Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimEpsgDatumFactory Class Reference
Class for creating datum instances from EPSG codes. More...
#include <ossimEpsgDatumFactory.h>
Inheritance diagram for ossimEpsgDatumFactory:
ossimDatumFactoryInterface
virtual ~ossimEpsgDatumFactory ()
 Destructor. More...
virtual const ossimDatumcreate (const ossimString &epsg_spec) const
 Creates a datum instance given an EPSG spec in the form "EPSG:<datum_code>". More...
virtual const ossimDatumcreate (const ossimKeywordlist &kwl, const char *prefix=0) const
 Creates a datum instance given a KWL and prefix. More...
virtual void getList (std::vector< ossimString > &list) const
 Returns list of all datums supported, in the form of "EPSG:<code>, <datum_name>". More...
const ossimDatumcreate (ossim_uint32 epsg_code) const
 Specific to this factory only. Creates a datum instance given an EPSG integer code. More...
ossim_uint32 findEpsgCode (const ossimString &alpha_code) const
 Specific to this factory only. More...
ossimString findAlphaCode (ossim_uint32 epsg_code) const
- Public Member Functions inherited from ossimDatumFactoryInterface
 ossimDatumFactoryInterface ()
 default constructor More...
virtual ~ossimDatumFactoryInterface ()
 virtual destructor More...
static ossimEpsgDatumFactoryinstance ()
 Singleton implementation. More...
 Hidden constructors for singleton implementation. More...
std::map< ossim_uint32, std::string > m_epsgToAlphaMap
 Presently implemented as a mapping from EPSG code to OSSIM/Geotrans alpha-codes found in ossimDatumFactory. More...
Detailed Description
Presently only a small subset of EPSG datums are supported. These are hardcoded here or, alternatively, the EPSG code is mapped to the OSSIM/Geotrans code and ossimDatumFactory is used to produce the final datum.
TO DO: Eventually we should have a disk-file based database lookup of datums with associated parameters similar to the EPSG projection factory and database.
Definition at line 31 of file ossimEpsgDatumFactory.h.
◆ ~ossimEpsgDatumFactory()
ossimEpsgDatumFactory::~ossimEpsgDatumFactory ( )
virtual
Destructor.
Definition at line 122 of file ossimEpsgDatumFactory.cpp.
123 {
124 }
◆ ossimEpsgDatumFactory()
ossimEpsgDatumFactory::ossimEpsgDatumFactory ( )
protected
Definition at line 47 of file ossimEpsgDatumFactory.cpp.
References m_epsgToAlphaMap.
48 {
49  m_epsgToAlphaMap.insert(std::make_pair(6135, std::string("OHI-M")));
50  m_epsgToAlphaMap.insert(std::make_pair(6139, std::string("PUR")));
51  m_epsgToAlphaMap.insert(std::make_pair(6152, std::string("NAR")));
52  m_epsgToAlphaMap.insert(std::make_pair(6154, std::string("EUR-M"))); // QUESTIONABLE
53  m_epsgToAlphaMap.insert(std::make_pair(6155, std::string("DAL")));
54  m_epsgToAlphaMap.insert(std::make_pair(6156, std::string("CCD")));
55  m_epsgToAlphaMap.insert(std::make_pair(6158, std::string("NAP")));
56  m_epsgToAlphaMap.insert(std::make_pair(6165, std::string("BID")));
57  m_epsgToAlphaMap.insert(std::make_pair(6169, std::string("AMA")));
58  m_epsgToAlphaMap.insert(std::make_pair(6175, std::string("SRL"))); // QUESTIONABLE
59  m_epsgToAlphaMap.insert(std::make_pair(6201, std::string("ADI-M")));
60  m_epsgToAlphaMap.insert(std::make_pair(6202, std::string("AUA")));
61  m_epsgToAlphaMap.insert(std::make_pair(6203, std::string("AUG")));
62  m_epsgToAlphaMap.insert(std::make_pair(6204, std::string("AIN-A"))); // QUESTIONABLE
63  m_epsgToAlphaMap.insert(std::make_pair(6205, std::string("AFG")));
64  m_epsgToAlphaMap.insert(std::make_pair(6209, std::string("ARF-M")));
65  m_epsgToAlphaMap.insert(std::make_pair(6210, std::string("ARS-M")));
66  m_epsgToAlphaMap.insert(std::make_pair(6216, std::string("BER")));
67  m_epsgToAlphaMap.insert(std::make_pair(6218, std::string("BOO"))); // QUESTIONABLE
