Functions | Variables
ossimSqlitePluginInit.cpp File Reference
#include <ossim/plugin/ossimSharedObjectBridge.h>
#include "ossimSqliteInfoFactory.h"
#include <ossim/plugin/ossimPluginConstants.h>
#include "ossimSqliteReaderFactory.h"
#include "ossimSqliteWriterFactory.h"
#include <ossim/imaging/ossimImageHandlerRegistry.h>
#include <ossim/imaging/ossimImageWriterFactoryRegistry.h>
#include <ossim/support_data/ossimInfoFactoryRegistry.h>
Go to the source code of this file.
Functions
const char * getSqliteDescription ()
int getSqliteNumberOfClassNames ()
const char * getSqliteClassName (int idx)
OSSIM_PLUGINS_DLL void ossimSharedLibraryInitialize (ossimSharedObjectInfo **info, const char *)
OSSIM_PLUGINS_DLL void ossimSharedLibraryFinalize ()
Variables
ossimSharedObjectInfo mySqliteInfo
ossimString theSqliteDescription
std::vector< ossimStringtheSqliteObjList
Function Documentation
◆ getSqliteClassName()
const char* getSqliteClassName ( int  idx)
Definition at line 44 of file ossimSqlitePluginInit.cpp.
References theSqliteObjList.
Referenced by ossimSharedLibraryInitialize().
45  {
46  if(idx < (int)theSqliteObjList.size())
47  {
48  return theSqliteObjList[idx].c_str();
49  }
50  return (const char*)0;
51  }
std::vector< ossimString > theSqliteObjList
◆ getSqliteDescription()
const char* getSqliteDescription ( )
Definition at line 34 of file ossimSqlitePluginInit.cpp.
References ossimString::c_str(), and theSqliteDescription.
35  {
36  return theSqliteDescription.c_str();
37  }
const char * c_str() const
Definition: ossimString.h:396
◆ getSqliteNumberOfClassNames()
int getSqliteNumberOfClassNames ( )
Definition at line 39 of file ossimSqlitePluginInit.cpp.
40  {
41  return (int)theSqliteObjList.size();
42  }
◆ ossimSharedLibraryFinalize()
OSSIM_PLUGINS_DLL void ossimSharedLibraryFinalize ( )
Definition at line 83 of file ossimSqlitePluginInit.cpp.
References ossimImageWriterFactoryRegistry::instance(), ossimSqliteWriterFactory::instance(), ossimSqliteReaderFactory::instance(), ossimSqliteInfoFactory::instance(), ossimInfoFactoryRegistry::instance(), and ossimImageHandlerRegistry::instance().
84  {
86  unregisterFactory(ossimSqliteReaderFactory::instance());
87
89  unregisterFactory(ossimSqliteInfoFactory::instance());
90
92  unregisterFactory(ossimSqliteWriterFactory::instance());
93  }
static ossimImageWriterFactoryRegistry * instance()
static ossimSqliteInfoFactory * instance()
static ossimSqliteReaderFactory * instance()
static method to return instance (the only one) of this class.
static ossimSqliteWriterFactory * instance()
static ossimInfoFactoryRegistry * instance()
instance method
static ossimImageHandlerRegistry * instance()
◆ ossimSharedLibraryInitialize()
OSSIM_PLUGINS_DLL void ossimSharedLibraryInitialize ( ossimSharedObjectInfo **  info,
const char *
Definition at line 54 of file ossimSqlitePluginInit.cpp.
References ossimSharedObjectInfo::getClassName, ossimSharedObjectInfo::getDescription, ossimSharedObjectInfo::getNumberOfClassNames, getSqliteClassName(), getSqliteDescription(), getSqliteNumberOfClassNames(), ossimImageWriterFactoryRegistry::instance(), ossimSqliteWriterFactory::instance(), ossimSqliteReaderFactory::instance(), ossimSqliteInfoFactory::instance(), ossimInfoFactoryRegistry::instance(), ossimImageHandlerRegistry::instance(), and mySqliteInfo.
57  {
61
62  *info = &mySqliteInfo;
63
64  /* Register the readers... */
66  registerFactory(ossimSqliteReaderFactory::instance());
67
68  /* Register the info factoy... */
70  registerFactory(ossimSqliteInfoFactory::instance());
71
72  /* Register the writers... */
74  registerFactory(ossimSqliteWriterFactory::instance());
75
76  setSqliteDescription(theSqliteDescription);
79  theSqliteObjList.push_back("ossimGpkgInfo");
80  }
ossimSharedLibraryGetNumberOfClassNamesPtr getNumberOfClassNames
virtual void getTypeNameList(std::vector< ossimString > &typeList) const
Adds ossimSqliteWriter to the typeList.
int getSqliteNumberOfClassNames()
const char * getSqliteDescription()
ossimSharedLibraryGetDescriptionPtr getDescription
ossimSharedLibraryGetClassNamesPtr getClassName
instance method
const char * getSqliteClassName(int idx)
Adds "ossimSqliteWriter" to list.
Variable Documentation
◆ mySqliteInfo
Definition at line 30 of file ossimSqlitePluginInit.cpp.
◆ theSqliteDescription
Definition at line 31 of file ossimSqlitePluginInit.cpp.
Referenced by getSqliteDescription().
◆ theSqliteObjList
std::vector<ossimString> theSqliteObjList
Definition at line 32 of file ossimSqlitePluginInit.cpp.
Referenced by getSqliteClassName(), and getSqliteNumberOfClassNames().
