Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimDatumFactoryRegistry Class Reference
#include <ossimDatumFactoryRegistry.h>
Inheritance diagram for ossimDatumFactoryRegistry:
ossimDatumFactoryInterface
 ~ossimDatumFactoryRegistry ()
 destructor More...
void registerFactory (ossimDatumFactoryInterface *factory)
 Method to add factory to registry. More...
virtual const ossimDatumcreate (const ossimString &code) const
 create method More...
virtual const ossimDatumcreate (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual void getList (std::vector< ossimString > &list) const
 getList method to return a combined list of all datums from registered datum factories. More...
- Public Member Functions inherited from ossimDatumFactoryInterface
 ossimDatumFactoryInterface ()
 default constructor More...
virtual ~ossimDatumFactoryInterface ()
 virtual destructor More...
static ossimDatumFactoryRegistryinstance ()
 instance method More...
 hidden from use default constructor More...
std::mutex theFactoryListMutex
 Single static instance of this class. More...
std::vector< ossimDatumFactoryInterface * > theFactoryList
Detailed Description
Definition at line 24 of file ossimDatumFactoryRegistry.h.
◆ ~ossimDatumFactoryRegistry()
ossimDatumFactoryRegistry::~ossimDatumFactoryRegistry ( )
destructor
Definition at line 20 of file ossimDatumFactoryRegistry.cpp.
21 {
22 }
◆ ossimDatumFactoryRegistry()
ossimDatumFactoryRegistry::ossimDatumFactoryRegistry ( )
protected
Definition at line 93 of file ossimDatumFactoryRegistry.cpp.
References ossimEpsgDatumFactory::instance(), ossimDatumFactory::instance(), and registerFactory().
94  : theFactoryList()
95 {
98 }
void registerFactory(ossimDatumFactoryInterface *factory)
static ossimDatumFactory * instance()
static ossimEpsgDatumFactory * instance()
Singleton implementation.
Member Function Documentation
◆ create() [1/2]
const ossimDatum * ossimDatumFactoryRegistry::create ( const ossimString code) const
virtual
create method
Implements pure virtual ossimDatumFactoryInterface::create.
Returns
const pointer to a datum.
Implements ossimDatumFactoryInterface.
Definition at line 45 of file ossimDatumFactoryRegistry.cpp.
References theFactoryList.
Referenced by ossimFgdcXmlDoc::createOssimDatum(), ossimEpsgProjectionDatabase::findProjection(), ossimMapProjection::loadState(), operator>>(), ossimStatePlaneProjectionInfo::ossimStatePlaneProjectionInfo(), and ossimInfo::printDatums().
47 {
48  const ossimDatum* result = 0;
49
50  std::vector<ossimDatumFactoryInterface*>::const_iterator i =
51  theFactoryList.begin();
52
53  while (i != theFactoryList.end())
54  {
55  result = (*i)->create(code);
56  if (result)
57  {
58  break;
59  }
60  ++i; // go to next factory
61  }
62  return result;
63 }
◆ create() [2/2]
const ossimDatum * ossimDatumFactoryRegistry::create ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Definition at line 65 of file ossimDatumFactoryRegistry.cpp.
67 {
68  const ossimDatum* result = 0;
69  std::vector<ossimDatumFactoryInterface*>::const_iterator i = theFactoryList.begin();
70
71  while (i != theFactoryList.end())
72  {
73  result = (*i)->create(kwl, prefix);
74  if (result)
75  return result;
76
77  ++i; // go to next factory
78  }
79  return result;
80 }
◆ getList()
void ossimDatumFactoryRegistry::getList ( std::vector< ossimString > &  list) const
virtual
Parameters
listThe list to add to.
Definition at line 82 of file ossimDatumFactoryRegistry.cpp.
Referenced by ossimInfo::printDatums().
83 {
84  std::vector<ossimDatumFactoryInterface*>::const_iterator i =
85  theFactoryList.begin();
86  while (i != theFactoryList.end())
87  {
88  (*i)->getList(list);
89  ++i;
90  }
91 }
◆ instance()
ossimDatumFactoryRegistry * ossimDatumFactoryRegistry::instance ( )
static
instance method
Returns
Point to the instance of the registry.
Definition at line 24 of file ossimDatumFactoryRegistry.cpp.
Referenced by ossimFgdcXmlDoc::createOssimDatum(), ossimEpsgProjectionDatabase::findProjection(), ossimInit::initializeDefaultFactories(), ossimMapProjection::loadState(), operator>>(), ossimStatePlaneProjectionInfo::ossimStatePlaneProjectionInfo(), and ossimInfo::printDatums().
25 {
26  static ossimDatumFactoryRegistry inst;
27
28  return &inst;
29  //if (!theInstance)
30  //{
31  // theInstance = new ossimDatumFactoryRegistry;
32  // }
33  // return theInstance;
34 }
◆ registerFactory()
void ossimDatumFactoryRegistry::registerFactory ( ossimDatumFactoryInterface factory)
Parameters
factoryFactory to register.
Definition at line 36 of file ossimDatumFactoryRegistry.cpp.
Referenced by ossimDatumFactoryRegistry().
38 {
39  if (factory)
40  {
41  theFactoryList.push_back(factory);
42  }
43 }
Member Data Documentation
◆ theFactoryList
std::vector<ossimDatumFactoryInterface*> ossimDatumFactoryRegistry::theFactoryList
protected
Definition at line 71 of file ossimDatumFactoryRegistry.h.
Referenced by create(), getList(), and registerFactory().
◆ theFactoryListMutex
std::mutex ossimDatumFactoryRegistry::theFactoryListMutex
mutableprotected
Definition at line 70 of file ossimDatumFactoryRegistry.h.