68  m_epsgToAlphaMap.insert(std::make_pair(6219, std::string("BUR")));
69  m_epsgToAlphaMap.insert(std::make_pair(6221, std::string("CAI")));
70  m_epsgToAlphaMap.insert(std::make_pair(6222, std::string("CAP")));
71  m_epsgToAlphaMap.insert(std::make_pair(6223, std::string("CGE")));
72  m_epsgToAlphaMap.insert(std::make_pair(6224, std::string("CHU")));
73  m_epsgToAlphaMap.insert(std::make_pair(6236, std::string("HTN")));
74  m_epsgToAlphaMap.insert(std::make_pair(6238, std::string("IDN")));
75  m_epsgToAlphaMap.insert(std::make_pair(6239, std::string("INF-A"))); // QUESTIONABLE
76  m_epsgToAlphaMap.insert(std::make_pair(6240, std::string("INH-A"))); // QUESTIONABLE
77  m_epsgToAlphaMap.insert(std::make_pair(6244, std::string("KAN")));
78  m_epsgToAlphaMap.insert(std::make_pair(6245, std::string("KEA")));
79  m_epsgToAlphaMap.insert(std::make_pair(6248, std::string("PRP-M"))); // QUESTIONABLE
80  m_epsgToAlphaMap.insert(std::make_pair(6250, std::string("LEH")));
81  m_epsgToAlphaMap.insert(std::make_pair(6251, std::string("LIB")));
82  m_epsgToAlphaMap.insert(std::make_pair(6253, std::string("LUZ-A"))); // QUESTIONABLE
83  m_epsgToAlphaMap.insert(std::make_pair(6255, std::string("HEN")));
84  m_epsgToAlphaMap.insert(std::make_pair(6256, std::string("MIK")));
85  m_epsgToAlphaMap.insert(std::make_pair(6261, std::string("MER")));
86  m_epsgToAlphaMap.insert(std::make_pair(6262, std::string("MAS")));
87  m_epsgToAlphaMap.insert(std::make_pair(6263, std::string("MIN-A"))); // QUESTIONABLE
88  m_epsgToAlphaMap.insert(std::make_pair(6266, std::string("MPO")));
89  m_epsgToAlphaMap.insert(std::make_pair(6267, std::string("NAS-C")));
90  m_epsgToAlphaMap.insert(std::make_pair(6269, std::string("NAR-C")));
91  m_epsgToAlphaMap.insert(std::make_pair(6270, std::string("NAH-C"))); // QUESTIONABLE
92  m_epsgToAlphaMap.insert(std::make_pair(6282, std::string("PTN")));
93  m_epsgToAlphaMap.insert(std::make_pair(6284, std::string("PUK")));
94  m_epsgToAlphaMap.insert(std::make_pair(6285, std::string("QAT"))); // QUESTIONABLE
95  m_epsgToAlphaMap.insert(std::make_pair(6287, std::string("QUO")));
96  m_epsgToAlphaMap.insert(std::make_pair(6292, std::string("SAP")));
97  m_epsgToAlphaMap.insert(std::make_pair(6293, std::string("SCK")));
98  m_epsgToAlphaMap.insert(std::make_pair(6297, std::string("TAN")));
99  m_epsgToAlphaMap.insert(std::make_pair(6298, std::string("TIL")));
100  m_epsgToAlphaMap.insert(std::make_pair(6301, std::string("TOY-M")));
101  m_epsgToAlphaMap.insert(std::make_pair(6304, std::string("VOI"))); // QUESTIONABLE
102  m_epsgToAlphaMap.insert(std::make_pair(6307, std::string("NSD")));
103  m_epsgToAlphaMap.insert(std::make_pair(6309, std::string("YAC")));
104  m_epsgToAlphaMap.insert(std::make_pair(6311, std::string("ZAN")));
105  m_epsgToAlphaMap.insert(std::make_pair(6322, std::string("WGD")));
106  m_epsgToAlphaMap.insert(std::make_pair(6326, std::string("WGE")));
107  m_epsgToAlphaMap.insert(std::make_pair(6601, std::string("AIA")));
108  m_epsgToAlphaMap.insert(std::make_pair(6604, std::string("ASM")));
109  m_epsgToAlphaMap.insert(std::make_pair(6611, std::string("HKD"))); // QUESTIONABLE
110  m_epsgToAlphaMap.insert(std::make_pair(6613, std::string("GSE")));
111  m_epsgToAlphaMap.insert(std::make_pair(6615, std::string("POS")));
112  m_epsgToAlphaMap.insert(std::make_pair(6616, std::string("SGM")));
113  m_epsgToAlphaMap.insert(std::make_pair(6618, std::string("SAN-M")));
114  m_epsgToAlphaMap.insert(std::make_pair(6658, std::string("HJO")));
115  m_epsgToAlphaMap.insert(std::make_pair(6668, std::string("EUS")));
116  m_epsgToAlphaMap.insert(std::make_pair(6807, std::string("NTF")));
117 }
Presently implemented as a mapping from EPSG code to OSSIM/Geotrans alpha-codes found in ossimDatumFa...
