#include <ossimGeoAnnotationFontObject.h>
ossimGeoAnnotationFontObject () | |
ossimGeoAnnotationFontObject (const ossimGpt &location, const ossimString &s, const ossimIpt &pixelSize=ossimIpt(12, 12), double rotation=0.0, const ossimDpt &scale=ossimDpt(1.0, 1.0), const ossimDpt &shear=ossimDpt(0.0, 0.0), ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255) | |
ossimGeoAnnotationFontObject (const ossimGeoAnnotationFontObject &rhs) | |
virtual ossimObject * | dup () const |
ossimAnnotationFontObject * | getFontObject () |
void | setFont (ossimFont *font) |
ossimFont * | getFont () |
virtual void | setPointSize (const ossimIpt &size) |
virtual void | setRotation (double rotation) |
virtual void | setScale (const ossimDpt &scale) |
virtual void | setShear (const ossimDpt &shear) |
virtual void | setColor (ossim_uint8 r, ossim_uint8 g, ossim_uint8 b) |
virtual void | transform (ossimImageGeometry *projection) |
virtual void | setCenterGround (const ossimGpt &gpt) |
virtual void | draw (ossimRgbImage &anImage) const |
virtual void | computeBoundingRect () |
virtual void | getBoundingRect (ossimDrect &rect) const |
virtual ossimAnnotationObject * | getNewClippedObject (const ossimDrect &rect) const |
virtual bool | intersects (const ossimDrect &rect) const |
virtual void | applyScale (double x, double y) |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
Saves the current state of this object. More... | |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
Method to the load (recreate) the state of an object from a keyword list. More... | |
ossimGeoAnnotationObject (unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1) | |
ossimGeoAnnotationObject (const ossimGeoAnnotationObject &rhs) | |
virtual | ~ossimAnnotationObject () |
ossimAnnotationObject (ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1) | |
virtual void | applyScale (const ossimDpt &scale) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual ossimDrect | getBoundingRect () const |
void | getColor (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const |
ossim_uint8 | getThickness () const |
virtual void | setThickness (ossim_uint8 thickness) |
virtual bool | isPointWithin (const ossimDpt &imagePoint) const |
virtual ossimString | getName () const |
virtual void | setName (const ossimString &name) |
ossim_uint32 | getId () const |
virtual ossim_uint32 | setId () |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
virtual | ~ossimGeoAnnotationFontObject () |
virtual | ~ossimGeoAnnotationObject () |
virtual | ~ossimReferenced () |
Protected Attributes | |
ossimGpt | theCenterGround |
ossimRefPtr< ossimFont > | theFont |
ossimFontInformation | theFontInfo |
ossimRefPtr< ossimAnnotationFontObject > | theAnnotationFontObject |
ossim_uint8 | theRed |
ossim_uint8 | theGreen |
ossim_uint8 | theBlue |
ossim_uint8 | theThickness |
ossimString | theName |
ossim_uint32 | theId |
static ossim_uint32 | getNextId () |
static void | restIdCounter () |
static ossim_uint32 | theIdCounter = 0 |
Definition at line 15 of file ossimGeoAnnotationFontObject.h.
ossimGeoAnnotationFontObject::ossimGeoAnnotationFontObject | ( | ) |
Definition at line 25 of file ossimGeoAnnotationFontObject.cpp.
References ossimRefPtr< T >::get(), ossimFontFactoryRegistry::instance(), ossimNotify(), ossimNotifyLevel_WARN, ossimAnnotationFontObject::setFont(), theAnnotationFontObject, and theFont.
Referenced by dup().
ossimGeoAnnotationFontObject::ossimGeoAnnotationFontObject | ( | const ossimGpt & | location, |
const ossimString & | s, | ||
const ossimIpt & | pixelSize = ossimIpt(12, 12) , |
double | rotation = 0.0 , |
const ossimDpt & | scale = ossimDpt(1.0, 1.0) , |
const ossimDpt & | shear = ossimDpt(0.0,0.0) , |
ossim_uint8 | r = 255 , |
ossim_uint8 | g = 255 , |
ossim_uint8 | b = 255 |
Definition at line 50 of file ossimGeoAnnotationFontObject.cpp.
References ossimDpt::makeNan(), and theAnnotationFontObject.
ossimGeoAnnotationFontObject::ossimGeoAnnotationFontObject | ( | const ossimGeoAnnotationFontObject & | rhs | ) |
Definition at line 81 of file ossimGeoAnnotationFontObject.cpp.
References ossimRefPtr< T >::get(), ossimAnnotationFontObject::setFont(), theAnnotationFontObject, and theFont.
protectedvirtual |
Definition at line 105 of file ossimGeoAnnotationFontObject.cpp.
References theAnnotationFontObject, and theFont.
Implements ossimAnnotationObject.
Definition at line 219 of file ossimGeoAnnotationFontObject.cpp.
References ossimAnnotationFontObject::applyScale(), theAnnotationFontObject, x, and y.
Definition at line 198 of file ossimGeoAnnotationFontObject.cpp.
References ossimAnnotationFontObject::computeBoundingRect(), and theAnnotationFontObject.
Definition at line 193 of file ossimGeoAnnotationFontObject.cpp.
References ossimAnnotationFontObject::draw(), and theAnnotationFontObject.
Definition at line 111 of file ossimGeoAnnotationFontObject.cpp.
References ossimGeoAnnotationFontObject().
Definition at line 203 of file ossimGeoAnnotationFontObject.cpp.
