  field_code |= Infrared;
94
95  return field_code;
96 }
unsigned int ossim_uint32
◆ getFieldMap()
const std::map<FIELD_CODES, ossim_float32>& ossimPointRecord::getFieldMap ( ) const
inline
Definition at line 72 of file ossimPointRecord.h.
Referenced by ossimPdalReader::establishMinMax().
72 { return m_fieldMap; }
◆ getPointId()
ossim_uint32 ossimPointRecord::getPointId ( ) const
inline
Definition at line 50 of file ossimPointRecord.h.
50 { return m_pointId; }
◆ getPosition()
const ossimGpt& ossimPointRecord::getPosition ( ) const
inline
This is either map/meters (x, y, z) or geog (lat, lon, hgt). Refer to the ossimPointCloudGeometry::getStoredPosFormat() available from the associated ossimPointCloudSource->getGeometry()
Definition at line 59 of file ossimPointRecord.h.
Referenced by ossimPointCloudImageHandler::addSample(), ossimPdalReader::establishMinMax(), ossimPointBlock::getBounds(), ossimPointCloudHandler::getBounds(), ossimPointBlock::scanForMinMax(), and ossimPointCloudImageHandler::setCurrentEntry().
59 { return m_position; }
◆ hasFields()
bool ossimPointRecord::hasFields ( ossim_uint32  code_mashup) const
inlinevirtual
Returns TRUE if ALL fields are present.
Definition at line 50 of file ossimPointRecord.cpp.
Referenced by ossimPdalReader::parsePoint().
51 {
52  bool found = true;
53
54  if (field_code & Intensity)
55  found &= m_fieldMap.find(Intensity) != m_fieldMap.end();
56  if (found && (field_code & ReturnNumber))
57  found = m_fieldMap.find(ReturnNumber) != m_fieldMap.end();
58  if (found && (field_code & NumberOfReturns))
59  found = m_fieldMap.find(NumberOfReturns) != m_fieldMap.end();
60  if (found && (field_code & Red))
61  found = m_fieldMap.find(Red) != m_fieldMap.end();
62  if (found && (field_code & Green))
63  found = m_fieldMap.find(Green) != m_fieldMap.end();
64  if (found && (field_code & Blue))
65  found = m_fieldMap.find(Blue) != m_fieldMap.end();
66  if (found && (field_code & GpsTime))
67  found = m_fieldMap.find(GpsTime) != m_fieldMap.end();
68  if (found && (field_code & Infrared))
69  found = m_fieldMap.find(Infrared) != m_fieldMap.end();
70
71  return found;
72 }
◆ isValid()
bool ossimPointRecord::isValid ( void  ) const
Definition at line 172 of file ossimPointRecord.cpp.
References ossimGpt::hasNans(), m_fieldMap, m_pointId, and m_position.
173 {
174  if ((m_pointId == 0) || m_fieldMap.empty() || m_position.hasNans())
175  return false;
176  return true;
177 }
bool hasNans() const
Definition: ossimGpt.h:135
◆ operator=()
ossimPointRecord & ossimPointRecord::operator= ( const ossimPointRecord pcr)
Definition at line 112 of file ossimPointRecord.cpp.
References m_fieldMap, m_pointId, and m_position.
113 {
114  if (this == &pcr)
115  return *this;
116
117  m_pointId = pcr.m_pointId;
118  m_position = pcr.m_position;
119  m_fieldMap = pcr.m_fieldMap;
120
121  return *this;
122 }
◆ setField()
void ossimPointRecord::setField ( FIELD_CODES  fc,
ossim_float32  value
Definition at line 106 of file ossimPointRecord.cpp.
References m_fieldMap.
Referenced by ossimPdalReader::establishMinMax(), ossimPointCloudHandler::normalizeBlock(), ossimPdalReader::parsePoint(), and ossimPdalReader::parsePointView().
107 {
108  m_fieldMap[fc] = value;
109 }
◆ setPointId()
void ossimPointRecord::setPointId ( ossim_uint32  id)
inline
Definition at line 51 of file ossimPointRecord.h.
Referenced by ossimPdalReader::parsePointView().
51 {m_pointId = id; }
◆ setPosition()
void ossimPointRecord::setPosition ( const ossimGpt p)
inline
Definition at line 60 of file ossimPointRecord.h.
Referenced by ossimPdalReader::establishMinMax(), and ossimPdalReader::parsePoint().
60 { m_position = p; }
◆ operator<<
std::ostream& operator<< ( std::ostream &  ostr,
friend
Definition at line 124 of file ossimPointRecord.cpp.
125 {
126  out << "ossimPointCloudRecord for pointId: " << p.m_pointId
127  << "\n Position: " << p.m_position << ends;
128
129  std::map<ossimPointRecord::FIELD_CODES, ossim_float32>::const_iterator iter = p.m_fieldMap.begin();
130  while (iter != p.m_fieldMap.end())
131  {
132  switch (iter->first)
133  {
135  out << "\n Intensity: ";
136  break;
138  out << "\n ReturnNumber: ";
139  break;
141  out << "\n NumberOfReturns: ";
142  break;
144  out << "\n Red: ";
145  break;
147  out << "\n Green: ";
148  break;
150  out << "\n Blue: ";
151  break;
153  out << "\n GpsTime: ";
154  break;
156  out << "\n Infrared: ";
157  break;
158  default:
159  out << "\n Unidentified: ";
160  }
161  out << iter->second;
162  ++iter;
163  }
164  return out;
165 }
Member Data Documentation
◆ m_fieldMap
std::map<FIELD_CODES, ossim_float32> ossimPointRecord::m_fieldMap
protected
◆ m_pointId
ossim_uint32 ossimPointRecord::m_pointId
protected
Definition at line 85 of file ossimPointRecord.h.
Referenced by clear(), isValid(), operator<<(), and operator=().
◆ m_position
ossimGpt ossimPointRecord::m_position
protected
Definition at line 86 of file ossimPointRecord.h.
Referenced by isValid(), operator<<(), and operator=().