Member Function Documentation
◆ create() [1/3]
const ossimDatum * ossimEpsgDatumFactory::create ( const ossimString epsg_spec) const
virtual
Creates given an EPSG spec in the form "EPSG:<datum_code>".
Implements ossimDatumFactoryInterface.
Definition at line 129 of file ossimEpsgDatumFactory.cpp.
References ossimString::after(), ossimString::before(), ossimString::contains(), ossimString::size(), and ossimString::toUInt32().
Referenced by create(), ossimEpsgProjectionDatabase::createProjFromFormatARecord(), and ossimWktProjectionFactory::doMapCommon().
130 {
131  if ( epsg_spec.size() )
132  {
133  ossim_uint32 gcs_code;
134  ossimString group; // assume we are working with EPSG codes
135  if (epsg_spec.contains(":"))
136  {
137  group = epsg_spec.before(":");
138  gcs_code = epsg_spec.after(":").toUInt32();
139  }
140  else
141  {
142  group = "EPSG"; // No group spec provided, assuming EPSG:
143  gcs_code = epsg_spec.toUInt32();
144  }
145  if ((group != "EPSG") || (gcs_code == 0))
146  return 0;
147
148  return create(gcs_code);
149  }
150  return 0;
151 }
ossimString before(const ossimString &str, std::string::size_type pos=0) const
METHOD: before(str, pos) Returns string beginning at pos and ending one before the token str If strin...
bool contains(char aChar) const
Definition: ossimString.h:58
ossim_uint32 toUInt32() const
virtual const ossimDatum * create(const ossimString &epsg_spec) const
std::string::size_type size() const
Definition: ossimString.h:405
unsigned int ossim_uint32
ossimString after(const ossimString &str, std::string::size_type pos=0) const
METHOD: after(str, pos) Returns string immediately after the token str.
◆ create() [2/3]
const ossimDatum * ossimEpsgDatumFactory::create ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Definition at line 157 of file ossimEpsgDatumFactory.cpp.
References create(), ossimString::empty(), ossimKeywordlist::find(), and ossimKeywordNames::GCS_CODE_KW.
158 {
159  ossimString lookup = kwl.find(prefix, ossimKeywordNames::GCS_CODE_KW);
160  if(!lookup.empty())
161  return create(lookup);
162  return 0;
163
164 }
static const char * GCS_CODE_KW
bool empty() const
Definition: ossimString.h:411
◆ create() [3/3]
const ossimDatum * ossimEpsgDatumFactory::create ( ossim_uint32  epsg_code) const
Definition at line 168 of file ossimEpsgDatumFactory.cpp.
References ossimDatumFactory::create(), ossimString::empty(), findAlphaCode(), and ossimDatumFactory::instance().
169 {
170  // Geographic coordinate system codes (4XXX) are sometimes used in place of their corresponding
171  // datum code (6XXX). Check for this possibility and transpose the code if so:
172  if ((datum_code >= 4135) && (datum_code <= 4807))
173  datum_code += 2000;
174
175  // Find the datum code in the map in order to determine the corresponding OSSIM/Geotrans alpha
176  // code. Then use the datum factory to create the datum.