References ossimAnnotationFontObject::getBoundingRect(), and theAnnotationFontObject.
ossimFont * ossimGeoAnnotationFontObject::getFont | ( | ) |
Definition at line 124 of file ossimGeoAnnotationFontObject.cpp.
References ossimRefPtr< T >::get(), and theFont.
ossimAnnotationFontObject * ossimGeoAnnotationFontObject::getFontObject | ( | ) |
Definition at line 188 of file ossimGeoAnnotationFontObject.cpp.
References ossimRefPtr< T >::get(), and theAnnotationFontObject.
Will allocate a new object that is clipped to the passed. in rect. Look at derived classes to see if the object is actually clipped or not. A new object is returned if it clips to the rect else NULL should be returned it doesn't clip.
Definition at line 208 of file ossimGeoAnnotationFontObject.cpp.
Definition at line 214 of file ossimGeoAnnotationFontObject.cpp.
References ossimAnnotationFontObject::intersects(), and theAnnotationFontObject.
Keywords:
For center format is: ( latitude, longitude, height, datum_code ) center: ( 42.01, -90.71, 0.0, WGE )
For point_size format is: "( x, y )" point_size: ( 18, 18 )
For scale format is: "( x, y )" scale: ( 1.0, 1.0 )
For shear format is: "( x, y )" shear: ( 0.0, 0.0 )
text: Airport
USE ONE OF family_name: family_name: URW Palladio L family_name: gd sans family_name: URW Bookman L family_name: Nimbus Roman No9 L family_name: Nimbus Sans L family_name: URW Palladio L family_name: Century Schoolbook L family_name: Nimbus Mono L family_name: Nimbus Sans L Condensed
USE ONE OF style_name: style_name: normal style_name: bold style_name: italic style_name: bold italic
Reimplemented from ossimGeoAnnotationObject.
Definition at line 234 of file ossimGeoAnnotationFontObject.cpp.
References ossimKeywordlist::find(), ossimRefPtr< T >::get(), ossimFontFactoryRegistry::instance(), ossimGeoAnnotationObject::loadState(), ossimFontInformation::loadState(), ossimAnnotationObject::setColor(), ossimAnnotationFontObject::setFont(), ossimAnnotationFontObject::setGeometryInformation(), ossimAnnotationFontObject::setString(), ossimAnnotationObject::setThickness(), status, theAnnotationFontObject, ossimAnnotationObject::theBlue, theCenterGround, theFont, theFontInfo, ossimAnnotationObject::theGreen, ossimAnnotationObject::theRed, ossimAnnotationObject::theThickness, and ossimRefPtr< T >::valid().
Definition at line 224 of file ossimGeoAnnotationFontObject.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimAnnotationFontObject::getString(), ossimGeoAnnotationObject::saveState(), ossimFontInformation::saveState(), theAnnotationFontObject, theCenterGround, theFontInfo, and ossimGpt::toString().
Definition at line 183 of file ossimGeoAnnotationFontObject.cpp.
References theCenterGround.
Reimplemented from ossimAnnotationObject.
Definition at line 161 of file ossimGeoAnnotationFontObject.cpp.
References ossimAnnotationObject::setColor(), theAnnotationFontObject, and ossimRefPtr< T >::valid().
Referenced by ossimVpfAnnotationFeatureInfo::buildTxtFeature(), and ossimVpfAnnotationFeatureInfo::setDrawingFeaturesToAnnotation().
void ossimGeoAnnotationFontObject::setFont | ( | ossimFont * | font | ) |
Definition at line 117 of file ossimGeoAnnotationFontObject.cpp.
Definition at line 129 of file ossimGeoAnnotationFontObject.cpp.
References ossimAnnotationFontObject::setPointSize(), size, theAnnotationFontObject, and ossimRefPtr< T >::valid().
Definition at line 137 of file ossimGeoAnnotationFontObject.cpp.
References ossimAnnotationFontObject::setRotation(), theAnnotationFontObject, and ossimRefPtr< T >::valid().
Definition at line 145 of file ossimGeoAnnotationFontObject.cpp.
References ossimAnnotationFontObject::setScale(), theAnnotationFontObject, and ossimRefPtr< T >::valid().
Definition at line 153 of file ossimGeoAnnotationFontObject.cpp.
References ossimAnnotationFontObject::setShear(), theAnnotationFontObject, and ossimRefPtr< T >::valid().
Add the projection interface to all geographically defined objects.
Implements ossimGeoAnnotationObject.
Definition at line 171 of file ossimGeoAnnotationFontObject.cpp.
References ossimAnnotationFontObject::computeBoundingRect(), ossimAnnotationFontObject::setCenterPosition(), theAnnotationFontObject, theCenterGround, and ossimImageGeometry::worldToLocal().
protected |
Definition at line 123 of file ossimGeoAnnotationFontObject.h.
Referenced by applyScale(), computeBoundingRect(), draw(), getBoundingRect(), getFontObject(), intersects(), loadState(), ossimGeoAnnotationFontObject(), saveState(), setColor(), setFont(), setPointSize(), setRotation(), setScale(), setShear(), transform(), and ~ossimGeoAnnotationFontObject().
protected |
Definition at line 120 of file ossimGeoAnnotationFontObject.h.
Referenced by loadState(), saveState(), setCenterGround(), and transform().
protected |
Definition at line 121 of file ossimGeoAnnotationFontObject.h.
Referenced by getFont(), loadState(), ossimGeoAnnotationFontObject(), setFont(), and ~ossimGeoAnnotationFontObject().
protected |
Definition at line 122 of file ossimGeoAnnotationFontObject.h.
Referenced by loadState(), and saveState().
