Factory for SQLITE image writer. More...
#include <ossimSqliteWriterFactory.h>
virtual | ~ossimSqliteWriterFactory () |
virtual destructor More... | |
virtual ossimImageFileWriter * | createWriterFromExtension (const ossimString &fileExtension) const |
Creates a writer from extension like "sqlite". More... | |
virtual ossimImageFileWriter * | createWriter (const ossimKeywordlist &kwl, const char *prefix=0) const |
Create that takes a keyword list and prefix. More... | |
virtual ossimImageFileWriter * | createWriter (const ossimString &typeName) const |
createWriter that takes a class name (ossimSqliteWriter) More... | |
virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
Creates and object given a keyword list. More... | |
virtual ossimObject * | createObject (const ossimString &typeName) const |
createObject that takes a class name (ossimSqliteWriter) More... | |
virtual void | getExtensions (std::vector< ossimString > &extList) const |
Adds "sqlite" to list. More... | |
virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
Adds "ossimSqliteWriter" to list. More... | |
virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
Adds "ossim_sqlite" to writer list. More... | |
virtual void | getImageFileWritersBySuffix (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &ext) const |
virtual void | getImageFileWritersByMimeType (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &mimeType) const |
virtual | ~ossimImageWriterFactoryBase () |
virtual | ~ossimObjectFactory () |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
static ossimSqliteWriterFactory * | instance () |
static method to return instance (the only one) of this class. More... | |
ossimSqliteWriterFactory () | |
hidden from use default constructor More... | |
ossimSqliteWriterFactory (const ossimSqliteWriterFactory &) | |
hidden from use copy constructor More... | |
void | operator= (const ossimSqliteWriterFactory &) |
virtual | ~ossimReferenced () |
Static Protected Attributes | |
static ossimSqliteWriterFactory * | theInstance = 0 |
static instance of this class More... | |
typedef std::vector< ossimRefPtr< ossimImageFileWriter > > | ImageFileWriterList |
Definition at line 20 of file ossimSqliteWriterFactory.h.
virtual destructor
Definition at line 23 of file ossimSqliteWriterFactory.cpp.
References theInstance.
protected |
Definition at line 138 of file ossimSqliteWriterFactory.cpp.
Referenced by instance().
protected |
Definition at line 140 of file ossimSqliteWriterFactory.cpp.
kwl | The keyword list. |
prefix | the keyword list prefix. |
Implements ossimObjectFactory.
Definition at line 88 of file ossimSqliteWriterFactory.cpp.
References createWriter().
typeName | Should be "ossimSqliteReader". |
Definition at line 94 of file ossimSqliteWriterFactory.cpp.
Implements ossimImageWriterFactoryBase.
Definition at line 49 of file ossimSqliteWriterFactory.cpp.
References ossimKeywordlist::find(), ossimImageFileWriter::loadState(), ossimRefPtr< T >::release(), ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
Referenced by createObject().
Definition at line 68 of file ossimSqliteWriterFactory.cpp.
References ossimImageFileWriter::hasImageType(), and ossimRefPtr< T >::release().
fileExtension | "sqlite" |
Definition at line 37 of file ossimSqliteWriterFactory.cpp.
References ossimRefPtr< T >::release().
extList | List to add to. |
Definition at line 100 of file ossimSqliteWriterFactory.cpp.
Reimplemented from ossimImageWriterFactoryBase.
Definition at line 128 of file ossimSqliteWriterFactory.cpp.
References ossimString::downcase(), and ossimString::push_back().
Definition at line 118 of file ossimSqliteWriterFactory.cpp.
imageTypeList | List to append to. |
Definition at line 111 of file ossimSqliteWriterFactory.cpp.
References ossimGpkgWriter::getImageTypeList().
typeList | List to add to. |
Definition at line 106 of file ossimSqliteWriterFactory.cpp.
static |
Definition at line 28 of file ossimSqliteWriterFactory.cpp.
References ossimSqliteWriterFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
protected |
Definition at line 142 of file ossimSqliteWriterFactory.cpp.
staticprotected |
Definition at line 107 of file ossimSqliteWriterFactory.h.
Referenced by instance(), and ~ossimSqliteWriterFactory().