177  ossimString alphaCode = findAlphaCode(datum_code);
178  if (!alphaCode.empty())
179  return ossimDatumFactory::instance()->create(alphaCode);
180
181  return 0;
182 }
virtual const ossimDatum * create(const ossimString &code) const
create method
ossimString findAlphaCode(ossim_uint32 epsg_code) const
static ossimDatumFactory * instance()
bool empty() const
◆ findAlphaCode()
ossimString ossimEpsgDatumFactory::findAlphaCode ( ossim_uint32  epsg_code) const
Given an EPSG, returns equivalent alpha-code datum code or empty string if not found.
Definition at line 232 of file ossimEpsgDatumFactory.cpp.
Referenced by create().
233 {
234  ossimString result("");
235  std::map<ossim_uint32, std::string>::const_iterator iter = m_epsgToAlphaMap.find(epsg_code);
236  if (iter != m_epsgToAlphaMap.end())
237  {
238  result = iter->second;
239  }
240  return result;
241 }
◆ findEpsgCode()
ossim_uint32 ossimEpsgDatumFactory::findEpsgCode ( const ossimString alpha_code) const
Given an alpha-code, returns equivalent EPSG datum code or 0 if not found.
Definition at line 216 of file ossimEpsgDatumFactory.cpp.
References m_epsgToAlphaMap, and ossimString::string().
Referenced by ossimDatum::ossimDatum().
217 {
218  std::map<ossim_uint32, std::string>::const_iterator iter = m_epsgToAlphaMap.begin();
219  while (iter != m_epsgToAlphaMap.end())
220  {
221  if (iter->second == alpha_code.string())
222  return iter->first;
223  ++iter;
224  }
225  return 0;
226 }
const std::string & string() const
Definition: ossimString.h:414
◆ getList()
void ossimEpsgDatumFactory::getList ( std::vector< ossimString > &  list) const
virtual
Definition at line 187 of file ossimEpsgDatumFactory.cpp.
References ossimDatumFactory::create(), ossimDatumFactory::instance(), m_epsgToAlphaMap, ossimDatum::name(), ossimString::push_back(), and ossimString::toString().
188 {
190  const ossimDatum* datum;
191  std::map<ossim_uint32, std::string>::const_iterator iter = m_epsgToAlphaMap.begin();
192
193  // Loop over all handled datum codes and instantiate the corresponding datum in order to
194  // get the corresponding OSSIM/Geotrans name. Eventually the datum info (including its name as
195  // it appears in the EPSG database) will be read directly from the Db without using
196  // ossimDatumFactory.
197  while(iter != m_epsgToAlphaMap.end())
198  {
199  datum = df->create(iter->second);
200  if (datum)
201  {
202  ossimString entry ("EPSG:");
203  entry += ossimString::toString(iter->first);
204  entry += ",";
205  entry += datum->name();
206  list.push_back(entry);
207  }
208  ++iter;
209  }
210 }
create method
Numeric to string methods.
virtual const ossimString & name() const
Definition: ossimDatum.h:58
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
◆ instance()
ossimEpsgDatumFactory * ossimEpsgDatumFactory::instance ( )
static
Definition at line 31 of file ossimEpsgDatumFactory.cpp.
Referenced by ossimEpsgProjectionDatabase::createProjFromFormatARecord(), ossimWktProjectionFactory::doMapCommon(), ossimDatum::ossimDatum(), and ossimDatumFactoryRegistry::ossimDatumFactoryRegistry().
32 {
33  static ossimEpsgDatumFactory inst;
34
35  return &inst;
36  // if(!m_instance)
37  // m_instance = new ossimEpsgDatumFactory;
38  // return m_instance;
39 }
Member Data Documentation
◆ m_epsgToAlphaMap
std::map<ossim_uint32, std::string> ossimEpsgDatumFactory::m_epsgToAlphaMap
protected
Eventually should be independent (and deprecate) ossimDatumFactory.
Definition at line 66 of file ossimEpsgDatumFactory.h.
Referenced by findAlphaCode(), findEpsgCode(), getList(), and ossimEpsgDatumFactory().
